2015 VW Sharan Ad Blue defect
United Vehicles
C?ID=69882
Hi, Once again we are after some assistance. We have in a 2015 VW Sharan that is displaying "Vehicle will not start in 25 miles unless AD blue is topped up", there are no fault codes stored and the additive tank is full. In live data it shows 80% full and we have tried to reset SCR tank levels which has not rectified the situation.
The vehicle arrived to us after a visit to the dealer who had told the customer that the vehicle required a new DPF. The reason for this is that the DPF internals had been removed prior to the customers recent purchase of the vehicle. We have installed a new DPF and there are now no fault codes stored as per log file attached.
Does anyone have any suggestions as what is required to extinguish the AD blue warning? I am concerned that the vehicle may have been mapped at the time of DPF removal. Would there be a way of finding out if this is the case?
Thank you all in advance for any help that you may be able to provide
Friday,26,February,2021,17:04:46:18746
VCDS Version: 20.12.0.0
Data version: 20201124 DS322.0
VIN: WVWZZZ7NZFV039167   License Plate: GM15FHS
Mileage: 194490km-120850mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 4C 52 53 56
          61 62 72 77
VIN: WVWZZZ7NZFV039167   Mileage: 194490km-120850miles
   Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H28 9981
   Revision: 44H28---    Serial number:
   Coding: 001D001A042501080000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HJ 003016
   ROD: EV_ECM20TDI01103L906018HJ_VW36.rod
   VCID: 79F23CBDF890684C44-802C
   Part No SW: 02E 300 062     HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4002
   Revision: 05653104    Serial number: 00001412030812
   Shop #: WSC 00020 000 90108
   VCID: 52A0AB11CDA67B14E5-8006
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 S    HW: 7N0 614 109 S
   Component: J104   C3 450M VDC5 0040
   Revision: --H07---    Serial number: 00000008717001
   Coding: 0028186
   Shop #: WSC 00020 790 00000
   VCID: 3D7AE8AD6438946C28-8068
                    Reset counter: 237
                    Mileage: 194495 km
                    Date: 2015.07.20
                    Time: 00:00:11
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.00 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 7N0 907 044 AG    HW: 7N0 907 044 AG
   Component: Clima-Sharan  H02 0606
   Revision: 00001K02
   Coding: 021000C449
   Shop #: WSC 00020 999 00000
   VCID: 75EA308DD4880C2C20-8020
   Part No SW: 5K0 937 084 K    HW: 5K0 937 084 K
   Component: BCM PQ35 B    122 0174
   Revision: BA122001
   Coding: 40180A3F8125F1C0408800C01400006443D11308426D29226480872000C1
   VCID: 3A70E3B1B516A3540D-806E
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    150117  033 0044
   Serial number:         150128073344
   Coding: 004DBD
   Component: RLHS  037 0059
   Serial number: S4Y15M03D06H03M29S06
   Coding: 0228BB
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28231505607117
   Coding: 108101
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 3972FCBDB810A84C04-806C
   Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
   Component: VW10Airbag00M H13 0014
   Serial number: 003LGP3V1A4S
   Coding: 00304D
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3F8692A5A634867C3A-806A
   Serial number: 3493ETS60E464091B9D
   Serial number: 3503ETS60E250011B9DF
   Serial number: 3513ETS607752091B9DO
   Serial number: 3523ETS607AD8001B9DX
   Serial number: 35540TS60E4C9201B9DQ
   Part No SW: 5K0 953 521 DF    HW: 5K0 953 569 AE
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150227201085
   Coding: 1882240000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 73EE0E95DAFC121C0E-8026
   Component: E221__MFL-TK6  H07 0023
   Serial number: 70000000000000868693
   Coding: E20000
   Part No SW: 7N0 920 970 L    HW: 7N0 920 970 L
   Component: KOMBI         H04 0905
   Coding: 440F01
   VCID: 3C7CE5A9B7229D641F-8068
   Part No: 7N0 963 271 G
   Component: Zuheizer        051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0000041
