Fuel Rail Pressure Too Low-Tested Injectors
passdattdi
California, USA
H11-NRRT
Hello all. I having P0087 code fuel rail pressure too low. I had injectors tested and resulted in one of the injectors has high return. Does this maybe explain the issue? if so, how? I would think if injector has high return, then it would mean i would have high fuel pressure, not low? Maybe i'm not thnking it right? Also, is there a way to see this high return with VCDS ? LIKE TESTING INJECTORS WITH vcds? Thanks
Westbury, UK
Would be a lot easier to help if we knew the vehicle, engine and model year - to help with this please post an Auto-Scan
What year is your Lada? ;)
Let's see that autoscan
passdattdi
California, USA
H11-NRRT
I'm not near the vcds. I took phone picture of log when code pops in with check engine light.
passdattdi
California, USA
H11-NRRT
Has specified high pressure and actual..will this help? Also, have been having DPF regen frequency fault as well. Not sure if this is related.
passdattdi
California, USA
H11-NRRT
This is last auto scan log:
Wednesday,03,January,2024,13:31:18:01454
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: 1VWBN7A32DC076445   License Plate:
Mileage: 221320km-137521mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
VIN: 1VWBN7A32DC076445   Mileage: 221320km-137521miles
   Component: R4 2.0l TDI   H23 9982
   Revision: 71H23---    Serial number:                CVN: D240C61F5C3E0D04
   Coding: 001D0012042400000000
   Shop #: WSC 22194 444 00000
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B233CC303E5FA323A1-806E
   VINID: 0669D27874430944C01C6104147C1ACF14
5211 - Fuel Rail/System Pressure
          P0087 00 [01100101] - Too Low
                    Mileage: 221294 km
                    Date: 2024.01.02
                    Time: 11:11:38
                    Engine RPM: 1988.50 /min
                    Normed load value: 88.6 %
                    Vehicle speed: 87 km/h
                    Coolant temperature: 103  C
                    Intake air temperature: 37  C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 14.200 V
                    Unlearning counter according OBD: 78
                    Fuel temperature: 25.9  C
                    Mean injection quantity: 52.44 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 5
                    Fuel high-pressure: actual value: 1294100 hPa
                    High fuel pressure: specified value: 1582900 hPa
                    Pressure control valve adaptation factor: 1.0945
                    Fuel level: 64.00 l
5227 - Fuel Rail/System Pressure
          P0087 00 [11101100] - Too Low
                    Mileage: 221297 km
                    Date: 2024.01.02
                    Time: 11:17:46
                    Engine RPM: 2209.50 /min
                    Normed load value: 84.7 %
                    Vehicle speed: 96 km/h
                    Coolant temperature: 104  C
                    Intake air temperature: 33  C
                    Voltage terminal 30: 14.260 V
                    Fuel temperature: 28.4  C
                    Mean injection quantity: 48.90 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 4
                    Fuel high-pressure: actual value: 1347900 hPa
                    High fuel pressure: specified value: 1664800 hPa
                    Pressure control valve adaptation factor: 1.0446
                    Fuel level: 3.00 l
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05551213    Serial number: 00001209182057
   Shop #: WSC 09003 957 00200
   VCID: 2411E7BF92DBA5CA6BB-8070
   Revision: 00H31001
   Coding: C54BC0F549290000A30F03E8921E0042A71000
   VCID: 7DA7F2DB5DF13402445-8028
   Part No SW: 561 907 426 A    HW: 561 907 426 A
   Component: AC Manuell    H02 0101
   Revision: 00001K07
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 196FC64BA919E822C8D-804C
9477489 - Motor for Air Distribution Flap
          B109D 71 [00001000] - Actuator Stuck
                    Reset counter: 105
                    Mileage: 221117 km
                    Date: 2023.12.22
                    Time: 17:40:26
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B902B08D408880001160085480071008640A00560648060000C70
   VCID: 74B1D7FF6EBB754A3BB-8020
   Component: RLS 240912 05  54  0403
   Coding: 22300A
00956 - Key 2
                    Fault Status: 01100101
                    Reset counter: 49
                    Mileage: 220719 km
                    Date: 2018.05.08
                    Time: 11:49:13
                    Voltage: 12.10 V
                    Fault Status: 00101010
                    Fault Frequency: 21
                    Reset counter: 113
                    Mileage: 220813 km
                    Date: 2018.05.09
                    Time: 16:29:32
                    Voltage: 13.70 V
                    Fault Status: 01101010
                    Reset counter: 49
                    Mileage: 220719 km
                    Date: 2018.05.08
                    Time: 11:49:15
                    Voltage: 12.15 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM056M09   Dataset Number: 560003v__A_ 0049
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBBD893071D5692C69-803A
   Serial number: 6940000Y120000LZBM0G
   Coding: 303044
   Serial number: 3572MSME30653173ZZZL
   Serial number: 3582MSME605A6273ZZZX
   Serial number: 3516KSME166B2520ZZZM
   Serial number: 3526KSME323B0B20ZZZM
   Serial number: 3556LSME64056E1EZZZ1
   Serial number: 3566LSME261A761EZZZ%
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010041    Serial number: 20121001302345
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76B5EDF77847675A05F-8022
   Coding: E20000
   Part No SW: 561 920 970 E    HW: 561 920 970 E
   Component: KOMBI         H07 0705
   Coding: 231E01
   VCID: 1C61DF5FA62B9D0AD3B-8048
9453074 - Fuel Level Sensor 1
          B103E 1B [00001000] - Resistance Too High
                    Reset counter: 114
9459995 - Covering for fuel level indicator sensor 1
          B1059 1B [00001000] - Resistance Too High
          [Geber 1 f r Kraftstoffvorratsanzeige:  bergangswiderstand zu gro ]
