Audi Q5 non oem hitch install
Q5hitch
FL, USA
C?ID=565426
Hello everyone. I am new to the forum. I have done extensive search for help on my Audi Q5 but no one has posted a fix for a non oem hitch install. The post are usually about Q7 or Q8 or installs on the oem hitch from the dealership.
My situation. Car had hitch and no harness. Car didn’t not have the PIN code etc for the hitch. Asked dealership and they told me that I would have to buy the whole kit again for the paperwork that has the code. It was pretax $2300. They would throw away the oem hitch and use the harness and module. The majority of the price is from bumper recalibration once the install is performed.
I used the DIY harness making info from AudiWorld forums. Bought a European tow module. 8W1907383A. Installed it all myself. Now I’m getting errors on vcds. I used some info from the AudiWorld forums to fix the error for controller 69. Changed the values from a one to a 2 to make is NAR. But it didn’t fix anything. So now I need help
Q5hitch
FL, USA
C?ID=565426
Before I post the auto scan. I’m getting présense malfunction. Please check trailer hitch. Adaptive light malfunction. And high beam assistant malfunction.
Interestingly the picture of the trailer on the dash does show up.
siLc
Tallinn, Estonia
C?ID=330192
Yes, because all those things need to be coded to make them aware of the trailer module being installed. This is not an uncommon situation to be in.
Q5hitch
FL, USA
C?ID=565426
Saturday,21,October,2023,12:37:33:42614
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
VIN: WA1CA1234564591   License Plate:
Mileage: 51536km-32022mi   Repair Order:
Chassis Type: FY-AU49 (80C)
Scan: 01 02 03 08 09 13 15 16 17 19 22 36 3C 42 44 46 52 5F 69 6C
          6D 75 80 81 82 8B A5 BB BC CA CF D6 D7 DE
VIN: WA1CA1234567891   Mileage: 51536km-32022miles
80-Batt. reg. aux. accum. -- Status: OK 0000
82-Head Up Display -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DPVA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 80A 906 259 M    HW: 06L 907 425 E
   Component: R4 2.0l TFSI  H08 0001
   Dataset Number: 06L909102BA 0005 CVN: 8B6307FC
   Coding: 2A6500322566012E74382000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS02080A906259M 001002
   ROD: EV_ECM20TFS02080A906259M.rod
   VCID: 353731FB25CB11C2ECD-8060
   VINID: 9D10534515A90DD08010020918BEB5229F
   Radiator shutter:
   Subsystem 1 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1       H13 0110
   Serial number: 20201031060104078411
23079 - Control unit for information electronics 1
          U1054 00 [032] - No Communication
19803 - EVAP System
17176 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 9
                    Reset counter: 40
                    Mileage: 50951 km
                    Date: 2023.10.12
                    Time: 13:42:11
                    Engine RPM: 1231.25 /min
                    Normed load value: 14.1 %
                    Coolant temperature: 47  C
                    Intake air temperature: 46  C
                    Voltage terminal 30: 12.363 V
                    Engine status: Idle
                    ECU_STATE: SYN_ENG_IGK_ON
                    ACC variants (coding): ACC with braking until standstill / Stop & Go
Address 02: Auto Trans (J217)       Labels:| 0CJ-927-156.clb
   Part No SW: 80A 927 155 DQ    HW: 0HK 927 156 B
   Component: 0JC 20TFSINAR H01 0002
   Revision: --H01---    Serial number: 0000001100 CVN: FAF0469F
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002038
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 7BA3E7C3436F07B25A9-802E
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 M
   Component: V553 MTFP  003 0582
   Serial number: 75290041200273001342
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 80A 907 379 AF    HW: 80A 907 379 H
   Component: ESP9 Premium  H17 0871
   Dataset Number: 80B909504AH 0002 CVN: C2732B8A
   Coding: 4CAA40BE2CA60A9693A6589A228352A2F5359A32023450C91A444A45AFAC59
   ASAM Dataset: EV_ESP9BOSCHCMP 002013
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 73B3CFE36B3F4FF2029-8026
419328 - TPMS Warning; Front Right Tire
          C1057 00 [032] - Flat
   Part No SW: 80A 820 043 AA    HW: 80A 820 043 AA
   Component: Klima Zone 3  H60 0270
   Coding: 640909095548010D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 5CE1845FE6A1E08A333-8008
   Subsystem 1 - Part No SW: 4M1 820 021 C    HW: 4M1 820 021 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000005484222
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H04 0010
   Serial number: A520858000PAG0MUFU04
   Rear air conditioning block 1:
   Subsystem 3 - Part No SW: 80A 919 158 A    HW: 80A 919 158 A
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W1 907 063 AG    HW: 8W1 907 063 G
   Component: BCM1 MLBevo   H10 0712
