ACC and Speed Limiter not available - MK7
kakubaz
Zgorzelec, Poland
C?ID=314093
Hey! i'm new member :D
I have a problem with radar (LRR) in my VW Golf mk7 . Before I installed the virtual cockpit, I had no problems with it. Currently, ACC and Speed Limiter functions are not available in my virtual cockpit. I tried the coding from the Spanish PDF from XaGico, but I couldn't fix this problem. Below I paste the logs from 13-Auto Dist. Reg and the results of measurements that were made in one of the posts in this forum.
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 J    HW: 5Q0 907 567 E
   Component: ACC3          H06 0395
   Serial number: 24021276240295
   Coding: 00001F00FE030B
   Shop #: WSC 01581 666 28888
   ASAM Dataset: EV_ACCBoschMQB 001022
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 42DE428ED4048CAB256-8016
Radar measurements:
Misalignment angle - 0.00°
Vertical angle deviation - 0.548828°
Horizontal angle deviation - 0.169922°
Adjustment angle - fast algorithm - 0.00°
I know that these two values should not be zeroes.
Photos:
and after clicking ACC or Speed Limiter:
Does anyone have any idea how to fix it?
Thank You!
ghost
C?ID=139898
Depends how your cockpit has been retrofitted... I've seen few times ODIS has been kicked out on coding procedure and it have to start again. In some cases you have to restore FEC on gateway and ACC after that.
kakubaz
Zgorzelec, Poland
C?ID=314093
Here is my complete Auto-scan:
Sunday,10,January,2021,12:49:49:46555
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: WVWZZZAUZDW049359   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 3C 42 44 47 52 55 57 5F
          69 A5
VIN: WVWZZZAUZDW049359   Mileage: 20034km-12448miles
57-TV Tuner -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 4946
   Revision: 84H22---
   Coding: 09250012035405092000
   Shop #: WSC 04520 002 104857
   ASAM Dataset: EV_ECM16TDI01104L906021N 002007
   ROD: EV_ECM16TDI01104L906021N_002_VW37.rod
   VCID: 303A18466AA80E3BC32-8064
   Part No SW: 0CW 300 044 S    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 4510
   Revision: 00043014    Serial number: CU501211176502
   ROD: EV_TCMDQ200021_VW37.rod
   VCID: 48CA50A6F238A6FBFB2-801C
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 61514000000904
   Coding: 01FA6BA134240975037A0605C1CCA980D62C90C0608395FFF9625028C509
   Shop #: WSC 00028 028 00067
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 46D65E9EF82CB08B09E-8012
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Reset counter: 45
                    Date: 2021.01.10
                    Time: 12:08:07
8351 - Databus
          [FCAN: Motor_17_alt veraltet bit is set]
                    Reset counter: 44
                    Date: 2021.01.10
                    Time: 12:08:07
8356 - Databus
          [FCAN: Klima_11_alt veraltet bit is set]
                    Reset counter: 44
                    Date: 2021.01.10
                    Time: 12:08:07
8368 - Databus
          [FCAN: Charisma_07 is not received]
                    Fault Frequency: 9
                    Reset counter: 45
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:14
   Part No SW: 5G1 907 044 AC    HW: 5G1 907 044 AC
   Revision: 00001K08
   Coding: 03020104204101011105010D00101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006143
   VCID: 698CB52289F2BFF3C4C-803C
   Air quality sensor:
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011233300379
   Coding: 00061A66C2C122FB4FA44000000C0788140A000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   Component: WWS    150420  043 0551
   Serial number:         150424114254
   Component: RLFS  024 0042
   Serial number: Y12M12D04H20M34S42S1
   Coding: 028877
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert->Keine Anzeige]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:07
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231231502631
   Coding: 0031151211
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   VCID: 3A2E3A6EBCD4C46B7D6-806E
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R01MMS.
