Brake Controller Long Coding (MK60EC1)
Jonsimek1999
H11-2H
Hey guys. Totally new here and am in need of help and knowledge. ;)
So the project we have undertaken is to put a VW mk6 tdi into a mk6 gti chassis. We are using the ECM from the diesel and the body control module from the gti (so that we can keep all the luxury features the old tdi did not have).
The project has gone alright so far and we have gotten the car to run and drive, however it doesn't have the power it should. We eliminated all the check engine lights and the only light that remains on is the ABS. We purchased the Ross tech scanning tool and the long coding for the brake controller is incorrect. Could this cause the car to go into a sort of limp-mode?
There were a few different modules which need the original long coding. Is there anyway to get the original coding for this car?
The Vin number is : WVWHV7AJ6AW091911
Any help would be greatly appreciated!!
Jonsimek1999
H11-2H
Will post one as soon as I can
Jonsimek1999
H11-2H
ok guys i got the auto scan for you today
Saturday,17,September,2022,19:32:28:44465
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 18 19 1C 25 2E 42 44 46 47 52 55 56 62
          65 72 77 7D A6
VIN: WVWMM7AJ6BW317366   Mileage: 143690km-89284miles
18-Aux. Heat -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: Cannot be reached 1100
A6-Microphone -- Status: Cannot be reached 1100
   Part No SW: 03L 997 030 C    HW: 03L 906 019 DA
   Component: R4 2.0l TDI G000SG  9983
   Revision: 12H14---    Serial number:
   Coding: 0050072
   Shop #: WSC 74291 008 00000
   VCID: 2E0503E0FC1D9E6B6D3-807A
   VINID: 9E69DD74745A1929C30470C6182F6A7EBE
001681 - Fan 1 Control Circuit
               P0691 - 000 - Short to GND
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 00:14:35
                    Temperature: 45.0°C
                    Temperature: 71.1°C
                    Temperature: 19.8°C
                    Lambda: 9.5 %
                    Lambda: 0.0 %
001668 - Glow Plug Control Module (J179)
               P0684 - 001 - Implausible Signal
                    Fault Status: 01100001
                    Mileage: 143693 km
                    Date: 2017.02.07
                    Time: 06:11:46
                    Voltage: 11.63 V
                    Temperature: 18.9°C
                    Bin. Bits: 00110000
                    Time: 0.18 s
                    Temperature: 16.2°C
Readiness: 0 0 0 X X
   Part No SW: 1K0 907 379 AM    HW: 1K0 907 379 AM
   Component: ESP MK60EC1   H45 0108
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   VCID: 7DA7F4AC6DFBB5F3A49-8028
                    Fault Status: 01100101
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:30
                    Count: 7
                    Count: 2
                    Count: 29184
                    Count: 279
                    Count: 50688
                    Count: 256
                    Count: 61952
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:30
                    Count: 7
                    Count: 2
                    Count: 29184
                    Count: 295
                    Count: 50688
                    Count: 256
                    Count: 61952
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:30
                    Count: 7
                    Count: 2
                    Count: 29184
                    Count: 270
                    Count: 50688
                    Count: 256
                    Count: 61952
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:30
                    Count: 7
                    Count: 2
                    Count: 29184
                    Count: 195
                    Count: 50688
                    Count: 256
                    Count: 61952
   Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 382925B802D950DB37F-806C
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Motorsteuergerät - bitte Fehlerspeicher auslesen]
                    Fault Frequency: 26
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2022.08.20
                    Time: 18:41:28
          B10AB F0 [009] - Too Low
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2022.08.20
                    Time: 18:41:28
   Part No SW: 1K0 937 087 G    HW: 1K0 937 087 G
   Component: BCM PQ35  H+  103 0576
   Revision: 00103 AD
   Coding: 6D180A1E90272AC48088008550000D0441050086534D8D60648020200000
   Shop #: WSC 02130 444 999999
   VCID: 35372C8C154BADB32C9-8060
   Component: Wischer 14090  21  0501
   Coding: 009795
12 Faults Found:
00483 - Control Module for Auxiliary Air Heater
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:28
                    Voltage: 13.90 V
                        Term 50 Off
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:28
                    Voltage: 13.90 V
                        Term 50 Off
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:28
                    Voltage: 13.90 V
                        Term 50 Off
01259 - Fuel Pump Relay (J17)
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:31
                    Voltage: 13.05 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 220
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 00:00:07
                    Voltage: 12.40 V
                        Term 50 Off
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 29
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:51
