A/C Problems
leztek
C?ID=182362
2007 Audi A6 saloon. Have a problem with the ac, have changed the pressure sensor and the air quality sensor, still no ac and still sowing pressure sensor and air quality sensor not functioning. Please help
Les
leztek
C?ID=182362
Thursday,22,July,2021,10:08:53:64473
VCDS Version: 21.3.0.0 (x64)
VIN: WAUZZZ4F37N141543   License Plate: LRO7UCZ
Mileage: 242150km-150465mi   Repair Order: july21
Gateway Installation List:  4F0 910 468 A
-Hi Uwe as mentioned I have changed the two sensors and still no joy
The above is not an Auto-Scan, just the Gateway Installation List (summary).
leztek
C?ID=182362
Monday,02,August,2021,14:15:29:64473
VIN: WAUZZZ4F37N141543   License Plate: LR07UCZ
Mileage: 242160km-150471mi   Repair Order: AUG2021/2
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53 56
          61 62 72
VIN: WAUZZZ4F37N141543   Mileage: 242160km-150471miles
Address 01: Engine        Labels: 03G-906-016-BLB.clb
   Part No SW: 03G 906 016 HS    HW: 03G 906 016 HS
   Component: R4 2,0L EDC G000SG  9673
   Revision: --H05---    Serial number:
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 7BF3BF023A1EB95396-802E
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -
                    Mileage: 242164 km
                    Date: 2021.07.29
                    Time: 13:44:48
                    Voltage: 12.01 V
                    Bin. Bits: 00101000
                    Temperature: 16.2°C
                    (no units): 16.0
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
   Component: ESP8 front      H01 0070
   Coding: 0020855
   Shop #: WSC 02325 785 00200
   VCID: 65C7F97AAC9A1FA350-8030
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100714934
   Coding: 0000017
   Shop #: WSC 00460 210 83628
   VCID: 63C3E762A2AE6193BE-8036
   Subsystem 1 - Part No: 4F0 910 131 D
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 731 R    HW: 4E0 035 729
   Component: Interfacebox    H43 3450
   Revision: 00000000    Serial number: 350CY077768952
   Coding: 0000002
   VCID: 316F5D2AA8D283037C-8064
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000000698796
   Subsystem 3 - Serial number: 0113.03.070000000100011806ÿ
   Subsystem 4 - Serial number: 011806ÿ
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 104
                    Mileage: 242164 km
                    Date: 2021.08.02
                    Time: 14:08:45
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 A    HW: 4F2 820 043 P
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000000371079
   Coding: 0001044
   VCID: 1C319C9EDF501E6B3F-8048
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 103
                    Mileage: 242164 km
                    Date: 2021.07.29
                    Time: 13:52:17
                    Temperature: 20.0°C
                    Reset counter: 103
                    Mileage: 242164 km
                    Date: 2021.07.29
                    Time: 13:52:17
   Part No SW: 4F0 910 279 L    HW: 4F0 907 279 B
   Component: ILM Fahrer      H17 0240
   Coding: 0000101
   Shop #: WSC 02335 785 00200
   VCID: 326D5226ADD4B81B05-8066
   Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H04 0190
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00146221
   Shop #: WSC 02335
                    Reset counter: 104
                    Mileage: 242164 km
                    Date: 2021.07.29
                    Time: 13:47:00
                    Reset counter: 104
                    Mileage: 242164 km
                    Date: 2021.07.29
                    Time: 13:47:00
Address 0E: Media Player 1 (R192)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785     HW: 4E0 035 785
   Component: SG ext.Player H09 0170
   Revision: 00000000
   VCID: 65C7F97A6C9A1FA350-8030
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4E AIRBAG AUDI8RH30 0280
   Revision: 09H30000    Serial number: 0037LD0PGD7J
   Coding: 0013381
   VCID: 295FB54A8002FBC3B4-807C
   Subsystem 1 - Serial number: 6332CSME16765A3CB
   Subsystem 2 - Serial number: 6342CSME171C715FB
   Subsystem 3 - Serial number: 6352QSME1A710B3BL
   Subsystem 4 - Serial number: 6362QSME276121298
   Subsystem 5 - Serial number: 63734SME222E4C3DA
   Subsystem 6 - Serial number: 63834SME22234B13U
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H08 0230
   Revision: 00H08000    Serial number: 90055070690285
   Coding: 0102041
   Shop #: WSC 02323 785 00200
   VCID: 66C5FE76519C14BB59-8032
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4F0 920 981 F
   Component: KOMBIINSTR. M73 H20 0170
   Revision: 00200000    Serial number: 5HS38K637
   Coding: 2308448
   Shop #: WSC 00000 067 57207
   VCID: 2343A762E22E2193FE-8076
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 1300807303022A
   Coding: 6CEE53C43B2104
   VCID: 275BB3729616CDB3A2-8072
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H44 0350
   Revision: 00044000    Serial number: AUZ5ZBG3193915
   VCID: 1839808E2B68724B1B-804C
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 L
   Component: MNS ECE         H48 1060
   Revision: 00000000    Serial number: 364C+077649389
   Shop #: WSC 00460 210 103256
   VCID: 3B737F027A9E7953D6-806E
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0120
   Revision: 00-00000
   Coding: 0002586
   Shop #: WSC 02327 785 00200
   VCID: 2C514C5E8FF0EEEB4F-8078
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01037197630000
   Coding: 0000251
   Shop #: WSC 00586 210 81414
   VCID: 2E554656B9EC9CFB61-807A
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 910 223 H    HW: 4F0 035 223 K
   Component: Amp.-ASK-RD   H07 0130
   Revision: 08S00000
   Coding: 030000
   Shop #: WSC 02399 823 56573
   VCID: 2343A762222E2193FE-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000411807
   Coding: 0001104
   VCID: 5EB5D69689CC4C7B91-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0120
   Revision: 00-00000
   Coding: 0002586
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0000111
   Shop #: WSC 00000 785 00200
   VCID: 2049A86EF3383A8BE3-8074
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394C 077749814
   Coding: 0000001
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000034695
   Shop #: WSC 00051 210 67755
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2703111163
   Coding: 344630393135313035442056413032373033313131313633
   Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0002050
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0050
   Coding: 0002050
End-------------------------(Elapsed Time: 02:18)--------------------------
Hi Uwe
Thanks for your patience, all assistance will be gratefully received.
regards
Les
The Air Quality Sensor shouldn't keep the A/C from working, but the A/C Pressure/Temperature Sensor (G395) would. If you've already replaced that sensor, first I'll ask: What was the source of the replacement? If OEM, then I think you need to get a wiring diagram and check/verify all relevant wiring and connectors.
leztek
C?ID=182362
Problem sorted there was no power to either of the sensors, traced back to the fuse number 6 if I recall correctly. Thanks again for your input.
Les
