[PQ25] Fog Lights supported in 937 087?
NEtech
Denmark
C?ID=56995
You can also use adaptation channel 27
   #42
Robert-VW
Ireland & Poland
C?ID=423656
yes it's byte 12 bit 0. but it will illuminate the front parking light (Standlicht) as well since they occupy the same BCM pins.
Absolutely correct but if you have OEM LED headlamps then the result is achieved.
DRLs only ON in the front and sides ON in the rear :).
   #43
iichel
Netherlands, eastern part
C?ID=284912
Yes, but the LED DRL will run in dimmed mode rather than full brightness. But that is not the case for TS since he doesn't have LED or bi-xenon headlights
   #44
VWT6
Finland
C?ID=295527
If you feel like being lab rats, download and test this newest updater (requires Release 20.12 US to be installed). Then let us know if it works as expected. ;)
Thank you very much! Just a minor glitch - adaptation channel 31 - Cornering light speed threshold (minimum) is missing from drop-down menu, however the balloon message will show up when manually browsing the channels (up/down).