   VCID: 40DA4886DA089EBB332-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 106 12
   Serial number: 3576700000078498BB00
   Subsystem 2 - Part No SW: -----------    HW: 480 002 106 12
   Serial number: 358670000001E3F89B04
   Subsystem 3 - Part No SW: -----------    HW: 480 401 811 12
   Serial number: 3516502A90D5D623537C
   Subsystem 4 - Part No SW: -----------    HW: 480 400 412 12
   Serial number: 3526502B50D46475B104
   Subsystem 5 - Part No SW: -----------    HW: 480 400 612 13
   Serial number: 3556502A11220565831R
   Part No SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
   Component: Lenks. Modul  004 0110
   Revision: --------    Serial number: 16101404400952
   Coding: 8C20
   Shop #: WSC 00078 790 12345
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 0350878A8B9E45A36E0-8056
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         405 3190
   Coding: 43AD21086E8C000807806E2B0401000080000000
   VCID: 2A0E0A2E4C7474EB0D6-807E
          U1014 00 [009] - -
                    Reset counter: 45
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:06
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:06
16776996 - Databus
          [FCW_01 keine Kommunikation]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:06
16777056 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_SDS_0x46 keine Kommunikation]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:11
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 A    HW: 5Q0 963 272 A
   Component: STH-MQB       005 0066
   Coding: 9309
   Shop #: WSC 00028 028 00312
   ASAM Dataset: EV_AuxilParkiHeateWOS 002012
   VCID: 343214569EB0321BA7A-8060
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000000818123
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   122 1109
   Revision: --------    Serial number: 0000203652
   Coding: 030100040B087300EF0006581C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   Generator:
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29160001908610056387
   Coding: 2FFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 0311268501
131693 - TV-Tuner
          U105C 00 [009] - No Communication
          [Timeout Knoten 0x6D / 57 - TV-Tuner]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:06
                    Terminal 30 power supply: 14.6 V
                    Terminal 15: On
          U1101 00 [009] - Active
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:06
                    Terminal 15: On
   Component: HRE_Master    H11 0071
   Serial number: 0363187924
   Coding: 01031103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C223C76B6E0FA5B6FA-8068
   Serial number: 0406890441
   Coding: 010311
336901 - Databus
          [Braking ECU ESP_33 - no signal/no communication]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:06
   Serial number: 220616EFM19394
   Coding: 003F0720D000048000001001
   VCID: 43D0478ACB1E85A32E0-8016
   Serial number: 00000000000007200009
   Coding: 110000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 11
   Shop #: WSC 00028 028 00025
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D243172ADFAF353584-8068
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD017WH-
   Coding: 1200000000000000000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E06063E709C18CBD1E-807A
   Serial number: 100716EG922156
   Coding: 003F0120DE00048000801001
   Serial number: 00000000000004424057
   Coding: 390000
   Coding: 051A000001010000
   Shop #: WSC 01608 111 28888
   VCID: 75B4E952D54A6B13504-8020
Address 57: TV Tuner
   Part No SW: 5NA 035 021     HW: 5NA 035 021
   Component: MU-H-LND-EU   H55 1367
   Serial number: A853H0JS070458
   Coding: 02730201000000005111120200880233AF0109F481200000FF
   VCID: 6FB8DB3AB71651C39A8-803A
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT2950992
   Subsystem 2 - Part No SW: V03 959 806 N    HW: -----------
   Component: ECE 2020/2021  --- 0187
   Compact disc data bank:
   Component: Gracenote2  --- 1017
8 Faults Found:
          B201A 00 [009] - -
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:15
                    Voltage terminal 30: 14.8 V
                    Status_Software_Version_Management-module_name: MDVB-DTV/MPEG-OS
          [Anti-theft protection - component protection active (0xEA6100)]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:10
                    Voltage terminal 30: 14.7 V
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
                    Reset counter: 45
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:10
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:11
                    BAP-BAP_Function_ID: 02
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:11
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:11
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:11
7237 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Display configuration (0x45) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:11
   Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Component: Anhaenger     H10 0030
   Revision: 6B001003    Serial number: 00000176223439
   Coding: 0100000202000000
   Shop #: WSC 01730 666 28888
   ASAM Dataset: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 3534295295CA2B13904-8060
   Part No SW: 5Q0 980 653 C    HW: 5Q0 980 653
   Component: MQB_MFK       H03 0030
   Serial number: 00000003485
   Coding: 0101010000020303000501010100000101
   Shop #: WSC 40657 150 20171
   ROD: EV_MFKBoschAU370.rod
   VCID: 382A206682D8D67B8B2-806C
2555904 - Databus
          [PSD_01_TO_FAILURE]
                    Reset counter: 44
                    Mileage: 20034 km
                    Date: 2021.01.10
                    Time: 12:08:08
                    Control Module temperature: 36 °C
                    Outside temperature: 4.0 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 14.6 V
                    Terminal 15 on: 881.2 s
End----------(Elapsed Time: 01:58, VBatt start/end: 14.7V/14.6V)-----------
I know there are more faults here, but I will work with them later.I am currently focusing on this problem.
If this is true, is it possible to do it without ODIS online?
@kakubaz: Hi. I'm intrigued by the DTC in the hex03 module regarding the incorrectly coded ECU
Here is a comparison of the ECU long-code string on your "Poland" vehicle and 2 other EU cars that I found on the forum that had Part No SW: 04L 906 021 N and HW: 04L 907 309 B
ECUPolandPolandIsraelIsraelGreeceGreece
ByteHexBinaryHexBinaryHexBinary
0090000100101000000010100000001
1250010010125001001012500100101
2000000000000000000000000000000
3120001001012000100101200010010
4030000001103000000110300000011
5540101010004000001002400100100
6050000010101000000010500000101
7090000100109000010010900001001
8200010000000000000002000100000
9000000000000000000000000000000
I've highlighted the (perhaps) dubious Bits:
  • In Byte 0, the lower nibble identifies the car-type - normally for VW, the setting is hex01.
