- Jan 12, 2015
- 185
- 15
- Singapore
- C?ID=232348
Hi team, can someone please assist as I'm stuck with Two electrical issues after replacing Coolant Pump-02.
I'm getting the same error as was the original cause for me doing the repairs. Now I have an additional issue of not having my radiator fans operating.
I have tested both on 12V battery and they work just fine.
Any Ideas? Please advise
Sunday,24,March,2024,08:03:06:41771
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 23.11.0.0
VIN: WVWZZZ1KZ9W506232 License Plate:
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZ9W506232 Mileage: 196020km-121801miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 LB HW: 03L 906 022 G
Component: R4 2.0l TDI G000AG 9979
Revision: 13H01--- Serial number:
Coding: 0001078
Shop #: WSC 18688 039 403977
VCID: 70EFE3E06300381133-8025
VINID: 9E69EAAAA05BA899C5006083084195CD38
001681 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Mileage: 196023 km
Date: 2018.08.15
Time: 22:54:15
Temperature: 36.0°C
Temperature: 54.9°C
Temperature: 22.5°C
Lambda: 9.5 %
Lambda: 0.0 %
009756 - Coolant Pump 2
P261C - 000 - Short to GND
Mileage: 196023 km
Date: 2018.08.15
Time: 22:54:56
RPM: 805 /min
Voltage: 12.39 V
Lambda: 79.7 %
Bin. Bits: 10011111
Bin. Bits: 00000000
Temperature: 35.1°C
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1913
Revision: 04844002 Serial number: 00000901080181
VCID: 51A94664C84A11191C-8005
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 163B400D09220000680D02E7901B0082B50000
Shop #: WSC 00028 028 00001
VCID: 76E3D5F8C1641621E9-8023
Part No SW: 5K0 907 044 AJ HW: 5K0 907 044 AJ
Component: Climatronic 130 0305
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
VCID: 73E5ECECDA160309CE-8027
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
Reset counter: 42
Mileage: 196023 km
Date: 2024.03.24
Time: 22:59:12
Part No SW: 1K0 937 086 HW: 1K0 937 086
Component: BCM PQ35 M 020 0358
Revision: 00020000
Coding: 46180A3A902518C044080080140081E441510088436D8960648000000000
VCID: 6DD1FA94B432D5F918-8039
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 06020 21 0501
Coding: 009795
Component: RLS 180209 05 54 0402
Coding: 0330AD
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 033 0604
Serial number: 003C2D093S1S Dataset Number: v00300535K0 0001
Coding: 00003134
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77FDD8FCCE6E6F29F2-8023
Component: S.Sens.Fahr.V U01 ----
Serial number: 5D634044ZZZZZZZZZZZZ
Component: S.Sens.Beif.V U01 ----
Serial number: 044E2544ZZZZZZZZZZZZ
Serial number: 0208220BZZZZZZZZZZZZ
Serial number: 3A41204BZZZZZZZZZZZZ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0001532
VCID: 76E3D5F801641621E9-8023
Subsystem 1 - Part No: 3C8 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H4ÿ 0021
Coding: 00000226
Part No SW: 5K0 920 870 C HW: 5K0 920 870 C
Component: KOMBI H21 KOMBI H21 00290029
Coding: 170B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: N/A
VCID: 2D513A947CB215F958-8079
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K0920410C6
Coding: ED807F06000202000003
VCID: 377D18FC46EEAF2932-8063
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H21 0029
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
Part No SW: 1K0 959 701 AM HW: 1K0 959 701 AM
Component: Tuer-SG 008 2042
Coding: 0000692
VCID: 79F9DEC4307A795984-802D
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 70 2501
Revision: 00H15000
VCID: 2C5737908FA81CF14F-8079
Part No SW: 1K0 959 702 AM HW: 1K0 959 702 AM
Coding: 0000692
VCID: 7AFBC1C8357C72418D-802F
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5814
Revision: -------- Serial number: VWZZZ4H6290655
Coding: 16000440040005
Shop #: WSC 127395 840 08317
VCID: 46836538F104C6A1B9-8013
Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
Component: Tuer-SG 007 2009
Coding: 0000144
Shop #: WSC 01357 011 1012552
Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
Coding: 0000144
VCID: 7BF5C4CC3A464B4996-802F
End-------------------------(Elapsed Time: 02:20)--------------------------