                    Fault Frequency: 139
                    Reset counter: 114
                    Mileage: 220722 km
                    Date: 2023.12.16
                    Time: 12:11:17
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 10111203290546
   Coding: 461000
   VCID: 76B5EDF778C7675A05F-8022
   Component: IMMO          H07 0705
   VCID: 6A8DC9873CFFB3BA917-803E
   Revision: A1001003    Serial number: 7663363842
   Coding: 020100
   VCID: 2A0D0987FCFF73BA517-807E
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H35 0319
   Serial number: VWZAZ2M4239743
   Coding: 0400040104000B000000100A
   ROD: EV_RNS315NARV2UDS_VW41.rod
   VCID: 2517FABB95615CC27C5-8070
   Component: NAR_V3_(0037)  0037
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [00001001] - General Memory Failure
          [ECU defect data memory failure]
                    Mileage: 146115 km
                    Date: 2020.10.01
                    Time: 22:27:47
   Revision: 13110009    Serial number: 0005720211
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE39C43E3A5DA321A1-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 372B20F3334DDE52DE9-8062
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: 6FBBD893079D5692C69-803A
   Serial number: 53388786011223200119
   Coding: 181100
   Revision: 15110009    Serial number: 0005690344
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE19F5FE6ABDD0A13B-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
End(Elapsed Time: 01:06, VBatt start/end: 11.9V/11.9V. VIgn 11.9V, udsna)--
passdattdi
California, USA
H11-NRRT
I clear fault codes then drive again. Codes come back, These are last ones:
Wednesday,03,April,2024,19:48:54:01454
                Address 01: Engine       Labels: 03L-906-022-CFC.clb
Control Module Part Number: 03L 997 009 J    HW: 03L 907 309 S
  Component and/or Version: R4 2.0l TDI   H23 9982
           Software Coding: 001D0012042400000000
            Work Shop Code: WSC 22194 444 00000
              ASAM Dataset: EV_ECM20TDI01103L997009J 004005 (VW41)
          P0087 00 [10101111] - Too Low
                    Mileage: 222412 km
                    Date: 2127.14.02
                    Time: 09:18:06
                    Engine RPM: 2126.00 /min
                    Normed load value: 79.2 %
                    Vehicle speed: 70 km/h
                    Intake air temperature: 25  C
                    Voltage terminal 30: 14.320 V
                    Fuel temperature: 45.0  C
                    Mean injection quantity: 31.85 mg/stroke
                    Fuel high-pressure: actual value: 1501700 hPa
                    High fuel pressure: specified value: 1701800 hPa
                    Pressure control valve adaptation factor: 1.1399
                    Fuel level: 33.00 l
8863 - Particulate Filter
          P2459 00 [01100101] - Regeneration Frequency
                    Mileage: 222413 km
                    Date: 2127.14.02
                    Time: 09:23:46
                    Engine RPM: 1472.00 /min
                    Normed load value: 80.4 %
                    Vehicle speed: 77 km/h
                    Intake air temperature: 26  C
                    Voltage terminal 30: 14.280 V
                    Exhaust gas jet volume in particle filter: 177.9 m /h
                    Particle filter: difference pressure: 159 hPa
                    Particle filter: soot mass measured: 24.12 g
                    Particle filter: soot mass calculated: 24.10 g
                    Particle filter: differential pressure: dynamic offset: -24 hPa
                    Exhaust gas temperature sensor 3: 293.9  C
                    Exhaust gas temperature sensor 4: 219.3  C
Yes it does.... think about it.... your pump pressurizes the rail to X amount. (well, in your case, attempts to.... because based on scan data, it can't do it)
Rich (BB code):
The injectors draw from said pressure when injecting, and also "bleed off" so much via their "return flow".
So now that one of them is "bleeding off" way more than normal, that means your rail pressure is "dropping" a lot more than it should... because there's a "bigger hole" in the system.
The injector's return doesn't flow back into the rail... so why would the fuel amount escaping through the return increase your rail pressure?
passdattdi
California, USA
H11-NRRT
Yea, that's where I was missunderstanding; return NOT going back to Rail then. Other thing is these loss of power happened only after driving for a while . At first, car drove fine. I there any ideas why the delay symptoms?
Visual for you
I'm not sure I follow what you are asking, but if we are to have theoretical discussions, it's possible that when you were "first driving", you were not asking for sufficient engine output, so as such, the HPFP would be able to keep up with the requested rail pressure (even with a giant hole in your system - aka leaky injector)..... but once you demanded more output, then the simple firing of the injectors was consuming (read draining) much more rail pressure, so now that giant leak was more of an issue and resulted in the HPFP not being able to supply enough flow\pressure to maintain the requested rail pressure for the operating conditions.
passdattdi
California, USA
H11-NRRT
Thanks, and it make sense your explanations and visuals. I guess my question is that when i first drove it at the beginning of the day, I could actually step on the gas, and pretty hard (demanding lots of pressure) . Car would respond as it should. After maybe 6-10 miles, at regular operating engine temp, is when i would get the fault and symptoms. Right before the fault (glowing plug and loss of power-limp mode) i would hear this whirring sound coming from engine bay. Maybe, there is a valve in the injector that after it reaches certain temp, it begins to fail, and why it does not fail right away? Thanka again for detailed explanations. I do have a new innjector on order and will replace. Hoping this is the issue and fix. If this is fixed, next step is to look into DPF-Regen Frequency issue; maybe i'm lucky and this is related and will fix that too .