   Dataset Number: 80C909514A  0011
   Coding: 07000360C0291CDD050757899CAF9CB9130B75490000009801010A0060001C01086302BB22B70A0000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 015F952B21836D62005-8054
   Wiper motor control module:
   Subsystem 1 - Part No SW: 80B 955 119 A    HW: 80B 955 119
   Component: 426 LL 201110  040 0581
   Serial number: 00000002011072113286
   Subsystem 2 - Part No SW: 81A 955 555 B    HW: 81A 955 555
   Component: G397_RLFSS  H06 0004
   Serial number: 40112520X81A955555B0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AP    HW: 4M0 941 531 AP
   Component: E1 - LDS  H07 0008
   Serial number: 05 11 2020  03100677
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z01E902
   Coding: 250000
   Automatic dimming interior mirror:
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR110112023311008
   Interior Light Module:
   Subsystem 6 - Part No SW: 80A 947 135 BJ    HW: 80A 947 135
   Component: Dachmodul  H42 0415
   Serial number: Q00181531
   Coding: 0D0101
   Adjustable Steering Column Control Module:
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H08 0210
   Serial number: WA145064000092600473
   Cup holder with heating and cooling element:
   Subsystem 8 - Part No SW: 80A 864 981 F    HW: 80A 864 981 F
   Component: Q5 THERMO CUP  H07 0020
   Serial number: 0016809843
   Blower 1 for left front backrest:
   Subsystem 9 - Part No SW: 4N0 963 575 B    HW: 4N0 963 575 B
   Component: V512 LLR1SLvL  H01 0012
   Serial number: X02AK30998633
   Blower 1 for left front seat cushion:
   Subsystem 10 - Part No SW: 4N0 963 575 B    HW: 4N0 963 575 B
   Component: V514 LLR1SKvL  H01 0012
   Serial number: X02AK31199112
   Blower 1 for right front backrest:
   Subsystem 11 - Part No SW: 4N0 963 575 B    HW: 4N0 963 575 B
   Component: V516 LLR1SLvR  H01 0012
   Serial number: X02AK30998648
   Blower 1 for right front seat cushion:
   Subsystem 12 - Part No SW: 4N0 963 575 B    HW: 4N0 963 575 B
   Component: V518 LLR1SKvR  H01 0012
   Serial number: X02AK31199095
67735 - Databus
          [MxB not available]
                    Reset counter: 217
                    Mileage: 50951 km
                    Date: 2023.10.12
                    Time: 13:42:14
                    average_Voltage_terminals: 14.00 V
                    Outside air temperature sensor-Resistance: 0.00 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 30.00  C
                    interior_temperature: 30.50  C
                    Vehicle speed: 0.00 km/h
                    Terminal activation-Terminal 75 status: On
                    Terminal activation-Terminal 15 status signal: On
                    Terminal activation-Terminal 15 via CAN: On
                    Terminal activation-Term 75: qualification: OFF
67737 - Databus
          [MXB_error-lamp_requested]
                    Reset counter: 217
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:26:28
                    average_Voltage_terminals: 14.20 V
                    Outside air temperature sensor-Outside air temperature on CAN: 33.00  C
                    interior_temperature: 28.00  C
   Part No SW: 80A 907 561 C    HW: 8W0 907 561
   Component: LRR4          H12 0451
   Dataset Number: 80B909863J  0004
   Coding: D5779FF358FFEC0A959B83E1
   ASAM Dataset: EV_ACCBOSCHAU49X 003024
   ROD: EV_ACCBOSCHAU49X_003_AU49.rod
   VCID: 2809E88FE2797C2A67B-807C
1229 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 217
                    Mileage: 50951 km
                    Date: 2023.10.12
                    Time: 13:42:11
                    Control Module temperature: 35  C
                    Voltage terminal 15: 12.3 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s
                    Adaptive distance regulation: status: ACC_Init
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 217
                    Mileage: 50951 km
                    Date: 2023.10.12
                    Time: 13:42:11
                    Adaptive distance regulation: status: ACC_irreversible error
Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
   Part No SW: 80A 959 655 R    HW: 80A 959 655 R
   Component: AirbagVW30    003 0703
   Serial number: 0032QM01CCME Dataset Number: 80A909602AA 0011
   Coding: AECCFCC000A00000A000003FF20C400000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001044
   ROD: EV_AirbaVW31SMEAU65x_001.rod
   VCID: 42DD5A276405B67A59F-8016
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2040
   Serial number: 80A857705M0290U01223
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2040
   Serial number: 80A857706M0292U00011
   Coding: 80000D
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D20000EQC1A0
   Coding: 303239
   Subsystem 4 - Part No SW: -----------    HW: 480 002 409 20
   Serial number: 3570000000012D21FB4L
