A7 3.0 UDS Unable to regenerate DPF
orangetech
C?ID=233796
Hi,
Got a A7 in calculated soot was around 40g actual 5g, i reset DPF so values go to 0 but every time i try to start regen it just says failed due to safety reasons.
I've tried adaptations -> regenerate while driving but it says security access required
the 27971 code that's shown gets accepted but it still tells me i need security access
the differential pressure on idle is 14/15 HPa which i didnt think was too bad? once reset it should let me do forced regen while standing?
If not does anyone know the code to do it while driving
Saturday,05,December,2020,00:32:42:55293
VIN: WAUZZZ4G9FN031684   License Plate: A7
Mileage: 84643km-52594mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 28 30 36 3B 3C 42 44 46
          52 53 55 5F 62 6D 72 82 85 8B 8E 8F 90 A9 AC C0
VIN: WAUZZZ4G9FN031684   Mileage: 84643km-52594miles
Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 589 D    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0001
   Revision: 54H23---
   Coding: 1A2A4032256603030800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30BTD0114G0907589D 001001
   ROD: EV_ECM30BTD0114G0907589D.rod
   VCID: 3536DA2535CC0973B15-8060
5188 - Diesel Particle Filter
          P2463 00 [167] - Excessive Soot Accumulation
5189 - Particulate Trap Bank 1
          P2002 00 [039] - Efficiency Below Threshold
   Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1003
   Revision: --H19---
   VCID: 77AA102D6F403B63639-8022
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 49B79E4B92ED79D29B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FDAB80D07F0C3236B9-806A
36352 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
          [HydraulicSupplyUndervoltage]
   Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
   Component: BCM2 2.0      H36 0551
   Coding: 05BA6F4E000000000000
   VCID: 7CA00F0156E6183B0EB-8028
   Serial number: 0214000143211005
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 21101400042413
   Coding: 362311B83D0000
   VCID: 6392547DCBD8C7C32F1-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00000921293502
   Coding: 0105C01440349FE2E10140C7800018000F9DC30A2F08020180000894610013020040002D030000
   VCID: 71BE2E3501A46553ADD-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140914  H37 0080
   Serial number:         140920170218
   Coding: 0045F7
   Serial number: 23352938
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 27 10 2014  00000595
   Component: EVLS-SG  H08 0300
   Serial number: WA108752000008582744
   Coding: 020300
   Serial number: 37794557000000000001
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7E04010201
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 290E0655E9745D9325D-807C
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_VDC_FAIL]
140288 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_ECD_FAIL]
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P10022D7A
   Coding: 30333046313230313031554A305234473853
   VCID: 3B22CC1D13E8DF03471-806E
   Serial number: 3575HRB405N2Q15Q7PSC
   Serial number: 3585HRB40612QP0S8HU8
   Serial number: 3515JRB405931BAKA8BY
   Serial number: 3525JRB404V31BAKC0RN
   Serial number: 3554VRB400I52RD8PQ10
   Serial number: 3564VRB400C52RD8DP7V
   Revision: --------    Serial number: 90372NJH000KJ
   Coding: 0000FC
   VCID: 372AD02D2F40FB63A39-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 11 10 2014  C0030120
   Part No SW: 4G8 920 985 T    HW: 4G8 920 985 T
   Component: TDieGb Acc    H07 0043
   Revision: 03001036    Serial number: 658270914592035
   Coding: 338602028F532600010100
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 48C8A3D1523E849BDA3-801C
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Revision: --------    Serial number: 00000001597405
   Coding: C0CD078118
   VCID: 75B61A25754C4973715-8020
   Serial number: 2968744703
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140811000000000001C1
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 001510140001007
   VCID: 28080351F27E649B3A3-807C
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0112
   Serial number: 14101400040148
   Coding: 22
   VCID: 3E24C50900FACA2B60F-806A
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000069948
   Coding: 01010101000000000001000202
   VCID: 64905761CE56C0FBD6B-8030
   Revision: AA000000    Serial number: 00000122042773
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77AA102D6FC03B63639-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E018E1$
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372AD02D2FC0FB63A39-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H06 0060
   Serial number: 0348170638
   Coding: 040312
   VCID: 392ED61519D4ED1355D-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0060
   Serial number: 0348211582
   Coding: 040312
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011C5E035E21628002080413
   VCID: 45D6AAE565AC99F3215-8010
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0008075943
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 3332E43D3BB817439F1-8066
   Revision: 00002001    Serial number: 0349887922
   Coding: 013B0E22A0B9B885C3200A040E030D470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO33187354
   Coding: 901F00
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA108942000008921468
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93357859
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0507
   Coding: 011C5E035E21628002080402
   VCID: 44D0B7E16E96A0FB36B-8010
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000002123536
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 313EEE35C1A42553EDD-8064
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 05FE02202A170200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   Coding: E02100
   Coding: E02100
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0030
   Coding: E02100
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0030
   Coding: E02100
5353456 - Fog mode active
          C118E 00 [008] - -
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 018     HW: 4G1 035 021
   Component: MU-H-LND-EU   040 0389
   Serial number: A588J0EB000390
   Coding: 017503010000000013111102000A00132F000CE7F1700100DF
   VCID: 5DE66285EDBCF133195-8008
   Subsystem 1 - Part No SW: V03 959 801 ET    HW: -----------
   Component: ECE 2015  --- 0105
   Subsystem 2 - Part No SW: 4G1 919 605     HW: 4G1 919 605
   Component: DU8 C7 SV  H42 0007
   Serial number: AUZ8Z9EL8004CR
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349NJB000D5
   Compact Disc Database:
   Component: Gracenote2  --- 1012
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
          [GPS aerial - open circuit]
   Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
   Component: TSG HL        H03 0507
   Coding: 01081C024021628002080002
   VCID: 47CAA0ED5FA08BE3D39-8012
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 289400737
   Coding: 0A3305C022
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 45D6AAE5652C99F3215-8010
   Component: TSG HR        H03 0507
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4G8 919 604 N    HW: 4G8 919 604 N
   Component: HeadUpDisplay H06 0304
   Coding: C60000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   Component: DPC-SG        H27 0081
   Coding: 6A160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C00FF41E68648BBDEB-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E04010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 270A006DFF606BE3339-8072
          U1113 00 [008] - -
          U1113 00 [008] - -
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621610147
   Coding: 03C2381A1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0028 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [ESP_ESP_01_Signal_Error]
   Coding: 0066E608031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 323CE139C4A21E4B947-8066
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 140916202924
   VCID: 2E04F549D09A3AABF0F-807A
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 142820657
   ROD: EV_RDCMA00100.rod
   VCID: 2B02FC5DE3884F83D71-807E
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 131218201781
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
End----------(Elapsed Time: 02:39, VBatt start/end: 14.5V/14.4V)-----------
orangetech
C?ID=233796
It seems to sort its self out and finally regen while standing all good now
curious as to what the access code is to do it while driving though?
Looks like a software update in available for this ECU:
orangetech
C?ID=233796
Yes! when customer collected he said it was going in to Audi for a recall due to DPF software on monday... wish he told me that before bringing it in!
