Monday,21,February,2022,15:42:09:28263
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: WAUR2AFD8DN015952 License Plate:
Mileage: 226560km-140777mi Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 1B 20 22 28 34 36 3B
3C 42 46 47 52 53 56 5F 62 6C 6D 6F 72 81 84 85 88 89 8B 8E
8F 90 BA
VIN: WAUR2AFD8DN015952 Mileage: 226560km-140777miles
Address 01: Engine (------CEUA) Labels:. 079-907-560-CFS2.clb
Part No SW: 4H0 906 014 L HW: 4H0 906 014
Component: 4.0l V8TFSI / H61 0005
Revision: NCH61--- CVN: 7AEC306B
Coding: 022A00326546010E1000
Shop #: WSC 56096 001 1048576
ASAM Dataset: EV_ECM40TFS0114H0906014L 001005
ROD: EV_ECM40TFS0114H0906014L.rod
VCID: 2C020D87668DD11B2B9-8078
VINID: 9D196209159421478004524508F4351E99
8218 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
P2098 00 [237] - Too Lean
Mileage: 224739 km
Date: 2022.02.18
Time: 09:15:45
Engine RPM: 2049.50 /min
Normed load value: 19.2 %
Vehicle speed: 124 km/h
Coolant temperature: 99 °C
Intake air temperature: 13 °C
Voltage terminal 30: 14.135 V
Engine status: COENG_RUNNING
7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 00 [237] - Too Lean
Mileage: 224760 km
Date: 2022.02.18
Time: 09:25:55
Engine RPM: 2051.50 /min
Normed load value: 23.5 %
Coolant temperature: 102 °C
Intake air temperature: 29 °C
Voltage terminal 30: 14.206 V
15356 - Oxygen (Lambda) Sensor Signal B1 S2
P2270 00 [096] - too Lean
Mileage: 224997 km
Date: 2022.02.18
Time: 11:42:09
Engine RPM: 1810.00 /min
Normed load value: 24.7 %
Vehicle speed: 110 km/h
Coolant temperature: 93 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.088 V
Unlearning counter according OBD: 33
Rear cat conv temp main cat conv model value: 584.03 °C
O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean: 0.10 s
O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich: 0.17 s
O2 sensor dwnstrm. of cat.: delay time transf. rich -> lean: 0.00 s
O2 sensor dwnstrm. of cat.: delay time transf. lean -> rich: 0.05 s
20040 - Oxygen (Lambda) Sensor Signal B2 S2
P2272 00 [096] - too Lean
Mileage: 224997 km
Date: 2022.02.18
Time: 11:42:09
Engine RPM: 1798.50 /min
Normed load value: 26.7 %
Vehicle speed: 109 km/h
Intake air temperature: 26 °C
Rear cat conv temp main cat conv bank 2 model value: 571.47 °C
O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean: 0.11 s
O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich: 0.15 s
O2 sens.dwnstrm. of cat. bank 2: delay time transf.rich -> lean: 0.00 s
O2 sen dwnstrm. of cat. bank 2: delay time transf. lean -> rich: 0.00 s
4120 - Oxygen (Lambda) Sensor B2 S1
P2198 00 [237] - Signal too High (Rich)
Mileage: 224854 km
Date: 2022.02.18
Time: 10:13:39
Engine RPM: 2047.50 /min
Normed load value: 40.8 %
Voltage terminal 30: 13.994 V
4116 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [237] - Signal too High (Rich)
Mileage: 226173 km
Date: 2022.02.20
Time: 15:29:10
Engine RPM: 1986.50 /min
Normed load value: 25.9 %
Vehicle speed: 120 km/h
Intake air temperature: 43 °C
Voltage terminal 30: 14.017 V
Readiness: 0000 0100
Part No SW: 4H1 927 158 EF HW: 0BK 927 156 AG
Component: 0BK 40TFSIUSA H16 1002
Revision: --H16--- CVN: 792F3907
VCID: 78AAE1D7E255ADBB9F1-802C
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Coding: C4FDF30023BFCF00E200
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 343215E7BEBD89DB739-8060
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 CD
Component: BCM2 2.0 H32 0510
Coding: 0DA72046000000000000
Shop #: WSC 35934 001 1048576
VCID: 6E86C78F9091E30B45D-803A
Serial number: 2312000158439009
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000040425010
Coding: C018320085047201010001010101112131313333283333
Shop #: WSC 02313 785 00200
VCID: 353428E3B54790D3447-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 L HW: 4H0 820 043 L
Component: Klima 4 Zonen H20 0121
Coding: 688122B87C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 290CF493697FC433D0F-807C
0386 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Reset counter: 239
Mileage: 224609 km
Date: 2022.02.17
Time: 16:27:39
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001463307
Coding: 09072091077C9FF3BB000804A0003800009CD3088E0001218001085C7B00
VCID: 6FB8DA8B979BEA034EB-803A
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 120909 H35 0080
Serial number: 121006121326
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10283621
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 C HW: 4H0 941 531 C
