Hello, I'm new to the VCD software and looking for some help with the Air Suspension system. It started with the ytwo rear shocks raised all up, searching on forums, they recommended to change the Residual Air Pressure Valve so I did by manually deflating the air suspension system and installing new valves. Then tr to inflate them and find out that the Air Compressor wasn't pumping the correct pressure, so I put on a new compressor. The rear shocks inflated to its highest level and both front shocks inflated to 445 mm. Checked for leaked and found none.
Try diagnostic Software to Level Calibration and it did not follow the procedure of setting for two position before starting to calibrate each shocks. Got a fault code 02250.
Suspecting about the Valve Block. Any suggestion would be appreciated.
Also realized that engine has fault codes! But engine is running fine with no warning lights.
Sunday,26,June,2022,15:20:49:12487
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: WVGZZZ7LZ7D081111 License Plate: DDB-40P
Mileage: 58420km-36300mi Repair Order: 01
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 34 46 55 56 68 76
VIN: WVGZZZ7LZ7D081111 Mileage: 58420km-36300miles
68-Wiper Electr. -- Status: OK 0000
Address 01: Engine Labels:. 079-907-560-BAR.clb
Part No SW: 7L0 907 560 C HW: 7L0 907 560
Component: 4.2l V8/4V 0020
Revision: 75H04--- Serial number: VWX3Z0G3607001
Coding: 04210010590F0560
Shop #: WSC 31414 790 00001
VCID: 313F18D2ED3A56F3701-5184
VINID: 9E65EAAAA1DCA8750020104104966492F0
9 Faults Found:
008196 - Intake Manifold Flap; Bank 1
P2004 - 004 - Stuck Open - Intermittent
Mileage: 57626 km
Date: 2021.11.26
Time: 05:17:03
RPM: 1166 /min
Load: 55.3 %
Temperature: 24.0°C
Temperature: 26.0°C
Absolute Pres.: 890.0 mbar
Voltage: 13.843 V
008197 - Intake Manifold Flap; Bank 2
P2005 - 004 - Stuck Open - Intermittent
Mileage: 57626 km
Date: 2021.11.26
Time: 05:17:03
RPM: 1220 /min
Load: 45.5 %
Temperature: 19.0°C
Temperature: 20.0°C
Voltage: 13.970 V
P2004 - 002 - Stuck Open - MIL ON
Fault Status: 11100010
Mileage: 57626 km
Date: 2021.11.26
Time: 05:17:04
RPM: 1187 /min
Load: 53.7 %
Temperature: 23.0°C
Temperature: 26.0°C
Voltage: 13.843 V
P2005 - 002 - Stuck Open - Intermittent
Mileage: 57626 km
Date: 2021.12.26
Time: 06:26:46
RPM: 1181 /min
Load: 53.7 %
Temperature: 22.0°C
Temperature: 24.0°C
Voltage: 13.462 V
005241 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure
Fault Status: 01101000
Mileage: 57626 km
Date: 2021.12.27
Time: 00:41:41
RPM: 1885 /min
Load: 64.3 %
Speed: 21.0 km/h
Temperature: 41.0°C
Temperature: 24.0°C
Absolute Pres.: 900.0 mbar
Voltage: 13.843 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 -
Mileage: 57735 km
Date: 2022.01.27
Time: 20:02:39
RPM: 735 /min
Load: 18.8 %
Speed: 5.0 km/h
Temperature: 94.0°C
Temperature: 33.0°C
Absolute Pres.: 910.0 mbar
Voltage: 13.970 V
008585 - Bank 2; System too Lean at Idle
P2189 - 004 - - Intermittent
Mileage: 57735 km
Date: 2022.01.27
Time: 20:02:51
RPM: 729 /min
Load: 18.0 %
Temperature: 60.0°C
Temperature: 30.0°C
Voltage: 14.224 V
005748 - Powertrain Data Bus
P1674 - 008 - Implausible Message from Instrument Cluster - Intermittent
Mileage: 58269 km
Date: 2022.02.18
Time: 02:56:16
RPM: 1153 /min
Load: 18.4 %
Speed: 82.0 km/h
Temperature: 99.0°C
Temperature: 56.0°C
Voltage: 12.827 V
P1653 - 002 - - Intermittent
Mileage: 58422 km
RPM: 90 /min
Load: 100.0 %
Temperature: 24.0°C
Temperature: 30.0°C
Voltage: 6.731 V
Readiness: 0000 1000
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 CS HW: 09D 927 750 CS
Component: AL 750 6A 0993
Revision: 00H61000 Serial number:
Coding: 0004458
VCID: 015F88121D1A0673C01-5160
Fault Frequency: 8
Reset counter: 22
Date: 2006.01.01
