Hi - first post, please be gentle
I retrofitted the OEM air suspension like the ROW Touaregs received besides NA. All the wiring is done, hardware is in, all sensors are connected. From what I gather from different other places is that some coding has to be changed to accept the Level Control Module (034) and in the various sites it's hinting towards changing the ABS long coding, but I'm unable to do that. Any change seems to always result in Error 31 - Coding Rejected.
I've gathered a few ABS Long Codings from Touareg owners with Air Suspension factory installed and compared against mine.
My ABS Long Coding (same as full scan below)
5B7613C349242554DAF5C89B92DAA4407700
ABS Long Coding from others:
5B6B13C34B24255BDAFBC89AD2D4A450F700 -- 14210000 (34 coding)
5B6B13C34B262555DAF5C89BD2D6A470F701 -- 14210000 (34 coding)
5B6B13C30B262557DAFCC897D0D4A4507700
5B6B13C30B252553DAFCC895D0D4A470F701
4B6B13C34B262558D2F7C89CD2D3A4507700 -- 14210001 (34 coding)
4B6B13C30B282F54D2FBC898D0DAF4507700 -- 14210001 (34 coding)
My HUNCH is to change Byte 1 from 76 to 6B, but when I tried that, like I said it rejected it with out of range. I also tried to enter Security Code 40168 before trying to change the long coding, but no luck.
There are a lot of error codes, because the car is stripped down at the moment (HVAC control is disconnected, Radio is disconnected, Seats are disconnected, etc)
Wednesday,16,June,2021,22:20:23:09013
VCDS Version: 21.3.0.0 (x64) HEX-NET CB: 0.4543.4
Workshop Code: 790 31414 000001
VIN: WVGFF9BP5BD001188 License Plate:
Mileage: 211925km-131684mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 34 42 46 52 53 55 56 5F 62 65
69 6C 6D 72
VIN: WVGFF9BP5BD001188 Mileage: 211925km-131684miles
08-Auto HVAC -- Status: Cannot be reached 0100
17-Instruments -- Status: Malfunction 0110
34-Level Control -- Status: Not registered 0011
56-Radio -- Status: Cannot be reached 0100
Address 01: Engine (J623-CGRA) Labels:. 03H-907-309-V1.clb
Part No SW: 03H 906 023 B HW: 03H 907 309
Component: 3,6 FSI ULEV2 H11 8688
Revision: M7H11---
Coding: 002A0012433600000000
Shop #: WSC 08272 444 00000
ASAM Dataset: EV_ECM36FSI01103H906023B 002006
ROD: EV_ECM36FSI01103H906023B.rod
VCID: A10A4A19B0EA5F836C-80F4
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [039] - -
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:19
Engine RPM: 1049.50 /min
Normed load value: 34.5 %
Coolant temperature: 52 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.654 V
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 A HW: 0C8 927 750 A
Component: AL1000 AISIN 001 1824
Coding: 001368
Shop #: WSC 09604 002 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_VW52.rod
VCID: AA18AD35CDDC9CDB3D-80FE
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 G HW: 7P0 907 379 A
Component: MK25A H33 0421
Revision: -------- Serial number: 417800010EC010
Coding: 5B7613C349242554DAF5C89B92DAA4407700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: C1CAEA9950AA7F830C-8094
267264 - Control Module Incorrectly Coded
U1014 00 [137] - -
[Steuergerät falsch codiert (Bytecodierung): keine Anzeige]
Reset counter: 136
Mileage: 211925 km
Date: 2021.06.16
Time: 22:15:51
Standard Freeze Frame Dynamic: 00 37 00 00 00 00 00 00 00 00 01 20 08
Part No SW: 4H0 907 064 AK HW: 4H0 907 064 H
Component: BCM2 2.0 H13 0208
Coding: 09860000000000000000
VCID: F2A875552D8C941B45-80A6
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Serial number: 0510000041835011
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 0210000092307012
Address 08: Auto HVAC
Part No SW: 4H0 907 063 D HW: 4H0 907 063 D
Component: BCM1 2.0 H11 0083
Revision: 15011002 Serial number: 00000000719199
Coding: 26001093973C5D010020180300005D0C431C660882010261000000020000
Shop #: WSC 12345 123 61029
VCID: A91A5239C0DA97C334-80FC
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 100705 31 0020
Serial number: 90243400100708104815
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10037845
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000003006100164
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R02EP06
No Faults Found
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 A HW: 7P0 959 655 A
Component: VW10Airbag099 H05 0020
Revision: -------- Serial number: 003FH000M33K
Coding: 000000000000000000000000000000003939
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: BFCEEC61265E09737A-80EA
Subsystem 1 - Part No SW: 000 000 000 00 HW: 000 000 000 00
Component: BF-Gewichtss. 000 0000
Serial number: 0000000R0000000000
Serial number: 3575LRB405J6U4L228EM
Serial number: 3585LRB405L6U4L23OK5
Serial number: 3515RRB405L6Q5E6310+
Serial number: 3525RRB405L6Q5E69105
Serial number: 3555NRB40516P1I849G4
Serial number: 3565NRB40536P1I87P1B
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:22
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:22
9444883 - Driver's seat position sensor
B101E 13 [137] - Open Circuit
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:20
9445139 - Passenger's seat position sensor
B101F 13 [137] - Open Circuit
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:20
9444627 - Safety belt switch - passenger side
B101D 13 [137] - Open Circuit
