Friday,22,January,2021,14:36:44:16513
VCDS Version: 21.1.0.1 (x64) HEX-NET2 CB: 0.4540.4
Data version: 20201124 DS324.0
Workshop Code: 204 00578 345678
VIN: WVWZZZCDZMW8xxxxx License Plate:
Mileage: 6km-3mi Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 4B 4B 52
5F 61 6C 6D 75 A5 C4 CC D6 D7 8107 811E 811F 8120 8121 C002 C003
VIN: WVWZZZCDZMW8xxxxx Mileage: 6km-3miles
23-Brake Booster -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
8107-Antenna -- Status: OK 0000
811E-Burglary Protection FL -- Status: Malfunction 0010
811F-Burglary Protection FR -- Status: Malfunction 0010
8120-Burglary Protection RL -- Status: Malfunction 0010
8121-Burglary Protection RR -- Status: Malfunction 0010
Address 01: Engine (J623-DFYA) Labels: None
Part No SW: 05E 906 012 Q HW: 05E 907 309 G
Component: R4 1.5l TFS H20 1131
Revision: 89H20000
Coding: 0125003223641D0830086000000000000000000000000000
ASAM Dataset: EV_ECM15TFS01105E906012Q 002004
ROD: EV_ECM15TFS01105E906012Q.rod
VCID: 2D0C62FCFD9536731C4-8078
44047 - Front Camera for Driver Assist Systems
U1229 00 [032] - Implausible Message
Reset counter: 40
Mileage: 4 km
Date: 2020.12.10
Time: 08:15:03
Engine RPM: 1730.00 /min
Normed load value: 23.5 %
Vehicle speed: 31 km/h
Coolant temperature: 85 °C
Intake air temperature: 23 °C
Voltage terminal 30: 13.920 V
Outside temperature: 4 °C
Absolute intake pressure: 56 kPa abs
Engine torque: 61.9 Nm
Fuel: tank fill level: 3.0 l
Oxygen sensor B1: sensor 1: specified value: 1.0000
Particulate filter: loading stage: 0
Overrun cut-off-Bits 0-7: 0
14690 - Loading Mode active
P169A 00 [175] - -
Reset counter: 0
Mileage: 3 km
Date: 2020.12.09
Time: 17:54:11
Engine RPM: 0.00 /min
Coolant temperature: 70 °C
Intake air temperature: 42 °C
Voltage terminal 30: 12.560 V
Unlearning counter according OBD: 0
Outside temperature: 215 °C
Absolute intake pressure: 99 kPa abs
Engine torque: 0.0 Nm
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0CW 906 556 M HW: 0CW 300 051 N
Component: GSG DQ200G2.1 H07 0562
Serial number: CU502011227807
ASAM Dataset: EV_TCMDQ200022 001001
ROD: EV_TCMDQ200022_VW38.rod
VCID: 56FEED10A88355AB8DE-8002
Parking lock:
Subsystem 1 - Part No SW: 5WA 713 033 AM HW: 610 5
Component: ZSB_SB_AUTO H08 1034
Serial number: 20201029000063173691
Selector lever:
Subsystem 2 - Part No SW: 5H0 713 059 Q HW: 5H0 713 059 Q
Component: ZSB_SB_Mono H03 0013
Serial number: 92478TKK01484
41777 - Loading Mode active
P169A 00 [047] - -
Fault Frequency: 14
Reset counter: 1
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:07
Engine torque: 0 Nm
Control Module temperature: 39 °C
CURRENT pressure: 38.0 bar
Clutch: primary stat: Neutral
selected gear: GANG_R
Driving position: P
Accelerator pedal position: 14.5 %
DTC memory status: 308
Part No SW: 5WA 614 517 BH HW: 5WA 614 517 P
Component: ESC H14 0129
Serial number: 63230000002162
Coding: 44FC22902220446E527E600006C76186ADB558504AC86708A1BCA231018FF141822814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013054
ROD: EV_Brake1ESCEPBMQB37W_013.rod
VCID: 0F70D87457D964630E8-805A
1905 - Transport Mode Active
U1105 00 [047] - -
Reset counter: 0
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:06
Vehlicle_speed: 0.0 km/h
Resolution Mileage: 560 m
Voltage_value_KL.30_ESC_V: 12.4 V
Wake up EPB: not active
Wake up CAN: not active
Postrun_activ: not active
Comparison_pressure_sensor: completed successfully
Comparison_longitudinal_accleration: completed successfully
