ABS pump change question
bonzo
Romania
C?ID=334156
hy all .i have a golf 5 with abs pump number 1K0907379CD / 1K0614517BD can i buy another pp with another code? because i cant find this code anywhere
The Auto-Scan would allow us to look up VIN specific parts information however I can share what we know based on your part number.
1K0 907 379 AD was flash updated to 1K0 907 379 CD on the dealer level at some point in time. 1K0 907 379 AD supers to 1K0 907 379 AN. For this reason the only directly compatible part numbers are:
1K0 907 379 AD
1K0 907 379 CD
1K0 907 379 AN
This should be helpful:
.. as well https://forums.ross-tech.com/index.php?threads/1997/
bonzo
Romania
C?ID=334156
so i will do a full scan and post here.today i have tried 1k0 907 379ah and i cannot code this pump on the car....i have the coding from the old pump
Sounds good. 1K0 907 379 AH is a different (newer model year) ABS module using the 19 Byte coding scheme. You may be able to code it only after modifying the original coding length by adding two zeros to the end of the string but that's experiential at best.
