Hey guys im needing help. car has arrived with me after some one has fitted an airbag slip ring for the air bag light on, now the steering is heavy, yet the steering light is not on in the dash, im thinking its a coding issue,as customer says steering was perfect before.
Friday,10,February,2023,20:37:56:24344
VCDS Version: 22.10.0.1 (x64) HEX-NET CB: 0.4622.4
VIN: WVGZZZ5NZDW013144 License Plate: TIGUAN 1
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 61 62 6C 72
VIN: WVGZZZ5NZDW013144 Mileage: 142020km-88247miles
Address 01: Engine (J623-CFFD) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 LK HW: 03L 907 309 AE
Component: R4 2,0L EDC H28 3526
Revision: 41H28--- Serial number: 00000000000000 CVN: 17669652
Coding: 00190012040501080000
ASAM Dataset: EV_ECM20TDI01103L906018LK 003007
ROD: EV_ECM20TDI01103L906018LK_VW36.rod
VCID: FEB0705A61A8ED7D70-80AA
VINID: 9E65EAAAA15EA949C004304410B2634574
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AM HW: 5N0 614 109 AM
Component: J104 C6 450M V4E7 0006
Revision: --H07--- Serial number: 00000005932076
Coding: 0035896
VCID: F6A0687A8198A53D28-80A2
Part No SW: 7N0 907 426 BG HW: 7N0 907 426 BG
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010004003
VCID: FAB87C4A7D80C15D4C-80AE
Part No SW: 5K0 937 084 H HW: 5K0 937 084 H
Component: BCM PQ35 B 021 0068
Revision: BA021001
Coding: 48180A3B8025F1C0408800C0100000644B01AA88424D8160648087000041
VCID: B73EA57E06121C35F3-80E2
Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 18061 013 0203
Serial number: N2955119 °203!
Coding: 009795
Subsystem 2 - Part No: 1K8 951 171
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__20E VW10 HI 2118
Revision: 24017000 Serial number: 003L7PDDYA74
Coding: 0012357
VCID: FCB47A52BFB4FF6D5E-80A8
Subsystem 1 - Serial number: 6332MTS663731712
Subsystem 2 - Serial number: 6342MTS643141732
Subsystem 3 - Serial number: 6351HTS6PUGE6BKR
Subsystem 4 - Serial number: 6361HTS649996BKR
Part No SW: 1K5 953 507 M HW: 5K0 953 549
Revision: -------- Serial number: 90440KJ7000SD
Coding: 5080080000
Shop #: WSC 35110 790 50316
ROD: EV_SMLSNGKUDS_A05.rod
VCID: BB36B94E323A385517-80EE
Part No SW: 5N0 920 973 A HW: 5N0 920 973 A
Component: KOMBI H05 0705
Coding: 411F00
VCID: B228946AE570F91DC4-80E6
Part No SW: 7N0 907 530 S HW: 7N0 907 530 J
Component: J533 Gateway H43 1632
Revision: H43 Serial number: 230612F1000079
Coding: 356003
VCID: C0CCCEA253DC5B8D42-8094
Component: IMMO H05 0705
VCID: EA984C0A0D2071DDBC-80BE
Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
Component: TUER-SG FT 002 0504
Revision: 13110009 Serial number: 0005123564
Coding: 0202B4
VCID: B83CA642030C134DFA-80EC
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 704 F HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1504
Serial number: 00000006904055
Coding: 000090
Part No: 5N0 909 144 P
Component: EPS_ZFLS Kl. 201 3305
Revision: 00H22000
Shop #: WSC 01324 785 00200
VCID: BE30B05AE9282D7D30-80EA
16353 - Control Module - Internal Malfunction
014 - Defective - MIL ON
Fault Status: 11101110
Reset counter: 231
Mileage: 142025 km
Date: 2017.07.03
Time: 00:50:13
Battery Volts: 14.8 V
DU
Temperature: 18.0°C
Error Code: 14799
Torque: 0.0 Nm
Torque: 0.004 Nm
16355 - Control Module - Watchdog Timer
Mileage: 142025 km
Date: 2017.07.03
Time: 00:56:34
Voltage: 12.38 V
ER
Temperature: 19.0°C
Count: 60
Reset counter: 231
Mileage: 142025 km
Date: 2017.07.03
Time: 00:50:13
ER
Temperature: 18.0°C
Error Code: 14081
(no units): 4
(no units): 0
(no units): 0
00573 - Steering Torque Sensor (G269)
004 - No Signal/Communication - Intermittent - MIL ON
Fault Status: 10100100
Mileage: 142025 km
Date: 2017.07.03
Time: 00:56:34
Battery Volts: 12.3 V
ER
Temperature: 19.0°C
(no units): 0
(no units): 0
Torque: 0.0 Nm
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 0.7 V
PD
Temperature: 18.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
Component: TUER-SG BT 002 0504
Revision: 15110009 Serial number: 0005122309
Coding: 0202B4
VCID: B93AA34638060A4505-80EC
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 703 F HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1504
Serial number: 00000006903166
Coding: 000090
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000291973
Coding: 0026167
VCID: B620A87AC118E53DE8-80E2
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 190 C HW: 3C8 035 190 C
Component: Radio RCD510 051 0213
Revision: 00000001 Serial number: VWZ1Z3M2026727
Coding: 0500040004000C
VCID: A306612EA28A60953F-80F6
Part No SW: 7N0 907 534 HW: 7N0 907 530 J
Component: Batt.regelung H43 1632
Coding: 030F1859
VCID: F1AA5B6628F68205FD-80A4
Component: J367-BDM H07 0180
Serial number: 00000000008900677324
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 5N0 907 441 A HW: 5N0 907 441 A
Component: J772__Rearview 0030
Revision: 00H11000 Serial number: 525PA8-J260525
Coding: 0000010
VCID: AD128716344EA6E599-80F8
End----------(Elapsed Time: 01:23, VBatt start/end: 14.6V/14.6V)-----------
