Audi A8 D3 carbon ceramic brake kit retrofit coding error. Error 31 Request out of range.
PedroT
Portugal
C?ID=505276
So I have an Audi A8 D3 4.2 TDI from 2007. I bought an original Audi carbon ceramic kit from an S8 D3 on ebay. I installed the kit, no issues there.
The issue is, when I try to code the ABS module to know about the brembo ceramic brake kit, it gives me a request out of range error.
I can successfully login to the module but then when I try to code the new values it gives me that error.
The ABS module is the original one that came with the car, so it's current coding the also the original coding. It was from it that I calculated the login password.
Also, If I try to code the original code, it says coding accepted ( but no further calibrations or whatever is needed or asked. no error codes ).
Also, I tried changing only the type of car from A8 short base to S8 and it also gives the same out of range error.
I am attaching the scan log, and some photos of the process.
The login code is: 05257 ( derived from the original coding )
The current code is: 0008557
The supposed code for the brembo is: 0008737
I also tried changing the workshop code etc, as advised on the VCDS wiki but it's the same error.
these are the images:
Thursday,23,June,2022,15:48:29:40836
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4608.4
VIN: WAUZZZ4EX7N009015   License Plate:
Mileage: 211230km-131252mi   Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 18 19 1D 1E
          28 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 65 66 67 6C 72
          76 77
VIN: WAUZZZ4EX7N009015   Mileage: 211230km-131252miles
1D-Driver Ident. -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
66-Seat, Rear -- Status: OK 0000
Address 01: Engine        Labels: 057-910-409-BVN1.clb
   Part No SW: 4E1 910 409 B    HW: 4E1 907 409 A
   Component: 4.2L V8TDI  A000AGMª0010
   Revision: --H02---    Serial number: AUX3Z0F8307471
   Coding: 0011773
   Shop #: WSC 66565 257 00032
   VCID: 2313EEAA07DC00539A3-8076
   VINID: 9D196AAAA115A0778000900114F70969E2
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E1 910 156 S    HW: 09E 927 156 B
   Component: AG6 09E 4,2 TDI RdW 0010
   Revision: --H01---    Serial number:        0093417
   Coding: 0000001
   Shop #: WSC 02313 785 00200
   VCID: 33331EEAB73C90D36A3-8066
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H46 0510
   Coding: 0008557
   Shop #: WSC 46940 000 00000
   VCID: 221DEBAE18C6095B915-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 K
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0F8307471
   Coding: 0410624
   Shop #: WSC 02311 785 00200
   VCID: 58E989460E1A938BBF1-800C
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063968
   VCID: 2411EDB602D2076BE39-8070
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 769 Q    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 300IR067573366
   Coding: 0010002
   Shop #: WSC 02555 823 21277
   VCID: 3A2D33CE9056619BA95-806E
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH03 0040
   Subsystem 2 - Serial number: 00000000021824
   Subsystem 3 - Serial number: 0128.08.060000000100010100ÿ
   Subsystem 4 - Serial number: 010100ÿ
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 H
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000105814
   Coding: 0137471
   VCID: 1C61D5563AA23FAB5B9-8048
   Subsystem 1 - Part No: 4E0 910 133
   Component: FHS             H03 0070
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H02  010
   Subsystem 3 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 4 - Serial number: 898053000
   Subsystem 5 - Serial number: HO15092006065A000000000089ÿ†89
   Subsystem 6 - Serial number: 000089ÿ†898053000      000-SHO
   Subsystem 7 - Serial number:     000-SHO15092006065A00000000
   Subsystem 8 - Serial number: 65A000000000124ÿ
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
   Component: ILM Fahrer      H15 0230
   Coding: 0143121
   VCID: 363527FEA44E85FB4DD-8062
   Subsystem 1 - Part No: 4E1 910 113 C
   Component: Wischer WWS D3  H60 0420
   Coding: 00000036
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00141886
   Shop #: WSC 02313
Address 0E: Media Player 1 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0850
   Revision: 00000000
   VCID: 2B03068A630CC813223-807E
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1229U7101108
   Coding: 0000001
Address 11: Engine II        Labels: 057-910-409-BVN2.clb
   Component: 4.2L V8TDI  A000AGSª0010
   Coding: 0011773
Address 13: Auto Dist. Reg        Labels: 4E0-910-561.clb
   Part No SW: 4E0 910 561 F    HW: 4E0 907 561 F
   Component: ABSTANDSREGELUNGH03 0020
   Coding: 0011164
   VCID: 2517F0B209E8FE63F47-8070
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H13 3710
   Revision: 91H13371    Serial number: 0037P0G02BL%
   Coding: 0430705
   VCID: 270BFABA73E4EC73C6B-8072
   Subsystem 1 - Serial number: 63328RB4018B9127H
   Subsystem 2 - Serial number: 63428RB4018B9138K
   Subsystem 3 - Serial number: 63528RB4018ABBE2.
