Check Engine light appeared scanned and got 18837 - Coolant Pump for Intercooler P16BA 00 [032] - Running Dry
rich dj
C?ID=245358
No affect to the cars running but engine fault lamp showing.
Looks like it points to the Coolant Pump for Intercooler but odd about the Fan 1 Control Circuit P0691 00 [032] - Short to GND, and maybe dpf slightly clogged? usual heated mirrors died and not sure about trailer wiring as borrowed my fathers trailer!
Here is full scans
Friday,12,November,2021,17:22:24:42520
VCDS Version: 21.9.0.2 (x64)
VIN: removed   License Plate: removed
Mileage: 151540km-94162mi   Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 69 6D
          72 AC
VIN: removed   Mileage: 151540km-94162miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 BM    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8508
   Revision: 85H23---    CVN: 2D79C64AC19C777138D3FF82
   Coding: 12254012243601080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906021BM 002008
   ROD: EV_ECM20TDI01104L906021BG_002.rod
   VCID: 71EE7418A00F0201BE-8024
   VINID: 9D196AAAA21B2164411C30090C37C41E0E
7140 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
4531 - Fan 1 Control Circuit
19226 - Particulate Trap Bank 1
          P2002 00 [236] - Efficiency Below Threshold
                    Fault Frequency: 24
                    Mileage: 147588 km
                    Date: 2021.09.28
                    Time: 16:12:55
                    Engine RPM: 1495.00 /min
                    Normed load value: 48.6 %
                    Vehicle speed: 75 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 76 °C
                    Voltage terminal 30: 14.540 V
                    Exhaust mass flow of low-pressure EGR: calculated: 3.054
                    Differential pressure ratio: low-pressure EGR: 20.5 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 33.6 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 33.5 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 75.35 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 37.66 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 32.3 hPa
Readiness: 1 1 0 0 0
   Part No SW: 8K9 927 156 B    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H03 0004
   Revision: --H03---    CVN: 000066E0
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001016
   ROD: EV_TCMDL501021.rod
   VCID: 3C70952CB7CDBF695D-8068
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 44DDC401
   VCID: 091E3CF8A09F5AC116-805C
   Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
   Component: BCM2 2.0      H15 0711
   Coding: 01B24040000000000000
   VCID: 7F0AA220EE5B647138-802A
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0815000094819001
   Serial number: 3215000133495008
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 BB    HW: 8K2 820 043 BB
   Revision: D1000000    Serial number: 01120820151921
   Coding: 342400A000
   VCID: 6ADC637485D9F1D9FF-803E
   Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 DD
   Revision: 04016001    Serial number: 00001132556402
   Coding: 290000308034A7C00081000300001F1F001D660827080201000008004000030000000024000000
   VCID: 74E07D0CD71D372955-8020
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 170815  H06 0080
   Serial number: SWF15088175065
   Coding: 00FD11
   Serial number: 20517247
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000003107151843
   Serial number: 62080FB7000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003KFDD15LBG
   Coding: 30534435363030303030554A3052384B3053
   VCID: 4898F9FCF315E3C9C9-801C
   Serial number: 6334MSME537B6F24Q
   Serial number: 6344MSME537B541CM
   Serial number: 6352QSME4D580E7E%
   Serial number: 6362QSME584E4944U
   Serial number: 63732SME16525660U
   Serial number: 63832SME25520C74.
