VW Touareg 7p - Air Suspension OEM Retrofit
muffin86
NJ, USA
C?ID=408397
Hi - first post, please be gentle :o
I retrofitted the OEM air suspension like the ROW Touaregs received besides NA. All the wiring is done, hardware is in, all sensors are connected. From what I gather from different other places is that some coding has to be changed to accept the Level Control Module (034) and in the various sites it's hinting towards changing the ABS long coding, but I'm unable to do that. Any change seems to always result in Error 31 - Coding Rejected.
I've gathered a few ABS Long Codings from Touareg owners with Air Suspension factory installed and compared against mine.
My ABS Long Coding (same as full scan below)
5B7613C349242554DAF5C89B92DAA4407700
ABS Long Coding from others:
5B6B13C34B24255BDAFBC89AD2D4A450F700 -- 14210000 (34 coding)
5B6B13C34B262555DAF5C89BD2D6A470F701 -- 14210000 (34 coding)
5B6B13C30B262557DAFCC897D0D4A4507700
5B6B13C30B252553DAFCC895D0D4A470F701
4B6B13C34B262558D2F7C89CD2D3A4507700 -- 14210001 (34 coding)
4B6B13C30B282F54D2FBC898D0DAF4507700 -- 14210001 (34 coding)
My HUNCH is to change Byte 1 from 76 to 6B, but when I tried that, like I said it rejected it with out of range. I also tried to enter Security Code 40168 before trying to change the long coding, but no luck.
There are a lot of error codes, because the car is stripped down at the moment (HVAC control is disconnected, Radio is disconnected, Seats are disconnected, etc)
Wednesday,16,June,2021,22:20:23:09013
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
Workshop Code: 790 31414 000001
VIN: WVGFF9BP5BD001188   License Plate:
Mileage: 211925km-131684mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 34 42 46 52 53 55 56 5F 62 65
          69 6C 6D 72
VIN: WVGFF9BP5BD001188   Mileage: 211925km-131684miles
08-Auto HVAC -- Status: Cannot be reached 0100
17-Instruments -- Status: Malfunction 0110
34-Level Control -- Status: Not registered 0011
56-Radio -- Status: Cannot be reached 0100
Address 01: Engine (J623-CGRA)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 B    HW: 03H 907 309
   Component: 3,6 FSI ULEV2 H11 8688
   Revision: M7H11---
   Coding: 002A0012433600000000
   Shop #: WSC 08272 444 00000
   ASAM Dataset: EV_ECM36FSI01103H906023B 002006
   ROD: EV_ECM36FSI01103H906023B.rod
   VCID: A10A4A19B0EA5F836C-80F4
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [039] - -
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:19
                    Engine RPM: 1049.50 /min
                    Normed load value: 34.5 %
                    Coolant temperature: 52 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 14.654 V
Readiness: 1110 0101
   Part No SW: 0C8 927 750 A    HW: 0C8 927 750 A
   Component: AL1000 AISIN  001 1824
   Coding: 001368
   Shop #: WSC 09604 002 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: AA18AD35CDDC9CDB3D-80FE
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 G    HW: 7P0 907 379 A
   Component: MK25A         H33 0421
   Revision: --------    Serial number: 417800010EC010
   Coding: 5B7613C349242554DAF5C89B92DAA4407700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: C1CAEA9950AA7F830C-8094
267264 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [Steuergerät falsch codiert (Bytecodierung): keine Anzeige]
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.16
                    Time: 22:15:51
                    Standard Freeze  Frame Dynamic: 00 37 00 00 00 00 00 00 00 00 01 20 08
   Part No SW: 4H0 907 064 AK    HW: 4H0 907 064 H
   Component: BCM2 2.0      H13 0208
   Coding: 09860000000000000000
   VCID: F2A875552D8C941B45-80A6
   Subsystem 1 - Part No SW: 7P6 959 754 M    HW: 7P6 959 754 M
   Component: FBSTOUAREGIDG  H04 0051
   Serial number: 0510000041835011
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 0210000092307012
Address 08: Auto HVAC
   Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Component: BCM1 2.0      H11 0083
   Revision: 15011002    Serial number: 00000000719199
   Coding: 26001093973C5D010020180300005D0C431C660882010261000000020000
   Shop #: WSC 12345 123 61029
   VCID: A91A5239C0DA97C334-80FC
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    100705  31  0020
   Serial number: 90243400100708104815
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10037845
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000003006100164
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R02EP06
No Faults Found
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 A    HW: 7P0 959 655 A
   Component: VW10Airbag099 H05 0020
   Revision: --------    Serial number: 003FH000M33K
   Coding: 000000000000000000000000000000003939
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: BFCEEC61265E09737A-80EA
   Subsystem 1 - Part No SW: 000 000 000 00    HW: 000 000 000 00
   Component: BF-Gewichtss.  000 0000
   Serial number: 0000000R0000000000
   Serial number: 3575LRB405J6U4L228EM
   Serial number: 3585LRB405L6U4L23OK5
   Serial number: 3515RRB405L6Q5E6310+
   Serial number: 3525RRB405L6Q5E69105
   Serial number: 3555NRB40516P1I849G4
   Serial number: 3565NRB40536P1I87P1B
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:22
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:22
9444883 - Driver's seat position sensor
          B101E 13 [137] - Open Circuit
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:20
9445139 - Passenger's seat position sensor
          B101F 13 [137] - Open Circuit
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:20
9444627 - Safety belt switch - passenger side
          B101D 13 [137] - Open Circuit
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:20
9445937 - Seat occupied recognition control module
          B1022 31 [137] - No Signal