   VCID: 3874F9B94B1AB144FB-806C
01415 - Recirculating Pump (V55)
                    Fault Status: 00100111
                    Reset counter: 213
                    Mileage: 101819 km
                    Date: 2018.09.08
                    Time: 18:43:38
                        Locked
                    Temperature: 64.0°C
                    Temperature: 89.0°C
                    Voltage: 14.31 V
02251 - Heater Unit Locked
                    Reset counter: 173
                    Mileage: 101819 km
                    Date: 2018.09.08
                    Time: 18:43:38
   Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1653
   Revision:   H58       Serial number: 270215F1002380
   Coding: 468003
   VCID: 7F06D2A5EEB4467C7A-802A
   Component: IMMO          H04 0905
   VCID: 6AD013F18D36D3D4BD-803E
Address 2E: Media Player 3
   Part No SW: 7N0 959 793 F    HW: 7N0 959 793 F
   Component: TSG FA        H03 0553
   Revision:             Serial number: 0000136821576
   Coding: 011006208001411011
   VCID: 458A804DCCE8DCAC70-8010
   Part No: 7N0 909 144 R
   Component: EPS_ZFLS Kl. 275    3501
   Revision: 00H21000
   VCID: 42809B511DC6EB9455-8016
   Part No SW: 7N0 959 792 F    HW: 7N0 959 792 F
   Component: TSG BF        H03 0553
   Revision:             Serial number: 0000135551992
   Coding: 011004208001411011
   VCID: 448C9D49C7D2E5A467-8010
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000560091
   Coding: 0024167
   Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
   Component: Radio RCD310  007 0119
   Revision: 01000001    Serial number: VWZ1Z2R0996104
   Coding: 0100040004000D
   VCID: 356AF08D9C084C2CE0-8060
   Component: Batt.regelung H58 1653
   Coding: 030F7859
   VCID: 71E2049DA8E0200CFC-8024
   Component: J367-BDM  H07 0180
   Serial number: 42055358531491540231
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 G    HW: 7N0 959 794 G
   Component: TSG HL        H04 0553
   Revision:             Serial number: 0000138988569
   Coding: 010004200001411001
   VCID: 47968A45F6E4CEBC82-8012
   Component: TSG HR        H04 0553
   Revision:             Serial number: 0000138988570
   Part No SW: 5N0 035 729 D    HW: 5N0 035 729 D
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007670180667
   Coding: 0A01000080010101
   ROD: EV_UHVUMI.rod
   VCID: 3162C49D6060600CBC-8064
End-------------------------(Elapsed Time: 04:07)--------------------------
Every one we've looked at shows ~80%, regardless of actual tank level, so I'm not surprised by that. I do find it quite frustrating that VAG won't show you anything resembling a real DEF level, even in measuring values, when some other manufacturers provide an actual, reasonably accurate gauge in the instrument cluster.
You have tried both of the following Basic Settings?
IDE04567 -- Resetting of SCR tank level detection
IDE04730 -- Reset SCR lock
Gone But Not Forgotten
VAG = Frustrating & no mater the place the definition lands to acronym correlation indeed means some sort of confusion? :confused:
United Vehicles
C?ID=69882
Thank you for taking the time to reply. We have tried both of the basic settings and neither have made any difference. Would you have any further suggestions please
Are you sure the programming is correct in engine controller & with a verified re-flash to stock to rule out FOD?
Did you ask your Governments emissions authority why there is not a conspicuous reset button or if there is a documented procedure? :popcorn:
Volkswagen​
PartVersion
FL_03L906018HJ8257
9236
9826
9957
9970
9978
9979
9980
9981
United Vehicles
C?ID=69882
Hi, No I am not sure if the software in the engine ecu is correct. I suspect as the internals of the DPF had been removed that the vehicle is most likely to have had some form of remap but I can not be sure of that fact. It appears that the suggestion would be to have a stock map flashed in to the controller and work from there. Is that the correct understanding of your post?
United Vehicles
C?ID=69882
Thank you both for your input so far. It is greatly appreciated