   Subsystem 5 - Part No SW: -----------    HW: 480 002 409 20
   Serial number: 358000000001A631FB4O
   Subsystem 6 - Part No SW: -----------    HW: 480 031 109 20
   Serial number: 351002C0C6B0D5B05D7K
   Subsystem 7 - Part No SW: -----------    HW: 480 031 209 20
   Serial number: 352002C0CEFA21616C3K
   Subsystem 8 - Part No SW: -----------    HW: 480 031 609 20
   Component: FrontSensor_D  002 0149
   Serial number: 355002C0C139A630A937
   Subsystem 9 - Part No SW: -----------    HW: 480 031 609 20
   Component: FrontSensor_P  002 0149
   Serial number: 356002C0CEFCAAA09DDH
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 708 20
   Component: CentrSensorXY  005 0108
   Serial number: I0O0001A6F510AC58893
1060617 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                    Fault Frequency: 9
                    Reset counter: 217
                    Mileage: 50951 km
                    Date: 2023.10.12
                    Time: 13:42:11
1060614 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Fault Frequency: 9
                    Reset counter: 217
                    Mileage: 50951 km
                    Date: 2023.10.12
                    Time: 13:42:11
   Part No SW: 80A 907 129 DH    HW: 80A 907 129 DH
   Component: Lenks.Modul   H03 0009
   ROD: EV_SMLSKLOAU736_007_AU49.rod
   VCID: 71BFC5EB11237DE2F05-8024
   Part No SW: 80A 920 790 J    HW: 80A 920 790 J
   Component: FBenRDW------ H10 0161
   Coding: 8BE63DC5EE88D7050280636018004B0008003000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU49.rod
   VCID: 2E051E97C09D221AAD7-807A
          U1014 00 [009] - -
          [ECU incorrectly coded]
                    Fault Frequency: 8
                    Reset counter: 217
                    Mileage: 50951 km
                    Date: 2023.10.12
                    Time: 13:42:09
16777018 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 252
                    Mileage: 51405 km
                    Date: 2023.10.16
                    Time: 12:05:38
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 252
                    Mileage: 51405 km
                    Date: 2023.10.16
                    Time: 12:05:38
16777022 - Control unit for information electronics 1
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 252
                    Mileage: 51405 km
                    Date: 2023.10.16
                    Time: 12:05:38
16777030 - Control unit for information electronics 1
          [BAP_TEL2_0x29 communication error bap_error_timeout heartbeat]
                    Reset counter: 252
                    Mileage: 51405 km
                    Date: 2023.10.16
                    Time: 12:05:38
16777058 - Control unit for information electronics 1
          [BAP_OnlineFunctions_0x2A communication error bap_error_timeout heartbeat]
                    Reset counter: 252
                    Mileage: 51405 km
                    Date: 2023.10.16
                    Time: 12:05:38
   Part No SW: 80C 907 468 F    HW: 80B 907 468 B
   Component: Gateway       H06 0613
   Serial number: 1JF04196927301 Dataset Number: 8W0909515VC 0002
   Coding: 02030001002006402987000000590032DC3A0001100000000100008E00000000
   GVL: 01D03C0808000000C0DCC8008002C800100C0000004000000000000000006500
   ASAM Dataset: EV_Gatew31xAU65x 003250
   ROD: EV_Gatew31xAU65x_AU49.rod
   VCID: 33330FE32BBF0FF2C29-8066
   Subsystem 1 - Part No SW: 80A 951 523 M    HW: 80A 951 523 M
   Component: J453 MFL  H07 0004
   Serial number: 20201128150912 00737
   Serial number: 4991157700
   Steering Wheel Touch Recognition Control Module:
   Subsystem 3 - Part No SW: 80A 419 508 B    HW: 80A 419 508 B
   Component: J1158 KLR  H03 0007
   Serial number: 20324033501S0007H031
66304 - Databus
          U1124 00 [008] - Additional Installations Detected
          [Data_Bus_Commponent_List_detected]
                    Fault Frequency: 37
                    Reset counter: 2
                    Mileage: 50951 km
                    Date: 2023.10.12
                    Time: 12:31:21
131830 - Ethernet Module for Emergency Call
          U1642 00 [008] - No Communication
          [Timeout_Node_0xF6_conBox_DiagAdress_0075]
                    Reset counter: 0
                    Mileage: 50743 km
                    Date: 2023.10.04
                    Time: 07:31:10
16711991 - Ethernet Databus Branch 2
          U122D 00 [008] - No Communication
          [Ethernet_databus_no_communication_port_2]
                    Reset counter: 252
                    Mileage: 51405 km
                    Date: 2023.10.16
                    Time: 12:05:41
                    Ethernet counter checksum error: branch 2: 0
                    Ethernet counter connection interruptions: branch 2: 1
Address 22: AWD (J492)       Labels:* Redir Fail!
