Sunday,10,January,2021,12:49:49:46555
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
VIN: WVWZZZAUZDW049359 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 3C 42 44 47 52 55 57 5F
69 A5
VIN: WVWZZZAUZDW049359 Mileage: 20034km-12448miles
57-TV Tuner -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 N HW: 04L 907 309 B
Component: R4 1,6L EDC H22 4946
Revision: 84H22---
Coding: 09250012035405092000
Shop #: WSC 04520 002 104857
ASAM Dataset: EV_ECM16TDI01104L906021N 002007
ROD: EV_ECM16TDI01104L906021N_002_VW37.rod
VCID: 303A18466AA80E3BC32-8064
Part No SW: 0CW 300 044 S HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4510
Revision: 00043014 Serial number: CU501211176502
ROD: EV_TCMDQ200021_VW37.rod
VCID: 48CA50A6F238A6FBFB2-801C
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 61514000000904
Coding: 01FA6BA134240975037A0605C1CCA980D62C90C0608395FFF9625028C509
Shop #: WSC 00028 028 00067
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 46D65E9EF82CB08B09E-8012
8309 - Engine Control Module Incorrectly Coded
P1612 00 [009] - -
Reset counter: 45
Date: 2021.01.10
Time: 12:08:07
8351 - Databus
[FCAN: Motor_17_alt veraltet bit is set]
Reset counter: 44
Date: 2021.01.10
Time: 12:08:07
8356 - Databus
[FCAN: Klima_11_alt veraltet bit is set]
Reset counter: 44
Date: 2021.01.10
Time: 12:08:07
8368 - Databus
[FCAN: Charisma_07 is not received]
Fault Frequency: 9
Reset counter: 45
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:14
Part No SW: 5G1 907 044 AC HW: 5G1 907 044 AC
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 03020104204101011105010D00101022
ASAM Dataset: EV_ACClimaBHBVW37X 006143
VCID: 698CB52289F2BFF3C4C-803C
Air quality sensor:
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011233300379
Coding: 00061A66C2C122FB4FA44000000C0788140A000000000000000000000000
ROD: EV_BCMBOSCH_010.rod
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150420 043 0551
Serial number: 150424114254
Component: RLFS 024 0042
Serial number: Y12M12D04H20M34S42S1
Coding: 028877
526359 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Steuergerät falsch codiert->Keine Anzeige]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:07
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231231502631
Coding: 0031151211
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_EPHVA18AU3700000 002016
VCID: 3A2E3A6EBCD4C46B7D6-806E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 J HW: 5Q0 907 567 E
Component: ACC3 H06 0395
Serial number: 24021276240295
Coding: 00001F00FE030B
Shop #: WSC 01581 666 28888
ASAM Dataset: EV_ACCBoschMQB 001022
ROD: EV_ACCBoschMQB_VW37.rod
VCID: 42DE428ED4048CAB256-8016
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Serial number: 003F5R01MMS.
VCID: 40DA4886DA089EBB332-8014
Subsystem 1 - Part No SW: ----------- HW: 480 002 106 12
Serial number: 3576700000078498BB00
Subsystem 2 - Part No SW: ----------- HW: 480 002 106 12
Serial number: 358670000001E3F89B04
Subsystem 3 - Part No SW: ----------- HW: 480 401 811 12
Serial number: 3516502A90D5D623537C
Subsystem 4 - Part No SW: ----------- HW: 480 400 412 12
Serial number: 3526502B50D46475B104
Subsystem 5 - Part No SW: ----------- HW: 480 400 612 13
Serial number: 3556502A11220565831R
Part No SW: 5Q0 953 507 JF HW: 5Q0 953 549 D
Component: Lenks. Modul 004 0110
Revision: -------- Serial number: 16101404400952
Coding: 8C20
Shop #: WSC 00078 790 12345
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID: 0350878A8B9E45A36E0-8056
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 405 3190
Coding: 43AD21086E8C000807806E2B0401000080000000
VCID: 2A0E0A2E4C7474EB0D6-807E
U1014 00 [009] - -
Reset counter: 45
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:06
16776980 - Databus
[PLA_Status_01 keine Kommunikation]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:06
16776996 - Databus
[FCW_01 keine Kommunikation]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:06
16777056 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP_SDS_0x46 keine Kommunikation]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:11
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 A HW: 5Q0 963 272 A
Component: STH-MQB 005 0066
Coding: 9309
Shop #: WSC 00028 028 00312
