Hi all looking for some guidance on this fan control module supply voltage malfunction issue thanks
Friday,11,March,2022,18:04:42:22536
VCDS Version: 22.3.0.1 (x64) HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WVWZZZAWZLU048278 License Plate: VW POLO R LINE
Mileage: 13932km-8656mi Repair Order: 232
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: WVWZZZAWZLU048278 Mileage: 13932km-8656miles
Address 01: Engine (J623-DKRF) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 AL HW: 04C 907 309 BP
Component: R3 1.0l TFS H20 7054
Revision: DGH20000 CVN: 3D899775
Coding: 0119003223041D080000
Shop #: WSC 31414 790 00200
ASAM Dataset: EV_ECM10TFS01104C906025AL 003001
ROD: EV_ECM10TFS01104C906025AK.rod
VCID: 6A8DCBAA5CFA69DB716-803E
VINID: 9E69EAAAA467A9C94010808720B1162752
4523 - Fan Control Module 1
P2D89 00 [039] - Supply Voltage Malfunction
Mileage: 13932 km
Date: 2021.12.17
Time: 08:20:32
Engine RPM: 1460.00 /min
Normed load value: 37.3 %
Coolant temperature: 61 °C
Intake air temperature: 14 °C
Voltage terminal 30: 13.340 V
Outside temperature: 9 °C
Absolute intake pressure: 79 kPa abs
Engine torque: 43.5 Nm
Fuel: tank fill level: 4.0 l
Oxygen sensor B1: sensor 1: specified value: 1.0000
Particulate filter: loading stage: 0
Overrun cut-off-Bits 0-7: 0
U0428 00 [039] - -
Mileage: 13932 km
Date: 2021.12.17
Time: 08:20:21
Engine RPM: 960.00 /min
Normed load value: 9.8 %
Coolant temperature: 60 °C
Voltage terminal 30: 13.360 V
Absolute intake pressure: 32 kPa abs
Engine torque: 15.2 Nm
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 2Q0 614 517 AG HW: 2Q0 614 517 N
Component: ESC_base_vFGS H23 0242
Serial number: 08506781190912
Coding: 09034C64354590B532FEAC1D24E242A649124526224A245844541254452442659248A2644452241A222A482AA251D64B3D8A6BD2BC
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
ROD: EV_Brake1BOSCHESPMQBA0_004.rod
VCID: 73B3D6CE0B30A813C20-8026
1360 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [153] - -
[LWI_SensorNotCalibrated]
MIL ON - Confirmed - Not Tested Since Memory Clear
Reset counter: 236
Mileage: 13932 km
Date: 2021.12.11
Time: 23:22:11
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 2G2 820 045 K HW: 2G2 820 045 K
Component: SG_AC_Manuell H60 0505
Coding: 012100000800010001000400020000000010000000000000000000000000
ASAM Dataset: EV_ACManuePrehMQBA0 001013
ROD: EV_ACManuePrehMQBA0_VW27.rod
VCID: 290FF4A6997CA2C3B8C-807C
Part No SW: 2Q0 937 089 B HW: 2Q0 937 089
Component: BCM A0 Std H10 0934
Serial number: 01101923301651
ASAM Dataset: EV_BCMA0 205001
ROD: EV_BCMA0_205.rod
VCID: 392F24E669DC1243C8C-806C
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 051 0206
Serial number: S6Y19M08D21H18M41S16
Coding: 0018DD
Driver door control module:
Subsystem 2 - Part No SW: 2Q2 959 405 B HW: 2Q2 959 163 B
Component: FHSG_DRV 002 0005
Serial number: 00000000000033375710
Coding: 1F0037
Front passenger door control module:
Subsystem 3 - Part No SW: 2Q2 959 406 B HW: 2Q2 959 164 B
Component: FHSG_PSG 002 0005
Serial number: 00000000000033357036
Coding: 058037
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY192301SKU
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000047647558
Subsystem 6 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000033753487
Coding: 1F0000
Subsystem 7 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000033862384
Coding: 070000
8202 - Bulb for Left DRL
B121D 15 [009] - Open or Short to Plus
Reset counter: 236
Mileage: 13932 km
Date: 2021.12.17
Time: 08:20:21
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 13.4 V
8458 - Bulb for Right DRL
B121E 15 [009] - Open or Short to Plus
Reset counter: 236
Mileage: 13932 km
Date: 2021.12.17
Time: 08:20:21
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058419256
Coding: 0471051001
