- Feb 10, 2022
- 3
- 1
- Chichester, UK
- C?ID=353554
Think some body has been playing around with the coding or swapped the abs module because it constantly states incorrectly coded in the abs module.
VCDS Version: 22.3.0.1 (x64) HEX-NET CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WVWZZZ13Z9V004484 License Plate: SCIROCCO
Mileage: 156680km-97356mi Repair Order:
Chassis Type: 13 (1K0)
Scan: 01 03 08 09 14 15 16 17 19 25 42 44 46 4C 52 53 62
VIN: WVWZZZ13Z9V004484 Mileage: 156680km-97356miles
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0011
14-Susp. Elect. -- Status: Not registered 0011
15-Airbags -- Status: Not registered 0011
16-Steering wheel -- Status: Not registered 0011
25-Immobilizer -- Status: Not registered 0011
44-Steering Assist -- Status: Not registered 0011
46-Central Conv. -- Status: Not registered 0011
4C-Tire Pressure II -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
Address 01: Engine (CAW) Labels:. 06J-906-026-CAW.clb
Part No SW: 06J 906 026 AR HW: 06J 906 026 D
Component: MED17.5 2718
Revision: A7H06--- Serial number: VWX7Z0H63NA0D8
Coding: 0403000318070060
Shop #: WSC 66565 257 00032
VCID: 7AB8F6DD3556355F8C-802E
VINID: 9E69EAAAA043A8998000410810CC588762
001378 - System Voltage
P0562 - 000 - Too Low - Intermittent
Mileage: 156680 km
Time: 22:12:32
Load: 0.0 %
Speed: 255.0 km/h
Temperature: 31.0°C
Temperature: 24.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 8.382 V
Readiness: 0000 0001
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 763B60F5092200FE6E0F06EC901D00813000
Shop #: WSC 16650 210 00001
VCID: 76A0E2EDC14E513FE8-8022
Reset counter: 71
Mileage: 156680 km
Count: 3
Count: 2
Count: 12288
Count: 320
Count: 45056
Reset counter: 71
Mileage: 156680 km
Count: 3
Count: 2
Count: 12288
Count: 8192
Count: 45056
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 71
Mileage: 156680 km
Count: 3
Count: 2
Count: 12288
Count: 8234
Count: 45056
Part No SW: 1K0 907 044 DA HW: 1K0 907 044 DA
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 699AB99140F08EC775-803C
00716 - Air recirculation Flap Positioning Motor (V113)
Revision: 00H54000 Serial number: 00000008671915
Coding: ED8E8F0300041A0067960E001900000000087F075C400124000000000000
Shop #: WSC 00020 790 00000
VCID: 33261BF952BC04170F-8066
Subsystem 1 - Part No: 1K8 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 190508 022 0602
Coding: 00038805
Shop #: WSC 00020
Component: RLS 030708 054 0402
Coding: 00208936
Shop #: WSC 00020
Fault Status: 01101100
Reset counter: 71
Mileage: 156680 km
Voltage: 10.85 V
Reset counter: 71
Mileage: 156680 km
Voltage: 11.70 V
Reset counter: 71
Mileage: 156680 km
Voltage: 6.50 V
Reset counter: 111
Mileage: 156680 km
Voltage: 6.50 V
00154 - Windshield Wiper Motor; Passenger Side (V217)
Reset counter: 111
Mileage: 156680 km
Voltage: 9.60 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Reset counter: 111
Mileage: 156680 km
Voltage: 9.60 V
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0069
Revision: 00000000 Serial number: 03070800240001
Coding: 000180
VCID: 6680B2AD91EEA1BF58-8032
03264 - Functionalty Shut Off
Reset counter: 111
Mileage: 156680 km
Time: 21:46:05
Error Code: 9
Bin. Bits: 00000000
Reset counter: 111
Mileage: 156680 km
Time: 22:11:14
Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
Component: 0H AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 003D1D003GSY
Coding: 0012360
VCID: 6FAED7897E1460F72B-803A
Subsystem 1 - Serial number: 6332MSME3D72386FS
Subsystem 2 - Serial number: 6342MSME3161655ED
Subsystem 3 - Serial number: 6352QSME7B2B4B0F
Subsystem 4 - Serial number: 6362QSME7B2B427F.
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent - MIL ON
Part No SW: 1K0 953 549 CB HW: 1K0 953 549 CB
Component: J0527 051 0101
Coding: 0002002
VCID: 74A4D8E51732432FD6-8020
Component: E0221 002 0010
00576 - Terminal 15
Part No SW: 1K8 920 970 FX HW: 1K8 920 970 FX
Component: KOMBIINSTRUMENT VDD 2444
Revision: V0005000 Serial number: VWX7Z0H63NA0D8
Coding: 0007403
Shop #: WSC 00011 888 06946
VCID: 0D52AD0114D832E7B9-8058
Reset counter: 111
Mileage: 156680 km
Time: 22:12:15
00003 - Control Module
014 - Defective
Fault Status: 01101110
Mileage: 153597 km
Time: 00:01:46
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 0000K087220287
Coding: 19903A000000020002
VCID: 352225E15CC81A2721-8060
Reset counter: 71
Mileage: 156680 km
Time: 22:12:39
Reset counter: 71
Mileage: 156680 km
Time: 22:13:43
03109 - Tire Pressure Monitoring Control Module 2 (J793)
Reset counter: 71
Mileage: 156680 km
Time: 22:13:48
Reset counter: 71
Mileage: 156680 km
Time: 22:13:48
Component: IMMO VDD 2444
Shop #: WSC 26432 001 1048576
014 - Defective
Mileage: 139212 km
Time: 16:45:47
Part No SW: 1Q0 959 701 F HW: 1Q0 959 701 F
Component: Tuer-SG 008 2018
Coding: 0016949
VCID: 373E2FE946C4E83733-8062
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 185 2301
Revision: 00H15000
VCID: 2A18069D857645DFBC-807E
00750 - Warning Lamp
Fault Status: 11101101
Voltage: 8.13 V
PD
Temperature: 23.0°C
RPM: 170 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0205
Coding: 81900A0002830C7F3F04840570085ACE903C00
VCID: 03468B39429C7497DF-8056
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K8 951 171
Component: DWA-Sensor 001 0104
Fault Status: 01100101
Reset counter: 71
Mileage: 156680 km
Time: 21:31:55
Reset counter: 71
Mileage: 156680 km
Time: 21:31:57
01134 - Alarm Horn (H12)
Reset counter: 71
Mileage: 156680 km
Time: 22:12:53
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Component: Tuer-SG 009 2124
Coding: 0016948
Shop #: WSC 00712 210 88117
VCID: 3A3836DD75D6F55FCC-806E
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 53: Parking Brake
Address 62: Door, Rear Left
End----------(Elapsed Time: 01:07, VBatt start/end: 13.8V/13.8V)-----------
