Passat low boost issue P0299
Rockfiend
C?ID=247661
Hi, i have a 2009 Passat 2.0 CR TDI (CBAB) 140 with a low boost issue. Serviced the car last week replacing all filters. After driving 400 miles over a few days, glow plug light and engine fault showing on dash. Straight into limp mode, reduced power etc. Switch off/on and some power was restored but still low. Scanned with VCDS and threw up the code as below.
Address 01: Engine Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 QC HW: 03L 907 309
Component and/or Version: R4 2,0L EDC G000SG 3732
Software Coding: 0000072
Work Shop Code: WSC 00700 210 88118
VCID: 76E3ADA101284A8E77-8022
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - MIL ON
Fault Status: 11100000
Mileage: 144625 km
Date: 2012.14.05
Time: 13:55:27
RPM: 2530 /min
Speed: 64.0 km/h
Load: 56.9 %
Absolute Pres.: 2131.8 mbar
Absolute Pres.: 1632.0 mbar
Lambda: 97.8 %
Lambda: 37.1 %
Had a quick look at the vacuum pipes etc but as i was away for the weekend couldnt do much. Driving home the light came on a few times and went into limp mode. Switched off and on again and some power was restored, still low on power but driveable. Doesnt seem to be any boost down low but up the rev range around 2500, it definitely seems to pull well. Seen lots of posts about the actuator issues. Thinking it might be this. Today when i got in the car, the brake pedal was hard after i started up to release e brake. The pedal feel was restored after a few seconds. This would mean i probably have a vacuum leak. I cant hear anything obvious again making me think its the actuator. I have ordered a vacuum tester and will see if it holds when i get it.
I have also graphed actual boost against specified boost and it appears to be well short. This i think indicates its not a map sensor?
Code came up again this morning but now says intermittent.
Any advice greatly appreciated.
Rockfiend
C?ID=247661
Sorry, cant figure out how to post the boost graph or any attachment. :(
Rockfiend
C?ID=247661
Yep, you have practically no boost.
I don't know that engine well enough to speculate why.
How about a charge pipe or loose connection.
Faulty WG or N75
Visual inspection of the pipes......... cooler and tug tests are advised
dafrazi
Norristown, PA
C?ID=173774
Wires at the N75 valve are a common failure point. Make sure to inspect them. I've seen a bunch broken at the connector on the N75.
Yup many chafe 150MM back from electrical connector location on N75.........
Rockfiend
C?ID=247661
Thanks for all the replies. I have verified all the intercooler and vacuum pipes complete. No damaged wiring at the n75 as suggested. After these tests completed, my vacuum tester arrived. I quickly checked the n75 and pipes. I'm getting vacuum from the n75 but no vacuum being held by the actuator. I guess the actuator diaphragm is bust? Short is I've ordered an actuator for delivery tomorrow. Hoping this will sort it out.
Thanks all for reading and replying. 😊