Time: 03:22:25
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 K HW: 7L0 907 379 K
Component: ESP ALLRAD MK25E1 0302
Revision: 00H53001
Coding: 0008578
VCID: 41DF48125DCAC673801-8014
Fault Frequency: 11
Reset counter: 218
Mileage: 58414 km
Date: 2022.04.09
Time: 10:24:06
Count: 128
Count: 12545
Count: 294
Count: 255
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 D HW: 5WK 485 05
Component: 23 Kessy 6840
Revision: 68406418 Serial number: VWX3Z0G3607001
Coding: 0147688
VCID: 2809F5B6DEB0173BA7F-807C
Component: ELV XXXX
00087 - Terminal 30 for Starting Relevant Consumers
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AD
Component: CLIMAtronic R/L 4326
Coding: 0020020
VCID: 72BDD7DE28EC2DEBC9B-8026
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2001
Revision: -0004--- Serial number: --------------
Coding: 600004003B261C000000000000000000
VCID: 00598D1616400F7BCFF-8054
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234 36 VW8T 0250
Revision: 92011025 Serial number: 0039P001D6DR
Coding: 0013110
VCID: 7AADFFFE709C55AB81B-802E
Mileage: 54663 km
Date: 2021.03.12
Time: 00:25:41
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 G
Component: Lenksaeulenmodul 3501
Coding: 0010211
VCID: 43D3421A47D6D46392D-8016
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 885 H HW: 7L6 920 885 H
Component: J0285 KOMBI-INST. 7018
Revision: KHH06X62
Coding: 0007101
Shop #: WSC 01102 604 66966
VCID: 41DF48125D8AC673801-8014
Fault Frequency: 8
Reset counter: 4
Mileage: 58355 km
Date: 2022.03.03
Time: 22:09:30
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 885 H
Component: J533 GW-K-CAN TP20 7018
Coding: 7FE2E78940046002
VCID: 70B9DDD626A01FFB3FF-8024
Fault Frequency: 8
Reset counter: 4
Mileage: 58355 km
Date: 2022.03.03
Time: 22:09:30
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0119
VCID: 7F5B0EEA6BEE7083B65-5184
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 G
Component: LUFTFDR.-CDC- 3C3P1 3112
Coding: 0015521
Shop #: WSC 01101 604 63859
VCID: 372B26CA035E88C33E5-5184
02250 - Function Deactivation; Valve Duty Cycle
01400 - Suspension Level Control
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L6 959 933
Component: 10 HSG 7124
Coding: 0000069
VCID: 7F5B0EEA6BEE7083B65-4B3C
Subsystem 1 - Part No: 7L0 959 701 P
Component: Tuersteuergeraet FS 6302
Subsystem 2 - Part No: 7L0 959 702 P
Component: Tuersteuergeraet BF 6302
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
Subsystem 5 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Subsystem 6 - Part No: 7L6 951 171 B
Component: Innenraumsensor 0020
10 Faults Found:
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 A HW: 7L6 907 357 A
Component: AFS-Steuergeraet X014
Revision: H01 Serial number:
Coding: 1288195
VCID: 392F20F2351A9EB3C81-806C
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X008
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r X008
Coding: 00000019
02233 - Left Headlight Power Output Stage (J667)
Reset counter: 59
Mileage: 55856 km
Date: 2021.05.10
Time: 16:01:05
Voltage: 11.22 V
ABS 1
Address 56: Radio Labels: 7L6-035-180-56.lbl
Part No SW: 7L6 035 180 C HW: 7L6 035 180 C
Component: Radio DE2 0007
Revision: 00004000 Serial number: VWZ4Z4GN008292
Coding: 0001402
VCID: 2D0704A2F1123213549-8078
00879 - Connection to Speaker Front Right
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119
Component: J400__ Front Wiper 5101
Coding: 0000341
VCID: 77ABE6CA43CE48C3FE5-8022
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 190407 020 0105
Coding: 00208933
Shop #: WSC 31414
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0D Einparkhilfe 1107
End----------(Elapsed Time: 01:51, VBatt start/end: 14.0V/14.1V)-----------
