Abs coding help please (MK60EC1)
adrian2ca
Chester, VA, USA
C?ID=427636
Hello . Help please . My abs code got lost some how after replacing battery . I have been trying to figure out the abs coding ince it went to all 0s but i have had no luck . I am complete newby at all this . Any suggestions on what i should do or where to look. Thanks in advance
iichel
Netherlands, eastern part
C?ID=284912
Start with an autoscan and determine why the coding was lost
adrian2ca
Chester, VA, USA
C?ID=427636
Thabks for the response .Cluster was disconected . Apparently once a cluster loses conection it causes all this crazy things .
iichel
C?ID=284912
Did you put back the original cluster and never connect another cluster?
adrian2ca
Chester, VA, USA
C?ID=427636
No . The digital display was messed up on the original so i tried to swap it woth a donor but than i started to get into the immobilizer and i swapped it back . Learned my lesson though.
iichel
C?ID=284912
So you did put in a different cluster from the donor? Not that I'm criticizing you, but at least it's good to know why your coding was lost and also that the original cluster is back.
Anyway, we're going to need that autoscan.
adrian2ca
Chester, VA, USA
C?ID=427636
Correct original is back but yeah u think that was the reason coding was lost. I had never scanned the car before until after the whole coding lost deal . And ok here is the scan got hopefully i did it right.
VIN: WVWHD91K69W107267 License Plate:
Mileage: 180180km-111958mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 65
72
VIN: WVWHD91K69W107267 Mileage: 180180km-111958miles
15-Airbags -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 1010
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AF HW: 1K0 907 115 AD
Component: 2.0l R4/4V TFSI 0010
Revision: E3H13--- Serial number: VWX7Z0H83N484I
Coding: 040301081C070160
Shop #: WSC 13621 538 460486
VCID: 6A8DC93C107792FBCD6-803E
053285 - Please Check Fault Codes in Control Module for HVAC (J301)
U1025 - 000 -
Mileage: 180183 km
Time: 21:31:50
RPM: 772 /min
Load: 26.7 %
Temperature: 45.0C
Temperature: 18.0C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
001169 - Secondary Air Injection System: Bank 1
P0491 - 000 - Insufficient Flow
Mileage: 180183 km
Time: 23:53:23
RPM: 1269 /min
Load: 46.3 %
Temperature: 30.0C
Temperature: 21.0C
Voltage: 13.589 V
Readiness: 0110 1101
Part No SW: 02E 300 044 J HW: 02E 927 770 AD
Component: GSG DSG 082 1408
Revision: 04808020 Serial number: 00000811050513
Shop #: WSC 04940 001 00001
VCID: 1C61DFE48AA3BC4B8FA-8048
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Shop #: WSC 03824 002 1048576
VCID: 00598B940A0B78AB732-8054
03306 - Coding Not Valid
Reset counter: 244
Mileage: 180185 km
Count: 3
Count: 14
Count: 13056
Count: 4161
Count: 50176
Fault Status: 01100101
Reset counter: 244
Mileage: 180185 km
Count: 3
Count: 14
Count: 12544
Count: 279
Count: 40192
Reset counter: 244
Mileage: 180185 km
Count: 3
Count: 14
Count: 12544
Count: 270
Count: 40192
Reset counter: 244
Mileage: 180185 km
Count: 7
Count: 14
Count: 13056
Count: 195
Count: 50432
Reset counter: 244
Mileage: 180185 km
Count: 3
Count: 14
Count: 12544
Count: 291
Count: 40192
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78A9E3745EDB306B4B2-802C
009 - Open or Short to Ground
01316 - ABS Control Module
Revision: 00H54000 Serial number: 00000008768565
Coding: B78D8F2540041500470A00000F0000000019950B5C000120000000000000
Shop #: WSC 12345 785 00200
VCID: 33331458073D1333BE0-8066
Component: Wischer 220808 021 0501
Coding: 00038805
Shop #: WSC 12345
Fault Status: 00101100
