Fuel Rail Pressure Too Low-Tested Injectors
   #21
passdattdi
California, USA
H11-NRRT
..another thing, would i be able to see this activity (high return) on vcds diagnostic? Or what on log, besides the discrepancy between actual and specified
   #22
Log your injector deviations.... I'd expect that one injector to be all out of whack compared to the rest
   #23
passdattdi
California, USA
H11-NRRT
Ok. So is this a matter of a Diesel Particulate Filter being too dirty and need cleaning? Is there a manual force regen i can do with vcds maybe will clean it? Or what things if any can i check that may be causing issue? I have heard that the filter can come off and be put in an "oven" to be cleaned. Of course, i'd rather not have to do that. Thanks again; this forum is awesome!
   #25
Yes, you can trigger a Regen with VCDS, but it will also take place autonomously once you fix everything that an issue like sensors, fuel, exhaust and ECU issues, and you drive while satisfying all the required conditions.
passdattdi
California, USA
H11-NRRT
Ok. Differential pressure Sensors were both replaced but no change. Will need to see what else. Thanks
   #27
Replaced according to service manual procedures, with required adaptations if applicable, etc?
Or just Mickey Mouse parts cannon type of replacements?
passdattdi
California, USA
H11-NRRT
Replaced with adaptation to the best of my knoweldge. There is something needs to be done with vcds ..something to do with resetting values. VCDS shows process "completed" succesfully. Drive around and get
-8863 Particulate Filter
P2459 00-Regen Frequency.
This is same result with original sensors, hence my conclusion is not a sensor issue, unless i'm doing something wrong or missing a servcie manual procedure step. The new sensor i got from Kerma TDI, reputable source I believe.
   #29
Search for distance since last Regen and cancellation of regen or similar terms in your controller.... If no faults are present, there should be some clues as to why regens aren't happening. Any airflow/fuel/egt/pressure issues will usually get in the way of it taking place
   #30
passdattdi
California, USA
H11-NRRT
Controller as in the log in vcds when it triggers fault? I'm sorry, I'm maybe not understanding, there are faults. So regen frequency fault means its not happening like it should? I was thinking it could mean that it's happening too much. Im going to be installing new injector and hopefully fix rail pressure issue. Then drive car and post log of dpf faults .
   #31
passdattdi
California, USA
H11-NRRT
"Any airflow/fuel/egt/pressure issues will usually get in the way of it taking place"
So there Is hope that issue gets fixed upon injector replacement. If been having fuel pressure issues, may be keeping from regenerating.
   #32
Controller as in the various controller you have in your vehicle.... Engine, Transmission, HVAC, etc.... those are controllers.
Frequency = definition of the word.... how often something takes place.....
Example (off my Touareg, so don't get stuck on the IDE#s.... search for terms instead to find the correct IDEs in your specific controller)
                Address 01: Engine  (7P0 907 401 K)
12:46:09
  IDE00432   Particle filter: time since last regeneration 21139 s
  IDE00433   Particle filter: oil ash volume 0.28 l
  IDE00434   Particle filter: soot mass calculated 20.88 g
  IDE00435   Particle filter: soot mass measured 20.52 g
  IDE00436   Particle filter: kilometers since last regeneration 310169 m
passdattdi
California, USA
H11-NRRT
Got it! Thank you.
INstalled new injector. Now i'm just waiting for coolant flange and temp sensor to install those and fire it up. If fuel pressure issues can affect DPF Regen Frequency issues, maybe by getting this low fuel pressure fixed can fix the DPF problem. Thanks and i'll provide update.
   #34
You made sure to code the injector right?
passdattdi
California, USA
H11-NRRT
Thanks for reminder. I haven't yet as battery is off. Had to remove it to get to coolant flange. But will do.
   #36
passdattdi
California, USA
H11-NRRT
UGH! Put everything back together. No water leaks, no gas leaks. Purged fuel system with vcds. Car started first attempt. Drove for about 4 miles and same result; Fuel Rail Pressure Too Low. It came up twice.
