2006 Jetta Can-Gateway 01044-Control module incorrectly coded
ruiz2710
C?ID=64318
Received this code today, and don't know what is wrong or how to recode. Can someone please Advise what could be wrong and how to fix?
ruiz2710
C?ID=64318
sorry its 19 CAN Gateway....don't know how to properly long code the module..never replaced it its the same module that came with the car only thing weve done is added OEM navigation
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
Tuesday,07,April,2015,18:15:56:49025
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: 3VWPF71KX6M629743   Mileage: 235300km-146208miles
37-Navigation -- Status: Not registered 0001
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 P    HW: Hardware No
   Component: 2.5l R5/4V      G   6699
   Revision: --------    Serial number: VWZ7Z0E2295000
   Coding: 0000001
   Shop #: WSC 00066 000 00000
   VCID: 3663F5BA41F8FC91843-8063
001056 - Catalyst System; Bank 1
               P0420 - 002 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100010
                    Fault Frequency: 36
                    Mileage: 178168 km
                    Time: 06:51:34
                    RPM: 2310 /min
                    Load: 29.4 %
                    Speed: 88.0 km/h
                    Temperature: 81.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.224 V
001041 - Secondary Air Injection System
               P0411 - 001 - Incorrect Flow Detected - MIL ON
                    Fault Status: 11100001
                    Mileage: 230928 km
                    Time: 03:03:48
                    RPM: 1546 /min
                    Load: 80.0 %
                    Speed: 23.0 km/h
                    Temperature: 35.0°C
                    Temperature: 29.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
   Part No: 1K0 907 379 P
   Coding: 0017025
   VCID: 3F8D909E6EC23DD9575-806A
   Part No: 1K0 820 047 DK
   Component: Climatic PQ35   090 0505
   VCID: 70EF03A2631C92A19EF-8025
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000111064
   Coding: 04050E234004180000140000001400000008730B5C
   VCID: 2A5BD1CA8540A87110B-807F
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00066
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD02GCSF
   Coding: 0012627
   VCID: 2E53DDDAB9A8C451CC3-807B
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 6332MSME0A0D073AE
   Subsystem 3 - Serial number: 6342MSME08746229A
   Subsystem 4 - Serial number: 6351HSME07215E523
   Subsystem 5 - Serial number: 6361HSME07214460Z
   Subsystem 6 - Serial number: 63727SME0673156B%
   Subsystem 7 - Serial number: 63827SME06731F14+
01218 - Side Airbag Igniter; Passenger Side (N200)
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000021
   VCID: 78FF3B820B6CCAE156F-802D
   Part No: 1K0 920 952 C
   Component: KOMBIINSTRUMENT 3HL 1012
   Coding: 0023203
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001054218EDB
   Coding: 3D3F0340071002
            000 -  -
                    Reset counter: 201
                    Mileage: 235301 km
                    Time: 05:42:49
   Component: IMMO            3HL 1012
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 G
   Component:      Navigation     0047
   Coding: 0000101
   VCID: 3D71EA9664CE2FC9459-8068
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001269
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 326BC9AAAD90E0B1A8B-8067
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AF
   Coding: 137803281B09058F880F048051A0
   VCID: 74E70FB21704AE817A7-8021
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 377DF8BE46F205999F5-8062
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095 F
   Component:        Radio        0047
   Coding: 0010400
   VCID: 285F2BC29B4C9A6106F-807D
00881 - Connection to Speaker Rear Right
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 3169C6A6A896DBA9D11-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
End-------------------------(Elapsed Time: 01:40)--------------------------
OK, the problem is right here:
[Select]
[19-CAN Gateway]
[Installation List]
Scroll down to 37-Navigation and put a check-mark in the box.
[Save Coding]
ruiz2710
C?ID=64318
thank you very much worked like a charm