Comparison_transverse_accleration: completed successfully
Comparison_yaw_rate_sensor: completed successfully
LWS_comparison: completed successfully
Internal_failure_code: 01 73
00 00 40 00 04 0C 80 08 20 84 80 80 80 00 00 40 00 00 08 40 04
590080 - Release / Enable Active
B184C 00 [032] - -
[Unlock_protection_of_vehicle_diagnosis_active]
Reset counter: 39
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:00
Voltage_value_KL.30_ESC_V: 12.2 V
Internal_failure_code: 01 AE
00 00 40 00 04 0C 80 08 80 84 80 80 80 00 00 40 00 00 08 40 04
Address 05: Acc/Start Auth. (J518) Labels: None
Part No SW: 5WA 959 436 C HW: 5WA 959 436 C
Component: Kessy IOBOX 070 0706
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 003022
ROD: EV_Kessy37w.rod
VCID: 54FA1718BE7F47BB73A-8000
1077250 - Transport Mode Active
U1105 00 [009] - -
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:11
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 5WA 907 727 P HW: 5WA 907 727 P
Component: Climatronic H02 0340
Coding: 202000010011120010100010111011110000131100200000000000000000
ASAM Dataset: EV_ACClimaBHBVW38X 005067
ROD: EV_ACClimaBHBVW38X_VW38.rod
VCID: 5DECF23CCDB586F3CC4-8008
Air quality sensor:
Subsystem 1 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H02 0003
Serial number: 00000000000000318511
Rear A/C control head:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
Interior temperature sensor:
Subsystem 3 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00001270920140159509
131076 - Function Restricted due to Insufficient Voltage
U1400 00 [040] - -
Fault Frequency: 0
B10CD 00 [044] - -
[Function limitation due to energy management 03]
Reset counter: 40
Mileage: 6 km
Date: 2021.01.23
Time: 03:34:23
Voltage terminal 30: 11.50 V
CAN input signal(s) status-Transport mode: OFF
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
CAN input signal(s) status-Back-up lamp: OFF
Blower reduction: No switch-off: no reduction
0515 - Transport Mode Active
U1105 00 [044] - -
Reset counter: 40
Mileage: 6 km
Date: 2021.01.23
Time: 03:34:02
Part No SW: 5WA 937 086 E HW: 5WA 937 086 E
Component: BCM 37W BOSCH 018 0158
Serial number: BXJ53F011220940
ASAM Dataset: EV_BCM37w 006001
ROD: EV_BCM37w_006_VW38.rod
VCID: 53F81404BB7140836A0-8006
Wiper motor control module:
Subsystem 1 - Part No SW: 5H1 955 119 HW: 5H1 955 119
Component: FWISCHER_MYJT 003 0051
Serial number: 907453F0302030800755
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: SBY20M11D24H03M16S44
Subsystem 3 - Part No SW: 5H0 941 193 AD HW: 5H0 941 193 AD
Component: LiSi H05 0007
Serial number: 92471TKJ000YD
Control head for driving and comfort functions:
Subsystem 4 - Part No SW: 5H0 925 200 P HW: 5H0 925 200 P
Component: DiETa H06 0007
Serial number: 92471TKR0017U
Roof electronics control module:
Subsystem 5 - Part No SW: 5H0 959 561 H HW: 5H0 959 561 H
Component: DACHKONSOLE 006 0006
Serial number: 92661TKJ01906-------
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 507 GB HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000020112004221596
Subsystem 7 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 38292427
1074808 - Unknown Error Code
B1ABB 00 [047] - -
[Transportschutz aktiv]
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:11
15401216 - Unknown Error Code
U14FE 00 [040] - -
[Sichere on-board Kommunikation: Signaturüberprüfung fehlgeschlagen]
Reset counter: 20
Mileage: 3 km
Date: 2020.12.09
Time: 18:02:19
15403264 - Release / Enable Active
B184C 00 [040] - -
