Regeneration doesnt work
khaledabdulaziz
Israel
C?ID=394371
hello all
i hope you are doing well
i have a vw jetta 2014 with dpf, engine, and glow plug light on and with this error *16848 - Diesel Particulate Filter *
i tried doing force regeneration but it shows *finished correctly* but no regeneration
could it be the g450 sensor ?
here is the auto scan
side question : whats the difference between soot measured and soot calculated
thanks.
Saturday,19,December,2020,19:02:13:04619
VCDS Version: 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: WVWZZZ16ZCM025052   License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ16ZCM025052   Mileage: 102910km-63945miles
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 ML    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 9052
   Revision: --H43---    Serial number: 00000000000000
   Coding: 10114014030400080000
   Shop #: WSC 00066 000 00081
   ASAM Dataset: EV_ECM16TDI02103L906023ML 003005
   ROD: EV_ECM16TDI02103L906023ML_003_VW32.rod
   VCID: 7CA1F2CB866A475B2FB-8028
          P2458 00 [175] - Regeneration Duration
                    Mileage: 102866 km
                    Date: 2020.12.19
                    Time: 00:09:23
                    Engine RPM: 781.50 /min
                    Normed load value: 30.6 %
                    Coolant temperature: 80 �C
                    Intake air temperature: 38 �C
                    Voltage terminal 30: 13.892 V
                    Particle filter: soot mass measured-MASS_SOOT_PHY_PF: -1.91 g
                    Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 10.82 g
                    Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 316 km
                    Counter for regeneration time of particulate filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 12596.0189 s
                    Particle filter: difference pressure-DIP_PF: 1.00 hPa
                    DPF: offset for differential pressure-DIP_PF_AD[0]: -2.07 hPa
                    Service regeneration: Release conditions 3-FRF_STATE_RGN: 1
Readiness: 1110 1000
   Revision: 00H31001
   Coding: A13B20F8092400FF850B04E9901B0041210000
   Shop #: WSC 00066 000 00000
   VCID: 7BA3F1D783E44063261-802E
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0304
   Revision: 00001015
   Coding: 0000004002
   Shop #: WSC 00066 000 00118
   ROD: EV_ACManueBHBVW36X_VW32.rod
   VCID: 0059863BEA8223BB733-8054
9477141 - Position Sensor for Air Distribution Flap Motor
          B109C 15 [008] - Open or Short to Plus
                    Fault Frequency: 8
                    Reset counter: 145
                    Mileage: 102196 km
                    Date: 2020.11.04
                    Time: 17:45:06
   Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
   Component: BCM PQ35 B    011 0048
   Revision: BA011001
   Coding: 00000A3A882DE3C040000080000000E403000088708085605CC000000040
   VCID: 353727EFE5405613905-8060
   Subsystem 1 - Part No: 1K8 951 171
   Subsystem 2 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
00984 - Left Tail Light (M4)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 105
                    Mileage: 82412 km
                    Date: 2012.04.23
                    Time: 19:46:32
                        Term 15 On
                    Voltage: 14.05 V
                    Fault Status: 00101010
                    Reset counter: 145
                    Mileage: 89954 km
                    Date: 2013.04.27
                    Time: 05:02:58
                        Term 15 On
                    Voltage: 14.10 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5C6 919 475     HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0005
   Revision: --------    Serial number: 84091116401713
   Coding: 108001
   ASAM Dataset: EV_EPHVA18VW3610000 001003
   ROD: EV_EPHVA18VW3610000.rod
   VCID: 71BFD3FFD1283A338CD-8024
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6M002XD9
   Coding: 00003242
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 323D1CF314AE412BB57-8066
   Serial number: 3572MSME2A0E2460ZZZV
   Serial number: 3582MSME5A56306BZZZ/
   Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3516KSME22532B11ZZZG
   Serial number: 3526KSME7E1A1B11ZZZ-
   Part No SW: 1K5 953 521 AE    HW: 5K0 953 569
   Revision: FF010040    Serial number: 20110604101456
   Coding: 4080040000
   Shop #: WSC 00066 000 00187
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 70B9D6FBDA22333B833-8024
   Part No SW: 5C6 920 861 A    HW: 5C6 920 861 A
   Component: KOMBI         H04 0606
   Coding: 170E00
   VCID: 290FFB9F397802F304D-807C
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 05081101270631
   Coding: 351002
   Component: IMMO          H04 0606
   ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
   VCID: 6A8DC493FCFEC9EBCD7-803E
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0515