What to do next? Here the fault code s log:
Tuesday,16,April,2024,12:38:45:01454
VCDS Version: Release 23.11.0 (x64) Running on Windows 11 x64
                Address 01: Engine       Labels: 03L-906-022-CFC.clb
Control Module Part Number: 03L 997 009 J    HW: 03L 907 309 S
  Component and/or Version: R4 2.0l TDI   H23 9982
           Software Coding: 001D0012042400000000
            Work Shop Code: WSC 22194 444 00000
              ASAM Dataset: EV_ECM20TDI01103L997009J 004005 (VW41)
                       ROD: EV_ECM20TDI01103L997009H.rod
                      VCID: 3B233CC303E5FA323A1-806E
5211 - Fuel Rail/System Pressure
          P0087 00 [10100111] - Too Low
                    Mileage: 222620 km
                    Date: 2127.14.07
                    Time: 01:31:55
                    Engine RPM: 1716.00 /min
                    Normed load value: 76.9 %
                    Vehicle speed: 75 km/h
                    Coolant temperature: 104 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 14.340 V
                    Unlearning counter according OBD: 80
                    Fuel temperature: 46.6 °C
                    Mean injection quantity: 25.79 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 5
                    Fuel high-pressure: actual value: 1382000 hPa
                    High fuel pressure: specified value: 1616700 hPa
                    Pressure control valve adaptation factor: 1.0000
                    Fuel level: 15.00 l
5212 - Fuel Rail/System Pressure
                    Mileage: 222620 km
                    Date: 2127.14.07
                    Time: 01:31:57
                    Engine RPM: 1740.00 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 76 km/h
                    Fuel temperature: 46.7 °C
                    Mean injection quantity: 22.81 mg/stroke
                    Fuel high-pressure: actual value: 1386900 hPa
                    High fuel pressure: specified value: 1600300 hPa
                    Fuel level: 15.00 l
passdattdi
California, USA
H11-NRRT
And here is auto scan again. I see issues with in-tank fuelpump now?
Tuesday,16,April,2024,12:43:57:01454
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: 1VWBN7A32DC076445   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
VIN: 1VWBN7A32DC076445   Mileage: 222620km-138329miles
   Component: R4 2.0l TDI   H23 9982
   Revision: 71H23---    Serial number:                CVN: D240C61F5C3E0D04
   Shop #: WSC 22194 444 00000
   VINID: 0669D27874430944C01C6104147C1ACF14
                    Mileage: 222620 km
                    Date: 2024.04.16
                    Time: 01:31:55
                    Fuel level: 15.00 l
                    Mileage: 222620 km
                    Date: 2024.04.16
                    Time: 01:31:57
                    Fuel level: 15.00 l
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05551213    Serial number: 00001209182057
   Shop #: WSC 09003 957 00200
   VCID: 2411E7BF92DBA5CA6BB-8070
   Revision: 00H31001
   Coding: C54BC0F549290000A30F03E8921E0042A71000
   VCID: 7DA7F2DB5DF13402445-8028
                    Reset counter: 170
                    Mileage: 222241 km
                    Date: 2018.08.17
                    Time: 00:02:58
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 16390
                    Count: 44032
                    Count: 1
                    Count: 253
   Part No SW: 561 907 426 A    HW: 561 907 426 A
   Component: AC Manuell    H02 0101
   Revision: 00001K07
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 196FC64BA919E822C8D-804C
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B902B08D408880001160085480071008640A00560648060000C70
   VCID: 74B1D7FF6EBB754A3BB-8020
   Component: RLS 240912 05  54  0403
   Coding: 22300A
00956 - Key 2
                    Fault Status: 01100101
                    Reset counter: 109
                    Mileage: 222183 km
                    Date: 2018.08.14
                    Time: 03:50:41
