- Dec 2, 2016
- 84
- 25
- Cardiff(ish), South Wales, UK.
- C?ID=288281
Hiya folks!
A customer of mine changed his wheels to 20" and wanted his speedo coded to suit the new wheel size.
No issue as this is an available change via the "K-Number" coding in 17 Instrument Cluster and done this many times in older Transporters and Amaroks.
Well, turns out there is an issue. You can change the coding up but not back down the sizes. In the T6.1 it's no longer called "K-Number" but "Variant" and runs numerically (1-8 or 0-8, I cant remember) and as we were checking the MM sizes in Advanced measuring, we changed it up too far and decided to revert to the last coding as it was the closest to what the customer wanted and was met with "Coding Rejected Error 22: Conditions Not correct or Request Sequence Error"
I also tried to revert the coding via ODIS online (genuine VAS6154 and legit GeKo access etc) and this also failed. So I am thinking that there is something else that needs to happen first before it will let me change the coding back.
The battery was removed to see if that rest the system to allow the coding changes but no help and thats where some of the new errors came from but since the coding changes the ACC no longer works in gears 5 & 6. I recall seeing an odd issue with one "K-Number" setting in the T5.1/T6 where the gear selection symbol in the DIS was incorrect for 5 & 6. So I am guessing this is the same issue but now as an added bonus it kicks out the ACC in those gears too. Works fine in 1-4 though.
So the question is, how to change the "Variant" coding in 17 back?
First Autoscan prior to coding changes:
Autoscan after changes:
Monday,14,June,2021,17:19:55:50827
VCDS Version: 21.3.0.0 (x64) HEX-NET CB: 0.4543.4
Dealer/Shop Name: Edited
VIN: ---VIN edited at user's request--- License Plate:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 55 5F 75 D6 D7
VIN: ---VIN edited at user's request--- Mileage: 3599km-2236miles
Address 01: Engine (J623-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 RS HW: 04L 907 445 M
Component: R4 2.0l TDI H01 9705
Revision: 23301001
Coding: 001940144344050900000000000000000000000000000000
Shop #: WSC 00035 377 00143
ASAM Dataset: EV_ECM20TDI03004L906056RS 004007
ROD: EV_ECM20TDI03004L906056LE_004.rod
VCID: 0F6E4247D69BE7F34A-805A
27277 - System Voltage
P0562 00 [032] - Too Low
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 7LB 614 517 B HW: 7LB 614 517
Component: ESC_base H01 0800
Serial number: 08500057201108
Coding: 105524524847E68B085A24AA126C6726393324B8
Shop #: WSC 00035 377 00128
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
VCID: 3FCEB287A6BB3773FA-806A
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 7LA 907 426 E HW: 7LA 907 426 E
Component: AC Manuell H01 0602
Coding: B03110000810030001000800504001050000000000011000800000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: EV_AirCondiBHTCVN54XT6PA.rod
VCID: 45C2A06FC4676DA3B0-8010
Rear A/C control head:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q5 937 090 A HW: 2Q5 937 090 A
Component: BCM T6PA Std+ H11 0943
Serial number: 00102031900349
Shop #: WSC 00035 377 00169
ASAM Dataset: EV_BCMA0 206001
ROD: EV_BCMA0_206.rod
VCID: 3522D0AF9487FD2320-8060
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: SAY20M10D30H16M07S40
Coding: 0018EE
Driver door control module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000045343844
Coding: 1F0007
Front passenger door control module:
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000044535492
Coding: 050007
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY2026511MR
Serial number: 00000000000048874482
8714 - Bulb for Left Fog Lamp
B121F 15 [009] - Open or Short to Plus
Reset counter: 92
Mileage: 1528 km
Date: 2021.04.13
Time: 12:45:02
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 14.9 V
592652 - Dimmer Switch; Driver Side
B1752 01 [008] - Electrical Failure
Reset counter: 254
Mileage: 3596 km
Date: 2021.06.14
Time: 10:03:45
Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
608520 - Unknown Error Code
B1A74 F1 [008] - Unknown Error Elaboration
[KiSi/Safe in Schiebetür HFS -> unplausibles Signal]
Reset counter: 250
Zusaetzliche Umgebungsdaten-voltage measurement: 12.7 V
1074834 - Program Monitoring
B201B 00 [008] - -
[Fensterheberelektronik Fahrer: Kontrollleuchte elektronische Kindersicherung / Laderaumschliessung (Funktions-LED) -> elektrischer Fehler]
Reset counter: 254
Mileage: 3596 km
Date: 2021.06.14
Time: 10:03:45
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000150058020311
Coding: 8451151801
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000.rod
VCID: 53E68E373A33C3132E-8006
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 2A00600201FF8748949C815560508700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VN54.rod
VCID: 43C6BE77CA5353939E-8016
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 016 0506
Revision: --------
Coding: 8800C00000000000400000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 7F4EF287E63BF773BA-802A
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI3
Part No SW: 7LA 920 941 A HW: 7LA 920 941 A
Component: KOMBI 202 8400
