Touch Control MFSW retrofit on a GTE
A4NOY
C?ID=263473
Hi all I'd like to fit a touch control MFSW from a golf MK8 to my 2017 Golf GTE but I don't know were to start with making it work .. i,ve had it fitted and had lots of faults on the dash which I thought was strange as they both use Lin control.. any thoughts please...
darkchina811
ITALY
C?ID=333184
you are entering totally uncharted territory, and my personal opinion is that I highly expect the mk8 MFSW NOT to work on the mk7.
let us know what you find out. happy retrofitting.
  • Agree
A4NOY
C?ID=263473
Hi there is a retrofitter here in the UK who sells the MFSW at a ridicules cost and has got them working on Passat B8 and T6.. so I thought I would be clever and buy from his supplier...He won't give me any help as you can expect ...
downtime
C?ID=280813
Best guess is that the steering wheel control module needs to upgraded as well and most likely the slip ring. And the new touch button MFSW has been installed to Passat B8 and T6 as you wrote, so it should work on other MQB chassis cars as well. Just need to find the correct combo of things.
DV52
C?ID=194404
@A4NOY: If I can add a personal opinion to the other views already provided, the MFSW arrangement on a MQB platform vehicle is deceptively simple in that while it has connections via the clock spring and the hex16 module, these have no effect there. These connections are just a wiring route; simply a way of getting the MFSW signal to the hex19 module (because the MFSW is a LIN slave of J533 on MQB cars - unlike in previous model Golfs where it was a slave of J527).
So- I suspect the biggest risk with your "courageous" project is the compatibility of your mk7 CAN gateway module with the mk8 MFSW!! Changing the hex19 module (while physically easy) is non-trivial from a coding perspective because of Component Protection complications and the need to visit a dealer (or if not, visit someone else with FAZIT connectivity)!
downtime
C?ID=280813
@DV52 You're right as usual :D Looking at few autoscans, the new platform seems to have a different layout vs previous MQB like you wrote. There's not a MFSW steering control module anymore but those functions are directly controlled by CAN gateway.
So that might make the retrofit more involved than usual. First of all new gateway is not just protected with CP but it also has the SFD scheme and now what happens to that if you put the module to a car that is not built for the SFD at all.
DV52
C?ID=194404
@downtime: Very true -but I wasn't suggesting the possibility of using a Gateway module from a MQB37W vehicle. Rather, I was contemplating whether another variant of mk7/mk7.5 hex19 module would be a better match to a mk8 MFSW (I don't know)!
In my response, I deliberately didn't entertain the risk of the MFSW on the mk8 no longer being a LIN slave to CAN Gateway -I haven't seen a CAN network diagram for a mk8, but that's also possible.
Lot's of unknowns -lots of interesting problems to solve for such a courageous project!!
NEtech
C?ID=56995
When the next VCDS beta get public, you can see more about J527 layout.
Then all different sub controllers are showed.