  • The upper nibble of Byte 5 tells the ECU what version of ACC is installed.I'm not sure (perhaps someone else can confirm), but in my MQB database, there isn't a version for the upper nibble value hex50 - pending advice to the contrary, maybe try either hex40 (PR-8T5), or hex60 (PR-8T3/8T8)?
  • The speed limit software switches are in Byte 8 - Bit 2 which is the switch for the speed limiter function isn't active and Bits3-4 which set the actual speed limit have the value hex00-so no speed limit. I'm not sure what the legislated upper speed is in Poland. I'm also not sure what Bit 5 does!!
kakubaz
Zgorzelec, Poland
C?ID=314093
I set byte 0 to 01, I tried to change the value of byte 8 in the second bit, but I got the information that the value is out of range. For byte 5, nothing has changed after setting the value to 44, for 64, the virtual cockpit was showing ACC and Front assist error and ACC settings were not available. Additional information on setting the gearbox lever to D on the virtual cockpit when the ACC window is running shows the message Speed limit. I was also unable to clear the error about the incorrectly coded ECU.
@kakubaz : "I tried to change the value of byte 8 in the second bit" - Bit 2 in Byte 8 is the third bit (because of Bit 0).
OK, perhaps the better way to do this (i.e. JUST address the incorrectly coded ECU DTC) is to look at an early copy of an auto-scan for the car - before the retrofit. You can find historic auto-scans in the directory C:\Ross-Tech\VCDS\Scans on the laptop that you use to run VCDS . The scans are listed by VIN/Date.
If you can't find an early scan, then the other option is to look at the change records that VCDS stores in the directory C:\Ross-Tech\VCDS\Debug . This directory stores a complete database of ALL the changes that you made with VCDS. The file that stores historic long-code changes is called CodingLog.CSV and the data is listed by module address and module Part Number. Each change record identifies the before value (called "from") and mercifully, each record is date/time stamped - so you should be able to identify the earliest "from" long-code value for the ECU.
kakubaz
Zgorzelec, Poland
C?ID=314093
Yes, i know that, i meant Bit 2.
I found one autoscan, without the virtual cockpit, but the engine coding was the same and the error was there too. I suppose the problem is with the ABS module, which was also replaced. Unfortunately I don't have an autoscan from before this module was replaced, but without the virtual cockpit and with this ABS module ACC was working. If useful, the previous Module number was 5Q0 907 379 Q. Currently, virtual cockpit shows me route and does not work, but after exceeding ~85km/h message pops up that ACC fault.
I found one autoscan, without the virtual cockpit, but the engine coding was the same and the error was there too. I suppose the problem is with the ABS module, which was also replaced. Unfortunately I don't have an autoscan from before this module was replaced, but without the virtual cockpit and with this ABS module ACC was working. If useful, the previous Module number was 5Q0 907 379 Q. If useful, the previous Module number was 5Q0 907 379 Q. Currently, virtual cockpit shows me route and does not work, but after exceeding ~85km/h message pops up that ACC fault.
@kakubaz: hmmm........new information - "the ABS module was replaced"!!
  • Why was it replaced?
  • Does the long-code string on the new hex03 module = the value on the old hex03 module (in your historic auto-scan)?
I found an ECU from a Polish mk7 with the same part numbers as your car and it has ACC (PR-8T3/8T8) - see below
Component: R4 1,6L EDC H22 8138
Revision: 84H22---
Coding: 01250012036405092000
Shop #: WSC 23920 001 104857
ASAM Dataset: EV_ECM16TDI01104L906021N 002013
ROD: EV_ECM16TDI01104L906021N_002.rod
VCID: 302C1CB66B298ACA6D-8064
I suggest that you try changing the long-code value on your ECU using the VCDS screen below (don't use the Long Coding Helper)
I've thieved the picture above from Ross-Tech's on-line manual - so obviously the values on your car will be different.
copy-and-paste
into the New Coding box and press Do It!!
kakubaz
Zgorzelec, Poland
C?ID=314093
I read in the XAGICO PDF that i need a different ABS module to install the Side Assist functionality. Like here:
https://forums.ross-tech.com/showth...ds-VW-Golf-MKVII&p=71716&viewfull=1#post71716
Yes it is the same. I'm posting an old autoscan here. Unfortunelly it's in the Polish language.