                    Voltage: 12.70 V
                        Term 50 Off
                    Fault Frequency: 29
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:51
                    Voltage: 12.70 V
                        Term 50 Off
                    Fault Status: 01101100
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.02.07
                    Time: 06:35:10
                    Voltage: 11.65 V
                        Term 50 Off
                    Fault Frequency: 24
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 00:00:13
                    Voltage: 12.35 V
                        Term 50 Off
                    Fault Frequency: 19
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 00:08:40
                    Voltage: 12.20 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 220
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 01:06:28
                    Voltage: 13.65 V
                        Term 50 Off
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.02.07
                    Time: 06:12:01
                    Voltage: 11.60 V
                        Term 50 Off
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   019 0706
   Serial number: 003C4D074TVH
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 392F20BC39D349D3C81-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0004MMP800
   Serial number: 3572MSME6C233246ZZZV
   Serial number: 3582MSME4278124AZZZW
   Serial number: 3512QSME0A533140ZZZH
   Serial number: 3522QSME32163004ZZZB
   Serial number: 35527SME570E1400ZZZ7
   Serial number: 35627SME42181300ZZZ$
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000532
   VCID: 78A9E5B84ED990DBF7F-802C
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Part No SW: 5K0 920 971 C    HW: 5K0 920 971 C
   Coding: 270F01
   VCID: 2F3B1EE4F7979763665-807A
Address 18: Aux. Heat
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 5223
   Revision:   H16       Serial number: 4120K097310118
   Coding: E9817F17101E12080002
   VCID: 6695BBC0146D162B553-8032
                    Reset counter: 180
                    Mileage: 143693 km
                    Reset counter: 180
                    Mileage: 143693 km
03272 - Control Module for Audio Interface
                    Reset counter: 180
                    Mileage: 143693 km
03753 - Control Module for Microphone
                    Reset counter: 180
                    Mileage: 143693 km
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T5ZRC04
   Coding: 0000002
   VCID: 7EA5F3A06CFDAEEBBD3-802A
   Component: IMMO          H20 0420
   VCID: 6A8DCFF00CF5324B71B-803E
Address 2E: Media Player 3
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2109
   Coding: 0001204
   VCID: 313F189CED238193701-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 343111881231B4BB1B7-8060
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218198610949
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 678BB6C41FE70F236E5-8032
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001204
   VCID: 323D1790E825BA8B09B-8066
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Component: AFS-Steuergeraet    0142
   Coding: 1446940
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000022
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
                    Fault Frequency: 28
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:29
                    Voltage: 13.92 V
                        ABS 1
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 180
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
                    Reset counter: 180
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
                    Reset counter: 180
                        Invalid
                        Invalid
                        Invalid
                    Fault Status: 11100101
                    Reset counter: 180
                        Invalid
                        Invalid
                        Invalid
   Part No SW: 1K0 035 180 AD    HW: 1K0 035 180 AD
   Component: Radio Prem-8  H04 0018
   Revision: -----17S    Serial number: VWZ4Z7L1115047
   Coding: 0100040004
   VCID: 629DA7D0F4456A0BB9B-8036
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:28
                    Reset counter: 180
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 00:00:37
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           103 0521
   Coding: 018704
   Shop #: WSC 52302 000 1048576
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:28
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:28
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0001168
   VCID: 35372C8C194BADB32C9-8060
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 C    HW: 1K8 035 730 C
   Component: Telefon       H08 6600
   Revision: 00008000    Serial number: 20389520187220
   Coding: 412100
   VCID: 290FF0FCC9F3F953B81-807C
03427 - Right Audio Channel
                    Fault Status: 00101011
                    Reset counter: 220
                    Mileage: 143693 km
                    Date: 2017.01.10
                    Time: 18:41:32
                    Reset counter: 220
                    Mileage: 143693 km
                    Date: 2017.02.07
                    Time: 06:12:09
Address 7D: Aux. Heat
Address A6: Microphone
End----(Elapsed Time: 01:19, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
Any advice would be great!