Example:
Friday,22,January,2021,14:36:44:16513
VCDS Version: 21.1.0.1 (x64)  HEX-NET2 CB: 0.4540.4
Data version: 20201124 DS324.0
Workshop Code: 204 00578 345678
VIN: WVWZZZCDZMW8xxxxx   License Plate:
Mileage: 6km-3mi   Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 4B 4B 52
      5F 61 6C 6D 75 A5 C4 CC D6 D7 8107 811E 811F 8120 8121 C002 C003
VIN: WVWZZZCDZMW8xxxxx   Mileage: 6km-3miles
23-Brake Booster -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
8107-Antenna -- Status: OK 0000
811E-Burglary Protection FL -- Status: Malfunction 0010
811F-Burglary Protection FR -- Status: Malfunction 0010
8120-Burglary Protection RL -- Status: Malfunction 0010
8121-Burglary Protection RR -- Status: Malfunction 0010
Address 01: Engine (J623-DFYA)       Labels: None
   Part No SW: 05E 906 012 Q    HW: 05E 907 309 G
   Component: R4 1.5l TFS   H20 1131
   Revision: 89H20000
   Coding: 0125003223641D0830086000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906012Q 002004
   ROD: EV_ECM15TFS01105E906012Q.rod
   VCID: 2D0C62FCFD9536731C4-8078
44047 - Front Camera for Driver Assist Systems
          U1229 00 [032] - Implausible Message
                    Reset counter: 40
                    Mileage: 4 km
                    Date: 2020.12.10
                    Time: 08:15:03
                    Engine RPM: 1730.00 /min
                    Normed load value: 23.5 %
                    Vehicle speed: 31 km/h
                    Coolant temperature: 85 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 13.920 V
                    Outside temperature: 4 °C
                    Absolute intake pressure: 56 kPa abs
                    Engine torque: 61.9 Nm
                    Fuel: tank fill level: 3.0 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
14690 - Loading Mode active
          P169A 00 [175] - -
                    Reset counter: 0
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:54:11
                    Engine RPM: 0.00 /min
                    Coolant temperature: 70 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 12.560 V
                    Unlearning counter according OBD: 0
                    Outside temperature: 215 °C
                    Absolute intake pressure: 99 kPa abs
                    Engine torque: 0.0 Nm
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0CW 906 556 M    HW: 0CW 300 051 N
   Component: GSG DQ200G2.1 H07 0562
   Serial number: CU502011227807
   ASAM Dataset: EV_TCMDQ200022 001001
   ROD: EV_TCMDQ200022_VW38.rod
   VCID: 56FEED10A88355AB8DE-8002
   Parking lock:
   Subsystem 1 - Part No SW: 5WA 713 033 AM    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20201029000063173691
   Selector lever:
   Subsystem 2 - Part No SW: 5H0 713 059 Q    HW: 5H0 713 059 Q
   Component: ZSB_SB_Mono    H03 0013
   Serial number: 92478TKK01484
41777 - Loading Mode active
          P169A 00 [047] - -
                    Fault Frequency: 14
                    Reset counter: 1
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:07
                    Engine torque: 0 Nm
                    Control Module temperature: 39 °C
                    CURRENT pressure: 38.0 bar
                    Clutch: primary stat: Neutral
                    selected gear: GANG_R
                    Driving position: P
                    Accelerator pedal position: 14.5 %
                    DTC memory status: 308
   Part No SW: 5WA 614 517 BH    HW: 5WA 614 517 P
   Component: ESC           H14 0129
   Serial number: 63230000002162
   Coding: 44FC22902220446E527E600006C76186ADB558504AC86708A1BCA231018FF141822814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013054
   ROD: EV_Brake1ESCEPBMQB37W_013.rod
   VCID: 0F70D87457D964630E8-805A
1905 - Transport Mode Active
          U1105 00 [047] - -
                    Reset counter: 0
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:06
                    Vehlicle_speed: 0.0 km/h
                    Resolution Mileage: 560 m
                    Voltage_value_KL.30_ESC_V: 12.4 V
                    Wake up EPB: not active
                    Wake up CAN: not active
                    Postrun_activ: not active
                    Comparison_pressure_sensor: completed successfully
                    Comparison_longitudinal_accleration: completed successfully
                    Comparison_transverse_accleration: completed successfully
