hello all
i hope you are doing well
i have a vw jetta 2014 with dpf, engine, and glow plug light on and with this error *16848 - Diesel Particulate Filter *
i tried doing force regeneration but it shows *finished correctly* but no regeneration
could it be the g450 sensor ?
here is the auto scan
side question : whats the difference between soot measured and soot calculated
thanks.
thanks.
Saturday,19,December,2020,19:02:13:04619
VCDS Version: 20.12.0.0 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WVWZZZ16ZCM025052 License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ16ZCM025052 Mileage: 102910km-63945miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 ML HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 9052
Revision: --H43--- Serial number: 00000000000000
Coding: 10114014030400080000
Shop #: WSC 00066 000 00081
ASAM Dataset: EV_ECM16TDI02103L906023ML 003005
ROD: EV_ECM16TDI02103L906023ML_003_VW32.rod
VCID: 7CA1F2CB866A475B2FB-8028
P2458 00 [175] - Regeneration Duration
Mileage: 102866 km
Date: 2020.12.19
Time: 00:09:23
Engine RPM: 781.50 /min
Normed load value: 30.6 %
Coolant temperature: 80 �C
Intake air temperature: 38 �C
Voltage terminal 30: 13.892 V
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: -1.91 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 10.82 g
Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 316 km
Counter for regeneration time of particulate filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 12596.0189 s
Particle filter: difference pressure-DIP_PF: 1.00 hPa
DPF: offset for differential pressure-DIP_PF_AD[0]: -2.07 hPa
Service regeneration: Release conditions 3-FRF_STATE_RGN: 1
Readiness: 1110 1000
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: A13B20F8092400FF850B04E9901B0041210000
Shop #: WSC 00066 000 00000
VCID: 7BA3F1D783E44063261-802E
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004002
Shop #: WSC 00066 000 00118
VCID: 0059863BEA8223BB733-8054
9477141 - Position Sensor for Air Distribution Flap Motor
B109C 15 [008] - Open or Short to Plus
Fault Frequency: 8
Reset counter: 145
Mileage: 102196 km
Date: 2020.11.04
Time: 17:45:06
Part No SW: 5K0 937 084 F HW: 5K0 937 084 F
Component: BCM PQ35 B 011 0048
Revision: BA011001
Coding: 00000A3A882DE3C040000080000000E403000088708085605CC000000040
VCID: 353727EFE5405613905-8060
Subsystem 1 - Part No: 1K8 951 171
Subsystem 2 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
00984 - Left Tail Light (M4)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 105
Mileage: 82412 km
Date: 2012.04.23
Time: 19:46:32
Voltage: 14.05 V
Fault Status: 00101010
Reset counter: 145
Mileage: 89954 km
Date: 2013.04.27
Time: 05:02:58
Voltage: 14.10 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 5C6 919 475 HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0005
Revision: -------- Serial number: 84091116401713
Coding: 108001
ASAM Dataset: EV_EPHVA18VW3610000 001003
ROD: EV_EPHVA18VW3610000.rod
VCID: 71BFD3FFD1283A338CD-8024
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6M002XD9
Coding: 00003242
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 323D1CF314AE412BB57-8066
Serial number: 3572MSME2A0E2460ZZZV
Serial number: 3582MSME5A56306BZZZ/
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME22532B11ZZZG
Serial number: 3526KSME7E1A1B11ZZZ-
Part No SW: 1K5 953 521 AE HW: 5K0 953 569
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110604101456
Coding: 4080040000
Shop #: WSC 00066 000 00187
ROD: EV_SMLSNGVOLWS.rod
VCID: 70B9D6FBDA22333B833-8024
Part No SW: 5C6 920 861 A HW: 5C6 920 861 A
Component: KOMBI H04 0606
Coding: 170E00
VCID: 290FFB9F397802F304D-807C
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 05081101270631
Coding: 351002
Component: IMMO H04 0606
VCID: 6A8DC493FCFEC9EBCD7-803E
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0515
Revision: 12110009 Serial number: 0003085488
Coding: 0000B5
Shop #: WSC 01383 790 50316
VCID: 1C61D24B662AE75B8FB-8048
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1508
Serial number: 00000005950012
Coding: 000090
66304 - Switch for Drivers Side Window Regulator
B11F0 29 [008] - Signal Implausible
Reset counter: 122
Mileage: 102371 km
Date: 2020.11.15
Time: 22:25:06
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 34311AEBE23A4F1BA7B-8060
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0515
Revision: 14110009 Serial number: 0004711312
Coding: 0001B4
VCID: 1D67DF4F7D30EE53785-8048
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1508
Serial number: 00000005943676
Coding: 000090
66562 - Heated Exterior Mirror
B11F8 14 [009] - Open or Short to Ground
Fault Frequency: 29
Reset counter: 29
Mileage: 42471 km
Date: 2013.10.27
Time: 21:24:19
67074 - Motors for Central Locking
B122B 01 [008] - Electrical Failure
Reset counter: 133
67330 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Reset counter: 119
Mileage: 102174 km
Date: 2020.11.02
Time: 18:23:14
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 032 0079
Revision: 01000001 Serial number: VWZ1Z2L3065716
Coding: 05000400040006
VCID: 72BDDCF3D4AE012B757-8026
Fault Status: 00101011
Fault Frequency: 42
Reset counter: 139
Mileage: 98802 km
Date: 2014.09.08
Time: 17:47:52
Reset counter: 53
Mileage: 81603 km
Date: 2012.03.13
Time: 13:58:02
Fault Frequency: 228
Reset counter: 98
Mileage: 88678 km
Date: 2013.02.12
Time: 23:53:34
End----------(Elapsed Time: 01:09, VBatt start/end: 14.0V/13.8V)-----------
