- Nov 13, 2021
- 2
- 1
- Illinois, USA
- C?ID=430081
Greetings,
Purchased an RCD330 unit from China in addition to the steering wheel control adaptor. Performed the install and everything worked great but I noticed a battery drain issue. I ordered a new Gateway ( 7N0 907 530AJ ) from China (Lemon Shark) to try and solve the battery drain issue. Made sure to write down everything checked off on the old Gateway ( 1K0 907 530F ) using the VCDS and did the did the swap. Used the VCDS to check off everything on the new Gateway from the old one, clicked OK and the coding was accepted. Also installed a new HPFP (banjo bolt FSI) and a new N205 Valve on the car. Car runs and drives great and the radio/phone works great.
Was able to run a report today (thanks again Ross-Tech support) and the results are below. It is a complete and total nightmare. I did not perform any resets so that may eliminate some of the Engine codes because parts were replaced, but the rest of the report melts my brain. Car still has a slight battery drain issue but not as quick as before. Should I try a non-China Gateway? I have read that any Gateway later than ( 530L ) version will work with my car. My car still has the factory sat. radio under the passenger seat if that matters. Car was basically issue free with only a few mechanical issues prior to the RCD330 swap.
I'm willing to drive anywhere in the Chicagoland area if someone out there knows how to help me fix my RCD330 issues. Thanks in advance to everyone I appreciate your time.
Robert
Robert
Thursday,02,December,2021,13:32:26:06135
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: WVWEV71K26W107850 License Plate: H420430
Mileage: 221600km-137695mi Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56
VIN: WVWEV71K26W107850 Mileage: 221600km-137695miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 B HW: 1K0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: --H10--- Serial number: VWZ7Z0E3084579
Coding: 0403010A18070160
Shop #: WSC 02132 444 52373
VCID: 2517FA5C39E07953F47-8070
VINID: 9E69D598705B0869C10072050058CD7D8A
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Mileage: 220981 km
Temperature: 19.0°C
Temperature: 19.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.065 V
000807 - Knock Sensor 1 (G61)
P0327 - 002 - Signal too Low - Intermittent
Mileage: 220981 km
Time: 15:06:58
RPM: 2985 /min
Load: 40.4 %
Speed: 26.0 km/h
Temperature: 81.0°C
Temperature: 33.0°C
Voltage: 14.224 V
008851 - Fuel Pressure Regulator Valve (N276)
P2293 - 002 - Inadequate Performance - Intermittent
Mileage: 221046 km
Time: 13:47:43
RPM: 3663 /min
Load: 89.4 %
Speed: 150.0 km/h
Temperature: 81.0°C
Temperature: 33.0°C
Voltage: 13.970 V
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
P1098 - 001 - Open or Short to Plus - Intermittent - MIL ON
Fault Status: 10100001
Mileage: 221583 km
Time: 14:03:44
RPM: 2961 /min
Load: 21.2 %
Speed: 80.0 km/h
Temperature: 86.0°C
Temperature: 26.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.097 V
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0021122
Shop #: WSC 01279 785 00200
VCID: 71BFDE0CBDA865F358F-8024
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
VCID: 6889B3688E72A43B0F1-803C
00898 - Control Circuit A/C compressor
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AA HW: 3C0 937 049 AA
Component: Bordnetz-SG H45 1402
Revision: 00H45000 Serial number: 00000002276032
Coding: 178F0F214004180000140000001400000028770B5C0000
Shop #: WSC 25807 128 67052
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00065493
Shop #: WSC 25807
Fault Status: 00100101
Mileage: 221464 km
Voltage: 12.40 V
006 - Short to Plus - Intermittent
Fault Status: 00100110
Reset counter: 42
Mileage: 221557 km
Voltage: 11.30 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7E2017480
VCID: 2A0D096050FE562BD95-807E
Reset counter: 176
Mileage: 221203 km
Time: 03:57:48
Voltage: 8.40 V
Reset counter: 176
Mileage: 221203 km
Time: 03:57:31
Voltage: 8.40 V
Reset counter: 140
Mileage: 221414 km
Time: 07:13:30
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 5L AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD03LPXZ
Coding: 0013644
VCID: 392F262CA558EDB3A0F-806C
Subsystem 1 - Part No: 1K0 959 339 D
Component: BF-Gewichtsens. 006 0006
Subsystem 2 - Serial number: 6332MSME0D466732C
Subsystem 3 - Serial number: 6342MSME0D44025CC
Subsystem 4 - Serial number: 6352QSME03332113-
Subsystem 5 - Serial number: 6362QSME03337A35C
Subsystem 6 - Serial number: 63727SME0843134F+
Subsystem 7 - Serial number: 63827SME08635410V
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
013 - Check DTC Memory - Intermittent - MIL ON
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002022
VCID: 7AADF920E0DE26ABE95-802E
Component: E0221 007 0050
Part No: 1K6 920 972 E
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0007203
Shop #: WSC 60491 444 60491
VCID: 34311718823A10DB739-8060
Part No SW: 7N0 907 530 AJ HW: 1K0 907 951
Component: J533 Gateway H41 1635
Revision: H41 Serial number: 270910F2001353
Coding: 350000
VCID: 78A9E328D2D234BB9F1-802C
Fault Frequency: 14
Mileage: 221464 km
Time: 03:01:13
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1225223T150E02
VCID: 7DA7F23CF1F01193CC7-8028
Component: IMMO VDD 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2389
Coding: 0001077
VCID: 36352D10944602CB4DD-8062
00109 - Left Mirror Turn Signal Lamp (L131)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 33331404873417E36A3-8066
00750 - Warning Lamp
Mileage: 1440 km
Temperature: 9.0°C
Voltage: 12.40 V
Voltage: 12.20 V
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AS HW: 1K0 959 433 AS
Component: 02 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 93900688510340242404058FB0080A0480A440
Shop #: WSC 01287 785 00200
VCID: 015F8ECC8D087573A8F-8054
Reset counter: 176
Mileage: 221203 km
Time: 03:59:39
Mileage: 221464 km
Time: 03:01:10
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001077
VCID: 372B2014934CFBC356B-8062
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1D718C2BA50DBB39-8020
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5536
Revision: -------- Serial number: VWZZZ4J6270795
Coding: 16000440040005
Shop #: WSC 00078 790 00101
VCID: 46D55DD0E8A6924BDDD-8012
12 Faults Found:
Fault Status: 00101110
Reset counter: 152
Fault Status: 00101011
Reset counter: 176
00871 - Bass Speaker Front Right (R23)
Reset counter: 176
Reset counter: 176
Reset counter: 176
00856 - Radio Antenna
Fault Status: 00111011
Reset counter: 0
00849 - S-contact at Ignition/Starter Switch (D)
Reset counter: 176
Reset counter: 136
Mileage: 221203 km
Time: 19:29:23
Mileage: 221203 km
Time: 19:29:23
Reset counter: 176
Mileage: 221203 km
Time: 03:57:00
Reset counter: 176
Mileage: 221203 km
Time: 03:56:59
Fault Status: 00110100
Reset counter: 137
Mileage: 221210 km
Time: 00:53:15
End----------(Elapsed Time: 01:08, VBatt start/end: 12.1V/12.0V)-----------