                    Voltage: 12.15 V
                    Fault Status: 00101010
                    Reset counter: 169
                    Mileage: 222382 km
                    Date: 2018.09.02
                    Time: 08:10:49
                    Voltage: 14.20 V
02391 - Terminal 30 Reference
                    Reset counter: 130
                    Mileage: 222567 km
                    Date: 2018.09.06
                    Time: 00:00:06
                        Term 15 Off
                    Voltage: 12.60 V
                    Fault Status: 01101010
                    Reset counter: 109
                    Mileage: 222183 km
                    Date: 2018.08.14
                    Time: 03:51:40
                    Voltage: 12.10 V
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 123
                    Reset counter: 131
                    Mileage: 222183 km
                    Date: 2018.08.14
                    Time: 03:50:40
                    Voltage: 12.15 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM056M09   Dataset Number: 560003v__A_ 0049
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBBD893071D5692C69-803A
   Serial number: 6940000Y120000LZBM0G
   Coding: 303044
   Serial number: 3572MSME30653173ZZZL
   Serial number: 3582MSME605A6273ZZZX
   Serial number: 3516KSME166B2520ZZZM
   Serial number: 3526KSME323B0B20ZZZM
   Serial number: 3556LSME64056E1EZZZ1
   Serial number: 3566LSME261A761EZZZ%
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010041    Serial number: 20121001302345
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76B5EDF77847675A05F-8022
   Coding: E20000
   Part No SW: 561 920 970 E    HW: 561 920 970 E
   Component: KOMBI         H07 0705
   Coding: 231E01
   VCID: 1C61DF5FA62B9D0AD3B-8048
9453074 - Fuel Level Sensor 1
          B103E 1B [00001000] - Resistance Too High
                    Reset counter: 160
9459995 - Covering for fuel level indicator sensor 1
          B1059 1B [00001000] - Resistance Too High
          [Geber 1 für Kraftstoffvorratsanzeige: Übergangswiderstand zu groß]
                    Reset counter: 154
                    Mileage: 222183 km
                    Date: 2024.03.23
                    Time: 04:53:48
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 10111203290546
   Coding: 461000
   VCID: 76B5EDF778C7675A05F-8022
   Component: IMMO          H07 0705
   VCID: 6A8DC9873CFFB3BA917-803E
   Revision: A1001003    Serial number: 7663363842
   Coding: 020100
   VCID: 2A0D0987FCFF73BA517-807E
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H35 0319
   Serial number: VWZAZ2M4239743
   Coding: 0400040104000B000000100A
   ROD: EV_RNS315NARV2UDS_VW41.rod
   VCID: 2517FABB95615CC27C5-8070
   Component: NAR_V3_(0037)  0037
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [00001001] - General Memory Failure
          [ECU defect data memory failure]
                    Mileage: 146115 km
                    Date: 2020.11.30
                    Time: 22:27:47
   Revision: 13110009    Serial number: 0005720211
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE39C43E3A5DA321A1-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
131584 - Motor for Rear Window Regulator
          B11EE 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 128
                    Mileage: 222183 km
                    Date: 2024.03.23
                    Time: 03:50:41
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 372B20F3334DDE52DE9-8062
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: 6FBBD893079D5692C69-803A
   Serial number: 53388786011223200119
   Coding: 181100
   Revision: 15110009    Serial number: 0005690344
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE19F5FE6ABDD0A13B-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
                    Reset counter: 128
                    Mileage: 222183 km
                    Date: 2024.03.23
                    Time: 03:50:41
