Golf MK7 Xenon no high beam headlamps
elektrocars
C?ID=447038
I can't activate the hig beam lights, I tried to do coding, adaptations etc ..
What type of lamps do I have? 8IG/8IM ???
shuter is controlled by can
HW : 7P6907357A
Wariant modulu:H07,ID Kontrolera:0008,Nr.kolejny:10070
LogicalBlock[0] : ProgrammingDate: 00.00.00 TesterID: [0,0,0] Status: 00
LogicalBlock[1] : ProgrammingDate: 00.00.00 TesterID: [0,0,0] Status: 00
==== ODX INFO ====
Serial: -------------- ODX ID: EV_HeadlRegulVWAFSMQB ODX Version: 001120
==== SLAVE INFO ====
3D0941329E LeiMo links Coding: 2E0000
3D0941329E LeiMo rechts Coding: 2E0000
I don't know what the coding should be for CAN controls the shutter .
which means lamp 8IG/8IM/8IP = 5G1 941 034 E?
elektrocars
C?ID=447038
Saturday,31,July,2021,15:42:00:46054
VCDS Version: 21.3.0.0 (x64)  HEX-NET2 CB: 0.4544.4
VIN: WVWWF7AU9HW119340   License Plate:
Mileage: 59786km-37149mi   Repair Order: Golf MK7 R
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52 55
          5F A5 A9
VIN: WVWWF7AU9HW119340   Mileage: 59786km-37149miles
3C-Lane Change -- Status: Cannot be reached 0100
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091900122446000E3004
   Shop #: WSC 00070 000 00000
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001005
   ROD: EV_ECM20TFS0208V0906259K.rod
   VCID: 48C2314D7238C52B073-801C
17186 - Databus
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:37:37
                    Engine RPM: 0.00 /min
                    Coolant temperature: 23 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.636 V
                    ACC variants (coding): ACC
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Status: OK
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: operated
                    Cruise control switch actuation-Coding: plausible
                    Cruise control switch actuation-Limit function: not selected
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: operated
                    Cruise control switch actuation-Large increment: Not operated
                    Cruise control switch actuation-Control component verified: Yes
                    ACC variants: ACC
                    Engine: operating status: ES
18876 - Cruise Control Switch (E45)
          P0568 00 [039] - Implausible Signal
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:47
                    CCS Switch: ACC operating unit
                    Cruise control switch actuation-Main switch CAN: Not operated
                    ACC variants: ACC
19853 - Implausible Data Received from Steering Column Control Module
          U0429 00 [039] - -
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:48
                    Voltage terminal 30: 12.656 V
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 22.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 20 min
                    T_AST_SAE: 0 s
15274 - Evap System Leak Detection or Fuel Vapor Temp Sensor
          P2026 00 [039] - Signal too Low
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:48
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 100 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 16.015625 %
                    FUP_H_SAE: 840.0 kPa
Readiness: 1110 0101
   Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
   Component: ESC           H62 0636
   Revision: 00000000    Serial number: 63006000002949
   Coding: 01FA6BA154211175457A030441C36980D62A88A2C0829637144050D4C0A803
   Shop #: WSC 00046 000 00000
   ROD: EV_Brake1UDSContiMK100IPB_035.rod
   VCID: 7AA69B857C5467BBC17-802E
8362 - Databus
          [FCAN: RCTA_01 is not received]
                    Reset counter: 102
                    Date: 2018.12.08
                    Time: 20:36:47
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0420640823
   Coding: 032C0C
   VCID: 3B285E8133EE9EB39A1-806E
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   080 Z052
   Revision: 00001K07
   Coding: 00020014200100011105000000101000
   VCID: 73B8B6A15B3E16F3821-8026
   Air quality sensor:
459018 - Databus
          [Steuergerät für Schiebe/Aufstelldach - kein Signal/Kommunikation]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:45
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061629700462
   Coding: 00010B46C04132F369E44000091C07201800000000000000000000000000
   Shop #: WSC 12345 123 12345
   ROD: EV_BCMBOSCH_015.rod
   VCID: 045AE57D0E90214BABB-8050
   Wiper motor control module:
   Component: WWS    160602  043 0551
   Serial number:         160613030936
   Component: RLHS  042 0105
   Serial number: S2Y16M03D14H20M41S13
   Coding: 00A8EE
9738 - Bulb for Left Parking Lamp
          B12E8 15 [009] - Open or Short to Plus
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:45
18954 - Left LED Module for DRL and Parking Lights
          B12EC F5 [009] - Control Circuit Open or Short to Plus
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:45
19466 - Right LED Module for DRL and Parking Lights
          B12ED F5 [009] - Control Circuit Open or Short to Plus
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:45
563221 - Databus
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:45
568836 - Databus
