MK60EC1 ABS FAQ
Jef
HQ
MK60EC1 ABS modules use a complex soft coding structure that varies from vehicle to vehicle. We strongly suggest everyone run an Auto-Scan BEFORE information is lost.
  • VCDS automatically saves Auto-Scans. If an Auto-Scan was performed prior to the soft coding being lost, you can retrieve that information. Details here.
  • If there is no past Auto-Scan that captured the soft coding information, you will need to post an Auto-Scan from the vehicle in the Car Repair Support section. Details here.
VIN Data:
The MK60EC1 ABS coding has data from the VIN in it, so coding will be specific to the VIN of a car. The following control modules have VIN data stored in them:
  • 01-Engine
  • 17-Instruments
  • 25-Immobilizer
The VIN is shown in the [Advanced ID-1A] function of VCDS while connected to Addresses 01, 17 and 25. If the stored VIN data in those modules do not match each other, it is not possible to code the MK60EC1 ABS module. VCDS can not resolve VIN mismatch issues.
If the stored VIN data in address 01, 17 and 25 match each other, but do not match the car's actual VIN data on the dash plaque, then make sure to include a photo of the PR-Code label located in the trunk.
ABS Part Numbers:
Including the part number of the original ABS control module is strongly recommended as well. If the original module did not communicate via diagnostics, the part numbers located on the original parts should be included.
We get asked about installing used ABS modules. For the 2009 and 2010 year models, DON'T! Early MK60EC1 modules fail a lot and we have seen many cases of the used module failing soon after being installed, or just outright worse than what it was replacing.
If you go with a used module... make sure the part numbers match 100%... and accept your fate when the used module is no good.
Coding Length:
In some cases, the new replacement ABS module will use coding that is a different length from the original ABS coding. The original coding might be 36 digits long and the replacement ABS module may need coding that is 38 digits long. If you encounter this, simply pad the end of the coding with zeros as needed. For example:
Original ABS coding (36 digits long):
113B400D49220000880F02EA921A00413000
Replacement ABS coding (38 digits long):
113B400D49220000880F02EA921A0041300000
Common DTCs with the MK60EC1 ABS module:
Jef
HQ
This post is blank for editing purposes. If you are reading this, you've gone too far. The real content ends with Jasper and his made with pride in America paddle.