VIN: WVWZZZAUZDW049359   Numer rejestracyjny:
Przebieg: 170387km   Numer naprawy:
Typ podwozia: AU-VW37 (5Q0)
Skanowanie: 01 02 03 08 09 10 13 15 16 17 18 19 3C 42 44 47 52 55 57 5F
          69 A5
VIN: WVWZZZAUZDW049359   Przebieg: 170387km
01-Silnik -- Stan: OK 0000
02-Skrzynia biegów -- Stan: OK 0000
03-ABS/hamulce -- Stan: Usterka 0010
08-Klimatyzacja -- Stan: OK 0000
09-Centr.zesp.elektr. -- Stan: Usterka 0010
10-Asyst.park./kierow. -- Stan: OK 0000
13-Reg.dystansu -- Stan: OK 0000
15-Airbag -- Stan: OK 0000
16-Koło kierownicy -- Stan: OK 0000
17-Zest.wskaźników -- Stan: Usterka 0010
18-Ogrzew.pomocn. -- Stan: OK 0000
19-CAN Gateway -- Stan: Usterka 0010
3C-Zmiana pas.ruchu -- Stan: Usterka 0010
42-Elektr.drzwi kier. -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: OK 0000
47-Sys.nagłaśniający -- Stan: OK 0000
52-Elektr.drzwi pas. -- Stan: OK 0000
55-Zasięg świateł -- Stan: OK 0000
57-Tuner TV -- Stan: Nie może być osiągnięty 0100
5F-Elektr.informacji -- Stan: Usterka 0010
69-Przyczepa -- Stan: OK 0000
A5-Czujniki asyst.j.-p. -- Stan: Usterka 0010
Adres 01: Silnik (J623-CLHA)       Plik etykiet:. 04L-907-309-V1.clb
   Oznaczenie elementu SW: 04L 906 021 N    HW: 04L 907 309 B
   Komponent: R4 1,6L EDC   H22 4946
   Weryfikacja: 84H22---
   Kodowanie: 09250012035405092000
   Kod serwisu: WSC 04520 002 104857
   Zbiór danych ASAM: EV_ECM16TDI01104L906021N 002007
   VCID: 303A18466AA80E37796-8064
Kody gotowości: 0 0 0 0 1
Adres 02: Skrzynia biegów (J743)       Plik etykiet: 0CW-927-769.clb
   Oznaczenie elementu SW: 0CW 300 044 S    HW: 0AM 927 769 G
   Komponent: GSG DQ200-MQB H43 4510
   Weryfikacja: 00043014    Numer seryjny: CU501211176502
   Kodowanie: 0014
   Kod serwisu: WSC 01357 011 00200
   Zbiór danych ASAM: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 48CA50A6F238A6F7416-801C
Nie znaleziono błędów.
Adres 03: ABS/hamulce (J104)       Plik etykiet: 5Q0-907-379-IPB-V1.clb
   Oznaczenie elementu SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Komponent: ESC           H31 0571
   Weryfikacja: 00000000    Numer seryjny: 61514000000904
   Kodowanie: 01FA6BA134240975037A0605C1CCA980D62C90C0608395FFF9625028C509
   Kod serwisu: WSC 00028 028 00067
   Zbiór danych ASAM: EV_Brake1UDSContiMK100IPB 033001
   VCID: 46D65E9EF82CB087B3A-8012
4 - ilość znalezionych błędów. Oto one:
          P1612 00 [009] - -
             Ramka zamrożona:
                    Stan błędu: 00000001
                    Priorytet błędu: 6
                    Częstość błędu: 2
                    Wew.licznik błędów: 69
                    Data: 2020.03.08
                    Czas: 11:40:37
8351 - Magistrala danych
          U1122 00 [009] - niewiarygodna informacja
          Potwierdzony - Testowany od skasowania kodów błędów
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Data: 2020.03.08
                    Czas: 11:40:37
8356 - Magistrala danych
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Data: 2020.03.08
                    Czas: 11:40:37
8368 - Magistrala danych
          U1121 00 [009] - brak informacji
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:44
Adres 08: Klimatyzacja (J255)       Plik etykiet:| 5G0-907-044.clb
   Oznaczenie elementu SW: 5G1 907 044 AC    HW: 5G1 907 044 AC
   Komponent: Climatronic   H04 1801
   Weryfikacja: 00001K08
   Kodowanie: 03020104204101011105010D00101022
   Zbiór danych ASAM: EV_ACClimaBHBVW37X 006143
   VCID: 698CB52289F2BFFF7E8-803C
   Sterownik dmuchawy świeżego powietrza (z przodu):
   Geber fuer Kaeltemitteldruck/Kaeltemitteltemperatur:
   Czujnik jakości powietrza:
Adres 09: Centr.zesp.elektr. (J519)       Plik etykiet:| 5Q0-937-08X-HV1.clb
   Oznaczenie elementu SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Komponent: BCM MQBAB H   H14 0106
   Numer seryjny: 00011233300379
   Kodowanie: 00061A66C2C122FB4FA44000000C0788140A000000000000000000000000
   Zbiór danych ASAM: EV_BCMCONTI 010001
   Sterownik silnika wycieraczek:
   Podsystem 1 - Oznaczenie elementu SW: 5G1 955 119 A    HW: 5G1 955 119 A  Plik etykiet: 5QX-955-119-V1.CLB
