VIN: WVWHD91K69W107267 License Plate:
Mileage: 180180km-111958mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 65
72
VIN: WVWHD91K69W107267 Mileage: 180180km-111958miles
15-Airbags -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 1010
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AF HW: 1K0 907 115 AD
Component: 2.0l R4/4V TFSI 0010
Revision: E3H13--- Serial number: VWX7Z0H83N484I
Coding: 040301081C070160
Shop #: WSC 13621 538 460486
VCID: 6A8DC93C107792FBCD6-803E
053285 - Please Check Fault Codes in Control Module for HVAC (J301)
U1025 - 000 -
Mileage: 180183 km
Time: 21:31:50
RPM: 772 /min
Load: 26.7 %
Temperature: 45.0C
Temperature: 18.0C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
001169 - Secondary Air Injection System: Bank 1
P0491 - 000 - Insufficient Flow
Mileage: 180183 km
Time: 23:53:23
RPM: 1269 /min
Load: 46.3 %
Temperature: 30.0C
Temperature: 21.0C
Voltage: 13.589 V
Readiness: 0110 1101
Part No SW: 02E 300 044 J HW: 02E 927 770 AD
Component: GSG DSG 082 1408
Revision: 04808020 Serial number: 00000811050513
Shop #: WSC 04940 001 00001
VCID: 1C61DFE48AA3BC4B8FA-8048
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Shop #: WSC 03824 002 1048576
VCID: 00598B940A0B78AB732-8054
03306 - Coding Not Valid
Reset counter: 244
Mileage: 180185 km
Count: 3
Count: 14
Count: 13056
Count: 4161
Count: 50176
Fault Status: 01100101
Reset counter: 244
Mileage: 180185 km
Count: 3
Count: 14
Count: 12544
Count: 279
Count: 40192
Reset counter: 244
Mileage: 180185 km
Count: 3
Count: 14
Count: 12544
Count: 270
Count: 40192
Reset counter: 244
Mileage: 180185 km
Count: 7
Count: 14
Count: 13056
Count: 195
Count: 50432
Reset counter: 244
Mileage: 180185 km
Count: 3
Count: 14
Count: 12544
Count: 291
Count: 40192
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78A9E3745EDB306B4B2-802C
009 - Open or Short to Ground
01316 - ABS Control Module
Revision: 00H54000 Serial number: 00000008768565
Coding: B78D8F2540041500470A00000F0000000019950B5C000120000000000000
Shop #: WSC 12345 785 00200
VCID: 33331458073D1333BE0-8066
Component: Wischer 220808 021 0501
Coding: 00038805
Shop #: WSC 12345
Fault Status: 00101100
Reset counter: 28
Mileage: 180183 km
Voltage: 11.95 V
Reset counter: 28
Mileage: 180183 km
Voltage: 12.00 V
00834 - Signal for Activation of Heated Rear Window
Fault Status: 00101001
Reset counter: 27
Mileage: 180145 km
Voltage: 12.70 V
Reset counter: 28
Mileage: 180183 km
Voltage: 12.00 V
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 28
Mileage: 180183 km
Voltage: 12.00 V
Reset counter: 27
Mileage: 178935 km
Voltage: 11.85 V
Revision: 00000000 Serial number: AUZ4Z7H0385509
Coding: 0000100
00003 - Control Module
Fault Status: 00101110
Fault Frequency: 12
Reset counter: 138
Mileage: 149721 km
Time: 03:59:12
Reset counter: 237
Mileage: 180089 km
Time: 23:41:13
Component: 6P AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BVK1A
Coding: 0013904
VCID: 6C81CF241A838CCBBFA-8038
Subsystem 1 - Part No: 000 000 000 000
Component: BF-Gewichtsens. 000 0000
Subsystem 2 - Serial number: 6332MSME3F5121266
Subsystem 3 - Serial number: 6342MSME3F162B69P
Subsystem 4 - Serial number: 6352QSME4B0431224
Subsystem 5 - Serial number: 6362QSME746D5033J
Subsystem 6 - Serial number: 63727SME1833110DX
Subsystem 7 - Serial number: 63827SME18331B783
02511 - Control Module for Seat Occupied Recognition (J706)
008 - Implausible Signal - MIL ON
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0101
Coding: 0012122
Component: E0221 002 0010
Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H83N484I
Coding: 0007103
Shop #: WSC 00000 785 00200
VCID: 392F26702551E96374C-806C
Fault Frequency: 12
Reset counter: 28
Mileage: 180183 km
Time: 00:48:15
Reset counter: 28
Mileage: 180183 km
Time: 01:08:26
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 250808F1000721
Coding: ED817F070013020002
VCID: 35372A4009490D03904-8060
Fault Status: 00110100
Reset counter: 27
Mileage: 180183 km
Time: 00:48:16
Reset counter: 27
Mileage: 180183 km
Time: 01:08:27
00381 - Databus Instrument Cluster
Reset counter: 26
Reset counter: 26
Reset counter: 26
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T44PV03
VCID: 7DA7F26071F91543184-8028
Reset counter: 27
Fault Frequency: 12
Reset counter: 28
Mileage: 180183 km
Time: 00:48:15
Component: IMMO VDD 2416
Component: Tuer-SG 006 1219
Coding: 0001205
VCID: 382923741E5BF06B8B2-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
02546 - Steering Limit Stop
Mileage: 180170 km
Temperature: 17.0C
Voltage: 13.90 V
Voltage: 13.70 V
Coding: 1B9006885103483E0904058FB0080F0488DC00
VCID: 045187841213648B57A-8050
Part No SW: 1K0 959 702 AK HW: 1K0 959 702 AK
Component: Tuer-SG 006 1203
Coding: 0001204
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1D74442B3540B67A-8020
Component: Radio PM6 019 0037
Revision: 00019000 Serial number: VWZ5Z7H2255653
Coding: 0040402
VCID: 290FF630D5F159E304C-807C
Fault Frequency: 8
Reset counter: 2
Mileage: 178821 km
Time: 03:29:57
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1305
Coding: 0001168
Shop #: WSC 01357 011 1012552
01554 - Motors for Central Locking; Rear Doors; Lock
Component: RDK 0450
Coding: 0100101
00625 - Vehicle Speed Signal
Fault Status: 00111000
Reset counter: 28
Mileage: 180183 km
Time: 00:48:16
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0001168
End----------(Elapsed Time: 01:32, VBatt start/end: 13.9V/13.9V)-----------