Component: E1 - LDS H07 0044
Serial number: 05 09 2012 00000829
Component: USHL4.2 H30 0030
Serial number: 0000002274555R3GZ902
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000016101200010053
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000022101200010132
Coding: 100000
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103816000001670826
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 0B78C356000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061229701454
Coding: A80B1E
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BCDCF3812FFCF358F-8024
Part No SW: 4H0 907 561 B HW: 4H0 907 561
Component: ACC3 H17 0400
Coding: 7E01020101
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A0E0B9F6C79CF2BD95-807E
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H44 0041
Revision: -------- Serial number: 003JS001D6H1
Coding: 303143303230303030314A55304C34483053
VCID: 372822EBAFCB62C356B-8062
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R12A01067A5
Serial number: 3575HRB405N1J828EP1D
Serial number: 3585HRB40551KADSAG6M
Serial number: 3515JRB400A4UON6NP16
Serial number: 3525JRB400G4UON6819P
Serial number: 3554VRB404P1M1UC71L%
Serial number: 3564VRB40531M1UCJP3/
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LJH0000N
Coding: 0004BC
VCID: 382A21D7A2556DBB5F1-806C
Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L
Component: E221 - MFL H09 0009
Serial number: 19 08 2012 33274741
Part No SW: 4H0 920 880 F HW: 4H0 920 880 F
Component: TBenUSAACCNV- H50 0515
Revision: 34081076 Serial number: 658181012592026
Coding: 0B460801F740D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU64.rod
VCID: 2D0400835D97D8133C7-8078
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G
Component: Analoguhr D4 H05 0225
Serial number: 1121001000455
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4H0 907 468 AC HW: 4H0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000725737
Coding: 00ED074800
GVL: FFAFEDCCFAE3E4CCC100
ASAM Dataset: EV_GatewPkoUDS 001018
VCID: 72BED3FF8429C7EBA15-8026
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 00000000004970384879
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 12283002327021200410
U140B 00 [008] - -
[Powermanagement active]
Reset counter: 239
Mileage: 224609 km
Date: 2022.02.17
Time: 16:27:39
Voltage terminal 30: 11.4 V
Voltage terminal 15: 11.4 V
Control Module temperature: 16 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 1
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4H0 907 144 C HW: 4H0 907 144 C
Component: DYNAMIKLENK. H06 0100
Revision: 51001005 Serial number: --------------
Coding: 0B0100
VCID: 280AF19772F5FD3BCF1-807C
Part No SW: 8K0 857 511 G HW: 8K0 857 511 G
Component: FLA H04 0020
Revision: AB001001
Coding: 04018B6B74745D545420363E00
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H15 0013
Serial number: 001610120001014
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 2708F2AB7F6BF243C6B-8072
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 K HW: 4H0 919 158 K
Component: Klima Fond H16 0121
Coding: 2000000000
ASAM Dataset: EV_AirCondiHeck 001039
ROD: EV_AirCondiHeck.rod
VCID: 382A21D7A2D56DBB5F1-806C
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008006
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E06078F5091A30B05D-807A
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000040425009
Coding: C0183B0085057201010001010101112131313333203333
Part No SW: 4H0 907 637 L HW: 4H0 907 637 G
Component: SARA 6D red H02 0053
Revision: -------- Serial number: EJ1BPA710032KR
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4H0 907 566 A HW: 4G0 907 566
Component: J769 SWA MasterH02 0050
Revision: 00H02000 Serial number: 6PZ 010 287-07
Coding: 0000002
VCID: 2E06078F5C11A30B05D-807A
Subsystem 1 - Part No: 4H0 907 568 A
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-27
Subsystem 3 - Serial number: 5F09.10.1200H02000AMS14105ÿ
Subsystem 4 - Serial number: S14105ÿ
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0263
Revision: -------- Serial number: 0000131499931
Coding: 011F1F005E0062C202003017
Shop #: WSC 02312 785 00200
VCID: 48CA5117D2B51D3B2F1-801C
Revision: 00002001 Serial number: 0186619568
Coding: 0106023A00FA759FB0B0C784020301070000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000110088
Subsystem 3 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J245 007C H06 0005