          [LWR AFS - Kein Signal/Kommunikation]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:45
   Revision: --------    Serial number: 39391532902704
   Coding: 0011051011
   Shop #: WSC 00028 028 00023
   VCID: 43D826614B1EE673D21-8016
12648721 - Databus
          [Getriebesteuergerät - Getriebe_11 - kein Signal/keine Kommunikation]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:46
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 2D0000C151FFC428949C8045000016
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
7 Faults Found:
0101 - Databus
          [FAULT_GRA_CODE]
                    Reset counter: 142
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:37:38
                    Control Module temperature: 50 °C
                    Voltage terminal 15: 12.5 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
2165 - Steering Column Control Module
          B105D 00 [009] - -
          [FAULT_GRA_TYPE_MISMATCH]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:47
2060 - Databus
          [FAULT_INFO_CONSTANT_CONTROL_UNIT_TYPE]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:47
2062 - Databus
          [FAULT_MAINSWITCH_FAIL]
                    Fault Frequency: 6
                    Reset counter: 142
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:37:36
2127 - Databus
          [FAULT_OP_FAIL]
                    Reset counter: 142
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:37:38
2074 - Databus
          [FAULT_SEATBELT_NOT_EQUIPPED]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:47
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:47
   Serial number: 29091641350037
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3822418D02D8B5AB773-806C
   Component: AirbagVW20    010 0388
   Serial number: 003GCR06EWVC
   VCID: 47C032717F26CA530E9-8012
   Subsystem 1 - Part No SW: -----------    HW: -----------
   Component: BF-Gewichtss.  --- ----
   Serial number: ---0000---000-----09
   Subsystem 2 - Part No SW: -----------    HW: 480 001 910 16
   Serial number: 357670000009A8201F1V
   Subsystem 3 - Part No SW: -----------    HW: 480 002 610 16
   Serial number: 35867000000546F8DE19
   Subsystem 4 - Part No SW: -----------    HW: 480 401 410 16
   Serial number: 3516502C5229A291A266
   Subsystem 5 - Part No SW: -----------    HW: 480 402 010 16
   Serial number: 3526502A3234FA315384
   Subsystem 6 - Part No SW: -----------    HW: 480 401 810 16
   Serial number: 3556502AD234FA33A08L
21 Faults Found:
9440539 - Driver's Safety Belt Tensioner Igniter 2
          B100D 1B [137] - Resistance Too High
                    Fault Priority: 15
                    Mileage: 59786 km
                    Date: 2018.10.20
                    Time: 01:38:32
9437979 - Igniter 2  for Passenger's Airbag
          B1003 1B [137] - Resistance Too High
                    Fault Priority: 15
                    Mileage: 59786 km
                    Date: 2018.10.20
                    Time: 01:38:32
9441051 - Front passenger's safety belt tensioner igniter 2
          B100F 1B [137] - Resistance Too High
                    Fault Priority: 15
                    Mileage: 59786 km
                    Date: 2018.10.20
                    Time: 01:38:32
9445121 - Passenger's seat position sensor
          B101F 01 [137] - Electrical Failure
                    Mileage: 59786 km
                    Date: 2018.10.20
                    Time: 01:38:33
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [129] - Open or Short to Ground
10487296 - Control Module Does Not Match Vehicle
          B2006 00 [129] - -
          [ECU does not fit to vehicle configuration]
13636352 - Control module not coded
          U1013 00 [137] - -
          [Electronic Control Unit uncoded]
9444117 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [129] - Open or Short to Plus
10490368 - Data Set Implausible
          B2012 00 [129] - -
          [Dataset not plausible]
9634820 - Control Module for Front Left Belt Tensioner
          B1304 04 [137] - Internal System Fault
                    Mileage: 59786 km
                    Date: 2018.10.20
                    Time: 01:38:33
10485760 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
          [Electronic Control Unit Malfunction]
16712487 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
16712491 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
16712493 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
16712495 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
16712496 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
16712498 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
16712566 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
16712585 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
16712588 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
16712590 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
   Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 12071604400401
   Coding: A408
   Shop #: WSC 06314 790 00021
   VCID: 0154EC691182346380D-8054
229131 - Cruise Control Switch
          B1154 13 [009] - Open Circuit
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:45
                    Operating time: 83007 min
