Hi, Once again we are after some assistance. We have in a 2015 VW Sharan that is displaying "Vehicle will not start in 25 miles unless AD blue is topped up", there are no fault codes stored and the additive tank is full. In live data it shows 80% full and we have tried to reset SCR tank levels which has not rectified the situation.
The vehicle arrived to us after a visit to the dealer who had told the customer that the vehicle required a new DPF. The reason for this is that the DPF internals had been removed prior to the customers recent purchase of the vehicle. We have installed a new DPF and there are now no fault codes stored as per log file attached.
Does anyone have any suggestions as what is required to extinguish the AD blue warning? I am concerned that the vehicle may have been mapped at the time of DPF removal. Would there be a way of finding out if this is the case?
Thank you all in advance for any help that you may be able to provide
Friday,26,February,2021,17:04:46:18746
VCDS Version: 20.12.0.0
Data version: 20201124 DS322.0
VIN: WVWZZZ7NZFV039167 License Plate: GM15FHS
Mileage: 194490km-120850mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 4C 52 53 56
61 62 72 77
VIN: WVWZZZ7NZFV039167 Mileage: 194490km-120850miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HJ HW: 03L 907 309 Q
Component: R4 2.0l TDI H28 9981
Revision: 44H28--- Serial number:
Coding: 001D001A042501080000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018HJ 003016
ROD: EV_ECM20TDI01103L906018HJ_VW36.rod
VCID: 79F23CBDF890684C44-802C
Part No SW: 02E 300 062 HW: 02E 927 770 AL
Component: GSG DSG AG6 531 4002
Revision: 05653104 Serial number: 00001412030812
Shop #: WSC 00020 000 90108
VCID: 52A0AB11CDA67B14E5-8006
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 S HW: 7N0 614 109 S
Component: J104 C3 450M VDC5 0040
Revision: --H07--- Serial number: 00000008717001
Coding: 0028186
Shop #: WSC 00020 790 00000
VCID: 3D7AE8AD6438946C28-8068
Reset counter: 237
Mileage: 194495 km
Date: 2015.07.20
Time: 00:00:11
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.00 V
Bin. Bits: 00011110
Count: 191
Hex Value: 0x0000
Part No SW: 7N0 907 044 AG HW: 7N0 907 044 AG
Component: Clima-Sharan H02 0606
Revision: 00001K02
Coding: 021000C449
Shop #: WSC 00020 999 00000
VCID: 75EA308DD4880C2C20-8020
Part No SW: 5K0 937 084 K HW: 5K0 937 084 K
Component: BCM PQ35 B 122 0174
Revision: BA122001
Coding: 40180A3F8125F1C0408800C01400006443D11308426D29226480872000C1
VCID: 3A70E3B1B516A3540D-806E
Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150117 033 0044
Serial number: 150128073344
Coding: 004DBD
Component: RLHS 037 0059
Serial number: S4Y15M03D06H03M29S06
Coding: 0228BB
Component: Sensor, DWA 0 005 0502
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 7N0 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0012
Revision: -------- Serial number: 28231505607117
Coding: 108101
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 3972FCBDB810A84C04-806C
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag00M H13 0014
Serial number: 003LGP3V1A4S
Coding: 00304D
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3F8692A5A634867C3A-806A
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60E464091B9D
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS60E250011B9DF
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS607752091B9DO
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS607AD8001B9DX
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60E4C9201B9DQ
Part No SW: 5K0 953 521 DF HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20150227201085
Coding: 1882240000
ROD: EV_SMLSNGVOLWS.rod
VCID: 73EE0E95DAFC121C0E-8026
Component: E221__MFL-TK6 H07 0023
Serial number: 70000000000000868693
Coding: E20000
Part No SW: 7N0 920 970 L HW: 7N0 920 970 L
Component: KOMBI H04 0905
Coding: 440F01
VCID: 3C7CE5A9B7229D641F-8068
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 G
Component: Zuheizer 051 3041
Revision: 00051000 Serial number: 09028242000000
Coding: 0000041
VCID: 3874F9B94B1AB144FB-806C
01415 - Recirculating Pump (V55)
Fault Status: 00100111
Reset counter: 213
Mileage: 101819 km
Date: 2018.09.08
Time: 18:43:38
Locked
Temperature: 64.0°C
Temperature: 89.0°C
Voltage: 14.31 V
02251 - Heater Unit Locked
Reset counter: 173
Mileage: 101819 km
Date: 2018.09.08
Time: 18:43:38
Part No SW: 7N0 907 530 AQ HW: 7N0 907 530 AL
Component: J533 Gateway H58 1653
Revision: H58 Serial number: 270215F1002380
Coding: 468003
VCID: 7F06D2A5EEB4467C7A-802A
Component: IMMO H04 0905
VCID: 6AD013F18D36D3D4BD-803E
Address 2E: Media Player 3
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 F HW: 7N0 959 793 F
Component: TSG FA H03 0553
Revision: Serial number: 0000136821576
Coding: 011006208001411011
VCID: 458A804DCCE8DCAC70-8010
Part No: 7N0 909 144 R
Component: EPS_ZFLS Kl. 275 3501
Revision: 00H21000
VCID: 42809B511DC6EB9455-8016
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 F HW: 7N0 959 792 F
Component: TSG BF H03 0553
Revision: Serial number: 0000135551992
Coding: 011004208001411011
VCID: 448C9D49C7D2E5A467-8010
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000560091
Coding: 0024167
Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
Component: Radio RCD310 007 0119
Revision: 01000001 Serial number: VWZ1Z2R0996104
Coding: 0100040004000D
VCID: 356AF08D9C084C2CE0-8060
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1653
Coding: 030F7859
VCID: 71E2049DA8E0200CFC-8024
Component: J367-BDM H07 0180
Serial number: 42055358531491540231
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 G HW: 7N0 959 794 G
Component: TSG HL H04 0553
Revision: Serial number: 0000138988569
Coding: 010004200001411001
VCID: 47968A45F6E4CEBC82-8012
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H04 0553
Revision: Serial number: 0000138988570
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 D HW: 5N0 035 729 D
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007670180667
Coding: 0A01000080010101
ROD: EV_UHVUMI.rod
VCID: 3162C49D6060600CBC-8064
End-------------------------(Elapsed Time: 04:07)--------------------------