Serial number: 240500002008
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 BR HW: 4H0 947 135 BR
Component: Dachelektroni H11 0080
Serial number: A2012000000000636394
Coding: 070000
Subsystem 5 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J394 0014 H06 0005
Serial number: 240400000900
Coding: 020200
Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J392 006A H06 0005
Serial number: 240500002010
Coding: 020200
Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J867 00E0 H06 0005
Serial number: 240400000898
Coding: 020200
Subsystem 8 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84302822
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000004662
Coding: 030000
Shop #: WSC 02311 785 00200
VCID: 1C62DD4736AD219B5B9-8048
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0273
Revision: -------- Serial number: 0000081384565
Coding: 011F1F005E0062C202003007
VCID: 3C223DC7966D419BBB9-8068
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000507504
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B000E9B6383D623223-807E
Part No SW: 4H0 035 082 E HW: 4H0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 155J 0C7525334
Coding: 020007010000000001
VCID: 2310E6BB0BD31E639A3-8076
Part No SW: 4H0 035 746 E HW: 4H0 035 746 C
Component: H-BNT-NA H50 0622
Revision: -------- Serial number: 183J 0C7504840
Coding: 020200000001F9EF7D168B1E00000003140001000000000000
VCID: 2A0E0B9F6CF9CF2BD95-807E
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4H0 919 604 F HW: 4H0 919 604 F
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDC9300X1Y8
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000094083
Component: CD-Database 4949
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0262
Revision: -------- Serial number: 0000131601850
Coding: 010F1F00400062C202003007
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0111
Revision: 11001001 Serial number: 82330JF0061132
Coding: 020A000101010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
ROD: EV_CamerSysteTopViewAUDI_005.rod
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 R HW: 4H0 959 107 M
Component: HDSG-Modul H11 0039
Revision: 10011001 Serial number: 283200510
Coding: 0210044100
ASAM Dataset: EV_DeckLidContrUnit 001025
ROD: EV_DeckLidContrUnit.rod
VCID: 3D2430C38DF748938C7-8068
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000087508
Coding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6390A6BB4BD35E63DA3-8036
Component: TSG HR H06 0262
Revision: -------- Serial number: 0000131601841
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5014 Serial number: SN120809 0180
ROD: EV_GSM2x3Mono_AU64.rod
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 F HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0042
Serial number: 0K84AE40082496
Coding: 1200
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 323E13FF44A987EB615-8066
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0008
Serial number: 00000000001223600125
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Coding: E9060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2616FFAF7861EB4BFDD-8072
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00008336011201
Coding: 766FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F381A8B579BAA030EB-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00008336051601
Coding: 366FF2
Part No SW: 4H0 907 541 B HW: 4H0 907 541
Coding: 7E01020101
ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
ROD: EV_AdaptCruisContr2AU64X_002.rod
VCID: 280AF1977275FD3BCF1-807C
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H31 0038
Serial number: 005000050110127
Coding: 02A19A030111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H13 0080
Coding: 0066F609031F0376070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313C1CF341AFBCF318F-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H05 0008
Revision: 00001001 Serial number: 97804000869104
ROD: EV_AEMLearAU64X.rod
End----(Elapsed Time: 03:28, VBatt start/end: 11.9V/12.0V. VIgn 12.0V)-----
My 2013 Audi A8L has been throwing DTCs for engine too rich and too lean. I can't believe that all 4 of the oxygen sensors are bad. What else could it be? I have erased the codes 3 times and they always return within about a hundred miles or so. I'm very confused by all these codes. Any suggestions about where to look for other possible solutions?? I have searched, and cannot find any similar faults.