   Komponent: WWS    150420  043 0551
   Numer seryjny:         150424114254
   Kodowanie: 0E4DDD
   Czujnik rozpoznawania deszczu i światła:
   Podsystem 2 - Oznaczenie elementu SW: 5Q0 955 547     HW: 5Q0 955 547   Plik etykiet: 5Q0-955-547.CLB
   Komponent: RLFS  024 0042
   Numer seryjny: Y12M12D04H20M34S42S1
   Kodowanie: 028877
Znaleziono 1 błąd:
526359 - Sterownik zakodowany nieprawidłowo
          U1014 00 [009] - -
          [Steuergeraet falsch codiert->Keine Anzeige]
             Ramka zamrożona:
                    Priorytet błędu: 2
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:37
Adres 10: Asyst.park./kierow. (J791)       Plik etykiet:| 5Q0-919-294.clb
   Oznaczenie elementu SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Komponent: PARKHILFE 8K  002 0026
   Weryfikacja: --------    Numer seryjny: 94231231502631
   Kodowanie: 0031151111
   Zbiór danych ASAM: EV_EPHVA18AU3700000 002016
   VCID: 3A2E3A6EBCD4C467C72-806E
Adres 13: Reg.dystansu (J428)       Plik etykiet:| 5Q0-907-567.clb
   Oznaczenie elementu SW: 5Q0 907 567 J    HW: 5Q0 907 567 E
   Komponent: ACC3          H06 0395
   Numer seryjny: 24021276240295
   Kodowanie: 00001F00FE030B
   Kod serwisu: WSC 01581 666 28888
   Zbiór danych ASAM: EV_ACCBoschMQB 001022
   VCID: 42DE428ED4048CA79F2-8016
Adres 15: Airbag (J234)       Plik etykiet:| 5Q0-959-655.clb
   Oznaczenie elementu SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Komponent: AirbagVW20    011 0361
   Numer seryjny: 003F5R01MMS.
   Kodowanie: 98CCC000000000005C0000CF004800000065
   Zbiór danych ASAM: EV_AirbaVW20SMEVW37X 002126
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 40DA4886DA089EB7896-8014
   Czujnik zderzenia bocznej poduszki bezp.po stronie kierowcy:
   Podsystem 1 - Oznaczenie elementu SW: -----------    HW: 480 002 106 12
   Komponent: SideSensor_Df  001 0887
   Numer seryjny: 3576700000078498BB00
   Kodowanie: 2D2D2D
   Czujnik zderzenia bocznej poduszki bezp.po stronie pasażera:
   Podsystem 2 - Oznaczenie elementu SW: -----------    HW: 480 002 106 12
   Komponent: SideSensor_Pf  001 0887
   Numer seryjny: 358670000001E3F89B04
   Kodowanie: 2D2D2D
   Czujnik zderzenia bocznej poduszki bezp.z tyłu po str.kierowcy:
   Podsystem 3 - Oznaczenie elementu SW: -----------    HW: 480 401 811 12
   Komponent: SideSensor_Dr  001 6149
   Numer seryjny: 3516502A90D5D623537C
   Kodowanie: 2D2D2D
   Czujnik zderz.bocznej poduszki bezp.z tyłu po str.przedn.pasaż.:
   Podsystem 4 - Oznaczenie elementu SW: -----------    HW: 480 400 412 12
   Komponent: SideSensor_Pr  001 6149
   Numer seryjny: 3526502B50D46475B104
   Kodowanie: 2D2D2D
   Czujnik zderzenia przedniej poduszki bezp.po stronie kierowcy:
   Podsystem 5 - Oznaczenie elementu SW: -----------    HW: 480 400 612 13
   Komponent: FrontSensor_D  001 6149
   Numer seryjny: 3556502A11220565831R
   Kodowanie: 2D2D2D
Adres 16: Koło kierownicy (J527)       Plik etykiet:| 5Q0-953-549.clb
   Oznaczenie elementu SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
   Komponent: Lenks. Modul  004 0110
   Weryfikacja: --------    Numer seryjny: 16101404400952
   Kodowanie: 8C20
   Kod serwisu: WSC 00078 790 12345
   Zbiór danych ASAM: EV_SMLSKLOMQB 017001
   VCID: 0350878A8B9E45AFD44-8056
Adres 17: Zest.wskaźników (J285)       Plik etykiet:| 5G0-920-XXX-17.clb-SRI3
   Oznaczenie elementu SW: 5G0 920 870 A    HW: 5G0 920 870 A
   Komponent: KOMBI         336 0555
   Kodowanie: 07A502086E8C000807886A0B040000
   Kod serwisu: WSC 00002 779 06150
   Zbiór danych ASAM: EV_DashBoardVDDMQBAB 008026
   VCID: 2708F31A5F66498FA8C-8072
Znaleziono 1 błąd:
13636608 - Sterownik zakodowany nieprawidłowo
          U1014 00 [009] - -
             Ramka zamrożona:
                    Priorytet błędu: 2
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:36
Adres 18: Ogrzew.pomocn. (J364)       Plik etykiet:| 5Q0-963-272.clb
   Oznaczenie elementu SW: 5Q0 963 272 A    HW: 5Q0 963 272 A
   Komponent: STH-MQB       005 0066
   Kodowanie: 9309
   Kod serwisu: WSC 00028 028 00312
   Zbiór danych ASAM: EV_AuxilParkiHeateWOS 002012