                    Terminal 30 power supply: 12.8 V
                    Voltage at switch: 4.98 V
                    Terminal 15 status: active
                    System status: 30
                    FF U GRA Plus Minus AD value: 254
                    FF U GRA Resume Cancel AD value: 254
                    FF U GRA Main Switch AD value: 141
                    FF U GRA Set AD value: 254
                    FF U GRA ACC AD value: 254
229195 - Cruise Control Switch
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:45
                    System status: 30
   Part No SW: 5G1 920 858 B    HW: 5G1 920 858 B
   Component: KOMBI         302 8300
   Coding: 0BAD08127F88CF0502886B0B5400000000000000
   Shop #: WSC 17483 796 00000
   VCID: 2F307AD1F7967213269-807A
16777008 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_SWA_0x1A keine Kommunikation]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:48
16776982 - Databus
          [SWA_01 keine Kommunikation]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:45
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 15041610802517
   Coding: 0101000838085900FB00023A880F00000001050000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 79A4848979526CA3C8D-802C
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29160001854400056392
   Coding: 34FFFF
131662 - Lane change assistant control module
          U1045 00 [009] - No communication
          [Timeout Knoten 0x4E / 3C - Steuergerät für Spurwechselassistent]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:46
                    Terminal 30 power supply: 12.6 V
                    Terminal 15: On
67072 - Local Databus
          U1125 00 [009] - Additional Installations Detected
          [Subsystem Mehrverbau erkannt]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:46
                    Terminal 15: On
0769 - Analog Measuring Input
          C1155 31 [009] - No Signal
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:46
                    Terminal 15: On
   Serial number: HA1-00015.09.16
   Coding: 0001
   VCID: 4AC60B456C34373B117-801E
   Revision: 00000000    Serial number: 16000177164003
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 343A75BD1EB051CB5BB-8060
Address 3C: Lane Change
   Serial number: 081016EJ819663
   Coding: 003E13208000040000000000
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000011989784
   Coding: 111000
65799 - Door Warning / Entry Lighting
          B1775 01 [009] - Electrical Failure
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:45
   Coding: 9102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A265B853CD4A7BB817-806E
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC401CGSE
   Coding: 120000008AAA8A0000
   Shop #: WSC 00028 028 00066
   ASAM Dataset: EV_AMPMst12C1ALPI 001005
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 6398C6E1EBDE8673F21-8036
0560 - Front Right Treble Speaker
          B1064 13 [143] - Open Circuit
          [Hochtonlautsprecher Kanal 7: Unterbrechung (AC-Diagnose)]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:47
0512 - Rear Right Treble Speaker
          B1068 13 [143] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:47
0517 - Rear Left Treble Speaker
          B1066 13 [143] - Open Circuit
          [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:47
0585 - Front Left Treble Speaker
          B1061 13 [143] - Open Circuit
          [Hochtonlautsprecher Kanal 12: Unterbrechung (AC-Diagnose)]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:47
   Serial number: 151016EJF02572
   Coding: 003E13208000040000800000
   VCID: 42D623655404EF7BD97-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000011974956
   Coding: 091000
   Coding: 022202000B000400
   VCID: 40D2296D5A08FD6BCF3-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 2E0000
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0757
   Coding: 027300010000000051110002001808009F0207F401200105C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323673A5E4A45FFB497-8066
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H52 1028
   Serial number: VWZ8Z9RFC009AS
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:50
                    Voltage terminal 30: 12.6 V
                    BAP-BAP_Function_ID: 02
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:49
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:49
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 12101611P12786
   Coding: 0003070000000201002213548040490084000E100020
1122649 - Databus
          [Timeout_SWA_01]
                    Reset counter: 102
                    Mileage: 59786 km
                    Date: 2018.12.08
                    Time: 20:36:46
                    Control Module temperature: 41 °C
                    Outside temperature: 24.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 415.8 s
                    mid: 02 0B
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 160126202071
End----------(Elapsed Time: 02:00, VBatt start/end: 12.8V/12.8V)-----------
DV52
C?ID=194404
@elektrocars: thanks for the auto-scan. Please tell us more of the back story for the car. Maybe describe how the car was factory built in respect of the original headlight fittings.