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000.rod
VCID: 50F97942DA66B30B1F2-8004
13637426 - Databus
Reset counter: 236
Mileage: 13932 km
Date: 2021.12.17
Time: 08:20:19
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 2A04600200FF8748949C810500408700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 43D3460E1B105893920-8016
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 236
Mileage: 13932 km
Date: 2021.12.17
Time: 08:20:18
Voltage terminal 15: 13.4 V
Control Module temperature: 28 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: -0.16 m/s²
Adaptive distance regulation: status: ACC_reversible_error
2055 - Databus
[FAULT_ALP_STEERINGWHEEL_INIT]
Reset counter: 236
Mileage: 13932 km
Date: 2021.12.17
Time: 08:20:18
Part No SW: 2Q0 959 655 AG HW: 2Q0 959 655 AG
Component: VW22Airbag 010 0248
Revision: --------
Coding: 88CCC0C0000000005C5400CF008800000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 025D830A448A919BD96-8056
Subsystem 1 - Part No SW: ----------- HW: 442 062 510 19
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y50B13251E51120L
Subsystem 2 - Part No SW: ----------- HW: 442 062 210 19
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y5099331F37251B2
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 908 19
Component: SideSensor_Dr 1C7 0148
Serial number: 3517781BD33B2852812F
Subsystem 4 - Part No SW: ----------- HW: 442 0B0 609 19
Component: SideSensor_Pr 1C7 0148
Serial number: 3527782B133A3551A1DE
Subsystem 5 - Part No SW: ----------- HW: 442 132 812 19
Component: FrontSensor_D 290 118A
Serial number: 355AG11AB30C15E256F$
Part No SW: 2G0 920 940 C HW: 2G0 920 940 C
Component: KOMBI 202 6700
Coding: 24A4010021802600018822011001000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001040
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: 2411E592FE5E7FAB8BA-8070
Part No SW: 2Q0 909 901 C HW: 2Q0 937 089
Component: GW MQB A0 H10 0934
Coding: 030100046F08560022000048080F00010001070000000000000000000000
GVL: 01443C0000000000400080000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0 013026
ROD: EV_GatewA0_VW27.rod
VCID: 323D13CAB4AAE11B096-8066
Generator:
Component: 2-01-14-01-04
Subsystem 2 - Part No SW: 2G0 959 442 N HW: 2G0 959 442 N
Component: E221__MFL-MD9 H04 0052
Serial number: 29190001324640099295
Coding: 24FFFF
Subsystem 3 - Part No SW: 2Q0 915 181 B HW: 2Q0 915 181 B
Component: J367-BDMBOSCH H02 2012
Serial number: 10029C65
Address 44: Steering Assist (J792) Labels:* 2Qx-909-144-V1.clb
Part No SW: 2Q2 909 144 M HW: 2Q2 909 144 F
Component: TRW_G4L_MQBA0 621 6041
Serial number: 1445222CB4K2681
Coding: 010000000000000001010201010001000000010001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: 3D2730F67DF42E63E44-8068
10531840 - Steering angle sensor
Reset counter: 236
Mileage: 13932 km
Date: 2021.12.17
Time: 08:20:19
Engine RPM: 954 /min
System status: Driving mode
Voltage terminal 30: 13.41 V
Power steering current consumption: 0.5 A
max.value: 0.5 A
End stage temperature: 15 °C
Steering assistance: engine output: 100 %
Engine angle: 0 °
Electric motor speed: 0 /min
Steering assistance: target engine torque: 0.0 Nm
Steering torque: 0.0 Nm
10551552 - Control Module Incorrectly Coded
U1014 00 [009] - -
[DEM_CODING_PLA_FAULT]
Reset counter: 236
Mileage: 13932 km
Date: 2021.12.17
Time: 08:20:24
Voltage terminal 30: 13.44 V
max.value: 0.5 A
Engine angle: 7 °
Electric motor speed: -1 /min
Part No SW: 3Q0 035 842 C HW: 3Q0 035 842 C
Component: MU-S-D-ER 724 0891
Coding: 02720000BE00000041110101008808001F0506C60120010003
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 2D0700B6AD94BEE3544-8078
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H61 8214
Serial number: VWZ6ZJW2550280
End----------(Elapsed Time: 00:56, VBatt start/end: 13.3V/13.3V)-----------