[Freischaltung aktiv]
Reset counter: 18
Mileage: 3 km
Date: 2020.12.09
Time: 17:50:12
527872 - Transport Mode Active
U1105 00 [046] - -
Fault Frequency: 13
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:11
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 298 A HW: 5WA 919 298
Component: PLA 12K Kanal H04 0230
Serial number: 000021112094560
Coding: 8200026011
ASAM Dataset: EV_EPHBO2CVW3800000 002028
ROD: EV_EPHBO2CVW3800000_VW38.rod
1114112 - Unknown Error Code
B1AE2 00 [038] - -
[sound_ouput_parkassist_disturbed]
Reset counter: 40
Mileage: 6 km
Date: 2021.01.23
Time: 03:34:08
13688835 - Databus
U1123 00 [038] - Received Error Message
[Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Reset counter: 40
Mileage: 6 km
Date: 2021.01.23
Time: 03:34:26
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 572 B HW: 5WA 907 572
Component: ACC Bosch MQB H20 0395
Coding: 2E0318FF0077404512474008004040054E4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
ROD: EV_FRONTRADARBOSCHVW380_004.rod
VCID: 4DCC027C9D5516733C4-8018
0110 - Transport Mode Active
U1105 00 [047] - -
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:07
0790 - Databus
U1122 00 [040] - Implausible Message
Reset counter: 40
Mileage: 5 km
Date: 2020.12.11
Time: 01:16:50
Address 15: Airbags (J234) Labels:* None
Part No SW: 5WA 959 655 J HW: 5WA 959 655 J
Component: AirbagVW40 007 0636
Serial number: 000000003C0J0R6
Coding: 88CC000000C0C000000000400000000051540000205400004000F68000130065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
ROD: EV_AirbaVW40SMEVW38X_VW38.rod
VCID: 5EEEF530C0B39DEBD5E-800A
Left seat belt tensioner:
Subsystem 1 - Part No SW: 5H0 980 945 A HW: 5H0 980 945 A
Component: BeltPretRevFL 005 0560
Serial number: 00000000000000300033
Right seat belt tensioner:
Subsystem 2 - Part No SW: 5H0 980 946 A HW: 5H0 980 946 A
Component: BeltPretRevFR 005 0560
Serial number: 00000000000000200046
Subsystem 3 - Part No SW: ----------- HW: 480 400 112 20
Component: SideSensor_Dr 002 6149
Serial number: 35100010E6387734817Z
Subsystem 4 - Part No SW: ----------- HW: 480 400 212 20
Component: SideSensor_Pr 002 6149
Serial number: 3520001126387734D7E0
Subsystem 5 - Part No SW: ----------- HW: 480 003 010 20
Serial number: 3570000000050798FC4W
Subsystem 6 - Part No SW: ----------- HW: 480 000 611 20
Serial number: 35800000000479297D4S
Subsystem 7 - Part No SW: ----------- HW: 480 402 311 20
Component: FrontSensor_D 002 614A
Serial number: 35500011463FB755E4AD
7 Faults Found:
9980928 - Release / Enable Active
B184C 00 [008] - -
[ECU unlocked]
Mileage: 3 km
Date: 2020.12.09
Time: 17:52:19
1075462 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_CW]
Reset counter: 1
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:12
1075463 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_Kollisionsueberdeckung]
Reset counter: 1
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:12
1075465 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_v_rel]
Reset counter: 1
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:12
1075461 - Databus
[NWD: 0x0DB AWV_03 error value SDF_PSF_Objektstatus]
Reset counter: 1
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:12
1075464 - Databus
[NWD: 0x0DB AWV_03 error value AWV_Time_to_collision]
Fault Frequency: 14
Reset counter: 2
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:12
9444359 - Safety belt switch - driver side
B101C 07 [009] - Mechanical Failure
Reset counter: 2
Mileage: 6 km