ASAM Dataset: EV_AuxilParkiHeateWOS 002012
VCID: 343214569EB0321BA7A-8060
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 5Q0 963 513 HW: 5Q0 963 513
Component: R149 T91-LIN 003 0301
Serial number: 00000000000000818123
Part No SW: 5Q0 907 530 F HW: 5Q0 907 530 F
Component: GW MQB High 122 1109
Revision: -------- Serial number: 0000203652
Coding: 030100040B087300EF0006581C0F00010001000000000000000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_006.rod
Generator:
Serial number: 29160001908610056387
Coding: 2FFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 0311268501
131693 - TV-Tuner
U105C 00 [009] - No Communication
[Timeout Knoten 0x6D / 57 - TV-Tuner]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:06
Terminal 30 power supply: 14.6 V
Terminal 15: On
U1101 00 [009] - Active
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:06
Terminal 15: On
Component: HRE_Master H11 0071
Serial number: 0363187924
Coding: 01031103
ROD: EV_HREntryHella_VW37.rod
VCID: 3C223C76B6E0FA5B6FA-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0406890441
Coding: 010311
336901 - Databus
[Braking ECU ESP_33 - no signal/no communication]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:06
Component: TSG FS 020 0041
Serial number: 220616EFM19394
Coding: 003F0720D000048000001001
VCID: 43D0478ACB1E85A32E0-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007200009
Coding: 110000
Coding: 11
Shop #: WSC 00028 028 00025
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D243172ADFAF353584-8068
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1HMD017WH-
Coding: 1200000000000000000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
VCID: 2E06063E709C18CBD1E-807A
Component: TSG BFS 020 0041
Serial number: 100716EG922156
Coding: 003F0120DE00048000801001
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004424057
Coding: 390000
Component: LWR-ECU 005 0080
Coding: 051A000001010000
Shop #: WSC 01608 111 28888
VCID: 75B4E952D54A6B13504-8020
Address 57: TV Tuner
Part No SW: 5NA 035 021 HW: 5NA 035 021
Component: MU-H-LND-EU H55 1367
Serial number: A853H0JS070458
Coding: 02730201000000005111120200880233AF0109F481200000FF
VCID: 6FB8DB3AB71651C39A8-803A
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT2950992
Data carrier:
Subsystem 2 - Part No SW: V03 959 806 N HW: -----------
Component: ECE 2020/2021 --- 0187
Compact disc data bank:
Component: Gracenote2 --- 1017
8 Faults Found:
B201A 00 [009] - -
[Check software version management]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:15
Voltage terminal 30: 14.8 V
Status_Software_Version_Management-module_name: MDVB-DTV/MPEG-OS
[Anti-theft protection - component protection active (0xEA6100)]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:10
Voltage terminal 30: 14.7 V
3084 - GSM antenna 2
B1533 13 [009] - Open Circuit
Reset counter: 45
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:10
7179 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:11
BAP-BAP_Function_ID: 02
7191 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:11
7219 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:11
7223 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:11
7237 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Display configuration (0x45) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:11
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 A HW: 5Q0 907 383 A
Component: Anhaenger H10 0030
Revision: 6B001003 Serial number: 00000176223439
Coding: 0100000202000000
Shop #: WSC 01730 666 28888
ASAM Dataset: EV_TrailFunctPivotHella 001001
ROD: EV_TrailFunctDemouHella.rod
VCID: 3534295295CA2B13904-8060
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 C HW: 5Q0 980 653
Component: MQB_MFK H03 0030
Serial number: 00000003485
Coding: 0101010000020303000501010100000101
Shop #: WSC 40657 150 20171
ROD: EV_MFKBoschAU370.rod
VCID: 382A206682D8D67B8B2-806C
2555904 - Databus
[PSD_01_TO_FAILURE]
Reset counter: 44
Mileage: 20034 km
Date: 2021.01.10
Time: 12:08:08
Control Module temperature: 36 °C
Outside temperature: 4.0 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 14.6 V
Terminal 15 on: 881.2 s
End----------(Elapsed Time: 01:58, VBatt start/end: 14.7V/14.6V)-----------