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:30
   Part No SW: 4H0 953 568 A    HW: 7P6 953 507
   Component: Lenks.Modul   H07 0007
   Revision: --------    Serial number: 90815JG70000S
   Coding: 000015
   VCID: B12ABA59E80AEF03FC-80E4
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0017974
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 980 M    HW: 7P6 920 980 M
   Component: Kombi         H09 0231
   Revision: 08140052    Serial number: 658120710593008
   Coding: 8B6732022B00D705020004
   Shop #: WSC 37643 272 11444
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: C6C0F985798458BB39-8092
          U1014 00 [009] - -
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:16
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000025299
   Coding: 0001032600
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: B83C877D03703E4BBB-80EC
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650274580
5055 - No Communications with HVAC Control Module (J301)
          U0164 00 [009] - -
          [No signal/communication to Aircondition- ECU (Climatronic)]
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:16
                    Voltage terminal 30: 14.1 V
                    Voltage terminal 15: 14.0 V
                    Control Module temperature: 31 °C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [009] - Open circuit
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:15:53
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 0.0 V
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
0021 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert (CAN)]
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:16
                    Voltage terminal 30: 13.9 V
                    Voltage terminal 15: 13.8 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 176
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 22:50:44
                    Voltage terminal 30: 11.5 V
                    Control Module temperature: 23 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [009] - -
          [Powermanagement active]
                    Fault Frequency: 8
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.16
                    Time: 02:01:30
                    Control Module temperature: 19 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
   Component: PASM          H01 1110
   Revision: 00000000    Serial number: 00000113411043
   Coding: 14210000
   Shop #: WSC 03650 002 104857
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
0838 - Indicator Lamp in Operating Control for Loading-Sill Lowering
          C10DA 13 [009] - Open Circuit
                    Fault Frequency: 136
                    Reset counter: 3
                    Mileage: 775424 km
                    Date: 2104.04.08
                    Time: 25:08:57
                    Default: 00
                    Default: 00
                    Default: 00
0786 - Electical Consumer Cut-Off Active
          U1402 00 [009] - -
          [Spannung Fahrbatterie - Abschaltstufe aktiv]
                    Fault Priority: 8
                    Reset counter: 3
                    Mileage: 775424 km
                    Date: 2104.04.08
                    Time: 28:28:57
                    Default: 00
                    Default: 00
                    Default: 00
12652551 - Ride Height Not Learned
          C1044 00 [137] - -
                    Reset counter: 0
                    Time: 00:00:56
                    Default: 00
                    Default: 00
                    Default: 00
   Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
   Component: TSG FA        H07 0162
   Revision: --------    Serial number: 0000106223950
   Coding: 011D07200000453005080000
   Shop #: WSC 00017 666 00728
   VCID: BC349B6D3F48126B5F-80E8
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:14
   Revision: 00002001    Serial number: 0132535493
   Coding: 01061E3A28BA500080B00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 169102143
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:14
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000106165681
   Coding: 011D07200C00453005080000
   VCID: BB3698713A46155356-80EE
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.15
                    Time: 20:11:14
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 E    HW: 7P0 907 801 E
   Component: EPB           H51 1100
   Revision: 00000000    Serial number: A106150022B
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   VCID: B5228E491462C323A0-80E0
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: FCB45B6D77C8D26B1F-80A8
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0006
   Coding: 130000
5256213 - Front Left Ride-Height Sensor
          C1034 15 [137] - Open or Short to Plus
                    Reset counter: 136
5256725 - Rear Left Ride-Height Sensor
          C1036 15 [137] - Open or Short to Plus
                    Reset counter: 136
Address 56: Radio
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000106248350
   Coding: 011C07200000253005080000
   VCID: BA389D75357C2C5B4D-80EE
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000006318
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 B    HW: 7P0 907 383 B
   Component: Anhaenger     H07 0100
   Revision: 5A001002    Serial number: 00000131777125
   Coding: 020D000000000000
   VCID: B73E8441066E3133B2-80E2
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H03000    Serial number: 525PA8-J050861
   Coding: 0110001
   VCID: B73E8441C66E3133B2-80E2
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0611
   Revision: 09145444    Serial number: 168000117
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000106248446
End----(Elapsed Time: 01:53, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
Hi and welcome.
