Saturday,17,September,2022,19:32:28:44465
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 18 19 1C 25 2E 42 44 46 47 52 55 56 62
65 72 77 7D A6
VIN: WVWMM7AJ6BW317366 Mileage: 143690km-89284miles
18-Aux. Heat -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: Cannot be reached 1100
A6-Microphone -- Status: Cannot be reached 1100
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 C HW: 03L 906 019 DA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H14--- Serial number:
Coding: 0050072
Shop #: WSC 74291 008 00000
VCID: 2E0503E0FC1D9E6B6D3-807A
VINID: 9E69DD74745A1929C30470C6182F6A7EBE
001681 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Mileage: 143693 km
Date: 2017.01.10
Time: 00:14:35
Temperature: 45.0°C
Temperature: 71.1°C
Temperature: 19.8°C
Lambda: 9.5 %
Lambda: 0.0 %
001668 - Glow Plug Control Module (J179)
P0684 - 001 - Implausible Signal
Fault Status: 01100001
Mileage: 143693 km
Date: 2017.02.07
Time: 06:11:46
Voltage: 11.63 V
Temperature: 18.9°C
Bin. Bits: 00110000
Time: 0.18 s
Temperature: 16.2°C
Readiness: 0 0 0 X X
Part No SW: 1K0 907 379 AM HW: 1K0 907 379 AM
Component: ESP MK60EC1 H45 0108
Revision: 00H45001
VCID: 7DA7F4AC6DFBB5F3A49-8028
Fault Status: 01100101
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:30
Count: 7
Count: 2
Count: 29184
Count: 279
Count: 50688
Count: 256
Count: 61952
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:30
Count: 7
Count: 2
Count: 29184
Count: 295
Count: 50688
Count: 256
Count: 61952
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:30
Count: 7
Count: 2
Count: 29184
Count: 270
Count: 50688
Count: 256
Count: 61952
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:30
Count: 7
Count: 2
Count: 29184
Count: 195
Count: 50688
Count: 256
Count: 61952
Part No SW: 3C8 907 336 N HW: 3C8 907 336 N
Component: Climatic H13 0203
Revision: 00006001
Coding: 0000000000
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW36.rod
VCID: 382925B802D950DB37F-806C
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Motorsteuergerät - bitte Fehlerspeicher auslesen]
Fault Frequency: 26
Reset counter: 180
Mileage: 143693 km
Date: 2022.08.20
Time: 18:41:28
B10AB F0 [009] - Too Low
Reset counter: 180
Mileage: 143693 km
Date: 2022.08.20
Time: 18:41:28
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0576
Revision: 00103 AD
Coding: 6D180A1E90272AC48088008550000D0441050086534D8D60648020200000
Shop #: WSC 02130 444 999999
VCID: 35372C8C154BADB32C9-8060
Component: Wischer 14090 21 0501
Coding: 009795
12 Faults Found:
00483 - Control Module for Auxiliary Air Heater
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:28
Term 15 On
Voltage: 13.90 V
Term 50 Off
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:28
Term 15 On
Voltage: 13.90 V
Term 50 Off
00834 - Signal for Activation of Heated Rear Window
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:28
Term 15 On
Voltage: 13.90 V
Term 50 Off
01259 - Fuel Pump Relay (J17)
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:31
Term 15 On
Voltage: 13.05 V
Term 50 Off
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 220
Mileage: 143693 km
Date: 2017.01.10
Time: 00:00:07
Term 15 On
Voltage: 12.40 V
Term 50 Off
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 29
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:51
Term 15 On
Voltage: 12.70 V
Term 50 Off
Fault Frequency: 29
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:51
Term 15 On
Voltage: 12.70 V
Term 50 Off
Fault Status: 01101100
Reset counter: 180
Mileage: 143693 km
Date: 2017.02.07
Time: 06:35:10
Term 15 On
Voltage: 11.65 V
Term 50 Off
Fault Frequency: 24
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 00:00:13
Term 15 On
Voltage: 12.35 V
Term 50 Off
Fault Frequency: 19
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 00:08:40
Term 15 On