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OHJ000MH
   Coding: 000017
   VCID: 4898F9FCFB15E3C9C9-801C
   Part No SW: 8K0 920 983 G    HW: 8K0 920 983 G
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 61+7ADW7G
   Coding: 33A6110003012600010000
   VCID: 397E8C38B0FF8A4146-806C
   Part No SW: 8R0 907 468 T    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0070
   Revision: 1Y090032    Serial number: 3241Y157160A38
   Coding: 80CF07FF00
   VCID: 50A8D19C03452B0991-8004
   Serial number: 2890887303
   Serial number: 15218000502011200181
   Component: TSG FA        H02 0511
   Revision:             Serial number: 0000161717685
   Coding: 011002205C01410001
   VCID: 4FAAD2E01E7B34F188-801A
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0003001771
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3E749F24A1D1AD7973-806A
   Revision: 00002001    Serial number: 0377229696
   Coding: 013B0622A0B930808320023680000047
   Component: TSG BF        H02 0511
   Revision:             Serial number: 0000161125302
   Coding: 011002205E01410001
   VCID: 4E94CFE419713DF983-801A
                    Fault Status: 01101100
                    Reset counter: 70
                    Mileage: 129724 km
                    Date: 2020.12.08
                    Time: 16:45:58
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000664358
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7C9334BDF981594F-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109HX0F8061261
   Coding: 010103020100000001
   VCID: 2B52A6704AA328D1C4-807E
02246 - Loudspeaker; Center
                    Reset counter: 31
                    Mileage: 129723 km
                    Date: 2020.11.30
                    Time: 15:50:09
                    Voltage: 13.30 V
03029 - Subwoofer (R157)
                    Fault Status: 00101011
                    Reset counter: 98
                    Voltage: 12.20 V
   Part No SW: 8R2 035 666 J    HW: 8R2 035 666 H
   Component: H-BN-EU       H49 0941
   Revision: --------    Serial number: 515H90F7548099
   Coding: 0F0101010006A1ED0180AB5E00000403E40000020000000000
   VCID: 4088E1DCD325DB8901-8014
   Subsystem 1 - Part No: 8R0 060 884 CR
   Component: EUR 2015  2102
   Component: DU7 High  H42 0104
   Serial number: A130H 0F3436838
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002339621
   Component: CD-Database  6208
02244 - Button in Control Head is Stuck
                    Fault Frequency: 38
                    Reset counter: 109
                    Mileage: 150764 km
                    Date: 2021.11.05
                    Time: 00:07:09
                    Voltage: 12.60 V
                    Hex Value: 0x0005
                        not available
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000162795327
   Coding: 010002204001210001
   VCID: 4684F7C4F101F5B93B-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H12 0100
   Revision: 1A001001    Serial number: 00000376611173
   Coding: 010D000000000000
   Shop #: WSC 25381 000 00000
   VCID: 3664870481E16539AB-8062
02562 - Trailer; Brake Lamps
                    Fault Status: 11101010
                    Reset counter: 189
                    Mileage: 135343 km
                    Date: 2021.04.02
                    Time: 18:26:14
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E749F24A9D1AD7973-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H56 0330
   Serial number: 8K9827852C
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000162795325
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 151970548
   ROD: EV_RDCMA00100.rod
   VCID: 2F6AB26076BB54F1E8-807A
End-------------------------(Elapsed Time: 03:50)--------------------------
Your ECU may not be willing to do any DPF regeneration while cooling system faults, although they are all "Intermittent - Not Confirmed", so I'm not sure how much confidence I have in them.
Those coolant pumps are ridiculously unreliable but I can’t help further because you removed the VIN which is what technicians on here use to pinpoint what the car is, it is not personal data like the reg.
rich dj
C?ID=245358
Sorry I haddnt realised that about the VIN, Thanks for the quick responce.
I assume I will just replace the coolant pump as bound to show again, the car is 2015 A4 Avant 2.0 TDI 190bhp Quattro DSG 7 speed Euro 6
I have cleared the DTC's and started engine and the check engine light has dispeared but i only ran it for a few mins. I will take it for a drive tomorrow.
here is the scan after the DTC's cleared with the VIN number attached this time.
So Just the door mirror heaters showing fault and the centre speaker is removed as replacement mid range and tweeters fitted to the dash speakers on the side.
Saturday,13,November,2021,13:52:00:42520
VIN: WAUZZZ8K8FA173093   License Plate:
          72 AC
VIN: WAUZZZ8K8FA173093   Mileage: 151540km-94162miles
   Coding: 44DDC401
   Coding: 342400A000
   Coding: 00FD11
   Coding: 02005D
   Coding: 000017
   Coding: 80CF07FF00
                    Reset counter: 70
                    Mileage: 151542 km
                    Date: 2021.11.13
                    Time: 13:46:47
                    Reset counter: 70
                    Mileage: 151542 km
                    Date: 2021.11.13
                    Time: 13:46:18
                    Voltage: 11.90 V
End-------------------------(Elapsed Time: 03:57)--------------------------
rich dj
C?ID=245358
I have just found this which appears to over the internet.
Audi Recall Is this just for the 2.0 TSi ENGINES? OR 2.0 TDi aswell?