                    Comparison_yaw_rate_sensor: completed successfully
                    LWS_comparison: completed successfully
                    Internal_failure_code: 01 73
                    00 00 40 00 04 0C 80 08 20 84 80 80 80 00 00 40 00 00 08 40 04
590080 - Release / Enable Active
          B184C 00 [032] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Reset counter: 39
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:00
                    Voltage_value_KL.30_ESC_V: 12.2 V
                    Internal_failure_code: 01 AE
                    00 00 40 00 04 0C 80 08 80 84 80 80 80 00 00 40 00 00 08 40 04
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 5WA 959 436 C    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0706
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w.rod
   VCID: 54FA1718BE7F47BB73A-8000
1077250 - Transport Mode Active
          U1105 00 [009] - -
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:11
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 727 P    HW: 5WA 907 727 P
   Component: Climatronic   H02 0340
   Coding: 202000010011120010100010111011110000131100200000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005067
   ROD: EV_ACClimaBHBVW38X_VW38.rod
   VCID: 5DECF23CCDB586F3CC4-8008
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000000000318511
   Rear A/C control head:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001270920140159509
131076 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
                    Fault Frequency: 0
          B10CD 00 [044] - -
          [Function limitation due to energy management 03]
                    Reset counter: 40
                    Mileage: 6 km
                    Date: 2021.01.23
                    Time: 03:34:23
                    Voltage terminal 30: 11.50 V
                    CAN input signal(s) status-Transport mode: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
                    CAN input signal(s) status-Back-up lamp: OFF
                    Blower reduction: No switch-off: no reduction
0515 - Transport Mode Active
          U1105 00 [044] - -
                    Reset counter: 40
                    Mileage: 6 km
                    Date: 2021.01.23
                    Time: 03:34:02
   Part No SW: 5WA 937 086 E    HW: 5WA 937 086 E
   Component: BCM 37W BOSCH 018 0158
   Serial number: BXJ53F011220940
   ASAM Dataset: EV_BCM37w 006001
   ROD: EV_BCM37w_006_VW38.rod
   VCID: 53F81404BB7140836A0-8006
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5H1 955 119     HW: 5H1 955 119
   Component: FWISCHER_MYJT  003 0051
   Serial number: 907453F0302030800755
   Component: RLHS           054 0206
   Serial number: SBY20M11D24H03M16S44
   Subsystem 3 - Part No SW: 5H0 941 193 AD    HW: 5H0 941 193 AD
   Component: LiSi           H05 0007
   Serial number: 92471TKJ000YD
   Control head for driving and comfort functions:
   Subsystem 4 - Part No SW: 5H0 925 200 P    HW: 5H0 925 200 P
   Component: DiETa          H06 0007
   Serial number: 92471TKR0017U
   Roof electronics control module:
   Subsystem 5 - Part No SW: 5H0 959 561 H    HW: 5H0 959 561 H
   Component: DACHKONSOLE    006 0006
   Serial number: 92661TKJ01906-------
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000020112004221596
   Subsystem 7 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 38292427
1074808 - Unknown Error Code
          B1ABB 00 [047] - -
          [Transportschutz aktiv]
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:11
15401216 - Unknown Error Code
          U14FE 00 [040] - -
          [Sichere on-board Kommunikation: Signaturüberprüfung fehlgeschlagen]
                    Reset counter: 20
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 18:02:19
15403264 - Release / Enable Active
          B184C 00 [040] - -
          [Freischaltung aktiv]
                    Reset counter: 18
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:50:12
527872 - Transport Mode Active
          U1105 00 [046] - -
                    Fault Frequency: 13
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:11
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 5WA 919 298 A    HW: 5WA 919 298
   Component: PLA 12K Kanal H04 0230
   Serial number: 000021112094560
   Coding: 8200026011
   ASAM Dataset: EV_EPHBO2CVW3800000 002028
