Got a A7 in calculated soot was around 40g actual 5g, i reset DPF so values go to 0 but every time i try to start regen it just says failed due to safety reasons.
I've tried adaptations -> regenerate while driving but it says security access required
the 27971 code that's shown gets accepted but it still tells me i need security access
the differential pressure on idle is 14/15 HPa which i didnt think was too bad? once reset it should let me do forced regen while standing?
If not does anyone know the code to do it while driving
Saturday,05,December,2020,00:32:42:55293
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WAUZZZ4G9FN031684 License Plate: A7
Mileage: 84643km-52594mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 28 30 36 3B 3C 42 44 46
52 53 55 5F 62 6D 72 82 85 8B 8E 8F 90 A9 AC C0
VIN: WAUZZZ4G9FN031684 Mileage: 84643km-52594miles
Address 01: Engine (J623-CVUA) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 589 D HW: 4G0 907 589 B
Component: 3.0BTD EDC17 H23 0001
Revision: 54H23---
Coding: 1A2A4032256603030800
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30BTD0114G0907589D 001001
ROD: EV_ECM30BTD0114G0907589D.rod
VCID: 3536DA2535CC0973B15-8060
5188 - Diesel Particle Filter
P2463 00 [167] - Excessive Soot Accumulation
5189 - Particulate Trap Bank 1
P2002 00 [039] - Efficiency Below Threshold
Part No SW: 4G0 927 158 AK HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H19 1003
Revision: --H19---
VCID: 77AA102D6F403B63639-8022
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 49B79E4B92ED79D29B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FDAB80D07F0C3236B9-806A
36352 - Function Restricted due to Insufficient Voltage
U1400 00 [040] - -
[HydraulicSupplyUndervoltage]
Part No SW: 4H0 907 064 FP HW: 4H0 907 064 EP
Component: BCM2 2.0 H36 0551
Coding: 05BA6F4E000000000000
VCID: 7CA00F0156E6183B0EB-8028
Serial number: 0214000143211005
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 21101400042413
Coding: 362311B83D0000
VCID: 6392547DCBD8C7C32F1-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000921293502
Coding: 0105C01440349FE2E10140C7800018000F9DC30A2F08020180000894610013020040002D030000
VCID: 71BE2E3501A46553ADD-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 140914 H37 0080
Serial number: 140920170218
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23352938
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
Component: E1 - LDS H07 0044
Serial number: 27 10 2014 00000595
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA108752000008582744
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 37794557000000000001
Part No SW: 4G0 907 561 B HW: 4G0 907 561
Component: ACC3 H21 0053
Coding: 7E04010201
ASAM Dataset: EV_AdaptCruisContrAU57X 002014
VCID: 290E0655E9745D9325D-807C
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_VDC_FAIL]
140288 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_ECD_FAIL]
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P10022D7A
Coding: 30333046313230313031554A305234473853
VCID: 3B22CC1D13E8DF03471-806E
Serial number: 3575HRB405N2Q15Q7PSC
Serial number: 3585HRB40612QP0S8HU8
Serial number: 3515JRB405931BAKA8BY
Serial number: 3525JRB404V31BAKC0RN
Serial number: 3554VRB400I52RD8PQ10
Serial number: 3564VRB400C52RD8DP7V
Revision: -------- Serial number: 90372NJH000KJ
Coding: 0000FC
VCID: 372AD02D2F40FB63A39-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 11 10 2014 C0030120
Part No SW: 4G8 920 985 T HW: 4G8 920 985 T
Component: TDieGb Acc H07 0043
Revision: 03001036 Serial number: 658270914592035
Coding: 338602028F532600010100
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 48C8A3D1523E849BDA3-801C
Part No SW: 4G8 907 468 HW: 4G8 907 468
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001597405
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001024
VCID: 75B61A25754C4973715-8020
Serial number: 2968744703
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 140811000000000001C1
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H17 0200
Serial number: 001510140001007
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
VCID: 28080351F27E649B3A3-807C
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 14101400040148
Coding: 22
VCID: 3E24C50900FACA2B60F-806A
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000069948
Coding: 01010101000000000001000202
VCID: 64905761CE56C0FBD6B-8030
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000122042773
Coding: 00781B0000006001000001010101102030303232203232
VCID: 77AA102D6FC03B63639-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E018E1$
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372AD02D2FC0FB63A39-8062
Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
Component: SWA Master H06 0060
Serial number: 0348170638
Coding: 040312
VCID: 392ED61519D4ED1355D-806C
Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
Component: SWA Slave H06 0060
Serial number: 0348211582
Coding: 040312
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011C5E035E21628002080413
VCID: 45D6AAE565AC99F3215-8010
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0008075943
Coding: 101001010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 3332E43D3BB817439F1-8066
Revision: 00002001 Serial number: 0349887922
Coding: 013B0E22A0B9B885C3200A040E030D470000000000000000000000000000
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO33187354
Coding: 901F00
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA108942000008921468
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93357859
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0507
Coding: 011C5E035E21628002080402
VCID: 44D0B7E16E96A0FB36B-8010
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000002123536
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 313EEE35C1A42553EDD-8064
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 D HW: 7P6 907 357 B
Component: MxB-ECU 001 0081
Coding: 05FE02202A170200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
Coding: E02100
Coding: E02100
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0030
Coding: E02100
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0030
Coding: E02100
5353456 - Fog mode active
C118E 00 [008] - -
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 018 HW: 4G1 035 021
Component: MU-H-LND-EU 040 0389
Serial number: A588J0EB000390
Coding: 017503010000000013111102000A00132F000CE7F1700100DF
VCID: 5DE66285EDBCF133195-8008
Subsystem 1 - Part No SW: V03 959 801 ET HW: -----------
Component: ECE 2015 --- 0105
Subsystem 2 - Part No SW: 4G1 919 605 HW: 4G1 919 605
Component: DU8 C7 SV H42 0007
Serial number: AUZ8Z9EL8004CR
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349NJB000D5
Component: Gracenote2 --- 1012
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS aerial - open circuit]
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: TSG HL H03 0507
Coding: 01081C024021628002080002
VCID: 47CAA0ED5FA08BE3D39-8012
Part No SW: 4G8 959 107 S HW: 4G8 959 107 H
Component: HDSG-Modul H14 0049
Revision: 11014001 Serial number: 289400737
Coding: 0A3305C022
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 45D6AAE5652C99F3215-8010
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 N HW: 4G8 919 604 N
Component: HeadUpDisplay H06 0304
Coding: C60000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Coding: 6A160000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C00FF41E68648BBDEB-8078
Part No SW: 4G0 907 541 B HW: 4G0 907 541
Coding: 7E04010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
VCID: 270A006DFF606BE3339-8072
U1113 00 [008] - -
U1113 00 [008] - -
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H33 0090
Serial number: 005000621610147
Coding: 03C2381A1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[ESP_ESP_01_Signal_Error]
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308004240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
VCID: 323CE139C4A21E4B947-8066
Part No SW: 4G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0007
Serial number: 140916202924
VCID: 2E04F549D09A3AABF0F-807A
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0010
Revision: 00000000 Serial number: 142820657
ROD: EV_RDCMA00100.rod
VCID: 2B02FC5DE3884F83D71-807E
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 E HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0011
Serial number: 131218201781
End----------(Elapsed Time: 02:39, VBatt start/end: 14.5V/14.4V)-----------
