Hi, i have a 2009 Passat 2.0 CR TDI (CBAB) 140 with a low boost issue. Serviced the car last week replacing all filters. After driving 400 miles over a few days, glow plug light and engine fault showing on dash. Straight into limp mode, reduced power etc. Switch off/on and some power was restored but still low. Scanned with VCDS and threw up the code as below.
Address 01: Engine Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 QC HW: 03L 907 309
Component and/or Version: R4 2,0L EDC G000SG 3732
Software Coding: 0000072
Work Shop Code: WSC 00700 210 88118
VCID: 76E3ADA101284A8E77-8022
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - MIL ON
Fault Status: 11100000
Mileage: 144625 km
Date: 2012.14.05
Time: 13:55:27
RPM: 2530 /min
Speed: 64.0 km/h
Load: 56.9 %
Absolute Pres.: 2131.8 mbar
Absolute Pres.: 1632.0 mbar
Lambda: 97.8 %
Lambda: 37.1 %
Had a quick look at the vacuum pipes etc but as i was away for the weekend couldnt do much. Driving home the light came on a few times and went into limp mode. Switched off and on again and some power was restored, still low on power but driveable. Doesnt seem to be any boost down low but up the rev range around 2500, it definitely seems to pull well. Seen lots of posts about the actuator issues. Thinking it might be this. Today when i got in the car, the brake pedal was hard after i started up to release e brake. The pedal feel was restored after a few seconds. This would mean i probably have a vacuum leak. I cant hear anything obvious again making me think its the actuator. I have ordered a vacuum tester and will see if it holds when i get it.
I have also graphed actual boost against specified boost and it appears to be well short. This i think indicates its not a map sensor?
Code came up again this morning but now says intermittent.
Any advice greatly appreciated.
Mileage: 144625 km
Date: 2012.14.05
Time: 13:55:27
RPM: 2530 /min
Speed: 64.0 km/h
Load: 56.9 %
Lambda: 97.8 %
Lambda: 37.1 %