   ROD: EV_EPHBO2CVW3800000_VW38.rod
1114112 - Unknown Error Code
          B1AE2 00 [038] - -
          [sound_ouput_parkassist_disturbed]
                    Reset counter: 40
                    Mileage: 6 km
                    Date: 2021.01.23
                    Time: 03:34:08
13688835 - Databus
          U1123 00 [038] - Received Error Message
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 40
                    Mileage: 6 km
                    Date: 2021.01.23
                    Time: 03:34:26
   Part No SW: 5WA 907 572 B    HW: 5WA 907 572
   Component: ACC Bosch MQB H20 0395
   Coding: 2E0318FF0077404512474008004040054E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
   ROD: EV_FRONTRADARBOSCHVW380_004.rod
   VCID: 4DCC027C9D5516733C4-8018
0110 - Transport Mode Active
          U1105 00 [047] - -
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:07
0790 - Databus
          U1122 00 [040] - Implausible Message
                    Reset counter: 40
                    Mileage: 5 km
                    Date: 2020.12.11
                    Time: 01:16:50
   Part No SW: 5WA 959 655 J    HW: 5WA 959 655 J
   Component: AirbagVW40    007 0636
   Serial number: 000000003C0J0R6
   Coding: 88CC000000C0C000000000400000000051540000205400004000F68000130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X_VW38.rod
   VCID: 5EEEF530C0B39DEBD5E-800A
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5H0 980 945 A    HW: 5H0 980 945 A
   Component: BeltPretRevFL  005 0560
   Serial number: 00000000000000300033
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5H0 980 946 A    HW: 5H0 980 946 A
   Component: BeltPretRevFR  005 0560
   Serial number: 00000000000000200046
   Subsystem 3 - Part No SW: -----------    HW: 480 400 112 20
   Component: SideSensor_Dr  002 6149
   Serial number: 35100010E6387734817Z
   Subsystem 4 - Part No SW: -----------    HW: 480 400 212 20
   Component: SideSensor_Pr  002 6149
   Serial number: 3520001126387734D7E0
   Subsystem 5 - Part No SW: -----------    HW: 480 003 010 20
   Serial number: 3570000000050798FC4W
   Subsystem 6 - Part No SW: -----------    HW: 480 000 611 20
   Serial number: 35800000000479297D4S
   Subsystem 7 - Part No SW: -----------    HW: 480 402 311 20
   Component: FrontSensor_D  002 614A
   Serial number: 35500011463FB755E4AD
7 Faults Found:
9980928 - Release / Enable Active
          B184C 00 [008] - -
          [ECU unlocked]
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:52:19
1075462 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_CW]
                    Reset counter: 1
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:12
1075463 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_Kollisionsueberdeckung]
                    Reset counter: 1
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:12
1075465 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_v_rel]
                    Reset counter: 1
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:12
1075461 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_Objektstatus]
                    Reset counter: 1
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:12
1075464 - Databus
          [NWD: 0x0DB AWV_03 error value AWV_Time_to_collision]
                    Fault Frequency: 14
                    Reset counter: 2
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:12
9444359 - Safety belt switch - driver side
          B101C 07 [009] - Mechanical Failure
                    Reset counter: 2
                    Mileage: 6 km
                    Date: 2020.12.24
                    Time: 05:14:55
   Part No SW: 5H0 920 340 A    HW: 5H0 920 340 A
   Component: KOMBI         203 3450
   Coding: 04A401406B9C00080180620B2000080800300400
   ASAM Dataset: EV_DashBoardVDDMQB37W 003032
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
   VCID: 20128BC8BA47EB1BA72-8074
16777018 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 42
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:22
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 42
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:22
16777022 - Control unit for information electronics 1
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 42
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:22
16711686 - Unknown Error Code
          U14FE 00 [008] - -
          [SOK_signature_verification_failed]