ROCKET.900
Pirate
Walking the Plank
Lebanon
LP/SN
Hi try this one if not good i want car equipment
PartNo: 1K0907379AM_H45
Coding: A14BC00C49230001850E03EA921F00410000
car equipment information 👇
Brake Disc Size
Hill Hold
Start Stop
Active Cruise Controll
Type of Drive
Park Assist
Transmission Type
Steering Wheel Side
Trailer Hitch
Tire Pressure Control
Brake Booster
Jonsimek1999
H11-2H
So went and tried the new coding this morning and it was rejected. The brake controller we are using for the car is the original one from the gti so the Vin provided in the auto-scan (I believe) is incorrect. I listed the Vin for the gti in my first post. Do you know if the coding would be different for the controller from the gti vs the tdi?
Jonsimek1999
H11-2H
Vin number from the gti (which is the controller we have installed)
WVWHV7AJ6AW091911
Vin number from the tdi (displayed in the auto-scan)
WVWMM7AJ6BW317366
Jonsimek1999
H11-2H
I'll see if I can list all the car equipment yet today as well. Thanks guys!
WVWHV7AJ6AW091911
WVWMM7AJ6BW317366
What VIN is in the cluster/immo?
Jonsimek1999
H11-2H
The cluster/immo is all taken from the diesel so the Vin is WVWMM7AJ6BW317366
ROCKET.900
Pirate
Walking the Plank
Lebanon
LP/SN
Please post car equipment to give you coding for this vinWVWMM7AJ6BW317366
ROCKET.900
Pirate
Walking the Plank
Lebanon
LP/SN
Brake Disc Size
Hill Hold
Start Stop
Type of Drive
Park Assist
Transmission Type
Steering Wheel Side
Trailer Hitch
Brake Booster
etz2k
C?ID=69430
The ABS controller read the vin that's stored in the cluster/immo.
Because you used also the TDI cluster with the VIN: WVWMM7AJ6BW317366 the ABS coding should be:
114B600C09230001880E06EA901F00423108
etz2k
C?ID=69430
@ROCKET.900 if you could read a autoscan and a little more and know something about the MK60EC1, you can answer the most stupid questions by yourself and if not, then you are the wrong person to give a coding, i think. Sorry
ROCKET.900
Pirate
Walking the Plank
Lebanon
LP/SN
try this one
Coding: A14B600C49230001850E06EA921F00414000
Jonsimek1999
H11-2H
etz2k the coding worked perfect!! We got the ABS working properly and followed the relearning process that Ross tech had posted a video for. That's another light off the cluster! 😁
Jonsimek1999
H11-2H
There are a couple more issues tho. The auto HVAC shows up with no coding and the climate control unit doest work at all. Could this also just be a simple coding issue? It is the original unit that was in the gti.
We also installed the auxiliary heater that was in the tdi but the auto-scan shows no signal/communication. I'm confused as to where the auxiliary Heat controller is tho ... or is it just simply controlled by the body control module? Thanks guys
etz2k
C?ID=69430
@Jonsimek1999 do you have a autoscan from before the engine swap and one from the donor car?
Jonsimek1999
H11-2H
Sadly I don't have either of those scans. We only purchased the VCDS scanner after we were quite a ways into the swap. ( had I known how amazing it works I'd have bought it much sooner 😝)
Is that gonna be an issue that I don't have the previous auto-scans?