Reset counter: 28
Mileage: 180183 km
Voltage: 11.95 V
Reset counter: 28
Mileage: 180183 km
Voltage: 12.00 V
00834 - Signal for Activation of Heated Rear Window
Fault Status: 00101001
Reset counter: 27
Mileage: 180145 km
Voltage: 12.70 V
Reset counter: 28
Mileage: 180183 km
Voltage: 12.00 V
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 28
Mileage: 180183 km
Voltage: 12.00 V
Reset counter: 27
Mileage: 178935 km
Voltage: 11.85 V
Revision: 00000000 Serial number: AUZ4Z7H0385509
Coding: 0000100
00003 - Control Module
Fault Status: 00101110
Fault Frequency: 12
Reset counter: 138
Mileage: 149721 km
Time: 03:59:12
Reset counter: 237
Mileage: 180089 km
Time: 23:41:13
Component: 6P AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BVK1A
Coding: 0013904
VCID: 6C81CF241A838CCBBFA-8038
Subsystem 1 - Part No: 000 000 000 000
Component: BF-Gewichtsens. 000 0000
Subsystem 2 - Serial number: 6332MSME3F5121266
Subsystem 3 - Serial number: 6342MSME3F162B69P
Subsystem 4 - Serial number: 6352QSME4B0431224
Subsystem 5 - Serial number: 6362QSME746D5033J
Subsystem 6 - Serial number: 63727SME1833110DX
Subsystem 7 - Serial number: 63827SME18331B783
02511 - Control Module for Seat Occupied Recognition (J706)
008 - Implausible Signal - MIL ON
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0101
Coding: 0012122
Component: E0221 002 0010
Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H83N484I
Coding: 0007103
Shop #: WSC 00000 785 00200
VCID: 392F26702551E96374C-806C
Fault Frequency: 12
Reset counter: 28
Mileage: 180183 km
Time: 00:48:15
Reset counter: 28
Mileage: 180183 km
Time: 01:08:26
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 250808F1000721
Coding: ED817F070013020002
VCID: 35372A4009490D03904-8060
Fault Status: 00110100
Reset counter: 27
Mileage: 180183 km
Time: 00:48:16
Reset counter: 27
Mileage: 180183 km
Time: 01:08:27
00381 - Databus Instrument Cluster
Reset counter: 26
Reset counter: 26
Reset counter: 26
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T44PV03
VCID: 7DA7F26071F91543184-8028
Reset counter: 27
Fault Frequency: 12
Reset counter: 28
Mileage: 180183 km
Time: 00:48:15
Component: IMMO VDD 2416
Component: Tuer-SG 006 1219
Coding: 0001205
VCID: 382923741E5BF06B8B2-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
02546 - Steering Limit Stop
Mileage: 180170 km
Temperature: 17.0C
Voltage: 13.90 V
Voltage: 13.70 V
Coding: 1B9006885103483E0904058FB0080F0488DC00
VCID: 045187841213648B57A-8050
Part No SW: 1K0 959 702 AK HW: 1K0 959 702 AK
Component: Tuer-SG 006 1203
Coding: 0001204
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1D74442B3540B67A-8020
Component: Radio PM6 019 0037
Revision: 00019000 Serial number: VWZ5Z7H2255653
Coding: 0040402
VCID: 290FF630D5F159E304C-807C
Fault Frequency: 8
Reset counter: 2
Mileage: 178821 km
Time: 03:29:57
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1305
Coding: 0001168
Shop #: WSC 01357 011 1012552
01554 - Motors for Central Locking; Rear Doors; Lock
Component: RDK 0450
Coding: 0100101
00625 - Vehicle Speed Signal
Fault Status: 00111000
Reset counter: 28
Mileage: 180183 km
Time: 00:48:16
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0001168
End----------(Elapsed Time: 01:32, VBatt start/end: 13.9V/13.9V)-----------
iichel
C?ID=284912
I'm sure that's the reason the coding was lost, yes.
adrian2ca
Chester, VA, USA
C?ID=427636
Any idea how i can get it back or get a new one?
iichel
C?ID=284912
Is there anything in your C:\Ross-Tech\VCDS\Logs folder from this car?
iichel
C?ID=284912
iichel
C?ID=284912
great, can you post a scan of the car in the fixed state?