Coding: 27A40A002580260001882A010401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 3E30CF83A1B13E7BF1-806A
9456433 - Key
B104B 31 [008] - No Signal
Mileage: 2920 km
Date: 2021.06.01
Time: 15:11:03
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 3596 km
Date: 2021.06.14
Time: 10:11:32
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 521 5423
Serial number: 06112010521760
Coding: 030100044F05730000000058000F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 74A42DABDF7DA42BD7-8020
Generator:
Component: 5-00-11-00-04
Subsystem 2 - Part No SW: 3G0 959 442 N HW: 3G0 959 442 N
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440066312201750
Coding: 2C0D00
Subsystem 3 - Part No SW: 7E0 915 181 N HW: 7E0 915 181 N
Component: J367-BDMConti H03 1052
Serial number: 773433010020101204DA
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB.rod
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 0C8E020009200003
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41CAB47FD04F41838C-8014
Part No SW: 3CN 035 869 A HW: 3CN 035 869 A
Component: MU-E-D-ER 720 0890
Serial number: 19102000020275
Coding: 066401003C00000041110101008000001F0000D60000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW27.rod
VCID: 44C4BD6BCF5D54ABA7-8010
0517 - Front Right Bass Speaker
B1062 13 [008] - Open Circuit
[Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
Reset counter: 254
Mileage: 3596 km
Date: 2021.06.14
Time: 10:11:29
Voltage terminal 30: 12.4 V
0522 - Front Left Bass Speaker
B105F 13 [008] - Open Circuit
[Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
Mileage: 3596 km
Date: 2021.06.14
Time: 10:55:28
1637 - Interface for External Media
U11B8 00 [008] - No Communications
[USB - communication error]
Reset counter: 254
Mileage: 3596 km
Date: 2021.06.14
Time: 10:01:25
Voltage terminal 30: 11.9 V
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0092
Serial number: 0000000008NVKE0
Coding: 06462000196818208005460160000607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_AU27.rod
VCID: 014A747F90CF8183CC-8054
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 658240EF64A74DA350-8030
Component: LED1R H08 9202
End----------(Elapsed Time: 01:26, VBatt start/end: 12.2V/12.2V)-----------
Monday,14,June,2021,19:12:36:50827
VIN: ---VIN edited at user's request--- Mileage: 3598km-2235miles
Revision: 23301001
P0562 00 [036] - Too Low
Mileage: 3579 km
Date: 2021.06.14
Time: 00:06:56
Engine RPM: 0.00 /min
Coolant temperature: 36 °C
Intake air temperature: 30 °C
Voltage terminal 30: 11.804 V
Air mass at air mass meter 1: 0.0 kg/h
Standardized air flow ratio: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.21 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 0.000 bar
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1019 mbar
Mean injection quantity: 0 mg/stroke
Index of current engine mode: 7
Index of next requested engine mode: 7
Index of engine target mode: 7
25126 - Implausible Data Received from ESP Control Module
U0416 00 [036] - -
Mileage: 3579 km
Date: 2021.06.14
Time: 00:09:31
Voltage terminal 30: 11.757 V
Acceleration: 0.000 m/s²
Average vehicle speed: 0.00 km/h
Cruise Control System (CCS): status: Initialization
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake function status-ABS intervention: No
Drivetrain coordinator: brake function status-ESP intervention: No
Drivetrain coordinator: brake function status-EDL intervention: No
Drivetrain coordinator: brake function status-ASR intervention: No
Drivetrain coordinator: brake function status-MSR intervention: No
Drivetrain coordinator: brake function status-Driver braking: No
Drivetrain coordinator: brake function status-HDC active: No
Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
Drivetrain coordinator: brake function status-EPB active: No
Drivetrain coordinator: brake function status-ASP intervention: No
Drivetrain coordinator: brake function status-ADS intervention: No
Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
Drivetrain coordinator: brake function status-ACC stopping distance control active: No
Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: N/A
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [008] - -
[Scl_LWI_Lenkradwinkel_Error]
Reset counter: 254
Mileage: 3598 km
Date: 2021.06.14
Time: 00:06:54
Coding: 0018EE
Coding: 1F0007
Coding: 050007
Coding: 8451151801
13637426 - Databus
Reset counter: 254
Mileage: 3598 km
Date: 2021.06.14
Time: 00:06:54
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 254
Mileage: 3598 km
Date: 2021.06.14
Time: 00:09:18
Voltage terminal 15: 11.6 V
Control Module temperature: 54 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: -1.09 m/s²
Adaptive distance regulation: status: ACC_irreversible error
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 254
Mileage: 3598 km
Date: 2021.06.14
Time: 00:09:18
Voltage terminal 15: 11.7 V
2055 - Databus
[FAULT_ALP_STEERINGWHEEL_INIT]
Reset counter: 254
Mileage: 3598 km
Date: 2021.06.14
Time: 00:09:18
Revision: --------
Coding: 27A50A072580260001882A010401000000000000
Generator:
Coding: 2C0D00
Coding: 0106
Coding: 06640100FC00000041110101008000001F0000D60000010000
End----(Elapsed Time: 01:28, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