   Subsystem 4 - Serial number: 63628RB4018B916EV
   Subsystem 5 - Serial number: 63729RB4018B6837R
   Subsystem 6 - Serial number: 63829RB4018B61FE/
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H14 0040
   Coding: 0012151
   VCID: 6597B0B249683E63347-8030
   Component: Lenkradmodul    H03 0040
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 931 J    HW: 4E0 920 931 J
   Component: KOMBIINSTR. VDO H82 0540
   Revision: D03         Serial number: AUDID3F8000770
   Coding: 0048103
   Shop #: WSC 11111 111 11111
   VCID: 2A0D038E60F6D11BD95-807E
Address 18: Aux. Heat        Labels: 4E0-910-105.clb
   Part No SW: 4E0 910 105 A    HW: 4E0 265 081 T
   Component: Heizgeraet      H08 0140
   Revision: 0000000C    Serial number: 00000009013887
   Coding: 0000111
   VCID: 1A6DD34E3096419B495-804E
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4E0 907 468 G
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 0100J0682180A6
   Coding: F5FDDFFF717A3E00
   Shop #: WSC 00046 123 12345
   VCID: 2D0708925118C6233C7-8078
Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
   Part No SW: 4E0 910 218 A    HW: 4E1 905 218 B
   Component: FPI_1           H01 0020
   Revision: 01000102    Serial number: 13102006152200
   VCID: 1F1BE25A2BB424B3BEB-804A
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8198724
   Part No SW: 4E0 910 158     HW: 4E0 919 158 E
   Component: KLIMA-STG. FOND 017 0230
   Revision: 00000019    Serial number: 00000000046128
   Coding: 0000000
   VCID: 619FA4A25D405243C8F-8034
   Subsystem 1 - Part No: 4E0 910 772 A
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO13092006065A000000000327ÿ†89
   Subsystem 5 - Serial number: 000327ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO13092006065A00000000
   Subsystem 7 - Serial number: 65A000000000341ÿ
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6330
   Coding: 0010010
   Shop #: WSC 00046 000 00000
   Component: Sitzmemory FS  H02  0010
   Coding: 4063982
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
   Component: MNS ECE         H48 1060
   Revision: 00000000    Serial number: 364I 067594157
   Shop #: WSC 00493 128 21413
   VCID: 3B2336CA9F6C5893B23-806E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H05 0090
   Serial number: 00000624800115
   Coding: 0069094
   VCID: 1D67D85221B836A3AC7-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 801 D
   Component: Türsteuer.FS BRM005 0180
   Coding: 0032749
   VCID: 2019E1A616CA1B4B871-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
   Component: Komfortgeraet   H07 0010
   Revision: 00100007    Serial number:  W040609220173
   Coding: 0004728
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel   P14H06 0070
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H05 0020
Address 47: Sound System        Labels: None
   Part No SW: 4E0 910 466 D    HW: 4E0 035 466
   Component: BO_D3           H06 0320
   Revision: 20S00002    Serial number: 01109060005181
   Coding: 0000022
   Subsystem 1 - Part No: 4E0 910 465 B
   Component: BO_D3_SLAVE     H31 0310
   Subsystem 2 - Serial number: 02509060003078
   Subsystem 3 - Serial number: 0225.09.060000000100030015ÿ
   Subsystem 4 - Serial number: 030015ÿ
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000091782
   Coding: 0010111
   VCID: 1E65DF5E2CBE2DBBB5D-804A
   Subsystem 1 - Part No: 4E0 910 511
   Component: UGDO HL ECE     H06 0050
   Subsystem 2 - Serial number: 0253439TJ91K06
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 802 D
   Component: Türsteuer.BF BRM005 0180
   Coding: 0032749
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
   Component: EPB  A32C0220   H02 0220
   Revision: A32C0220
   Coding: 0001031
   Shop #: WSC 77721 150 29413
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000018
   Shop #: WSC 74501 141 91550
   VCID: 290FFC8265F0DA03D0F-807C
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 396I4067546659
   Coding: 0000001
   VCID: 313F14E24D20A2C318F-8064
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000018413
   Subsystem 1 - Part No: 4F0 915 105 E
   Component: von VA0  2502160100
   Coding: 344630393135313035452056413032353032313630313030
   Shop #: WSC 63868 001 104857
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: Türsteuer.HL BRM005 0180
   Coding: 0032749
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05
   Revision: 00050340    Serial number: 00000700047479
   Coding: 0212328
                    Reset counter: 0
                    Mileage: 211225 km
                    Date: 2022.06.23
                    Time: 12:35:57
                    (no units): 9.0
                    Temperature: 18.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
            004 - No Signal/Communication - Intermittent - MIL ON
                    Fault Status: 10100100
                    Reset counter: 172
                    Mileage: 211229 km
                    Date: 2022.06.23
                    Time: 13:07:37
                    (no units): 33.0
                    Temperature: 18.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 66: Seat, Rear        Labels: None
   Part No SW: 4E0 910 860     HW: 4E0 959 860
   Component: Sitz Fond      H06  0050
   Revision: 00000000    Serial number: 5DS 008 795-01
   Coding: 0000511
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0630
   Revision: 00000000    Serial number: 00000609210546
   Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
   Part No SW: 4E0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J6810UN
   Coding: 1020402
   Shop #: WSC 40838 000 1048576
   VCID: 5CE195567A227FAB9B9-8008
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0032749
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08730626204859
   Coding: 0321008
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336     HW: 4F1 862 335
   Component: BTA             H09 0530
   Revision: 00H09000    Serial number: 00000007508309
   Coding: 1060091
End----------(Elapsed Time: 02:59, VBatt start/end: 13.5V/13.7V)-----------
JMR
Romania
C?ID=432218
a better picture with the entire coding codes would've helped me much better ..
