hi friends
i lose MFL command and airbag driver
so i doubt about steering angle sensor 5K0.953.569.AK
have you same idea ?
thanks
thanks
Saturday,20,January,2024,10:06:22:51859
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
VIN: WVWZZZ7NZJV037331 License Plate: EX481VH
Mileage: 62870km-39065mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 4C 52 53 5F 61 62
72
VIN: WVWZZZ7NZJV037331 Mileage: 62870km-39065miles
Address 01: Engine (J623-DFLD) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 JM HW: 04L 907 309 K
Component: R4 2.0l TDI H20 4639
Revision: 8AH20--- CVN: 1984B597B866C2AD
Coding: 0119001A042401082000
Shop #: WSC 47935 005 1048576
ASAM Dataset: EV_ECM20TDI01104L906016JM 004003
ROD: EV_ECM20TDI01104L906016HD_004_VW36.rod
VCID: 7DA7F1FA9D7DC7D2445-8028
VINID: 9E69EAAAA1DEA9A9800C70C304C46BAEFE
4714 - Steering Column Control Module
U0212 00 [00101111] - No Communications
Mileage: 62625 km
Date: 2024.01.11
Time: 07:59:03
Engine RPM: 978.00 /min
Normed load value: 27.8 %
Coolant temperature: 53 °C
Intake air temperature: 44 °C
Voltage terminal 30: 14.860 V
Cruise Control System (CCS): status-Bits 0-7: 7
selected gear-Bits 0-7: 0
18875 - Cruise Control Switch (E45)
P0568 00 [00101111] - Implausible Signal
Fault Frequency: 61
Mileage: 62625 km
Date: 2024.01.11
Time: 07:59:02
Engine RPM: 978.50 /min
Normed load value: 27.1 %
Voltage terminal 30: 14.900 V
ACC variants-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 128
ACC variants (coding)-Bits 0-7: 1
Acceleration: 0.000 m/s²
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb
Part No SW: 5N0 614 109 CL HW: 5N0 614 109 CL
Component: ESC-EBC460iV1 H14 0014
Serial number: A01R0LN
Coding: 12F0449A0923C273087A480322C490431031170000014084
Shop #: WSC 00020 999 00000
VCID: 77ABE3D2BF41ED821E9-8022
Part No SW: 7N0 907 044 BD HW: 7N0 907 044 BD
Component: Clima-Sharan H04 0707
Revision: 00001K06
Coding: 021000C449
ASAM Dataset: EV_ClimatronicSharan A01724
VCID: 73B3D7C2AB3981A2221-8026
Part No SW: 5K0 937 084 M HW: 5K0 937 084 M
Component: BCM PQ35 B 122 0186
Revision: BA122001
Coding: 60180A3B812508C4408800C09400007403D10008426D29226480872000C1
Shop #: WSC 00020 790 00000
VCID: 3C213CFEC6670EDA33B-8068
Subsystem 1 - Part No SW: 7N1 955 119 C HW: 7N1 955 119 C Labels: 1KX-955-119.CLB
Component: WWS428 180213 024 0646
Serial number: 18020803084141
Coding: 004DBD
Component: RLHS 050 0107
Serial number: SAY18M04D16H03M27S36
Coding: 0228BB
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331810200664
Coding: 0031051001
ASAM Dataset: EV_EPHVA18VW364GP00 001007
VCID: 372B23D2FFC12D82DE9-8062
Part No SW: 7N0 959 655 D HW: 7N0 959 655 D
Component: VW10Airbag110 H15 0016
Serial number: 003PWP4UVYY3
Coding: 003130
ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 40D9480EAA0F6A3A6F3-8014
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS6084E2DA1D9DB
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS60AEF7DA1D9DL
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS6056E9DA1DDDE
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60090DDB1D9D0
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS6080F1C31DDDU
9437211 - Igniter for Driver's Airbag
B1000 1B [10001001] - Resistance Too High
Mileage: 62625 km
Date: 2024.01.11
Time: 07:59:03
Part No SW: 5K0 953 501 CP HW: 5K0 953 569 AK
Component: LENKS.MODUL 016 0180
Revision: FF010042 Serial number: 20180414202143
Coding: 1182440008
VCID: 7AADFAE68C53F0EA617-802E
365080 - Controls in Steering Wheel
U108E 00 [00001001] - No Communications
Reset counter: 109
Mileage: 62625 km
Date: 2024.01.11
Time: 07:59:00
Part No SW: 7N0 920 870 Q HW: 7N0 920 870 Q
Component: KOMBI H03 1107
Coding: 110F010800
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 G
Component: Zuheizer 051 3041
Revision: 00051000 Serial number: 09028242000000
Coding: 0000041
VCID: 382920EEFE5F22FAD73-806C
Part No SW: 7N0 907 530 BJ HW: 7N0 907 530 AL
Component: J533 Gateway H58 1682
Revision: H58 Serial number: 140418F1000365
Coding: 468032
VCID: 79AFE5EA89D5FBF268D-802C
Component: IMMO H03 1107
VCID: 6A8DCAA6FCF3406A917-803E
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 H HW: 7N0 959 793 F
Component: TSG FA H05 0561
Revision: Serial number: 0000310373310
Coding: 011007208000411011
VCID: 47CB53128FA15D02AE9-8012
Part No SW: 5N1 909 144 S HW: 5N1 909 148 K
Component: J500__APA-BS KL.323 1501
Revision: 1BH04741 Serial number: 00180670069701
Coding: 0000258
VCID: 42DD4206A883782A797-8016
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 H HW: 7N0 959 792 F
Component: TSG BF H05 0561
Revision: Serial number: 0000312494783
Coding: 011005208000411011
VCID: 46D55E1688AB440A55F-8012
Part No SW: 5C0 035 680 F HW: 5C0 035 680 F
Component: MU-S-N-ER H41 0472
Serial number: VWZAZ2U0739746 Dataset Number: V03935269PZ 0001
Coding: 02240801FF0000001111000100080A001F0100C400200100CF
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2411E49E5E57561A6BB-8070
Data carrier:
Subsystem 1 - Part No SW: 3G0 919 866 BJ HW: -----------
Component: ECE1 2018 --- 0915
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1682
Coding: 030F7859
VCID: 71BFDDCAD1A5B3B2D0D-8024
Subsystem 1 - Part No SW: 1K0 915 181 L HW: 1K0 915 181 L
Component: J367-BDM H07 0270
Serial number: 35099D14175830954201
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 K HW: 7N0 959 794 G
Component: TSG HL H06 0561
Revision: Serial number: 0000309903009
Coding: 010005200000411001
VCID: 4BC36F2293C9B9628A1-801E
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H06 0561
Revision: Serial number: 0000314301291
End----(Elapsed Time: 01:17, VBatt start/end: 12.0V/11.9V. VIgn 11.8V)-----