"Several reasons to address coolant pump issues
There are several reasons that the coolant pump issues have to be addressed. The most pressing, of course, is the fact that if you were to leave this issue alone, it is possible that various Audi models might become toast.
Not as obvious, though, is the need for a working coolant pump to ensure that the heater/air conditioner system is working correctly. The coolant pump pushes coolant past the heater core, heating the liquid inside, causing the heater to work correctly. On the cooling side, the coolant pump ensures that the liquid inside cycles through the compressor so that the liquid cycles past the cooling system radiator. This ensures that heat is pulled from the radiator and the liquid going out is cooled so the system works.
Of the 1.16 million vehicles worldwide that have been recalled for the second time to address issues dealing with the coolant pump, 342,867 units are in the U.S. automotive fleet. They include 2013-17 Audi A4 sedans and Allroads, 2013- 17 A5 coupes and cabriolets, 2012-5 A6 and 2013-17 Q5 crossovers, equipped with the automaker’s 2.0-liter turbo four.
Audi pump recall handles must-fix issues
According to Audi, there are two problems that must be addressed:
The first is the potential for vehicle fires if debris gets lodged inside the pump, causing it to short out. The second, which also can cause short-circuiting, is caused by moisture within the pump.
To fix the problems, dealers will install an upgraded pump that features pressure compensation. The pressure compensation is achieved through an element that prevents moisture buildup. And, there is also an update for the engine control module software."
The mechanical belt driven pump on your engine has been revised three times with it initially having the first revision but it must have had the second revision now during the cam belt change it had in September at Bury St Edmonds Audi but the fault code relates to the electric water pump for the intercooler which has also been revised to part number 4H0 965 569 A and these are £281.63 but they are available aftermarket with the OE brand Pierburg being my preferred choice
Something that caught me out the first time I saw that code was the pump not being faulty but suffering cavitation due to the second electric pump used for heater support delivery on stop start vehicles and the fault code suggests this may be the case here.
rich dj
C?ID=245358
So the Check engine light reapeared after a couple of hundred miles
19226 - Particulate Trap Bank 1 showed again.
Friday,19,November,2021,13:05:33:42520
www.Ross-Tech.com|+++++++++++++++++
Mileage: 151940km-94411mi   Repair Order:
          72 AC
VIN: WAUZZZ8K8FA173093   Mileage: 151940km-94411miles
          P2002 00 [237] - Efficiency Below Threshold
                    Mileage: 151662 km
                    Date: 2021.11.16
                    Time: 16:17:41
                    Engine RPM: 1950.00 /min
                    Normed load value: 63.5 %
                    Vehicle speed: 77 km/h
                    Coolant temperature: 66 °C
                    Intake air temperature: 68 °C
                    Exhaust mass flow of low-pressure EGR: calculated: 3.012
                    Differential pressure ratio: low-pressure EGR: 38.4 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 47.2 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 47.5 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 59.44 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 66.38 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 46.5 hPa
The DPF needs cleaning
rich dj
C?ID=245358
Thanks for the reply Crasher can I do it using VCDS Diesel Particle Filter Emergency Regeneration?
Can I do this while driving I have an hours journey to do in 1 hit tonight. 15 mins B roads and 45 mins Dual carageway.
I looked at this article on the Ross-tech.com site
Emergency Regenaration
My son will be with me to keep an eye on the Measuring Data. I will need to do a scan to see what engine type CAN or UDS
2.0l R4 CR-TDI (CAN) or 2.0l R4 & 3.0l V6 CR-TDI (UDS) unless you know which one.
P2002 - Efficiency Below Threshold is generally not indicative of needing regeneration.
I would be checking the readings from the pressure sensors first.
You will have to check the soot loading percentage, above a certain amount (usually 40%) it will not allow a regen and if it is cheated the car can catch fire.
rich dj
C?ID=245358
I’ve just driven home and the car has done a regen from 19.39g soot mass calc and after regen it went to 5.22g so it’s doing a regen of its own accord I didn’t tell it to. I used an android app called VAG… to watch this (well the passenger did)
was going to check figures lunchtime but to busy at work. So will try to measure the reading from pressure sensors.
Is it the differential sensors I noticed 2 back to back near the oil filler
Part number 030 906 051B.