   VCID: 343214569EB032171DE-8060
   Zdalne sterowanie radiowe ogrzewania postojowego:
   Podsystem 1 - Oznaczenie elementu SW: 5Q0 963 513     HW: 5Q0 963 513
   Komponent: R149 T91-LIN  003 0301
   Numer seryjny: 00000000000000818123
Adres 19: CAN Gateway (J533)       Plik etykiet:| 5Q0-907-530-V1.clb
   Oznaczenie elementu SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Komponent: GW MQB High   122 1109
   Weryfikacja: --------    Numer seryjny: 0000203652
   Kodowanie: 030100040B087300EF0006581C0F00010001000000000000000000000000
   Kod serwisu: WSC 131071 1023 2097151
   Zbiór danych ASAM: EV_GatewLear 006010
   Sterownik kierownicy wielofunkcyjnej:
   Podsystem 2 - Oznaczenie elementu SW: 5G0 959 442 K    HW: 5G0 959 442 K  Plik etykiet: 3C8-959-537.CLB
   Komponent: E221__MFL-DC1  H17 0040
   Numer seryjny: 29160001908610056387
   Kodowanie: 2FFFFF
   Sterownik układu kontroli akumulatora:
   Podsystem 3 - Oznaczenie elementu SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Komponent: J367-BDMHella  H03 8042
   Numer seryjny: 0311268501
Znaleziono 1 błąd:
131693 - Tuner TV
          U105C 00 [009] - Brak komunikacji
             Ramka zamrożona:
                    Priorytet błędu: 2
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:37
                    Napięcie zasilania zacisku 30: 12.0 V
                    Status podrzędnych immobilisera / zacisk 15: ON
Adres 3C: Zmiana pas.ruchu (J1086)       Plik etykiet:| 5Q0-907-686.clb
   Oznaczenie elementu SW: 5Q0 907 686 B    HW: 5Q0 907 686 B
   Komponent: HRE_Master    H11 0071
   Numer seryjny: 0363187924
   Kodowanie: 01031103
   Kod serwisu: WSC 12345 123 12345
   Zbiór danych ASAM: EV_HREntryHella 001028
   VCID: 3C223C76B6E0FA57D5E-8068
   Sterownik 2 asystenta zmiany pasa ruchu:
   Podsystem 1 - Oznaczenie elementu SW: 5Q0 907 685 B    HW: 5Q0 907 685 B
   Komponent: HRE_Slave  H12 0071
   Numer seryjny: 0406890441
   Kodowanie: 010311
Znaleziono 1 błąd:
336901 - Magistrala danych
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:36
Adres 42: Elektr.drzwi kier. (J386)       Plik etykiet:| 5QX-959-X93-42.clb
   Oznaczenie elementu SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Komponent: TSG FS        020 0041
   Numer seryjny: 220616EFM19394
   Kodowanie: 003F0720D000048000001001
   Zbiór danych ASAM: EV_DCUDriveSideEWMAXKLO 006003
   VCID: 43D0478ACB1E85AF944-8016
   Sterownik tylnych drzwi po stronie kierowcy:
   Podsystem 1 - Oznaczenie elementu SW: 5Q0 959 811     HW: 5Q0 959 811   Plik etykiet: 5QX-959-81X-V1.CLB
   Komponent: FOND_FHSG_DRV  005 0005
   Numer seryjny: 00000000000007200009
   Kodowanie: 110000
Adres 44: Wsp.kierownicy (J500)       Plik etykiet:| 5Q0-909-144.clb
   Oznaczenie elementu SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Komponent: EPS_MQB_ZFLS  119 1021
   Kodowanie: 11
   Kod serwisu: WSC 00028 028 00025
   Zbiór danych ASAM: EV_SteerAssisMQB 008022
   VCID: 3D243172ADFAF35FE20-8068
Adres 47: Sys.nagłaśniający (J525)       Plik etykiet:| 5Q0-035-456.clb
   Oznaczenie elementu SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Komponent: MIB2_lite_amp H40 0200
   Weryfikacja: 00000001    Numer seryjny: VWZ8Z1HMD017WH-
   Kodowanie: 1200000000000000000000000000
   Zbiór danych ASAM: EV_AMPMst11CGen2ALPI 001003
   VCID: 2E06063E709C18C76BA-807A
Adres 52: Elektr.drzwi pas. (J387)       Plik etykiet:| 5QX-959-X92-52.clb
   Oznaczenie elementu SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Komponent: TSG BFS       020 0041
   Numer seryjny: 100716EG922156
   Kodowanie: 003F0120DE00048000801001
   Zbiór danych ASAM: EV_DCUPasseSideEWMAXKLO 006003
   Sterownik tylnych drzwi po stronie przedniego pasażera:
   Podsystem 1 - Oznaczenie elementu SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Plik etykiet: 5QX-959-81X-V1.CLB
   Komponent: FOND_FHSG_PSG  005 0005
   Numer seryjny: 00000000000004424057
   Kodowanie: 390000
Adres 55: Zasięg świateł (J431)       Plik etykiet:| 5Q0-907-357.clb
   Oznaczenie elementu SW: 5Q0 907 357     HW: 6R0 907 357 A