I don't know if this will help with the ABS coding issue at all, but you should "register" the 34-Level Control module in the Gateway.
[Select]
[19-CAN Gateway]
[Installation List]
- Scroll down to 34-Level Control and put a check-mark next to it.
[Save Coding]
FWIW, I've never seen anything resembling a decent coding chart for these MK25A modules. If anyone else has info, please chime in.
Here's a 2015 NAR TDI "Natasha" (no air ride):
5B7613C349246F56DAF8C89492D5F6607301
And a 2017 NAR VR6 "Boris" (no air ride):
5B7613C349246F57DAF8C89692D3F660F701
muffin86
NJ, USA
C?ID=408397
Unfortunately no joy :(
New Scan:
Thursday,17,June,2021,20:41:22:09013
          69 6C 6D 72
   Revision: M7H11---
          U0164 00 [039] - -
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:35:25
                    Engine RPM: 950.00 /min
                    Normed load value: 78.0 %
                    Coolant temperature: 25 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 13.334 V
   Coding: 001368
          U1014 00 [137] - -
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:33:58
                    Standard Freeze  Frame Dynamic: 00 36 00 00 00 00 00 07 00 00 01 20 08
   Coding: 004DBD
   Coding: 035223
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:00
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:22
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:22
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:20
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:20
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:20
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:29
   Coding: 000015
          U1014 00 [009] - -
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:35:24
   Coding: 0001032600
          U0164 00 [009] - -
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:16
                    Voltage terminal 30: 10.8 V
                    Voltage terminal 15: 10.8 V
                    Control Module temperature: 36 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:35:25
                    Voltage terminal 30: 12.9 V
                    Voltage terminal 15: 12.8 V
                    Control Module temperature: 38 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
          U140B 00 [008] - -
                    Reset counter: 176
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:16
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 2
   Coding: 14210000
                    Reset counter: 3
                    Mileage: 775424 km
                    Date: 2104.04.08
                    Time: 25:08:57
                    Default: 00
                    Default: 00
                    Default: 00
          U1402 00 [008] - -
                    Fault Frequency: 176
                    Reset counter: 3
                    Mileage: 775424 km
                    Date: 2104.04.08
                    Time: 28:28:57
                    Default: 00
                    Default: 00
                    Default: 00
          C1044 00 [137] - -
                    Reset counter: 3
                    Mileage: 775424 km
                    Date: 2104.13.03
                    Time: 06:24:56
                    Default: 00
                    Default: 00
                    Default: 00
0851 - Control Head for Level Control System
          C10D4 07 [008] - Mechanical Failure
                    Reset counter: 3
                    Mileage: 775424 km
                    Date: 2104.13.04
                    Time: 17:49:04
                    Default: 00
                    Default: 00
                    Default: 00
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:15
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:14
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:15
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   Slave 3:
   Coding: 130000
   Coding: 130000
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:16
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.17
                    Time: 20:30:16
Address 56: Radio
   Coding: 0110001
   Coding: 0533314003
End----------(Elapsed Time: 01:49, VBatt start/end: 13.8V/14.0V)-----------
NEtech
Denmark
C?ID=56995
Test [03] Coding: 5B7613C34B242554DAF5C89BD2DAA4407700
muffin86
NJ, USA
C?ID=408397
Woo.. it accepted the coding! But I think my battery might be super low, so it's on the charger now. That's again just a hunch because I see this in 34: 0786 - Electical Consumer Cut-Off Active
Will update the thread later after the battery is charged up a bit and I clear out faults.
