2007 Audi A6 saloon. Have a problem with the ac, have changed the pressure sensor and the air quality sensor, still no ac and still sowing pressure sensor and air quality sensor not functioning. Please help
Les
Les
Please post an Auto-Scan for context.
Thursday,22,July,2021,10:08:53:64473
VCDS Version: 21.3.0.0 (x64)
VIN: WAUZZZ4F37N141543 License Plate: LRO7UCZ
Mileage: 242150km-150465mi Repair Order: july21
Gateway Installation List: 4F0 910 468 A
The above is not an Auto-Scan, just the Gateway Installation List (summary).I have changed the two sensors and still no joy
Monday,02,August,2021,14:15:29:64473
VIN: WAUZZZ4F37N141543 License Plate: LR07UCZ
Mileage: 242160km-150471mi Repair Order: AUG2021/2
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53 56
61 62 72
VIN: WAUZZZ4F37N141543 Mileage: 242160km-150471miles
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 HS HW: 03G 906 016 HS
Component: R4 2,0L EDC G000SG 9673
Revision: --H05--- Serial number:
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 7BF3BF023A1EB95396-802E
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Mileage: 242164 km
Date: 2021.07.29
Time: 13:44:48
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00101000
Temperature: 16.2°C
(no units): 16.0
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Coding: 0020855
Shop #: WSC 02325 785 00200
VCID: 65C7F97AAC9A1FA350-8030
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100714934
Coding: 0000017
Shop #: WSC 00460 210 83628
VCID: 63C3E762A2AE6193BE-8036
Subsystem 1 - Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 R HW: 4E0 035 729
Component: Interfacebox H43 3450
Revision: 00000000 Serial number: 350CY077768952
VCID: 316F5D2AA8D283037C-8064
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000698796
Subsystem 3 - Serial number: 0113.03.070000000100011806ÿ
Subsystem 4 - Serial number: 011806ÿ
00003 - Control Module
Fault Status: 01100101
Reset counter: 104
Mileage: 242164 km
Date: 2021.08.02
Time: 14:08:45
Part No SW: 4F0 910 043 A HW: 4F2 820 043 P
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000000371079
Coding: 0001044
VCID: 1C319C9EDF501E6B3F-8048
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 103
Mileage: 242164 km
Date: 2021.07.29
Time: 13:52:17
Temperature: 20.0°C
00256 - A/C Pressure/Temperature Sensor (G395)
Reset counter: 103
Mileage: 242164 km
Date: 2021.07.29
Time: 13:52:17
Part No SW: 4F0 910 279 L HW: 4F0 907 279 B
Component: ILM Fahrer H17 0240
Coding: 0000101
Shop #: WSC 02335 785 00200
VCID: 326D5226ADD4B81B05-8066
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Reset counter: 104
Mileage: 242164 km
Date: 2021.07.29
Time: 13:47:00
Reset counter: 104
Mileage: 242164 km
Date: 2021.07.29
Time: 13:47:00
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 HW: 4E0 035 785
Component: SG ext.Player H09 0170
Revision: 00000000
VCID: 65C7F97A6C9A1FA350-8030
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0PGD7J
Coding: 0013381
VCID: 295FB54A8002FBC3B4-807C
Subsystem 1 - Serial number: 6332CSME16765A3CB
Subsystem 2 - Serial number: 6342CSME171C715FB
Subsystem 3 - Serial number: 6352QSME1A710B3BL
Subsystem 4 - Serial number: 6362QSME276121298
Subsystem 5 - Serial number: 63734SME222E4C3DA
Subsystem 6 - Serial number: 63834SME22234B13U
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90055070690285
Coding: 0102041
Shop #: WSC 02323 785 00200
VCID: 66C5FE76519C14BB59-8032
Component: Lenkradmodul H07 0090
Part No SW: 4F0 910 930 C HW: 4F0 920 981 F
Component: KOMBIINSTR. M73 H20 0170
Revision: 00200000 Serial number: 5HS38K637
Coding: 2308448
Shop #: WSC 00000 067 57207
VCID: 2343A762E22E2193FE-8076
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300807303022A
Coding: 6CEE53C43B2104
VCID: 275BB3729616CDB3A2-8072
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H44 0350
Revision: 00044000 Serial number: AUZ5ZBG3193915
VCID: 1839808E2B68724B1B-804C
Part No SW: 4E0 910 888 P HW: 4E0 919 887 L
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: 364C+077649389
Shop #: WSC 00460 210 103256
VCID: 3B737F027A9E7953D6-806E
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00-00000
Coding: 0002586
Shop #: WSC 02327 785 00200
VCID: 2C514C5E8FF0EEEB4F-8078
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01037197630000
Coding: 0000251
Shop #: WSC 00586 210 81414
VCID: 2E554656B9EC9CFB61-807A
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 H HW: 4F0 035 223 K
Component: Amp.-ASK-RD H07 0130
Revision: 08S00000
Coding: 030000
Shop #: WSC 02399 823 56573
VCID: 2343A762222E2193FE-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000411807
Coding: 0001104
VCID: 5EB5D69689CC4C7B91-800A
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0002586
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000111
Shop #: WSC 00000 785 00200
VCID: 2049A86EF3383A8BE3-8074
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394C 077749814
Coding: 0000001
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000034695
Shop #: WSC 00051 210 67755
Component: von VA0 2703111163
Coding: 344630393135313035442056413032373033313131313633
Shop #: WSC 00000 384 00290
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0002050
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0002050
End-------------------------(Elapsed Time: 02:18)--------------------------