   Part No SW: 80A 927 755     HW: 0CJ 927 749 A
   Component: Q5_DL3_N_SD5H02 0006
   Serial number: 20290B6460
   Coding: 110F0000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 6C81D49F3601900AC33-8038
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0064
   Serial number: 12A14032202884 Dataset Number: 80B909856C  0014
   Coding: 015C1A000000B0010003010101010000000000000000000000000000004000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013
   ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
   Part No SW: 80A 907 566 B    HW: 80A 907 566
   Component: MRR1Rear      H22 0441
   Revision: --------    Dataset Number: 80B909535C  0006
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 2C01149FF681500A833-8078
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0425
   Serial number: CLSM1TK20008I Dataset Number: 80B909872F  0044
   Coding: 005D8B015E00148000010032
   ROD: EV_DCU2DriveSideMAXHKLO_AU49.rod
   VCID: 46D54637482D8A5A757-8012
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Dataset Number: 80B909852M  0001
   Coding: B0112101010001
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D0AE7D4A506FAC9F-8066
   Part No SW: 4N0 907 064 EP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H16 0224
   Dataset Number: 80C909501A  0008
   Coding: 013400004FB100C0650BA0006C019802030340008104A6502F0000000F04803F001E0681000A11
   ASAM Dataset: EV_BCM2CONTIAU651 011009
   ROD: EV_BCM2CONTIAU651_011.rod
   ID - sensor:
   Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY2028007QY
   Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000048909873
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 14866849
   Rear spoiler control module:
   left tail lamp 2:
   Subsystem 6 - Part No SW: 80A 945 429 A    HW: 80A 945 429 A
   Component: T2 LH SAE  H10 0403
   Serial number: 30U
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 80A 945 430 A    HW: 80A 945 430 A
   Component: T2 RH SAE  H10 0403
   Serial number: 1S9
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0425
   Serial number: CLSM1TJQ000I5 Dataset Number: 80B909873F  0044
   Coding: 005D8B015E00148000010030
   ROD: EV_DCU2PasseSideMAXHKLO_AU49.rod
   VCID: 45D7413B752B81427CD-8010
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 80A 035 050 H    HW: 80A 035 050
   Component: MU-TH-NS-US   042 3696
   Serial number: 8VV-DDM25.11.20 Dataset Number: 8W1909545G  0035
   Coding: 14260010804020000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU37.rod
   VCID: 1E65CE57B03DB29A1D7-804A
   Multimedia System 1:
   Subsystem 1 - Part No SW: 80B 919 620     HW: 80B 919 620
   Component: CenterDisplay  H41 0160
   Serial number: AUZ8Z9L6H00VJ7
   Data carrier:
   Subsystem 2 - Part No: V03 959 808 FR
   Component: MIB3_NA_       0816
   Compact disc data bank:
   Component: Gracenote2     3004
   Volume Control 1:
   Subsystem 4 - Part No SW: 80B 919 616 A    HW: 80B 919 616 A
   Component: LSR-Q5PA       H20 0103
   Serial number: ALJAL203092000050863
   Media socket:
   Subsystem 5 - Part No: 8W0 035 708 A
009 0007
   Digital Sound System Control Module 2:
   Subsystem 6 - Part No SW: 8Y0 035 465     HW: 8Y0 035 465
   Component: B_A_3_P_0_AU   H10 0140
   Serial number: YJL-26021.11.2066610
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 8W1 907 383 A    HW: 8W1 907 383
   Component: Anhaenger     H07 0039
   Serial number: 000000000005260 Dataset Number: 8Y0909527A  0005
   Coding: 0200000200001100
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 3FDB53D317F7DB92361-806A
9 Faults Found:
656906 - Bulb for Left Turn Signal on Trailer
          C10F7 15 [040] - Open or Short to Plus
                    Reset counter: 28
                    Mileage: 51027 km
711179 - Switch on Locking Bolt
          C10E7 13 [040] - Open Circuit
          [Switching contact for trailer locking bolt - open circuit]
                    Reset counter: 17
                    Mileage: 180 km
136203 - Supply Voltage
          P1757 00 [047] - Open Circuit
                    Fault Frequency: 16
                    Reset counter: 40
                    Mileage: 50951 km
336388 - Databus
          U1121 00 [040] - Missing Message
          [Engine electronics - no signal/communication]
                    Reset counter: 25
                    Mileage: 54409 km
                    Date: 2022.09.11
                    Time: 03:20:21
336900 - Databus
          U1121 00 [032] - Missing Message
          [Brake electronics - no signal/communication]
336920 - Implausible Data Received from ABS Control Module
          U0415 00 [046] - -
          [Brake electronics - implausible message (ESP_v_signal)]
                    Reset counter: 40
                    Mileage: 36032 km
                    Date: 2021.09.29
                    Time: 18:39:43
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [109] - Performance
          [Convenience data bus - no signal/communication]
                    Reset counter: 40
                    Mileage: 54408 km
                    Date: 2023.02.16
                    Time: 08:56:22
136198 - Voltage Supply Terminal 30
          B1996 F1 [047] - Charging Cable Open Circuit
                    Fault Frequency: 16