Friday,18,June,2021,10:59:51:09013
          69 6C 6D 72
17-Instruments -- Status: Cannot be reached 0100
   Revision: M7H11---
   Coding: 001368
   Coding: 004DBD
   Coding: 035223
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.18
                    Time: 10:56:00
                    Mileage: 211925 km
                    Date: 2021.06.18
                    Time: 10:56:18
                    Mileage: 211925 km
                    Date: 2021.06.18
                    Time: 10:56:18
                    Mileage: 211925 km
                    Date: 2021.06.18
                    Time: 10:56:16
                    Mileage: 211925 km
                    Date: 2021.06.18
                    Time: 10:56:16
                    Mileage: 211925 km
                    Date: 2021.06.18
                    Time: 10:56:16
   Coding: 000015
   Coding: 0001032600
   Coding: 14210000
                    Reset counter: 3
                    Mileage: 775424 km
                    Date: 2104.04.08
                    Time: 25:08:57
                    Default: 00
                    Default: 00
                    Default: 00
          U1402 00 [009] - -
                    Fault Priority: 15
                    Reset counter: 3
                    Mileage: 775424 km
                    Date: 2104.04.08
                    Time: 28:28:57
                    Default: 00
                    Default: 00
                    Default: 00
          C1044 00 [137] - -
                    Reset counter: 3
                    Mileage: 775424 km
                    Date: 2105.02.22
                    Time: 15:32:57
                    Default: 00
                    Default: 4E
                    Default: 00
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.18
                    Time: 10:56:45
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.18
                    Time: 10:56:52
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   Slave 3:
   Coding: 130000
   Coding: 130000
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.18
                    Time: 10:57:02
                    Reset counter: 136
                    Mileage: 211925 km
                    Date: 2021.06.18
                    Time: 10:57:02
Address 56: Radio
   Coding: 0110001
   Coding: 0533314003
End----(Elapsed Time: 02:21, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
muffin86
NJ, USA
C?ID=408397
Some more updates.
Did another scan and all looked good for ABS module. I noticed in 17-Instruments, it also had a Controle Module Incorrectly Coded. Luckily it has a label file and I adjusted it from
8B6732022B00D705020004 to
8B6732023B00D705020004
"Daempfer regelung" (can't do my umlauts on an English keyboard :D )
After that I started up the car and did the Basic Settings in 34-Level Control.
I initially did "Fill functions" and did it for all 4 corners. I also had a Nitrogen tank hooked up to the air tank (using R134A low fittings) to keep it at 150PSI/17bar.
After that I did the Adaptation and adjusted all 4 corners heights based on how I measured from center wheel cap to wheel well.
Changed the "Complete Height calibration" to a "Yes" (this was initially set to No for me).
Then off to testing and grinning I went because the car went up and down. I should've stopped here, but I wanted to bleed and refill up the tank + suspensions with Nitrogen.
Went through bleeding/filling functions again..and now the car doesn't respond to the controls anymore :(
BUT on the bright side..no codes in dash for air suspension issues. Adaptive Lightning code came up though, so I might have to check into that, because the front left and rear left height sensors had to get rewired to the Air Suspension Module instead of the Light Control Module (I think that's what it is?!). Had to take a break and do my real job :D
muffin86
NJ, USA
C?ID=408397
Alrighty - Final update..I think I have a bad rear right height sensor. It works for a little bit, and then always gives me a reading of -128mm.
I did go cheapo on those and ordered Chinese sensors :D let's see if I can get an OEM sensor somewhere local, else I gotta order one.
For the time it does read the height, it goes up and down nicely.
Thanks a bunch for the ABS coding! Will do a full retrofit write up on clubtouareg once I have my car puzzled back together
muffin86
NJ, USA
C?ID=408397
My late night write up of the retrofit:
Thanks again for the quick responses!!
muffin86
NJ, USA
C?ID=408397
Btw - quick question, is it ok for me to post screenshots of VCDS over there? Would love to add that to the guide, but rather want to ask for permission first before posting :)
