- Oct 19, 2022
- 10
- 0
- Houston, TX, USA
- C?ID=314389
Hi everyone,
I've been a long-time lurker and received so much help over the years. It's my turn to ask for some help.
I replaced my bumper with a GTI-style bumper that came with fog lights. I also bought a BCM from a 2012 GTI and installed it into the car to enable the fogs (my original did not have provisions for fog lights). The original BCM to the car is a 5K0 937 084 L unit. While the new one is a 1K0 937 087 L unit. As advised, I copied over the long coding from the old one and coded it into the new unit. The front lights work as they're supposed to (turn signal, high, low, fogs all work fine). But for some reason the reverse lights now act as the DRL in the rear when the light switch in the 0 position. The cluster shows errors for brake lights, reverse lights, and license plate lights (even though brake lights and license plates work as designed). My biggest pain point is that the key remote stopped working (the car does not have KESSY). When I first plugged in the module, bit 18 showed VW EOS NAR version. So I followed the steps to change it to 00, and then to Jetta Sportwagen ROW thinking that it would solve my issues. But the errors still remain.
I hope I explained the issue correctly. Please advise on what I should do. I have attached the scan below:
Wednesday,19,October,2022,19:03:09:12942
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
VIN: 3VWPL7AJ9EM601169 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 22 25 2E 42 44 46 52 56 62 72
77
VIN: 3VWPL7AJ9EM601169 Mileage: 132030km-82039miles
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H16--- Serial number:
Coding: 0050078
Shop #: WSC 74291 008 00000
VCID: 303A186A36207B6B573-8064
VINID: 0E69E070745A2557460010462482F0B2C6
Readiness: 0 0 0 X X
Part No SW: 02E 300 015 HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3521
Revision: 05551213 Serial number: 00001208131527
Shop #: WSC 05311 000 00000
VCID: 50FA78EA56E01B6B373-8004
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 114B600C492200FB880C06EA92220042B70000
Shop #: WSC 00066 000 00000
VCID: 7DA4F15EBDF246038C5-8028
Part No SW: 561 907 044 D HW: 561 907 044 D
Component: Climatronic 042 0102
Revision: 00001001
Coding: 0010001012
Shop #: WSC 09003 957 00200
ROD: EV_ACClimaBHBVW411_VW36.rod
VCID: 186AC0CAB210832B3F3-804C
9496597 - Sunlight Photo Sensor
B10E8 15 [009] - Open or Short to Plus
Reset counter: 208
Mileage: 132036 km
Date: 2022.10.19
Time: 18:50:45
9496613 - Sunlight Photo Sensor
Reset counter: 208
Mileage: 132036 km
Date: 2022.10.19
Time: 18:50:45
9479189 - Signal Line for Air Quality Sensor
B10A4 15 [009] - Open or Short to Plus
Reset counter: 208
Mileage: 132036 km
Date: 2022.10.19
Time: 18:50:45
Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
Component: BCM PQ35 H 104 0615
Revision: 00104 AF
Coding: AF380E3A882F3EC400080040710089C0496C0886535D0520648420200040
VCID: 3A2E3A42EC5CB13BE97-806E
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 29061 26 0512
Coding: 009795
014 - Defective
Fault Status: 01101110
Reset counter: 208
Mileage: 132036 km
Date: 2017.03.11
Time: 18:59:39
Voltage: 13.95 V
Term 50 Off
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 208
Mileage: 132036 km
Date: 2017.03.11
Time: 19:00:07
Voltage: 13.90 V
Term 50 Off
Reset counter: 208
Mileage: 132036 km
Date: 2017.03.11
Time: 19:00:07
Voltage: 13.90 V
Term 50 Off
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R024L73
Coding: 00004E42
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C223C5AE6E88F0BFBB-8068
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00008DFZ00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME190A1479ZZZY
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME600A1479ZZZV
Serial number: 3511HSME715B592FZZZ-
Serial number: 3521HSME5C4B592FZZZ2
Serial number: 35527SME4C63532FZZZQ
Serial number: 35627SME15365C2FZZZQ
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90440MEB00088
Coding: 189A140000
Shop #: WSC 00066 000 00185
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B6EE729844155BCDF-8022
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0032
Serial number: 0099245
Coding: 830000
Part No SW: 5K0 920 973 G HW: 5K0 920 973 G
Component: KOMBI H04 0811
Coding: 270F01
Shop #: WSC 00066 000 00118
VCID: 3534297EC5C25E43045-8060
Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
Component: J533 Gateway H57 1642
Revision: H57 Serial number: 01071303000399
Coding: 352002
Shop #: WSC 00066 123 12345
VCID: 79ACE54EA9DA7A23A0D-802C
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RNMPK07
Coding: 0000002
VCID: 7EA6F652BCF45D1B95F-802A
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0AY 907 554 E HW: 0AY 907 554 E
Component: Haldex 4Motion 0043
Coding: 0000005
VCID: 4DC4619E41D236835C5-8018
Component: IMMO H04 0811
VCID: 6A8ECA02DCFCC1BB597-803E
Address 2E: Media Player 3
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0007003560
Coding: 0004B5
Shop #: WSC 01383 790 50316
VCID: 5BE09FC603A6A833D21-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1509
Serial number: 00000007951207
Coding: 000490
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 37282376D34EAC53169-8062
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0007033323
Coding: 0004B4
VCID: 5CE29CDA06A8AF0BDBB-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1509
Serial number: 00000007819183
Coding: 000490
Address 56: Radio (J503) Labels: None
Part No SW: ----------- HW: -----------
Component: Radio --- 5814
Coding: 16000440040000
VCID: 6FB8DB16E79E24930E9-803A
00856 - Radio Antenna
Reset counter: 208
Mileage: 132036 km
Date: 2017.03.11
Time: 18:50:44
Reset counter: 208
Mileage: 132036 km
Date: 2017.03.11
Time: 18:58:14
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007664875704
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E06061220946D9B45F-807A
End----------(Elapsed Time: 01:11, VBatt start/end: 14.0V/14.0V)-----------
