Hey everyone,
I hope and pray this is the LAST TIME in a LONG TIME I am asking for help with my car. I have a 2014 VW Passat TDI SEL. My car is a salvaged title that sustained very minor frontal damage (broken tabs on headlights, cracked bumper and plastics, radiator was clipped just enough to warrant replacement. Engine, transmission, frame, etc were unaffected. Took me a mere 3 weeks to disassemble, order replacement parts, and reassemble myself in my garage.
Unfortunately, the battery was bad. I attempted to jump start the car but to no avail. Battery was replaced. Only electric issues I had/ have: amplifier was replaced, speakers work excellent now, trunk release switch was replaced on driver door, and the sensor for "hood open" seems to not work (which ill replace later), and the airbag passenger seat module was replaced and coded (as per my last post). The one issue with the vehicle that I cant seem to figure out is my fuel gauge. When I fill the car to FULL, it doesnt reach full. Stops about 90% of the way there. After reading some posts online, I opted to replace the fuel sender unit. Got a genuine one from my VW dealer and installed it. Initially, the issue was solved. Appoximately 5 ignition cycles later (and only 5 miles on the ODO since fill up, the need dropped to 85%. Refueling the vehicle will not bring it back to full.
I found other threads that speak of recalibration (draining tank, filling 2.5L, calibrating reserve under INSTRUMENTS, ADAPTATION, and calibrating fuel gauge. However, before I do this, I want to make sure this will indeed fix the issue (if anyone has experience with this). I got the car up on stands and checked wiring integrity, found nothing. I only got 1 code from the fuel sender in VCDS which read HIGH RESISTANCE, but this was around the time I swapped the 2 out. I have no idea if the code was from the new one or old one. Like an idiot I didnt think to check first or disconnect the battery.
Dealer told this morning that recalibration should not be necessary and that I should give it some time and drive it around to let it "settle in" but I am having my doubts.
My thoughts at the moment are:
1) replacement fuel sender could be faulty
2) replacement sender could be inside the tank incorrectly? (points approximately NorthWest inside the tank, as i found the old sender in this position).
3) replacement sender needs to be calibrated
4) gauge cluster could be bad after battery died and subsequent attempts to jump?
Any help with this would be greatly appreciated!!
Here is a full scan done this morning for reference:
Saturday,03,December,2022,13:20:29:61775
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
VIN: 1VWCN7A30EC029565 License Plate:
Mileage: 97880km-60819mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 75 77
VIN: 1VWCN7A30EC029565 Mileage: 97880km-60819miles
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H24 9982
Revision: 71H24--- Serial number: CVN: D240C61FD45710C1
Coding: 001D0012042400008000
Shop #: WSC 00023 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B233BD703EAB423FE0-806E
VINID: 0669D37874430154C0089146146CEF1DD7
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 521 9437
Revision: 05652104 Serial number: 00001307040358
Shop #: WSC 09003 957 00200
VCID: 1471B06B42749B5B5FA-8040
Revision: 00H31001
Coding: C54BC0F549240003A31003EA921E0042A71000
VCID: 7DA7F5CF5DFE7A13804-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0193938492
Coding: 130C0C
VCID: 343110EB2EB47B5B3FA-8060
Part No SW: 561 907 044 AB HW: 561 907 044 AB
Component: Climatronic H03 0505
Revision: 00001K01
Coding: 0030019012
VCID: 57EB87679F827043FA8-8002
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0173
Revision: BL122001
Coding: EF200E1B982B08D4098802013600854800F1A086458015B064806000BC70
VCID: 78A9E4DB72DC5F3BD32-802C
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 8
Reset counter: 213
Mileage: 97847 km
Date: 2017.04.24
Time: 13:46:10
Term 15 On
Voltage: 12.10 V
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM02NBTF
Coding: 00005033
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75B7EDEF654E2253C84-8020
Serial number: 6940000Y210001ZB3W09
Coding: 303044
Serial number: 3572MSME2341227DZZZR
Serial number: 3582MSME3B24227DZZZ
Serial number: 3516KSME40624925ZZZL
Serial number: 3526KSME154C5625ZZZU
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME6A406526ZZZX
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME385A7926ZZZ2
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Revision: FF010042 Serial number: 20130712201512
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DA7F5CF5D7E7A13804-8028
Component: E221__MFL-YVJ H07 0022
Coding: E30000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H04 0811
Coding: 231E01
VCID: 1E65D243B038C10BF9E-804A
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 24081303000048
Coding: 461000
VCID: 7BA3FBD743EA7423BE0-802E
Component: IMMO H04 0811
Coding: 000007
VCID: 6A8DCE933CF0FDAB556-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000100346003
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 30391CFBDAAC477B5B2-8064
Address 2E: Media Player 3
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0182
Revision: AA000000 Serial number: 00000070069643
VCID: 221DE6B384C0E5EBDD6-8076
Part No SW: 3C0 035 684 J HW: 3C0 035 684 G
Component: RNS-MID H03 4366
Revision: AB001001 Serial number: VWZ6Z7N5080077
Coding: 04090042010000A6000B
VCID: 2A0D0E93FCF03DAB956-807E
Component: NAR V6 7963
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0007265878
Coding: 0405FD
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C61D84BA624D31B17A-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14202630130903084916
Coding: 800000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 290 3501
Revision: 00H22000
VCID: 392F21DF05568633ECC-806C
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0098608
ROD: EV_AudioVerst10KanalSTT3_VW36.rod
VCID: 2615FAA3E86819CBB1E-8072
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 01030108
VCID: 6FBBDF8707921883028-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011311600258
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0007257879
Coding: 0405FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D67D54FBD3EDA13E04-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631130903101628
Coding: 800000
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0086
Serial number: 000003554140505
Coding: 02140102C2423A007F1606000000
ROD: EV_OCULow_001.rod
VCID: 53F373778B7A5C63060-8006
2103041 - Control Module
Fault Priority: 8
Reset counter: 213
Mileage: 97882 km
Date: 2022.12.03
Time: 13:19:51
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007664920309
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E050283C098518B49E-807A
End----------(Elapsed Time: 01:19, VBatt start/end: 12.1V/12.1V)-----------