   Komponent: LWR-ECU       005 0080
   Weryfikacja: --------    Numer seryjny: --------------
   Kodowanie: 051A000001010000
   Kod serwisu: WSC 01608 111 28888
   Zbiór danych ASAM: EV_HeadlRegulVWLWRMQB 001110
   VCID: 75B4E952D54A6B1FEA0-8020
Adres 57: Tuner TV
Adres 5F: Elektr.informacji (J794)       Plik etykiet:* Brak
   Oznaczenie elementu SW: 3G0 035 021     HW: 3G0 035 021
   Komponent: MU-H-TND-EU   H33 0078
   Numer seryjny: A292E0EB001269
   Kodowanie: 02730101FFFFFFFF11111202000808105F0009F4012001009F
   Kod serwisu: WSC 05311 115 00005
   Zbiór danych ASAM: EV_MUHig4CGen2HBAS 001030
   VCID: 55F489D2358A0B1FCA0-8000
   Jednost.wskazań i obsługi 1 elektroniki układów informacyjnych:
   Podsystem 1 - Oznaczenie elementu SW: 5G0 919 606     HW: 5G0 919 606
   Komponent: ABT_High  H62 0031
   Numer seryjny: VWZ8Z9RU3053AY
   Naklejka z danymi:
   Podsystem 2 - Oznaczenie elementu SW: V03 959 806 FN    HW: -----------
   Komponent: ECE 2020  --- 0184
   Numer seryjny: --------------------
   Baza danych Compact Disc:
   Podsystem 3 - Oznaczenie elementu SW: V03 959 800 EG    HW: -----------
   Komponent: Gracenote2  --- 1005
6 - ilość znalezionych błędów. Oto one:
1543 - Sterownik zakodowany nieprawidłowo
          U1014 00 [009] - -
             Ramka zamrożona:
                    Priorytet błędu: 4
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:40
                    Napięcie zacisku 30: 12.3 V
                    Byte_Coding_Condition-byte_5_condition: ERROR
                    Byte_Coding_Condition-byte_6_condition: ERROR
                    Byte_Coding_Condition-byte_7_condition: ERROR
1555 - Sprawdzanie układu zarządzania wersją oprogramowania
          B201A 00 [009] - -
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:40
                    Status_Software_Version_Management-module_name: ADUV101/ABT
6679 - Tuner TV
          [Control module for TV tuner: no communication]
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:40
7170 - Ograniczenie działania z powodu braku informacji
          U1111 00 [009] - -
          [A/C system (0x02) - function restriction due to communication error - BapErr_retry not successful]
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:42
7179 - Ograniczenie działania z powodu braku informacji
          U1111 00 [009] - -
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:42
7191 - Ograniczenie działania z powodu braku informacji
          U1111 00 [009] - -
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:42
Adres 69: Przyczepa (J345)       Plik etykiet:| 5Q0-907-383.clb
   Oznaczenie elementu SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Komponent: Anhaenger     H10 0030
   Weryfikacja: 6B001003    Numer seryjny: 00000176223439
   Kodowanie: 0100000202000000
   Kod serwisu: WSC 01730 666 28888
   Zbiór danych ASAM: EV_TrailFunctPivotHella 001001
   VCID: 3534295295CA2B1F2A0-8060
Adres A5: Czujniki asyst.j.-p. (R242)       Plik etykiet:| 5Q0-980-653.clb
   Oznaczenie elementu SW: 5Q0 980 653 C    HW: 5Q0 980 653
   Komponent: MQB_MFK       H03 0030
   Numer seryjny: 00000003485
   Kodowanie: 0101010000020303000501010100000101
   Kod serwisu: WSC 40657 150 20171
   Zbiór danych ASAM: EV_MFKBoschAU370 001001
   VCID: 382A206682D8D677316-806C
Znaleziono 1 błąd:
2555904 - Magistrala danych
          [PSD_01_TO_FAILURE]
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Przebieg: 170387 km
                    Data: 2020.03.08
                    Czas: 11:40:38
                    Temperatura sterownika: 23 °C
                    Temperatura zewnętrzna: 9.0 °C
                    Prędkość pojazdu: 0.00 km/h
                    Napięcie zacisku 15: 12.0 V
                    Zacisk 15 ON: 281.9 s
Koniec (Skanowanie trwało: 01:56, Napięcie akumulatora - na początku skanowania / przy końcu skanowania: 12.2V/12.1V)
copy-and-paste
I did it, but still the error about wrong ECU coding stayed and on virtual cockpit information about ACC fault appeared. I installed the ABS module from this car and nothing changed, all errors still stay.