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 18:02:15
16711687 - Unknown Error Code
          U14FF 00 [008] - -
          [SOK_signature_creation_failed]
                    Reset counter: 40
                    Mileage: 6 km
                    Date: 2021.01.05
                    Time: 00:18:25
16711684 - Release / Enable Active
          B184C 00 [008] - -
                    Reset counter: 41
   Part No SW: 5WA 907 530 J    HW: 5WA 907 530 C
   Component: GW2020 High   752 7083
   Revision: --------    Serial number: 771049050020335
   Coding: 0000810D6700000003000000010303367301610902000100030100010001010000000000000000000000000000000000
   ASAM Dataset: EV_GatewMQB2020 004008
   ROD: EV_GatewMQB2020_VW38.rod
   VCID: 4FF01874975924634E8-801A
   Subsystem 1 - Part No SW: 5WA 915 181 D    HW: 5WA 915 181 D
   Component: J367-BDMConti  H04 1070
   Serial number: 764071030020112900DC
   Subsystem 2 - Part No SW: 3G0 959 442 S    HW: 3G0 959 442 S
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440066332201365
   Steering Wheel Touch Recognition Control Module:
   Subsystem 3 - Part No SW: 5H0 959 542 A    HW: 5H0 959 542 A
   Component: KLR_JSS_1Zone  076 0019
12320 - Transport Mode Active
          U1105 00 [047] - -
                    Fault Frequency: 65
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:07
12400 - Release / Enable Active
          B184C 00 [032] - -
                    Fault Frequency: 0
                    Reset counter: 0
                    Time: 00:00:00
8466689 - VKMS
          B18B0 F0 [040] - Missing Adaptation
          [VKMS_new_download_container_required_due_to_vehicle_change]
                    Reset counter: 22
                    Mileage: 6 km
                    Date: 2021.01.05
                    Time: 00:17:53
Address 23: Brake Booster (J539)       Labels: None
   Part No SW: 5WA 909 059 H    HW: 3Q0 909 059 A
   Component: EBKV          H06 0112
   Serial number: BPA085041120013
   Coding: 1302C104730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 014027
   ROD: EV_BrakeBoostG2BoschVW37W_014.rod
   VCID: 55FCEA1CB5855EB3844-8000
107024 - Unknown Error Code
          U14E4 00 [032] - -
          [Scl_Getriebe_11_GE_Fahrstufe_Error]
1024304 - Release / Enable Active
          B184C 00 [040] - -
          [SECDIAG_ROLE_UNLOCKED]
                    Reset counter: 18
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:00
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 20000287132004
   Coding: 8800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002004
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 32367180E4AB698B416-8066
   Part No SW: 5WA 959 760 H    HW: 5WA 959 760 H
   Component: MEM-FS        009 0361
   Serial number: 20A2901KA02743
   Coding: 01589A400000B0508803010101010000000000212100000000000000215000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   VCID: 59E4E62CD99D7AD3A0C-800C
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 E    HW: 2Q0 907 686 E
   Component: HRE_Master    H25 0284
   Serial number: 00000560922532
   Coding: 5AA945D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   VCID: 3C2A5FB836EFAFFB9BA-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 E    HW: 2Q0 907 685 E
   Component: HRE_Slave      H25 0284
   Serial number: 00000561692801
   Lane change assistance display left:
   Subsystem 2 - Part No SW: 5H1 949 145     HW: 5H1 949 145
   Component: SWA LED VL     H05 0005
   Serial number: 00000000000016909060
   Lane change assistance display right:
   Subsystem 3 - Part No SW: 5H1 949 146     HW: 5H1 949 146
   Component: SWA LED VR     H05 0005
1245184 - Transport Mode Active
          U1105 00 [046] - -
          [The transportation mode is active]
                    Fault Priority: 9
                    Fault Frequency: 18
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:06
2240562 - Databus
          U1123 00 [046] - Received Error Message
          [databus error value received - MainUnit_01 - MIB_Tongenerator_PH_verfuegbar]
                    Reset counter: 40
                    Mileage: 6 km
                    Date: 2021.01.23
                    Time: 03:34:09
2232369 - Databus
          [databus error value received - MainUnit_01 - MIB_ASW_Diagnose]
                    Fault Frequency: 13
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:23
