- Nov 25, 2022
- 24
- 7
- South Florida, USA
- C?ID=44489
Hello, first post, but am at a loss. Have a 2010 Golf GTI in the shop. It was diagnosed some time back as needing a new ABS module. I have done a couple of these before without a problem. The problem I am having is on Channel 026. No errors and able to use the brake pedal to match what the value the software is displaying. Was able to calibrate channel 025 in less than 5 mins. Have tried doing the calibration on Channel 026 multiple times without it ever completing. Today we ran the calibration for 20 mins without success. Below is the last Scan. No visible brake fluid leaks. Bled a second time and the rear pads are worn to the thickness of the pad backing plate. Waiting on the engine and ECU to cool again. I have seen where others have had this same problem, but no solutions I could find. Using a Ross Tech dongle and current VCDS software. Thank you for any assistance.
Friday,25,November,2022,10:38:25:34808
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
VIN: WVWEV7AJ9AW271192 License Plate:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 65 77
VIN: WVWEV7AJ9AW271192 Mileage: 81210km-50461miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AM HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH11--- Serial number:
Coding: 0403010A18070160
VCID: 71E98C24682EE201BE-8024
VINID: 9E69D598745A2519C21C104908CEB169CE
Readiness: 0000 0001
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H31 0107
Revision: 00H31001
Coding: 114B600C492900FB880C06ED921B0041300800
VCID: 78FFB100CB54B34979-802C
00003 - Control Module
Fault Status: 01100101
Reset counter: 128
Mileage: 81212 km
Date: 2017.04.17
Time: 10:35:02
Count: 3
Count: 2
Count: 28672
Count: 143
Count: 43776
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: 75E1B834D446CE2162-8020
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0576
Revision: 00103 AF
Coding: 6D180A1A90272A0480080081700005C441010086534D8D60648020200000
Shop #: WSC 05064 444 10367
VCID: 356178349CC68E21A2-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 17120 21 0512
Coding: 009795
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0A8L6Y
Coding: 00003031
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 39797404B8DE6A4146-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0004YJGV00
Serial number: 3572MSME432D004FZZZY
Serial number: 3582MSME3679354EZZZ2
Serial number: 3512QSME383F4477ZZZ%
Serial number: 3522QSME3A284600ZZZP
Serial number: 35527SME650B511FZZZK
Serial number: 35627SME0C4B421FZZZQ
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78FFB1000B54B34979-802C
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Coding: 00000130
Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
Component: KOMBI H03 0305
Coding: 270F00
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 050110F2000752
Coding: E9801F07001612000000
VCID: 69D9E44440FE1AC1F6-803C
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T76P904
VCID: 7EF3A71829708D7933-802A
Component: IMMO H03 0305
VCID: 6ADB9B488DF811D9FF-803E
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667733962
VCID: 2643AF785160F5B91B-8072
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2111
Coding: 0001076
VCID: 31694C24A8AEA201FE-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 326B4328ADA8991987-8066
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7J1139000
Coding: 0100040004
VCID: 61C9FC6478CE52812E-8034
Fault Status: 01101011
Reset counter: 125
Mileage: 81203 km
Date: 2017.04.17
Time: 17:59:23
Reset counter: 125
Mileage: 81203 km
Date: 2017.04.17
Time: 17:59:23
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018705
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000329389176
Coding: 412100
VCID: 2A5B5B484578D1D93F-807E
End-------------------------(Elapsed Time: 02:16)--------------------------
