Hello this is my first post and will try to I will try to follow the sticky rules "JPPSG". Sorry it will be a very long post as I try to give all the information I have.
1.
2. Car is stock as far as I know, I have owned it for two years.
3. See scan below.
4. My engine quit while driving a couple months ago and will not restart. I originally pulled the code (and deleted it) with a generic scan tool and I dont remember the number just that it translated to low fuel pressure. I checked the fuel tank and it looked like water in the tank so I drained, cleaned totally dry and blew out the fuel lines with air. Then replaced the in-take pump and filter. Primed the pump several times using wires straight from the battery to the pump. This did not fix it so I replaced the HPFP (there were no metal flakes in the tank, filter or inside the HPFP solenoid hole) and bought the VCDS to properly prime the car. This did not fix it. At that point I took the car to the VW stealership for repair. After a month and several hundred dollars they told me the new HPFP I put in was bad. So I replaced the pump again and still nothing. If there was a fuel problem, I do not think there is one anymore.
I think the problem is in the Camshaft sensor circuit. I am new to the VCDS so I tried to start the car with a real-time log going. I selected the cam and crank RPM and cranked the car with the laptop outside. When I looked at the screen it showed 125 cam rpm and 0 crankshaft. I though it was showing the highest value during the start so I changed the crankshaft sensor and re-did the test. Later I realized how the logging works and assume the crankshaft was correct and the camshaft was wrong.
If I read the cam RPM it reads 125 rpm with the ignition on engine not running, when I try to start it it stays about the same up or down a few and stays about 125 after I stop cranking. The crankshaft rpm starts off at 0 and will go to about 260 until I stop cranking it and back down to 0. It seems obvious the cam should be zero, go up to around 1/2 the crankshaft and back to zero. I dont know how to insert the excel real-time log from the VCDS to show this. FYI it shows the the fuel pressure at around 300000 hPa standard is 280000 hPa. Could have saved about $1200 on pumps if I had known this VCDS feature from the start.
5. In-tank fuel pump is some Chinese job from ebay. Most likely causing the Address 17 fault in the scan. It is certainly pumping enough fuel to start, about 1 gallon a minute into a bucket. Filter is VW/Audi OEM. Both pumps were OEM/Bosch remanufactured sourced from RockAuto. Crankshaft sensor is another Chinese job from RockAuto.
6. I find it strange there is no fault for the cam circuit. I want to know what voltage and/or continuity should I get when testing the wire harness going to the cam sensor. And if it is possible to test the sensor, what numbers should I get from it.
1.
3. See scan below.
Thursday,22,October,2020,17:22:50:50070
VIN: 1VWCN7A3XCC069746 License Plate: MINE
Mileage: 258770km-160792mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A3XCC069746 Mileage: 258770km-160792miles
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H21 9982
Revision: 71H21--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 07207 444 00000
ROD: EV_ECM20TDI01103L997009H.rod
VCID: 3B2333BC93E999B3471-806E
Readiness: 0 0 0 1 1
Part No SW: 02E 300 057 P HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9435
Revision: 05551213 Serial number: 00001112150136
Shop #: WSC 09003 957 00200
VCID: 2615F2C874EB345B08F-8072
18149 - Clutch Pressure Adaptation
P1741 - 002 - Limit Reached
Fault Status: 01100010
Fault Frequency: 40
Reset counter: 2
Mileage: 258771 km
Date: 2015.02.23
Time: 13:31:29
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: C54BC0F549280003A31203E8921F0042A71000
VCID: 7DA7FDA4CDFD5783395-8028
Reset counter: 167
Mileage: 258771 km
Date: 2015.02.23
Time: 13:45:48
Count: 7
Count: 15
Count: 20480
Count: 128
Count: 27392
Count: 65280
Count: 65535
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0168590523
Coding: 130C0C
VCID: 34311880BEB756CB86B-8060
Part No SW: 561 907 044 H HW: 561 907 044 H
Component: Climatronic 043 0202
Revision: 00001001
Coding: 0010001012
VCID: 1C61D0203627FE8BAEB-8048
9474161 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Reset counter: 207
Mileage: 258771 km
Date: 2020.10.02
Time: 13:31:40
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0164
Revision: BL121001
Coding: 6F200E1B982B08D408880201360085480071008645A005F0648060009C70
VCID: 74B1D880FEB716CB46B-8020
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 250212 05 54 0403
Coding: 22300A
Fault Status: 00101011
Reset counter: 207
Mileage: 258771 km
Date: 2015.03.04
Time: 14:11:25
Term 15 Off
Voltage: 12.70 V
Fault Status: 00101001
Reset counter: 207
Mileage: 258771 km
Date: 2015.03.04
Time: 14:11:36
Term 15 Off
Voltage: 12.65 V
Reset counter: 207
Mileage: 258771 km
Date: 2015.03.04
Time: 14:07:45
Term 15 Off
Voltage: 12.75 V
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM01SH1N
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FBBD7EC97113513BB9-803A
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000BRTM0G
Coding: 303047
Serial number: 3572MSME5F094566ZZZ0
Serial number: 3582MSME47483369ZZZ
Serial number: 3516KSME5D512916ZZZV
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME57043516ZZZL
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME24432615ZZZL
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME30432615ZZZJ
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20111215300823
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DA7FDA4CD7D5783395-8028
Component: E221__MFL-YVJ H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 C HW: 561 920 970 C
Component: KOMBI H07 0507
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 1A6DD6383C1380BBBC7-804E
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Resistance Too High
Reset counter: 167
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 09031201291398
Coding: 461000
VCID: 3D273DA48D7D9783795-8068
Component: IMMO H07 0507
Coding: 000007
VCID: 6A8DC6F8ACF3D03BEC7-803E
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000288212003
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW01.rod
VCID: 2E050AE8509B7C1BF0F-807A
U1400 00 [008] - -
[Under voltage (temporary)]
Reset counter: 207
Mileage: 258771 km
Date: 2020.10.02
Time: 13:45:46
ELV State: 0C
Information Clamps: 77 64
CoCo State: F0 01
WFS State: 67 1A
Vehicle speed: 327.25 km/h
Voltage: 49
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661600495
VCID: 290FF9F469F51B2325D-807C
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000024591913
Coding: 00581B0000000000000021010100202020202120202020
VCID: 6099A4D05A4F9A6B323-8034
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C8 035 684 E HW: 3C8 035 684 E
Component: RNS-MID H61 3690
Revision: AB001001 Serial number: VWZ6Z7M5065041
Coding: 04090002010000A6000B
VCID: 2D070DE45D1D0703C95-8078
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0004089438
Coding: 0405FD
ROD: EV_TSGFPQ25BRFVW46X.rod
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Coding: 800000
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 290 3301
Revision: 00H22000
VCID: 35372584B94D4FC3B15-8060
Part No SW: 5C6 035 456 HW: 5C6 035 456
Component: KonzernAmp10K H07 0468
Revision: -------- Serial number: EAA083A0002862
ROD: EV_AudioVerst10KanalSTT3_VW41.rod
VCID: 6597B5C445EDFF43C15-8030
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 01030108
VCID: 6FBBD7EC97913513BB9-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011133500599
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0004
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0004010018
Coding: 0405FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D67DD242D3DF783595-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H12 2902
Revision: 1B001001 Serial number: 00007661728987
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270BFFCC7F612D53339-8072
End----------(Elapsed Time: 01:19, VBatt start/end: 12.2V/12.2V)-----------