Date: 2020.12.24
Time: 05:14:55
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 5H0 920 340 A HW: 5H0 920 340 A
Component: KOMBI 203 3450
Coding: 04A401406B9C00080180620B2000080800300400
ASAM Dataset: EV_DashBoardVDDMQB37W 003032
ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
VCID: 20128BC8BA47EB1BA72-8074
16777018 - Control unit for information electronics 1
U1054 00 [008] - No Communication
[Audio_0x31 communication error bap_error_timeout heartbeat]
Reset counter: 42
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:22
16777020 - Control unit for information electronics 1
[TEL_0x28 communication error bap_error_timeout heartbeat]
Reset counter: 42
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:22
16777022 - Control unit for information electronics 1
[NAV_SD_0x32 communication error bap_error_timeout heartbeat]
Reset counter: 42
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:22
16711686 - Unknown Error Code
U14FE 00 [008] - -
[SOK_signature_verification_failed]
Mileage: 3 km
Date: 2020.12.09
Time: 18:02:15
16711687 - Unknown Error Code
U14FF 00 [008] - -
[SOK_signature_creation_failed]
Reset counter: 40
Mileage: 6 km
Date: 2021.01.05
Time: 00:18:25
16711684 - Release / Enable Active
B184C 00 [008] - -
Reset counter: 41
Part No SW: 5WA 907 530 J HW: 5WA 907 530 C
Component: GW2020 High 752 7083
Revision: -------- Serial number: 771049050020335
Coding: 0000810D6700000003000000010303367301610902000100030100010001010000000000000000000000000000000000
ASAM Dataset: EV_GatewMQB2020 004008
ROD: EV_GatewMQB2020_VW38.rod
VCID: 4FF01874975924634E8-801A
Subsystem 1 - Part No SW: 5WA 915 181 D HW: 5WA 915 181 D
Component: J367-BDMConti H04 1070
Serial number: 764071030020112900DC
Subsystem 2 - Part No SW: 3G0 959 442 S HW: 3G0 959 442 S
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440066332201365
Steering Wheel Touch Recognition Control Module:
Subsystem 3 - Part No SW: 5H0 959 542 A HW: 5H0 959 542 A
Component: KLR_JSS_1Zone 076 0019
12320 - Transport Mode Active
U1105 00 [047] - -
Fault Frequency: 65
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:07
12400 - Release / Enable Active
B184C 00 [032] - -
Fault Frequency: 0
Reset counter: 0
Time: 00:00:00
8466689 - VKMS
B18B0 F0 [040] - Missing Adaptation
[VKMS_new_download_container_required_due_to_vehicle_change]
Reset counter: 22
Mileage: 6 km
Date: 2021.01.05
Time: 00:17:53
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 H HW: 3Q0 909 059 A
Component: EBKV H06 0112
Serial number: BPA085041120013
Coding: 1302C104730000CE39E79C73000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 014027
ROD: EV_BrakeBoostG2BoschVW37W_014.rod
VCID: 55FCEA1CB5855EB3844-8000
107024 - Unknown Error Code
U14E4 00 [032] - -
[Scl_Getriebe_11_GE_Fahrstufe_Error]
1024304 - Release / Enable Active
B184C 00 [040] - -
[SECDIAG_ROLE_UNLOCKED]
Reset counter: 18
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:00
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H09 0040
Serial number: 20000287132004
Coding: 8800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002004
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 32367180E4AB698B416-8066
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 5WA 959 760 H HW: 5WA 959 760 H
Component: MEM-FS 009 0361
Serial number: 20A2901KA02743
Coding: 01589A400000B0508803010101010000000000212100000000000000215000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013
ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