Since you have posted in the retrofit part of the forum, it's not unreasonable for readers to assume that some (all?) of the equipment in your pictures was not original to the car. This begs the bigger question as to what (if any) modifications were made to the factory wiring loom to accommodate the new gear.
The reason why it's important for readers to understand this matter is because the way that the BCM controls the exterior lamps (i.e via "Leuchte-sets") is specific to individual pins on the module housing connector. This means that if your car was not factory fitted with shutter type headlights, there won't be shutter wires in the original loom from the car-end of the headlight connector to the BCM
If this is so (i.e. if the car was factory fitted with halogen headlights-say), it's necessary to understand how the shutter pins on the new headlight fittings were connected to the BCM in the retrofit exercise. How was this done?
elektrocars
C?ID=447038
The car was broken. came without lamps. I don't know what the original lamps should be. These new lamps don't have pin 11 installed.
DV52
C?ID=194404
@elektrocars: hmm....... OK, then the retrofit is non-standard (by definition - not OEM), which makes it difficult to remotely diagnose!
The answer to my question - about how the car was factory fitted with headlights can usually be answered by looking at the car-side headlight connector. Normally, this connector has 10 x pins if incandescent fittings were factory installed on the car and it has 14 x pins if non-incandescent fittings were installed
But regardless of how many pins are on the car-side connector, the fact that pin #11 on the headlight-side of the connector is vacant is problematic. Clearly the new fittings are non OEM - maybe contact the seller and ask which pin on their product is the shutter-pin? Once you have this answer, trace the wiring on the mating car-side of the connector and tell me the pin number. We can then decide which Leuchte-set on the BCM to energise!!
how the car was factory fitted with headlights can usually be answered by by looking at the car-side headlight connector
... or checking a proper parts catalog by VIN. ;)
elektrocars
C?ID=447038
I am looking for a scan of the adaptation and coding of the 09 module for Golf 7 R, bixenon lamps with a shutter controlled via Can
In module 55 made basic settings. Direction indicator, low beam, positions everything works, only Hig beam not work
DV52
C?ID=194404
@elektrocars : hmm........ OK, maybe it's my thick Aussie accent that's confusing the situation - if so, then you have my most sincere apology!
l'll try one more time: although launching into solution mode might appear to be an easy fix to your problem , it's of no use at all without having first undertaken the necessary diagnostic investigation (IMHO, of course).
As I have said before, the BCM on MQB platform cars manages the 35 x exterior lights on your mk7 in a very particular way- meaning that lamp management depends on which lamp is connected to which pin on the BCM connector - and this varies with the lighting equipment options that are installed at the factory. This is a key point in the resolution of your problem (again, IMO). I hope that you understand!
For example:
  • on factory fitted incandescent headlight cars for RoW model mk7s, the main-beam lamps are connected to:
    • BCM pin #39, Socket B - Left side
    • BCM pin #2, Socket B - Right side
  • on factory fitted non-incandescent (i.e. HID/LED) headlight cars for RoW model mk7s, the shutters are connected to:
    • BCM pin #23. Socket B - Left- side
    • BCM pin #22, Socket B - Right side
Hopefully, the information above explains that if your car was factory built with incandescent main-beam lights, the "shutter" pins will NOT have wires terminated on pin #22 & #23 Socket B of the BCM connector - and therefore, it's pointless using the adaptation channels from a car that is factory fitted with HID/LED headlights.
In the alternative that your car was actually factory fitted with HID/LED headlights, the fact that pin#11 on your non-OEM new headlights is missing (as you have said) means again that it's pointless using the adaptation channels from a car that is fitted with OEM HID/LED headlights. This is because the factory shutter pins on the BCM on your car are NOT connected to the shutter pins on your new non-OEM headlight fittings.
So please, I ask again with a degree of increasing frustration:
Or,