Voltage: 12.20 V
Term 50 Off
Fault Status: 00101010
Reset counter: 220
Mileage: 143693 km
Date: 2017.01.10
Time: 01:06:28
Term 15 On
Voltage: 13.65 V
Term 50 Off
Reset counter: 180
Mileage: 143693 km
Date: 2017.02.07
Time: 06:12:01
Term 15 On
Voltage: 11.60 V
Term 50 Off
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 019 0706
Serial number: 003C4D074TVH
Coding: 00003031
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 392F20BC39D349D3C81-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0004MMP800
Serial number: 3572MSME6C233246ZZZV
Serial number: 3582MSME4278124AZZZW
Serial number: 3512QSME0A533140ZZZH
Serial number: 3522QSME32163004ZZZB
Serial number: 35527SME570E1400ZZZ7
Serial number: 35627SME42181300ZZZ$
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78A9E5B84ED990DBF7F-802C
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Coding: 00000131
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
Component: KOMBI H20 0420
Coding: 270F01
VCID: 2F3B1EE4F7979763665-807A
Address 18: Aux. Heat
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 5223
Revision: H16 Serial number: 4120K097310118
Coding: E9817F17101E12080002
VCID: 6695BBC0146D162B553-8032
Reset counter: 180
Mileage: 143693 km
Reset counter: 180
Mileage: 143693 km
03272 - Control Module for Audio Interface
Reset counter: 180
Mileage: 143693 km
03753 - Control Module for Microphone
Reset counter: 180
Mileage: 143693 km
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T5ZRC04
VCID: 7EA5F3A06CFDAEEBBD3-802A
Component: IMMO H20 0420
VCID: 6A8DCFF00CF5324B71B-803E
Address 2E: Media Player 3
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2109
Coding: 0001204
VCID: 313F189CED238193701-8064
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 343111881231B4BB1B7-8060
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218198610949
VCID: 678BB6C41FE70F236E5-8032
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 323D1790E825BA8B09B-8066
Address 55: Headlight Range Labels: 5M0-907-357-V2.clb
Component: AFS-Steuergeraet 0142
Coding: 1446940
Subsystem 1 - Part No: ID-L fehlt Labels: ID-55-01.CLB
Component: AFS-Lst.-Modul l ....
Coding: 00000255
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
02233 - Left Headlight Power Output Stage (J667)
Fault Status: 11100100
Fault Frequency: 28
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:29
Voltage: 13.92 V
ABS 1
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 180
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Reset counter: 180
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Reset counter: 180
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
Fault Status: 11100101
Reset counter: 180
Invalid
Invalid
Invalid
Part No SW: 1K0 035 180 AD HW: 1K0 035 180 AD
Component: Radio Prem-8 H04 0018
Revision: -----17S Serial number: VWZ4Z7L1115047
Coding: 0100040004
VCID: 629DA7D0F4456A0BB9B-8036
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:28
Reset counter: 180
Mileage: 143693 km
Date: 2017.01.10
Time: 00:00:37
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018704
Shop #: WSC 52302 000 1048576
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:28
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:28
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0001168
VCID: 35372C8C194BADB32C9-8060
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
Component: Telefon H08 6600
Revision: 00008000 Serial number: 20389520187220
Coding: 412100
VCID: 290FF0FCC9F3F953B81-807C
03427 - Right Audio Channel
Fault Status: 00101011
Reset counter: 220
Mileage: 143693 km
Date: 2017.01.10
Time: 18:41:32
Reset counter: 220
Mileage: 143693 km
Date: 2017.02.07
Time: 06:12:09
Address 7D: Aux. Heat
Address A6: Microphone
End----(Elapsed Time: 01:19, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