End----------(Elapsed Time: 01:07, VBatt start/end: 14.2V/14.1V)-----------
CODE WRAP
   #39
Where are you showing the injector deviations that you were going to log?
Have you tested fuel supply\pressure to the filter canister?
Log fuel pressure (actual vs specified) to see if it shows a potential HPFP issue across the range, not just the snapshot provided by the FF data.
   #40
passdattdi
California, USA
H11-NRRT
Here deviations-sorry if didnt do right. I have tested supply/pressure before filter and after filter. I get 59-60 psi. As far as log actual vs specified, working on how to do that. Thanks
Tuesday
16​
April
2024​
13:51:41:01454-VCID:3B233CC303E5FA323A1-806EVCDS Version: Release 23.11.0 (x64)Data version: 20231027 DS351.0
03L 997 009 JADVMBR4 2.0l TDI H23 9982
G054F0G055F0G056F0G057F0G000
MarkerTIMELoc. IDE00365TIMELoc. IDE00366TIMELoc. IDE00367TIMELoc. IDE00368
STAMPInjection quantity deviation cylinder 1STAMPInjection quantity deviation cylinder 2STAMPInjection quantity deviation cylinder 3STAMPInjection quantity deviation cylinder 4
mg/strokemg/strokemg/strokemg/stroke
0.13​
-0.03​
0.22​
0.04​
0.35​
0.02​
0.02​
-0.03​
0.57​
-0.04​
0.66​
0.04​
0.77​
0.02​
0.44​
-0.02​
1.03​
-0.03​
1.13​
0.03​
1.26​
0.02​
0.9​
-0.02​
1.51​
-0.04​
1.6​
0.03​
1.73​
0.03​
1.37​
-0.02​
1.95​
-0.04​
2.04​
0.02​
2.18​
0.03​
1.84​
-0.01​
2.37​
-0.04​
2.5​
0.01​
2.59​
0.04​
2.27​
-0.01​
2.81​
-0.04​
2.93​
0.01​
3.03​
0.04​
2.71​
-0.01​
3.24​
-0.04​
3.37​
0.01​
3.46​
0.04​
3.15​
-0.01​
3.68​
-0.04​
3.81​
0.01​
3.9​
0.03​
3.59​
0​
4.12​
-0.04​
4.25​
0.01​
4.35​
0.03​
4.03​
0​
4.6​
-0.04​
4.69​
0.02​
4.82​
0.02​
4.47​
-0.01​
5.04​
-0.03​
5.13​
0.01​
5.24​
0.03​
4.91​
-0.01​
5.47​
-0.03​
5.59​
0.01​
5.69​
0.03​
5.38​
0​
5.9​
-0.04​
6.03​
0.01​
6.12​
0.03​
5.81​
0​
6.34​
-0.04​
6.47​
0.01​
6.56​
0.03​
6.25​
0​
6.78​
-0.03​
6.91​
0.01​
7​
0.03​
6.69​
-0.01​
7.22​
-0.03​
7.35​
0.01​
7.43​
0.03​
7.13​
0​
7.65​
-0.03​
7.78​
0​
7.87​
0.02​
7.56​
0​
8.11​
-0.03​
8.22​
0.01​
8.35​
0.02​
8​
0​
8.56​
-0.04​
8.66​
0.01​
8.78​
0.02​
8.44​
0​
9​
-0.04​
9.13​
0.01​
9.22​
0.02​
8.87​
0​
9.45​
-0.04​
9.57​
0.02​
9.66​
0.02​
9.35​
0​
9.88​
-0.03​
10.01​
0.01​
10.11​
0.01​
9.79​
0​
10.35​
-0.03​
10.45​
0.01​
10.54​
0.01​
10.21​
0​
10.76​
-0.03​
10.89​
0.01​
10.98​
0.02​
10.67​
0​
11.23​
-0.03​
11.33​
0.01​
11.45​
0.02​
11.1​
0​
11.67​
-0.03​
11.77​
0.02​
11.89​
0.02​
11.54​
0​
12.11​
-0.04​
12.24​
0.01​
12.36​
0.02​
11.98​
0​
12.6​
-0.04​
12.71​
0.01​
12.79​
0.01​
12.49​
0​
13.01​
-0.03​
13.14​
0.01​
13.23​
0.01​
12.92​
0​
13.48​
-0.03​
13.59​
0.01​
13.7​
0.01​
13.35​
0​
13.92​
-0.04​
14.01​
0​
14.14​
0.02​
13.79​
0.01​
14.36​
-0.04​
14.48​
0​
14.6​
0.02​
14.23​
0.01​
14.79​
-0.05​
14.93​
0​
15.02​
0.02​
14.71​
0.02​
15.24​
-0.05​
15.36​
0​
15.49​
0.02​
15.15​
0.02​
15.71​
-0.05​
15.81​
0​
15.92​
0.02​
15.59​
0.02​
16.13​
-0.05​
16.23​
0​
16.35​
0.02​
16.01​
0.02​
16.59​
-0.04​
16.67​
0​
16.79​
0.02​
16.45​
0.02​
17.02​
-0.04​
17.11​
0​
17.24​
0.02​
16.89​
0.01​
17.45​
-0.04​
17.55​
0​
17.67​
0.01​
17.35​
0.01​
17.89​
-0.04​
17.99​
0​
18.11​
0.01​
17.77​
0.01​
18.35​
-0.04​
18.46​
0.01​
18.55​
0.01​
18.24​
0.01​
18.77​
-0.04​
18.88​
0.01​
19.01​
0.01​
18.68​
0.01​
19.23​
-0.04​
19.33​
0.02​
19.42​
0.01​
19.13​
0.01​
19.64​
-0.04​
19.73​
0.02​
19.85​
0.01​
19.51​
0​
20.09​
-0.04​
20.2​
0.02​
20.29​
0.01​
19.98​
0​
20.51​
-0.03​
20.64​
0.02​
20.73​
0.01​
20.42​
0​
20.95​
-0.03​
21.09​
0.02​
21.17​
0.01​
20.86​
0​
21.39​
-0.03​
21.52​
0.01​
21.61​
0.01​
21.3​
0​
21.85​
-0.03​
21.96​
0.01​
22.05​
0.01​
21.74​
0​
22.26​
-0.03​
22.39​
0.01​
22.48​
0.01​
22.18​
0​
22.73​
-0.03​
22.83​
0.01​
22.95​
0.02​
22.6​
0​
23.17​
-0.04​
23.26​
0.01​
23.39​
0.02​
23.04​
0​
23.6​
-0.04​
23.74​
0​
23.83​
0.02​
23.48​
0​
24.05​
-0.04​
24.17​
0​
24.26​
0.02​
23.96​
0​
24.48​
-0.04​
24.61​
0​
24.74​
0.02​
24.39​
0​
24.96​
-0.04​
25.05​
0​
25.17​
0.02​
24.84​
0.01​
25.39​
-0.04​
25.49​
0​
25.61​
0.02​
25.26​
0.01​
25.85​
-0.04​
25.96​
0​
26.05​
0.02​
25.74​
0.01​
26.27​
-0.04​
26.39​
0​
26.48​
0.03​
26.18​
0.01​