VCID: 59E4E62CD99D7AD3A0C-800C
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 E HW: 2Q0 907 686 E
Component: HRE_Master H25 0284
Serial number: 00000560922532
Coding: 5AA945D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
ROD: EV_HREntryHellaGen3Mstr_VW38.rod
VCID: 3C2A5FB836EFAFFB9BA-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 E HW: 2Q0 907 685 E
Component: HRE_Slave H25 0284
Serial number: 00000561692801
Lane change assistance display left:
Subsystem 2 - Part No SW: 5H1 949 145 HW: 5H1 949 145
Component: SWA LED VL H05 0005
Serial number: 00000000000016909060
Lane change assistance display right:
Subsystem 3 - Part No SW: 5H1 949 146 HW: 5H1 949 146
Component: SWA LED VR H05 0005
1245184 - Transport Mode Active
U1105 00 [046] - -
[The transportation mode is active]
Fault Priority: 9
Fault Frequency: 18
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:06
2240562 - Databus
U1123 00 [046] - Received Error Message
[databus error value received - MainUnit_01 - MIB_Tongenerator_PH_verfuegbar]
Reset counter: 40
Mileage: 6 km
Date: 2021.01.23
Time: 03:34:09
2232369 - Databus
[databus error value received - MainUnit_01 - MIB_ASW_Diagnose]
Fault Frequency: 13
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:23
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0330
Serial number: YE007TJS14417
Coding: 003B1B20D200048000001000
VCID: 49C4366C693D0A5310C-801C
Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000045560087
Coding: 110000
Part No SW: 5WA 907 144 G HW: 5WA 907 144 C
Component: BASGEN1MQB37 102 1040
Serial number: 00106107
Coding: 0000000000000100000102010100010000000101010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 007046
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5WA 907 338 HW: 5WA 907 338
Component: FCM2020 Low 009 1372
Serial number: 150151220452154
Coding: 00000000090007CA00002F10020003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW38X 002010
ROD: EV_MultiModulContiVW38X_002_VW38.rod
VCID: 0B48CC6423C15843E20-805E
B184C 00 [008] - -
Mileage: 3 km
Date: 2020.12.09
Time: 17:50:06
B184C 00 [008] - -
Mileage: 3 km
Date: 2020.12.09
Time: 17:50:06
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0330
Serial number: YE007TK10368A
Coding: 003B1120DE00048000801000
VCID: 48C233687237F35B0F2-801C
Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000045363266
Coding: 090000
Part No SW: 5H0 035 820 D HW: 5H0 035 820
Component: MU-O-ND-EU H56 1788
Serial number: WG8LGM021220000
Coding: 23820000000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 001002
ROD: EV_MUOIMQB37w_VW38.rod
VCID: 231884C4AB51F003BA0-8076
Subsystem 1 - Part No SW: 5H0 919 605 B HW: 5H0 919 605 B
Component: ABT_W_10 H41 3074
Serial number: VDD02420112012210408
Data carrier:
Subsystem 2 - Part No SW: V03 959 809 CP HW: -----------
Component: EU 2021 --- 4031
Address 61: Battery Regul. (A6) Labels: None
Part No SW: 5WA 915 107 HW: 5WA 915 107
Component: BMS_48V_LiIon H10 0445
Serial number: 252000013395000
ASAM Dataset: EV_BMSmHevCATL 003004
ROD: EV_BMSmHevCATL.rod
VCID: 045AE7580E9F173BA3A-8050
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 5WA 980 556 B HW: 5WA 980 556 B
Component: RV eCompact H26 0254
Serial number: FCLK20031020000
Coding: 02030060E43000
ASAM Dataset: EV_CamSysRVCCompaFicos 009020
ROD: EV_CamSysRVCCompaFicos.rod
VCID: 50F21B088A673B9B572-8004
Address 6D: Trunk Elect. (J605) Labels:* None
Part No SW: 5WC 959 107 HW: 5WC 959 107