   Revision: 12110009    Serial number: 0003085488
   Coding: 0000B5
   Shop #: WSC 01383 790 50316
   VCID: 1C61D24B662AE75B8FB-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1508
   Serial number: 00000005950012
   Coding: 000090
66304 - Switch for Drivers Side Window Regulator
          B11F0 29 [008] - Signal Implausible
                    Reset counter: 122
                    Mileage: 102371 km
                    Date: 2020.11.15
                    Time: 22:25:06
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 34311AEBE23A4F1BA7B-8060
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0515
   Revision: 14110009    Serial number: 0004711312
   Coding: 0001B4
   VCID: 1D67DF4F7D30EE53785-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1508
   Serial number: 00000005943676
   Coding: 000090
66562 - Heated Exterior Mirror
          B11F8 14 [009] - Open or Short to Ground
                    Fault Frequency: 29
                    Reset counter: 29
                    Mileage: 42471 km
                    Date: 2013.10.27
                    Time: 21:24:19
67074 - Motors for Central Locking
          B122B 01 [008] - Electrical Failure
                    Fault Frequency: 6
                    Reset counter: 133
67330 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Reset counter: 119
                    Mileage: 102174 km
                    Date: 2020.11.02
                    Time: 18:23:14
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: Radio RCD310  032 0079
   Revision: 01000001    Serial number: VWZ1Z2L3065716
   Coding: 05000400040006
   VCID: 72BDDCF3D4AE012B757-8026
                    Fault Status: 00101011
                    Fault Frequency: 42
                    Reset counter: 139
                    Mileage: 98802 km
                    Date: 2014.09.08
                    Time: 17:47:52
                    Fault Status: 01101011
                    Reset counter: 53
                    Mileage: 81603 km
                    Date: 2012.03.13
                    Time: 13:58:02
                    Fault Frequency: 228
                    Reset counter: 98
                    Mileage: 88678 km
                    Date: 2013.02.12
                    Time: 23:53:34
End----------(Elapsed Time: 01:09, VBatt start/end: 14.0V/13.8V)-----------
khaledabdulaziz
Israel
C?ID=394371
The same, it doesn't give me any error in g450 sensor
"The same" is not a a reading of values.
Should be something like:
IDE00427-ENG101722 -- Particle filter: difference pressure (hPa)
khaledabdulaziz
Israel
C?ID=394371
Now I don't have the car in my hands, thought I should ask for future cos it seems like a regular problem where dpf doesn't regenerate
I thought the g450 would be the problem because dpf light is on while soot calculated and soot measured is less the 35g
Component: 1,6l R4 CR td H43 9052 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< VWWWWHAT FOD IS DIS?
Mileage: 102866 km
Date: 2020.12.19
Time: 00:09:23
PARDON ME........HOLY MOLY! ;)
Volkswagen
PartVersion
FL_03L906023ML6836
9052
9647
9917
9917
9970
9971
C-U-B-E-_-
C?ID=327304
All files here "before emissions update"
Volkswagen
PartVersion
FL_03L906023ML6836
9052
9647
9917
9917
9970
9971
After emissions diesel update:
03L906023ML > 03L997557P
FL_03L997557P9978
9980
9982
Old firmware isn't "FOD" in my book, but yeah., it should be updated, at least to the latest version before the emissions fix/fail.
It is FOD if it was determined by a High German or US Court.
Don't worry OP the Israelites are a little late but not to worry right?
Funny thing about "Games of the system" and "Courts" they are usually played with "Rackets" huh? :p
khaledabdulaziz
Israel
C?ID=394371
so first, car owner need to update firmware, how he can do that?
then i perform regeneration?
C-U-B-E-_-
C?ID=327304
With the 9052 there were occasional problems with insufficient pressure tolerance = no regeneration. I would flash the "9971" and test it again. Whatever the case, the car had the update and was flashed back but part number 3C0129363A was not removed.
C-U-B-E-_-
C?ID=327304
khaledabdulaziz
Israel
C?ID=394371
im sorry but first you said part 3C0129363A was not removed and then
I don't know how to write it. The error P2458 can have many causes, from G450, exhaust sensors, DPF loading. But the MSG software 9052 could also be the cause. Off topic, look that 3C0129363A is not installed.
This part is not for this MSG software.
here you said the same part is not installed, im not quite understanding
C-U-B-E-_-
C?ID=327304
OK, I wasn't thinking about your country. Then please forget about the spare part. I just came up with the idea since there are people who reverse emissions updates and forget to remove the spare at 1.6. For your understanding:
FL_03L906023ML
6836 ?
9052 Bug
9647 Bug
9917 ?
9970 Ok
9971 OK
These are all no emission updates and no 3C0129363A installed.