                    Reset counter: 40
                    Mileage: 50951 km
136199 - Voltage Supply Terminal 30
          B1996 F2 [047] - For Tilting; Open Circuit
                    Fault Frequency: 16
                    Reset counter: 40
                    Mileage: 50951 km
   Part No SW: 8W0 907 428 A    HW: 4M0 907 428
   Component: Areaview 2    H16 0106
   Serial number: C854609JI005614 Dataset Number: 80B909460L  0020
   Coding: 02240602BE0FA10038004004
   ASAM Dataset: EV_CamSysRVAV2CE2MLBPA 001001
   ROD: EV_CamSysRVAV2CE2MLBPA_001.rod
   VCID: 3E252ED710FDD29A3D7-806A
   Part No SW: 8W8 959 107 E    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0172
   Revision: --------    Serial number: A2-C748-5750-9 Dataset Number: 80B909541D  0010
   Coding: 0730
   ROD: EV_DeckLidCONTIAU736_AU37.rod
   VCID: 4BC37703534F7732AA9-801E
   Part No SW: 4KE 035 283 F    HW: 4KE 035 283 B
   Component: CB_H_NAR      039 0372
   Serial number: A971I0LS063855 Dataset Number: 8W0909612F  0024
   Coding: 01E0E0F8C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X.rod
Address 80: Batt. reg. aux. accum. (A1)       Labels: 8W0-915-101.clb
   Part No SW: 8W0 915 101 A    HW: 8W0 915 101 A
   Component: MQ-BMS        H20 0127
   Serial number: 20000100622003
   ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
   ROD: EV_BMS12VLiIonSDIAU49X.rod
   VCID: 313F05EBD1A33DE2B05-8064
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 80B 713 041 N    HW: 80B 713 041 N
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 20201112001635
   ASAM Dataset: EV_GSMWaehlZFAU736 001017
   ROD: EV_GSMWaehlZFAU736_AU49.rod
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 80A 919 617 D    HW: 80A 919 617 D
   Component: HeadUpDisplay H16 1952
   Coding: 4F01E0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU49.rod
16777040 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [NAV_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 252
                    Mileage: 51405 km
                    Date: 2023.10.16
                    Time: 12:05:43
16777042 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [AIO_0x42 communication error bap_error_timeout heartbeat]
                    Reset counter: 252
                    Mileage: 51405 km
                    Date: 2023.10.16
                    Time: 12:05:43
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541 C    HW: 8W0 907 541
   Dataset Number: 80B909885F  0002
   ASAM Dataset: EV_ACC2BOSCHAU49X 003024
   ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
   VCID: 2615E6B7E86D6A5A557-8072
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 F    HW: 80A 907 217 D
   Component: BVS           H24 0070
   Dataset Number: 80B909466F  0036
   Coding: 0404020600000201022023AEC50000FEB0F0C020E280
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002028
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 290FED8BF9734522785-807C
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Variant_coding_failure]
                    Reset counter: 217
                    Mileage: 50951 km
                    Date: 2023.10.12
                    Time: 13:42:09
                    Control Module temperature: 25  C
                    Voltage terminal 15: 11.60 V
1123220 - Databus
          [KLR_01_KLR_Touchauswertung]
                    Reset counter: 0
                    Mileage: 51477 km
                    Date: 2023.10.20
                    Time: 06:52:16
                    Control Module temperature: 18  C
                    Voltage terminal 15: 14.40 V
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS004 0425
   Serial number: CLSM1TKK00763 Dataset Number: 80B909897G  0046
   Coding: 000D89000000148040000020
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   VCID: 48C9480F42399C2A87B-801C
   Component: TSG HBFS004 0425
   Serial number: CLSM1TKK0075Z Dataset Number: 80B909896G  0046
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Dataset Number: 80B909469G  0012
   Coding: 22804004260C
   ROD: EV_SunRoofCONTIAU736_009_VW48.rod
   VCID: 75B7F1FB654B51C22CD-8020
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 80A 907 590 B    HW: 80A 907 590
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   ROD: EV_RearRadarS2BoschAU736.rod
   Part No SW: 4K0 941 591 BD    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0040
   Dataset Number: 80B909471E  0010
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 72BDCAE7142546FA09F-8026
   Dataset Number: 80B909472E  0010
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
   ROD: EV_LMSRightHELLAAU58X.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 80A 035 502 B    HW: 80A 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 1A6DC247AC15DEBAE1F-804E
End----------(Elapsed Time: 02:23, VBatt start/end: 14.3V/14.2V)-----------
VIN: WA1CAAFY3M2040896   Mileage: 51536km-32022miles
82-Head Up Display -- Status: OK 0000
   Radiator shutter:
17176 - Databus
                    Reset counter: 40
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:24
                    Engine RPM: 846.25 /min
                    Normed load value: 14.5 %
                    Coolant temperature: 107  C