Yes yours has the dual pressure sensor system
rich dj
C?ID=245358
Here is what I’ve found I took readings at IGN on, Idle and 2500 revs
Ignition onIdle2500 RPM
Loc.DescriptionActualActualActual
IDE00021Engine RPM0 /min830 /min2501 /min
IDE00432Particle filter: time since last regeneration380 S391 s414 s
IDE00433Particle filter: oil ash volume0.11 |0.11 |0.111
IDE00434Particle filter: soot mass calculated5.27 g5.27 g5.27 g
IDE00435Particle filter: soot mass measured-5.27 g-5 27 g-5.18 g
IDE00436Particle filter: kilometers since last regeneration3082 m3082 m3082 m
IDE07084Differential pressure ratio: low-pressure EGR0.0 kg/h11.6 kg/h37.2 kg/h
IDE07745Particl.filt.: different.press.sensor 1 bank 1: adaptat. value2 hPa11 hPa32 hPa
IDE07746Particl.filt.: differential press.sens.1 bank 1: uncnd voltage1006.6 mV1073 6 mV1269.2 mV
IDE07750Exhaust recirculat.2: different.press sens.1 bank 1: raw value3.3 hPa15.8 hPa54.7 hPa
IDE07751Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value2.5 hPa15 0 hPa54.0 hPa
IDE07752Exh.recirculat.2: different. press.sensor 1 bank 1: uncnd.volt.1011 0 mV1054 4 mV1190.6 mV
the last time the DTC Code shown was still on the 16th Nov last Thursday its driven 100 plus miles since then.
I have cleared the DTC. Let me know what you think of the numbers.
DGMotors
C?ID=57532
EGR cooler ????
rich dj
C?ID=245358
I put some DPF cleaner though it in the fuel about half a tank full of diesel got it nice and hot a few times and now on another tank of fuel so driven about 500 miles and no check engine light so far. At 94000 miles and EGR cooler has never been replaced. After lots of trawling the net it seems Lickly. It doesn’t do many town miles mainly open road.
rich dj
C?ID=245358
So it reared it head again after 1162miles
Tuesday,14,December,2021,16:59:19:42520
Mileage: 154100km-95573mi   Repair Order:
          72 AC
VIN: WAUZZZ8K8FA173093   Mileage: 154100km-95753miles
          P2002 00 [232] - Efficiency Below Threshold
                    Fault Frequency: 12
                    Mileage: 152193 km
                    Date: 2021.11.24
                    Time: 16:15:29
                    Engine RPM: 1685.00 /min
                    Normed load value: 52.2 %
                    Vehicle speed: 50 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 80 °C
                    Voltage terminal 30: 14.620 V
                    Exhaust mass flow of low-pressure EGR: calculated: 3.044
                    Differential pressure ratio: low-pressure EGR: 26.2 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 23.3 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 24.7 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 61.00 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 42.49 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 20.3 hPa
   Coding: 44DDC401
   Coding: 342400A000
   Coding: 00FD11
   Coding: 02005D
   Coding: 000017
   Coding: 80CF07FF00
                    Fault Frequency: 19
                    Reset counter: 80
                    Mileage: 151542 km
                    Date: 2021.11.13
                    Time: 13:46:47
                    Reset counter: 70
                    Mileage: 151542 km
                    Date: 2021.11.13
                    Time: 13:46:18
                    Voltage: 11.90 V
                    Reset counter: 156
                    Mileage: 152837 km
                    Date: 2021.11.30
                    Time: 16:45:15
                    Voltage: 12.40 V
                    Reset counter: 177
                    Mileage: 153878 km
                    Date: 2021.12.10
                    Time: 16:50:56
                    Voltage: 13.50 V
                    Hex Value: 0x0005
                        not available
End-------------------------(Elapsed Time: 04:15)--------------------------
JMR
Romania
C?ID=432218
STOP putting all kinds of shite in your fuel. The car should regenerate fine on it's own diesel without crappy additives and stuff like that. All you do is killing that DPF. I would change the Differential sensor , re adapt and see if the problems reappear. Usually the below threshold efficiency appears when you drive mostly town. Verify hoses from dpf pressure sensor, might be cracked /broken
Take the DPF off and send it to DPF Clean Team in Hinckley.