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TJS14417
   Coding: 003B1B20D200048000001000
   VCID: 49C4366C693D0A5310C-801C
   Subsystem 1 - Part No SW: 5Q0 959 408 G    HW: 5Q0 959 164 C
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000045560087
   Coding: 110000
   Part No SW: 5WA 907 144 G    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  102 1040
   Serial number: 00106107
   Coding: 0000000000000100000102010100010000000101010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 007046
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
Address 4B: Multifunc. Module (J745)       Labels:* None
   Part No SW: 5WA 907 338     HW: 5WA 907 338
   Component: FCM2020 Low   009 1372
   Serial number: 150151220452154
   Coding: 00000000090007CA00002F10020003000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW38X 002010
   ROD: EV_MultiModulContiVW38X_002_VW38.rod
   VCID: 0B48CC6423C15843E20-805E
          B184C 00 [008] - -
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:50:06
          B184C 00 [008] - -
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:50:06
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TK10368A
   Coding: 003B1120DE00048000801000
   VCID: 48C233687237F35B0F2-801C
   Subsystem 1 - Part No SW: 5Q0 959 407 G    HW: 5Q0 959 163 C
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000045363266
   Coding: 090000
   Part No SW: 5H0 035 820 D    HW: 5H0 035 820
   Component: MU-O-ND-EU    H56 1788
   Serial number: WG8LGM021220000
   Coding: 23820000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_VW38.rod
   VCID: 231884C4AB51F003BA0-8076
   Subsystem 1 - Part No SW: 5H0 919 605 B    HW: 5H0 919 605 B
   Component: ABT_W_10       H41 3074
   Serial number: VDD02420112012210408
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 809 CP    HW: -----------
   Component: EU 2021        --- 4031
Address 61: Battery Regul. (A6)       Labels: None
   Part No SW: 5WA 915 107     HW: 5WA 915 107
   Component: BMS_48V_LiIon H10 0445
   Serial number: 252000013395000
   ASAM Dataset: EV_BMSmHevCATL 003004
   ROD: EV_BMSmHevCATL.rod
   VCID: 045AE7580E9F173BA3A-8050
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 5WA 980 556 B    HW: 5WA 980 556 B
   Component: RV eCompact   H26 0254
   Serial number: FCLK20031020000
   Coding: 02030060E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 009020
   ROD: EV_CamSysRVCCompaFicos.rod
   VCID: 50F21B088A673B9B572-8004
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 5WC 959 107     HW: 5WC 959 107
   Component: HDSG-Modul    H04 0430
   Revision: --------    Serial number: A2-C767-1160-5
   Coding: 2008
   ASAM Dataset: EV_DeckLidCONTIAU536 001001
   ROD: EV_DeckLidCONTIAU536.rod
   VCID: 0E4EC57050D36D6B05E-805A
   Part No SW: 5WA 035 284 C    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H12 0135
   Serial number: 0000000010VITDB
   Coding: 023800109068A8209405460071502E07
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 46DE3D507823E52BFDE-8012
7248 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [InfotainmentSettings (0x50) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Reset counter: 40
                    Mileage: 6 km
                    Date: 2021.01.04
                    Time: 21:14:08
                    Voltage terminal 30: 14.2 V
1644017 - Online Services
          B1915 F1 [008] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
                    Fault Frequency: 11
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:50:04
                    Voltage terminal 30: 12.6 V
                    Remaining long term energy budget: 3600 mAh
                    Remaining short term energy budget: 0 mAh
                    Wake up cycles counter: 25
1592320 - Release / Enable Active
          B184C 00 [008] - -
                    Reset counter: 39
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:50:04
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H06 3129
   Serial number: E57830711203330
   Coding: 00000888116CC040109E40001030008000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 5WA 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0111
   Serial number: DC20481000763
   ASAM Dataset: EV_DCDC48VFLEXAU581 004003
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
   VCID: 1378D4047BF180832A0-8046
Address CC: Starter-Generator (C29)       Labels: None