                    Intake air temperature: 59  C
                    Voltage terminal 30: 14.101 V
                    Engine status: Idle
Readiness: 1110 0101
   MTF pump:
   Coding: 02006E
   Coding: 250000
   Coding: 0D0101
67735 - Databus
          [MxB not available]
                    Reset counter: 217
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:24
                    Outside air temperature sensor-Outside air temperature on CAN: 34.50  C
                    interior_temperature: 25.50  C
67737 - Databus
                    Reset counter: 217
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:42
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 217
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:23
                    Control Module temperature: 59  C
                    Voltage terminal 15: 14.0 V
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 217
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:23
                    Voltage terminal 15: 14.2 V
   Coding: 80000D
   Coding: 80000D
   Coding: 303239
1060617 - Databus
                    Reset counter: 217
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:23
1060614 - Databus
                    Reset counter: 217
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:23
          U1014 00 [009] - -
                    Reset counter: 217
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:22
   Coding: 110F0000
   Coding: 0EC002
   ID - sensor:
   left tail lamp 2:
   Serial number: 30U
   Serial number: 1S9
   Data carrier:
   Volume Control 1:
   Media socket:
009 0007
                    Reset counter: 40
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:22
                    Reset counter: 40
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:22
                    Reset counter: 40
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:22
   Coding: 0730
   Coding: 4F01E0
          U1014 00 [009] - -
                    Reset counter: 217
                    Mileage: 51536 km
                    Date: 2023.10.21
                    Time: 12:38:22
                    Control Module temperature: 40  C
                    Voltage terminal 15: 14.30 V
   Revision: --------
   Coding: 0EC002
   Coding: 800000
End----------(Elapsed Time: 02:37, VBatt start/end: 14.3V/14.0V)-----------
Q5hitch
FL, USA
C?ID=565426
The only change I made so as not to confuse myself is module 69.
Trailer module 69
changed
0100000202001100
to
0200000200001100
I read that the 01 is ROW and 02 is USA
The middle 20 I dont know what it does but other people who had dealer configured coding had the 20 removed from the middle section of the code.
From
0200000202001100
to
0200000200001100
Next. my system was completely fine. I attached the trailer module. Hooked it up and connected power to the unit. Started engine, opened the hood of the car, and ran autoscan. Then errors popped up. I know for sure some of the errors are related to the European swivel hitch which I do not own but is likely programmed into the unit. I dont know how to shut off that system so it doesnt ask for power to the unit. My trailer unit has port D which I read is for controlling the swivel hitch from inside the trunk and the dashboard. I assume I need to disable that port?
Q5hitch
FL, USA
C?ID=565426
Thanks. I am a newbie and Im worried im gonna mess up my car which is still under warranty. I have backed up my original files via raw and hex just to make sure.
I can give you a few coding changes, but I doubt this will be all of them:
13: Byte 3, Bit 3: Control_module_for_towing _sensor
17: Byte 14, Bit 5: Trailer
46: Byte 4, Bit 7: trailer_monitoring
A5: Byte 11, Bit 0: AAG ("Anhaenger Agregat").
The catch with making these changes manually on a car this new rather than purchasing the kit that includes an SVM code from the dealer is that if a dealer ever runs SVM on this car, it will un-do all your changes. So definitely keep track of everything that you do to make this work.
Q5hitch
FL, USA
C?ID=565426
UWE
thanks so much. I will try those codes.
I see the issue with the SVM codes. But if this works I will be so happy. Im in the hole by $400 for the controller and harness. New OEM kit was $875 and they refused to program unless they install it (harness and modulle. They said they would leave the metal hitch in the box and not use it and use the after market hitch that was already installed). So it would have been the whole $2300.
I guess I would have to get it working. Save the files. Revert back to the original codes when taking it to the dealer so they wont void my warranty?
I've never heard of warranty being voided due to a DIY trailer hitch installation, but then again, I can't promise it either.
Q5hitch
FL, USA
C?ID=565426
That is good to know. I thought they would poke around and find something. My newbie fear.
I have made the following changes. Cleared DTCs. Reran autoscan and no malfunctions have been cleared yet.
Trailer module 69
changed
0100000202001100 to
0200000200001100
Controller 17
8BE63DC5EE88D7050280636018004B0008003000 to
8BE63DC5EE88D7050280636018006B0008003000
Controller 13
D5779FF358FFEC0A959B83E1 to
D5779FFB58FFEC0A959B83E1
Controller 46 and A5 I will get to after I get home.
