Hello.
My name is Przemek. Im from Poland, and I am looking for help.
My car has a CE2 electrical system manufactured after 1990.
Under the hood I have a yellow diagnostic connector next to the ignition coil. I have two black and beige plugs under the gearbox bellow inside the vehicle. I bought an OBD1 to OBD2 and OBD ELM BT connector but it does not start because the K line is probably missing in these plugs. There is probably only an L line and ground and + 12V. Is it possible to somehow run or connect OBD2 by somehow remaking the old plugs? I also thought to connect directly to the central device under the hood under the shaft with the appropriate PINs of the K and L lines as well as the grounding and + 12V from the battery .. Greetings from Poland and thanks for help!