Component: HDSG-Modul H04 0430
Revision: -------- Serial number: A2-C767-1160-5
Coding: 2008
ASAM Dataset: EV_DeckLidCONTIAU536 001001
ROD: EV_DeckLidCONTIAU536.rod
VCID: 0E4EC57050D36D6B05E-805A
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 284 C HW: 5WA 035 284 C
Component: OCU3HMQB37W H12 0135
Serial number: 0000000010VITDB
Coding: 023800109068A8209405460071502E07
ASAM Dataset: EV_OCU3HMQB37W 002012
ROD: EV_OCU3HMQB37W_002_VW38.rod
VCID: 46DE3D507823E52BFDE-8012
7248 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[InfotainmentSettings (0x50) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
Reset counter: 40
Mileage: 6 km
Date: 2021.01.04
Time: 21:14:08
Voltage terminal 30: 14.2 V
1644017 - Online Services
B1915 F1 [008] - Temporary Function Restriction due to Battery Budget
[Functional restriction due to insufficient power budget]
Fault Frequency: 11
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:50:04
Voltage terminal 30: 12.6 V
Remaining long term energy budget: 3600 mAh
Remaining short term energy budget: 0 mAh
Wake up cycles counter: 25
1592320 - Release / Enable Active
B184C 00 [008] - -
Reset counter: 39
Mileage: 3 km
Date: 2020.12.09
Time: 17:50:04
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 5WA 980 653 A HW: 5WA 980 653
Component: MQB MFK 3.0 H06 3129
Serial number: E57830711203330
Coding: 00000888116CC040109E40001030008000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005050
ROD: EV_MFK3ValeoMQB_005_VW38.rod
Address C4: DC/DC Converter (A7) Labels: None
Part No SW: 5WA 959 663 HW: 4K0 959 663
Component: DCDC_GEN_2 H20 0111
Serial number: DC20481000763
ASAM Dataset: EV_DCDC48VFLEXAU581 004003
ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
VCID: 1378D4047BF180832A0-8046
Address CC: Starter-Generator (C29) Labels: None
Part No SW: 05E 903 018 G HW: 05E 903 018 G
Component: iBSG4U_000 H16 0224
Serial number: 5201123082928
ASAM Dataset: EV_SGCM600210005E903018G 002004
ROD: EV_SGCM600210005E903018G.rod
VCID: 261E9DD0D863052BDDE-8072
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 659CDADCE5E5CE33144-8030
Component: LED1R H08 9202
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
Address 8107: Antenna (J666) Labels:* None
Part No SW: 5WA 035 741 B HW: 5WA 035 741 B
Component: TrxModulHigh H10 0078
Serial number: 0000000011VITD1
Coding: 02382011040080
ASAM Dataset: EV_TrxMLGEMQB37W 005006
ROD: EV_TrxMLGEMQB37W.rod
VCID: 43D824444B11D003DA0-8016
B184C 00 [032] - -
0083 - Unknown Error Code
U1541 00 [032] - -
[Ethernet-Datenbus - fehlende Botschaft von der Informationselektronik]
Address 811E: Burglary Protection FL (J518) Labels: None
Part No SW: 5WA 962 133 B HW: 5WA 962 133 B
Component: Kessy RSAD 070 0636
ASAM Dataset: EV_RSADVL37w 002013
ROD: EV_RSADVL37w.rod
VCID: 47C030547F29FC23068-8012
U1105 00 [009] - -
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:11
Address 811F: Burglary Protection FR (J518) Labels: None
ASAM Dataset: EV_RSADVR37w 002013
ROD: EV_RSADHL37w.rod
U1105 00 [009] - -
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:11
Address 8120: Burglary Protection RL (J518) Labels: None
ASAM Dataset: EV_RSADHL37w 002013
U1105 00 [009] - -
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:11
Address 8121: Burglary Protection RR (J518) Labels: None
ASAM Dataset: EV_RSADHR37w 002013
U1105 00 [009] - -
Reset counter: 40
Mileage: 3 km
Date: 2020.12.09
Time: 17:53:11
End----------(Elapsed Time: 01:51, VBatt start/end: 14.8V/14.9V)-----------