Monday,23,October,2023,08:44:49:42614
VIN: WA1CA123456789123   License Plate: POST13 POST 17 AND POST 69 CHANGES
Mileage: 51576km-32047mi   Repair Order:
VIN: WA1CA123456789123   Mileage: 51576km-32047miles
   Radiator shutter:
17176 - Databus
                    Reset counter: 40
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 07:58:29
                    Engine RPM: 853.50 /min
                    Normed load value: 12.2 %
                    Coolant temperature: 108  C
                    Intake air temperature: 47  C
                    Voltage terminal 30: 14.179 V
                    Engine status: Idle
Readiness: 1010 0101
   MTF pump:
   Coding: 02006E
   Coding: 250000
   Coding: 0D0101
67735 - Databus
          [MxB not available]
                    Reset counter: 221
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 07:58:28
                    Outside air temperature sensor-Outside air temperature on CAN: 22.00  C
                    interior_temperature: 24.50  C
67737 - Databus
                    Reset counter: 221
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 08:38:45
                    average_Voltage_terminals: 14.30 V
                    Outside air temperature sensor-Outside air temperature on CAN: 21.00  C
   Coding: D5779FFB58FFEC0A959B83E1
          U1014 00 [008] - -
          [FAULT_CODING_AAG]
                    Reset counter: 6
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 07:58:27
                    Control Module temperature: 43  C
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 221
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 07:58:27
   Coding: 80000D
   Coding: 80000D
   Coding: 303239
1060617 - Databus
                    Reset counter: 221
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 07:58:28
1060614 - Databus
                    Reset counter: 221
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 07:58:28
   Coding: 8BE63DC5EE88D7050280636018006B0008003000
   Coding: 110F0000
   Coding: 0EC002
   ID - sensor:
   left tail lamp 2:
   Serial number: 30U
   Serial number: 1S9
   Data carrier:
   Volume Control 1:
   Media socket:
009 0007
                    Reset counter: 40
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 07:58:27
          U0415 00 [040] - -
                    Reset counter: 40
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 08:03:35
                    Reset counter: 40
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 07:58:27
   Coding: 0730
No ASAM data for: "Unknown" (AU49)
   Coding: 4F01E0
          U1014 00 [009] - -
                    Reset counter: 221
                    Mileage: 51576 km
                    Date: 2023.10.23
                    Time: 07:58:27
                    Control Module temperature: 30  C
   Revision: --------
   Coding: 0EC002
End-----(Elapsed Time: 02:32, VBatt start/end: 14.4V/0.0V. VIgn 0.0V)------
Q5hitch
FL, USA
C?ID=565426
Monday,23,October,2023,14:28:34:42614
VIN: WA1CA123456789121   License Plate: POSTGEMREBOOT
Mileage: 51707km-32129mi   Repair Order:
VIN: WA1CA123456789121   Mileage: 51707km-32129miles
   Radiator shutter:
   MTF pump:
   Coding: 02006E
   Coding: 250000
   Coding: 0D0101
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 8
                    Mileage: 51704 km
                    Date: 2023.10.23
                    Time: 13:52:25
                    Control Module temperature: 64  C
                    Voltage terminal 15: 13.0 V
                    Adaptive distance regulation: status: ACC_StandBy
   Coding: 80000D
   Coding: 80000D
   Coding: 303239
                    Reset counter: 8
                    Mileage: 51707 km
                    Date: 2023.10.23
                    Time: 14:08:51
   Coding: 110F0000
   Coding: 0EC002
   Coding: 01340000CFB100C0650BA0006C019802030340008104A6502F0000000F04803F001E0681000A11
   ID - sensor:
   left tail lamp 2:
   Serial number: 30U
   Serial number: 1S9
   Data carrier:
   Volume Control 1:
   Media socket:
009 0007
                    Reset counter: 40
                    Mileage: 51704 km
                    Date: 2023.10.23
                    Time: 13:52:26
                    Reset counter: 40
                    Mileage: 51704 km
                    Date: 2023.10.23
                    Time: 13:52:26
   Coding: 0730
   Coding: 4F01E0
   Coding: 0404020600000201022023AFC50000FEB0F0C020E280
   Revision: --------
   Coding: 0EC002
   Coding: 800000
End----------(Elapsed Time: 02:17, VBatt start/end: 13.0V/12.9V)-----------
Q5hitch
FL, USA
C?ID=565426
above code is post these changes below and after MMI3 reboot with GEM
BCM2 MLBEVO
Trailer module 69
changed
0100000202001100 to
0200000200001100
Controller 17 cleared
Controller 13 1 Fault
Controller 46 No faults
013400004FB100C0650BA0006C019802030340008104A6502F0000000F04803F001E0681000A11 to
Controller A5 1 Fault engine has to be off
0404020600000201022023AEC50000FEB0F0C020E280 to
So after reboot of the MMI. I only have one dashboard error. It is the trailer hitch error. I went from 6 Autoscan codes to only 3 autoscan codes
I found this on the web and it does pertain to my coding so I made these additional changes
  • Select: 01 - Engine
    • Select: Coding - 07
      • Toggle to Byte 5 and make sure Bit 4 is checked
      • Do It!
    • Close Controller, Go Back - 06
    • Select: 69 - Trailer
        • Byte 0, Bit 0-7: 02 Market/Country: North American Region (NAR)
        • Byte 1, Bit 4-7: 10 Partial Network Operation active
        • Byte 3, Bit 0-7: 00 Terminal 30 Output (Pin 9) NOT active)
        • Byte 4, Bit 0-7: 02 Terminal 30 Output switched (Pin 10) active while Trailer connected
Cleared DTC and shut off car. Turned car back on. And ran an autoscan below. I believe the error is related to power to the swivel hitch. I just need to deactive that option?