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:20
9445937 - Seat occupied recognition control module
B1022 31 [137] - No Signal
Reset counter: 136
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:30
Part No SW: 4H0 953 568 A HW: 7P6 953 507
Component: Lenks.Modul H07 0007
Revision: -------- Serial number: 90815JG70000S
Coding: 000015
VCID: B12ABA59E80AEF03FC-80E4
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0017974
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 M HW: 7P6 920 980 M
Component: Kombi H09 0231
Revision: 08140052 Serial number: 658120710593008
Coding: 8B6732022B00D705020004
Shop #: WSC 37643 272 11444
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: C6C0F985798458BB39-8092
U1014 00 [009] - -
Reset counter: 136
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:16
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000025299
Coding: 0001032600
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: B83C877D03703E4BBB-80EC
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650274580
5055 - No Communications with HVAC Control Module (J301)
U0164 00 [009] - -
[No signal/communication to Aircondition- ECU (Climatronic)]
Reset counter: 136
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:16
Voltage terminal 30: 14.1 V
Voltage terminal 15: 14.0 V
Control Module temperature: 31 °C
System status: Terminal 15 on
IN ESP_standstill flag: no standstill detected
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
0267 - Optical data bus
U1049 00 [009] - Open circuit
Reset counter: 136
Mileage: 211925 km
Date: 2021.06.15
Time: 20:15:53
Voltage terminal 30: 11.7 V
Voltage terminal 15: 0.0 V
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
0021 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Steuergerät falsch codiert (CAN)]
Reset counter: 136
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:16
Voltage terminal 30: 13.9 V
Voltage terminal 15: 13.8 V
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
12290 - Quiescent Current
U1406 00 [008] - Too High
Reset counter: 176
Mileage: 211925 km
Date: 2021.06.15
Time: 22:50:44
Voltage terminal 30: 11.5 V
Control Module temperature: 23 °C
System status: LIN_active
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
U140B 00 [009] - -
[Powermanagement active]
Fault Frequency: 8
Reset counter: 136
Mileage: 211925 km
Date: 2021.06.16
Time: 02:01:30
Control Module temperature: 19 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 K HW: 7P0 907 553 K
Component: PASM H01 1110
Revision: 00000000 Serial number: 00000113411043
Coding: 14210000
Shop #: WSC 03650 002 104857
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
0838 - Indicator Lamp in Operating Control for Loading-Sill Lowering
C10DA 13 [009] - Open Circuit
Fault Frequency: 136
Reset counter: 3
Mileage: 775424 km
Date: 2104.04.08
Time: 25:08:57
Default: 00
Default: 00
Default: 00
0786 - Electical Consumer Cut-Off Active
U1402 00 [009] - -
[Spannung Fahrbatterie - Abschaltstufe aktiv]
Fault Priority: 8
Reset counter: 3
Mileage: 775424 km
Date: 2104.04.08
Time: 28:28:57
Default: 00
Default: 00
Default: 00
12652551 - Ride Height Not Learned
C1044 00 [137] - -
Reset counter: 0
Time: 00:00:56
Default: 00
Default: 00
Default: 00
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000106223950
Coding: 011D07200000453005080000
Shop #: WSC 00017 666 00728
VCID: BC349B6D3F48126B5F-80E8
Reset counter: 136
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:14
Revision: 00002001 Serial number: 0132535493
Coding: 01061E3A28BA500080B00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 169102143
Reset counter: 136
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:14
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000106165681
Coding: 011D07200C00453005080000
VCID: BB3698713A46155356-80EE
Reset counter: 136
Mileage: 211925 km
Date: 2021.06.15
Time: 20:11:14
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 E HW: 7P0 907 801 E
Component: EPB H51 1100
Revision: 00000000 Serial number: A106150022B
Coding: 01040000
ROD: EV_ParkbA7.rod
VCID: B5228E491462C323A0-80E0
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: FCB45B6D77C8D26B1F-80A8
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0006
Coding: 130000
5256213 - Front Left Ride-Height Sensor
C1034 15 [137] - Open or Short to Plus
Reset counter: 136
5256725 - Rear Left Ride-Height Sensor
C1036 15 [137] - Open or Short to Plus
Reset counter: 136
Address 56: Radio
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000106248350
Coding: 011C07200000253005080000
VCID: BA389D75357C2C5B4D-80EE
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000006318
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 B HW: 7P0 907 383 B
Component: Anhaenger H07 0100
Revision: 5A001002 Serial number: 00000131777125
Coding: 020D000000000000
VCID: B73E8441066E3133B2-80E2
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H03000 Serial number: 525PA8-J050861
Coding: 0110001
VCID: B73E8441C66E3133B2-80E2
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 09145444 Serial number: 168000117
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000106248446
End----(Elapsed Time: 01:53, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
