Hi,
I retrofitted the Facelift Fabia 2 fog lights with DRL lights and wired it to the DRL switch and the fog lights to PIN 9 and 10 of T73B as erWin shows it. (PIN 7 of T73a from Light switch and to cluster as well). Before I started, it wasnt clear, if my BCM would support it, so I disconnected it from my car and tooked a look to the PINs. Some are missing inside the BCM but those for Fog lights (see above) were there. I believed that this would indicate support for those.
I was also able to Code "Fog lights installed" and "turn fog lights on with turn signals" (or similar). The coding was accepted. But it does not work. Neither with the light switch set to front fog lights nor while turn the turn signal on. EDIT: Byte 21, Bits 2 and 7
The engine was not running, only ignition was on.
Does m BCM support it? If no, why are the PINS there? I tried to open the BCM for further inspections but it seems to be locked somehow with a one time solution.
Reagrds,
Mittwoch,09,September,2020,16:35:11:25454
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: DRV 20.4.1.1 HEX-NET CB: 0.4513.4
Datenstand: 20200518 DS317.0
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: TMBEL65J2B3027879 KFZ-Kennzeichen: HZ RK 693
Kilometerstand: 152650km Reparaturauftrag: park 4k index B
Fahrzeugtyp: 5J-SK25 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 56
Fahrzeug-Ident.-Nr.: TMBEL65J2B3027879 Kilometerstand: 152650km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
37-Navigation -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CAYC) Labeldatei:. DRV\03L-906-023-CAY.clb
Teilenummer SW: 03L 906 023 DN HW: 03L 906 023 DL
Bauteil: 1,6l R4 CR td H13 9971
Revision: --H13--- Seriennummer:
Codierung: 00114014002400080000
Betriebsnr.: WSC 12345 123 12345
ASAM Datensatz: EV_ECM16TDI02103L906023DN 003008
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: F5A2A11754A2D82EA9-80A0
Kein(e) Fehlercode(s) gefunden.
Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\6R0-907-37x-ESP82.clb
Teilenummer SW: 6R0 907 379 AA HW: 6R0 907 379 AF
Bauteil: ESP8.2i front H05 0003
Revision: --------
Codierung: 410148DB416F00B9822D12E982DA00421300
Betriebsnr.: WSC 13765 790 00046
VCID: FDB2B9376092806EE1-80A8
Adresse 08: Klima-/Heizungsel. (J301) Labeldatei: 6R0-820-045-9AP.clb
Teilenummer SW: 5J0 820 045 B HW: 5J0 820 045 B
Bauteil: Climatic 12 0660
Revision: 0002S 12
VCID: A404AC53A7B811A6CE-80F0
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\6R0-937-08x-09.clb
Teilenummer SW: 6R7 937 087 H HW: 6R7 937 087 F
Bauteil: PQ25 BCM H11 0023
Revision: -1------ Seriennummer: 1002424901
Codierung: 7C980B3808210000002800C03E0B18C10080400F600000000000
Betriebsnr.: WSC 00070 000 00000
VCID: C9DA1DE760DAECCE1D-809C
Subsystem 1 - Teilenummer SW: 6R0 959 801 M HW: 6R0 959 801 M Labeldatei: 6R0-959-801.CLB
Bauteil: J386__TSG_FT 002 3210
Seriennummer: --------------------
Codierung: 020000
Subsystem 2 - Teilenummer SW: 6R0 959 802 P HW: 6R0 959 802 P Labeldatei: 6R0-959-802.CLB
Bauteil: J387__TSG_BT 002 3210
Codierung: 020000
Subsystem 3 - Teilenummer SW: 3T0 959 537 D HW: 3T0 959 537 D
Bauteil: E221__MFL-URO H07 0012
Seriennummer: 2276407
Codierung: 800000
Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\5J0-919-475.clb
Teilenummer SW: 5J0 919 475 B HW: 5J0 919 475 A
Bauteil: PARKHILFE 4K H11 0010
Revision: --H11--- Seriennummer: 32961324505738
Codierung: 100002
Betriebsnr.: WSC 33361 790 00052
ASAM Datensatz: EV_EPHVA14SKxxx0000 002001
ROD: EV_EPHVA14SKxxx0000_002.rod
VCID: B4245C131F5881265E-80E0
Adresse 15: Airbag (J234) Labeldatei:| DRV\5K0-959-655.clb
Teilenummer SW: 6R0 959 655 D HW: 6R0 959 655 D
Bauteil: VW10AirbagT13 H09 0018
Revision: -------- Seriennummer: 003DX0018RXW
Codierung: 003133
ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: C3C60FCF4AF6369ED7-8096
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 3496GRB401RCOTCN63UW
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 3506GRB402VCOTCN43QN
Crashsensor für Seitenairbag hinten Fahrerseite:
Seriennummer: 3516GRB402FCOTCMORC.
Crashsensor für Seitenairbag hinten Beifahrerseite:
Seriennummer: 3526GRB402FCOTCMOJDV
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
Teilenummer SW: 5J0 920 841 D HW: 5J0 920 841 D
Bauteil: KOMBI H05 0306
Seriennummer: 00000000000000
Codierung: 020A01
Betriebsnr.: WSC 00070 123 12345
ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
VCID: AB16476FC266DEDE0F-80FE
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\6N0-909-901-6R.clb
Teilenummer SW: 6N0 909 901 HW: 6R7 937 087 F
Bauteil: GW-K-CAN TP20 0023
Revision: -1------
Codierung: 032200
VCID: F0AC900323C0FD067A-80A4
Adresse 25: Wegfahrsperre (J334) Labeldatei:| DRV\5K0-920-xxx-25.clb
Teilenummer SW: 5K0 953 234 HW: 5K0 953 234
Bauteil: IMMO H05 0306
Codierung: 000000
Betriebsnr.: WSC 00000 000 00000
ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03009
VCID: EA98826B0D1C07D634-80BE
Adresse 37: Navigation (J794) Labeldatei:| DRV\1K0-035-27x-37.clb
Teilenummer SW: 3T0 035 192 J HW: 3T0 035 192 J
Bauteil: RNS315-EU H52 0329
Seriennummer: SKZAZ2M9282440
Codierung: 000004110106000001000001
ASAM Datensatz: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: B52261171422982E69-80E0
Datenträger:
Subsystem 1 - Teilenummer: 3AA 919 866
Bauteil: EUR_W_V10 0070
Adresse 44: Lenkhilfe Labeldatei: DRV\6Q0-423-156.clb
Teilenummer: 6R0 423 156 B
Bauteil: LenkhilfeTRW V277
Codierung: 11230
VCID: AF2E537F6A7EA2FE23-80FA
Ende--------(Dauer: 00:45, Batt.-Spannung Start/Ende: 13.9V/14.1V)---------
Reagrds,