PedroT
Portugal
C?ID=505276
You are right. I am sorry.
Here are two photos, one from the login ( coding II ) and the other from the coding:
^^^ Which should match this page:
One possibility is that cars that came from the factory with those ceramic brakes had a different ABS module (or different software in the module) that would accept said coding, while more pedestrian modules don't. But I'm only speculating...
PedroT
Portugal
C?ID=505276
yes, it matches that page.
JMR
Romania
C?ID=432218
i was thinking just that because his login is exactly for a car without brembo, no ? The second 5 in his 05257 indicates just that
PedroT
Portugal
C?ID=505276
well, the idea of being able to code an ABS unit with different values is that it shouldn't matter what the coding the unit was coded in at the factory.
according to car prog2:
There are several ABS units for the A8/S8 with 8 cylinder diesel ( mine ) or 10/12 cylinder petrol. It appears that my unit hardware BC was only for the 8 cylinder diesel. the Ones for the 10 or 12 petrol end with different letters.
Another question is, is coding the unit to the correct brakes important? what does the unit do exactly? I heard that it activates a "heating" cycle when it's raining or something. like it touches the pads on the disk from time to time.
Good point.
Login:
05 - A8 Short
2 - 2FNR 42 AL 17" -- I think this should be 7
5 - 6/8 Cyl. Diesel w/o Brembo M6 AL 19" (PR-1LW) - I think this should be 3
7 - Automatic (09E/09L)
Coding:
0008 - A8 Short
7 - Brembo M6 AL 19"
3 - 12 Cyl. Gasoline OR 6/8 Cyl. Gasoline/Diesel with Brembo M6 AL 19" (PR-1LW)
Is it possible that @PedroT does not understand that the Login is not fixed, but must match the coding that about to be entered next?
Reactions: JMR
PedroT
Portugal
C?ID=505276
oh!
so the login must match what I am going to code and not what is previously coded?
  • Agree
PedroT
Portugal
C?ID=505276
so it should be 05737 ?
JMR
Romania
C?ID=432218
try it
with coding 0008737 as Uwe suggested
PedroT
Portugal
C?ID=505276
So it didn't work.
It doesn't accept 05737 as a login code.
I tried login code 05157 ( the pr-1lj/lk ) and also didn't work
I tried login code 05457 ( pr-1lg ) and it accepted this login.
So it seems that it only accepts to be coded with brakes PR-1LG and PR-1LL/LM :(
anything I can do besides replacing the ABS unit? Is it really needed?
I don't know. We've had some people do big-brake upgrades in other vehicles that were just fine without changing the coding, but those were just bigger iron/steel rotors. Ceramic might just be different enough that it really should have the right module and coding.
  • Agree
Reactions: JMR
JMR
Romania
C?ID=432218
Do you have a picture with your PR sticker ?
Could you try 03737 ( short S8 )?
PedroT
Portugal
C?ID=505276
nope, the sticker is long gone. Why would you need it?
JMR
Romania
C?ID=432218
well really i thought you might've misinterpreted the login code and coding. But really you could only try a coding for an S8 short..see if that works
PedroT
Portugal
C?ID=505276
so like 03737 ?
JMR
Romania
C?ID=432218
besides, the ceramic is muchoooo moola :)
  • Agree
JMR
Romania
C?ID=432218
so like 03737 ?
yes, see if it accepts it as a login and then do the coding...nothing to loose. However, if it does accept it,don't forget to do the basic settings in same session by loging in with 40168 otherwise coding won't stick