myounus
Northwest UK
C?ID=321059
Another retrofit I see.....
Have you managed to remove the component protection error from your gateway? Also, the software on it is far too old and requires updating which may just cure your problem. If you have access to another tool you could flash it to AJ, but personally I’d recommend you swap it for a 3Q0907530. If wouldn’t hurt upgrading the BCM either to AJ....
ghost
C?ID=139898
Why don't you just run SVM with ODIS on 01, 03 and 13? You will see after that what faults are back.
kakubaz
Zgorzelec, Poland
C?ID=314093
Welcome back ;)
I am still fighting with this problem, I have acquired the given Gateway module 3Q0907530 . I succeeded to remove some errors in the meantime. I am uploading the current autoscan here.
VIN: WVWZZZAUZDW049359   License Plate: SREBRNY
Mileage: 20654km-12833mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
          69 A5
VIN: WVWZZZAUZDW049359   Mileage: 20654km-12833miles
   Revision: 84H22---
   Coding: 01250012035405092000
          P1612 00 [009] - -
                    Reset counter: 20
                    Date: 2021.02.02
                    Time: 19:03:34
   Revision: 00001K08
   Air quality sensor:
   Coding: 028877
          U1014 00 [009] - -
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:33
   Coding: 0031151211
   Coding: 8C20
          U1014 00 [009] - -
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:33
16776980 - Databus
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:33
16776996 - Databus
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:33
          U1110 00 [009] - -
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:36
   Coding: 9309
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   515 5302
   Serial number: 22091610800558
   Coding: 030300345F017300FB00205A1E0F00010001070000000000000000000000
   Shop #: WSC 05311 115 00011
   ROD: EV_GatewNF_VW37.rod
   VCID: 3330174A9BBE3523BE0-8066
   Generator:
   Coding: 2FFFFF
197234 - Analog Clock
          U1096 00 [009] - No Communications
          [Analoguhr (LIN#2) Timeout]
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:34
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: On
197681 - Controls in Steering Wheel
          U108F 00 [009] - Implausible Signal
          [MFL (LIN#2) unplausibles Signal]
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:34
                    Terminal 15: On
   Coding: 01031103
   Coding: 010311
   Coding: 110000
   Coding: 11
   Coding: 390000
Address 57: TV Tuner (R78)       Labels:* None
   Part No SW: 8V0 919 191 C    HW: 8V0 919 191 B
   Component: DVB-DTV       H09 1800
   Coding: 0203010101000100010000
   ASAM Dataset: EV_TVMELC 001033
   ROD: EV_TVMELC_VW37.rod
   VCID: 3FD84B7AA7F6E1434A8-806A
7 Faults Found:
          B201A 00 [009] - -
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:42
                    Voltage terminal 30: 12.3 V
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:37
          U1111 00 [009] - -
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:39
          U1111 00 [009] - -
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:39
          U1111 00 [009] - -
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:39
          U1111 00 [009] - -
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:39
          U1111 00 [009] - -
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:39
2555904 - Databus
          [PSD_01_TO_FAILURE]
                    Reset counter: 20
                    Mileage: 20654 km
                    Date: 2021.02.02
                    Time: 19:03:34
                    Control Module temperature: 27 °C
                    Outside temperature: 9.0 °C
                    Voltage terminal 15: 11.9 V
                    Terminal 15 on: 253.9 s
@ghost I have access to odis, but I don't know all its functions. Can you explain me how to make this SVM? Is it an online function?
myounus
Northwest UK
C?ID=321059
Whilst you have access to online ODIS. I’d recommend you use ODIS-e update the software on the gateway and bcm before using SVM to code them as you’d have to do this again.
kakubaz
Zgorzelec, Poland
C?ID=314093
I have upgraded my BCM to AJ, but am unable to upgrade Gateway. If I would like to try SVM coding, this option is available in Odis -> Special features -> Adapting software?
Here I have a few options:
1.Update software using diagnostic address
2.Update software using measure code
3.Run re-/retrofit solution
Should I choose first option? Where can I get codes for second option?
myounus
Northwest UK
C?ID=321059
You would simply flash it with the AJ software file and then re-paramaterise it. You need to download the file from erwin or I can see if I have it and email it to you.