   Part No SW: 05E 903 018 G    HW: 05E 903 018 G
   Component: iBSG4U_000    H16 0224
   Serial number: 5201123082928
   ASAM Dataset: EV_SGCM600210005E903018G 002004
   ROD: EV_SGCM600210005E903018G.rod
   VCID: 261E9DD0D863052BDDE-8072
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 659CDADCE5E5CE33144-8030
   Component: LED1R         H08 9202
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 B    HW: 5WA 035 741 B
   Component: TrxModulHigh  H10 0078
   Serial number: 0000000011VITD1
   Coding: 02382011040080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
   VCID: 43D824444B11D003DA0-8016
          B184C 00 [032] - -
0083 - Unknown Error Code
          U1541 00 [032] - -
          [Ethernet-Datenbus - fehlende Botschaft von der Informationselektronik]
Address 811E: Burglary Protection FL (J518)       Labels: None
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w.rod
   VCID: 47C030547F29FC23068-8012
          U1105 00 [009] - -
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:11
Address 811F: Burglary Protection FR (J518)       Labels: None
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w.rod
          U1105 00 [009] - -
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:11
Address 8120: Burglary Protection RL (J518)       Labels: None
   ASAM Dataset: EV_RSADHL37w 002013
          U1105 00 [009] - -
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:11
Address 8121: Burglary Protection RR (J518)       Labels: None
   ASAM Dataset: EV_RSADHR37w 002013
          U1105 00 [009] - -
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2020.12.09
                    Time: 17:53:11
End----------(Elapsed Time: 01:51, VBatt start/end: 14.8V/14.9V)-----------
From autoscan and WD, I think it should be something like this:
DV52
C?ID=194404
@NEtech : Interesting - thanks for posting. So you are suggesting that on a mk8, J527 has been relegated from a directly CAN connected module on mk7/7.5 - to being a LIN slave of the BCM? Increases the role of the BCM further-wonder whether this will be a trend on future MQB models (i.e. a greater emphasis on distributed module intelligence, rather than centralized CAN communication)?
As these cars get more sophisticated, the demands on a centralized CAN bus increases - another option to manage increased traffic on the CAN network probably might be to add more buses, but I guess eventually the congestion coalesces at J533. I suppose greater distributed module intelligence (i.e. more LIN buses) is preferable where the slave module activity is simple - maybe?
Have you seen a SSP for the mk8?
NEtech
C?ID=56995
Yes there a 2 available on erwin, 702 and 706, but there is not yet an complete overview of all controllers.
ghost
C?ID=139898
New Passat wheel can be made to work in MK7, however airbag wiring needs to be altered. See vid below
If you thinking about MK8 wheel - that can be made to work as well, but coding is required
See vid below
Regards
Johan1
C?ID=359010
ok i did yestreday the same retrofit so the MFSW MK8 on Passat B8 and result all butt5ons works except the distance for acc and the sped limiter
after my research i cam out with 2 conclusions:
one told me about the right coding in the steering wheel must be done
other one told me that the right coding must be done in 19
so tell now im still hoping to find the right pad to the right solution
any tips or hints i appreciated guys
Spacewalker
C?ID=159607
both must be do
Adaptation in GW, and proper coding Slave - MFSW
Got new MFSW with touch button and ACC was not there ...but it was on PCB
after compare coding , I enable ACC
downtime
C?ID=280813
Like Spacewalker wrote as well, both must be coded. But to get the ACC button lighted up and working you need to change the respective adaptation channel in the module 19 CAN gateway. There's adaptation channels for MFL multifunction steering wheel. Change ACC adaptation channel from automatic -> Activated.
Johan1
C?ID=359010
thanks space walker and downtime i will give it a try and feed you guys back
appreciated
downtime
C?ID=280813
Would be good to see autoscan from your car in it’s current state. The touch wheel needs a gateway to be 3q0 AC or later for these channels to be there.
Johan1
C?ID=359010
mate, i have a 5q gateaway all is working and i miss only two buttons only the sped limiter and distace change for acc
cheers