Monday,23,October,2023,16:34:08:42614
VIN: WA1CA123456789123   License Plate: POST01CLEARDTC
Mileage: 51745km-32152mi   Repair Order:
          6D 75 80 81 8B A5 BB BC CA CF D6 D7 DE
VIN: WA1CA123456789123   Mileage: 51745km-32152miles
   Coding: 2A6500322576012E74382000000000000000000000000000
   Radiator shutter:
   MTF pump:
   Coding: 02006E
   Coding: 250000
   Coding: 0D0101
   Coding: 80000D
   Coding: 80000D
   Coding: 303239
   Coding: 110F0000
   Coding: 0EC002
   ID - sensor:
   left tail lamp 2:
   Serial number: 30U
   Serial number: 1S9
   Data carrier:
   Volume Control 1:
   Media socket:
009 0007
   Coding: 0210000002001100
                    Reset counter: 40
                    Mileage: 51745 km
                    Date: 2023.10.23
                    Time: 16:30:57
                    Reset counter: 40
                    Mileage: 51745 km
                    Date: 2023.10.23
                    Time: 16:30:57
                    Reset counter: 40
                    Mileage: 51745 km
                    Date: 2023.10.23
                    Time: 16:30:57
   Coding: 0730
   Revision: --------
   Coding: 0EC002
   Coding: 800000
End----------(Elapsed Time: 02:18, VBatt start/end: 13.1V/13.1V)-----------
Q5hitch
FL, USA
C?ID=565426
So i have been working on this all week. I finally have it down to just Trailer 69 errors below. I cannot figure it out.
I have tried every reasonable permutation of the trailer coding but it doesnt fix the errors.
0210000000001100 byte 3 bit 00 byte 4 bit 0 2-3 errors
0210000001001100 byte 3 bit 00 byte 4 bit 01 3 errors
0210000002001100 byte 3 bit 00 byte 4 bit 02 3 errors
0210000100001100 byte 3 bit 01 byte 4 bit 0 2-3 errors
0200000101001100 byte 3 bit 01 byte 4 bit 1 active dtc clear is no errors but upon refresh 3 errors
0200000102001100 byte 3 bit 01 byte 4 bit 2 clear dtc no erros. but refresh 3 errors.
0200000200001100 byte 3 bit 02 byte 4 bit 00 clear dtc 2 erros. refresh 3 errors
0210000200001100 byte 3 bit 02 byte 4 bit 00 same as above
0200000201001100 byte 3 bit 02 byte 4 bit 01 3 errors
0210000201001100 byte 3 bit 02 byte 4 bit 01 3 errors
0200000202001100 byte 3 bit 02 byte 4 bit 02 3 errors
0210000202001100 byte 3 bit2 byte 4 bit 2 3 errors
Friday,27,October,2023,14:50:48:42614
VCDS Version: Release 23.3.1 (x64) Running on Windows 11 x64
                Address 69: Trailer       Labels: 5H0-907-383.clb
Control Module Part Number: 8W1 907 383 A    HW: 8W1 907 383
  Component and/or Version: Anhaenger     H07 0039
           Software Coding: 0200000202001100
            Work Shop Code:
              ASAM Dataset: EV_TrailFunctGener3Hella 001009 (AU49)
                      VCID: 3FDB53D31677DB92361-806A
                    Reset counter: 40
                    Mileage: 51917 km
                    Date: 2023.10.27
                    Time: 14:50:23
                    Reset counter: 40
                    Mileage: 51917 km
                    Date: 2023.10.27
                    Time: 14:50:23
                    Reset counter: 40
                    Mileage: 51917 km
                    Date: 2023.10.27
                    Time: 14:50:23
TTT
C?ID=547002
Dataset is for a swivel type which you said it’s not.
Q5hitch
FL, USA
C?ID=565426
Thank you TTT. I bought a donor Euro module but I live in the USA. I change the setting for USA in the trailer control module. But the error in vcds wont go away.
My main issue the error shows up like the picture above and it is in the dash
Changing the country setting doesn't change the dataset, the dataset is a separate file that has to be uploaded to the module - something VCDS cannot do.
  • Agree
Q5hitch
FL, USA
C?ID=565426
Ok. thanks for the info.
Q5hitch
FL, USA
C?ID=565426
Ok. I give up. How do I load the original files back into my car so that its like I never did the changes. I did save all of the files as HEX and Prelable before doing anything.
I say this because I have tried to remove 69 trailer module from the 19 CAN gateway but I cant? If I could do that that would be great. Then I would just re add 69 trailer from the installation list, get trailer lights activated that way. Tow something. Then when the towing was done. Remover trailer module 69 from the list. My car wont have any Yellow hitch light errors on the car dashboard. But that is not the case. I unplugged the module and it still says trailer hitch error on my cars dashboard.
