i got this message on the dash board ... switch off engine oil pressure too low....i did change oil pressure switch ..i did change the oil pump ..and i did change the engine oil separator crankase vent valve....and i still have the same light on the dash board....please help...
Sunday,04,October,2020,13:11:43:20576
VCDS Version: 20.4.2.0 (x64) HEX-NET CB: 0.4513.4
VIN: WAUFFAFL9BN037793 License Plate:
Mileage: 104400km-64871mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
72
VIN: WAUFFAFL9BN037793 Mileage: 104400km-64871miles
Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 0002
Revision: E1H19---
Coding: 0104010A290F0160
Shop #: WSC 01122 444 11740
ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: 74A41B74DFEB4F2607-8020
5582 - Oil Pressure Switch for reduced Oil Pressure
P164D 00 [032] - Malfunction
Mileage: 104405 km
Date: 2020.10.03
Time: 16:17:10
Engine speed: 711.50 /min
Normed load value: 12.5 %
Coolant temperature: 59 °C
Intake air temperature: 31 °C
Voltage terminal 30: 13.122 V
4010 - Idle Control System
P0506 00 [100] - RPM Lower than Expected
Mileage: 104405 km
Date: 2020.10.03
Time: 16:17:57
Engine speed: 754.50 /min
Normed load value: 16.9 %
Coolant temperature: 64 °C
Intake air temperature: 30 °C
Voltage terminal 30: 13.735 V
Readiness: 1110 0101
Part No SW: 8K0 927 158 K HW: 0BK 927 156 N
Component: 0BK 20TFSIUSA H08 0010
Revision: --H08---
Coding: 001112
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMAL551211 001013
ROD: EV_TCMAL551211_001.rod
VCID: 3E30F95CA127D57621-806A
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 1D0D18
Shop #: WSC 02391 823 56573
VCID: 02484DAC9D5F719605-8056
02214 - Tire Pressure Warning
Reset counter: 31
Mileage: 104386 km
Date: 2020.09.30
Time: 12:33:46
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x1237
Hex Value: 0x1FB2
Hex Value: 0x00FF
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H05 0434
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 76A0217CC1975D3639-8022
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H50 0071
Serial number: 0810000121581007
Component: J764 ELV MLB H37 0042
Serial number: 2310000074932013
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01061220100116
Coding: 64102000
VCID: 004C47A49353638613-8054
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000876130
Coding: 26001091063CAF010000080300003D0D0F1C520802010161000000
VCID: 3C34F354BF3BC7660F-8068
Component: WWS 081210 H06 0070
Serial number: SWF10120085543
Coding: 00FD11
Component: RLS H04 0003
Serial number: 11180810
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000002511100707
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0080
Revision: 11001001 Serial number: 36891033409342
Coding: 200103
VCID: 4AD8A58CE5EF69D68D-801E
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H41 0610
Serial number: 003GLD0GY0J-
Coding: 303837354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
VCID: 45C296B0C4F186AE60-8010
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1000002LSA
Serial number: 6334MSME59644733E
Serial number: 6344MSME5963641DL
Serial number: 6352QSME587B1110B
Serial number: 6362QSME33765816H
Serial number: 63732SME3177390C+
Serial number: 63832SME4E7C0B06B
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372JL300037
Coding: 000016
VCID: 3D32FE50A421CE6E38-8068
Component: E221 - MFL H02 0010
Part No SW: 8K0 920 981 C HW: 8K0 920 981 C
Component: KOMBIINSTR. H23 0258
Revision: 00100000 Serial number: EJB32M0DA
Coding: 8B1609000300D705020000
VCID: 3326D8689265081EDE-8066
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E10B15817E
Coding: 00C303
VCID: 034648A88245789E0E-8056
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1000B172301110
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C03204000410001
VCID: 53E6B8E832A5281EFE-8006
Revision: 00002001 Serial number: 0139666721
Coding: 0106023A00FA440480B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0050
Serial number: 00000000000000336481
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS039 H07 0041
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
VCID: 52E8BDEC0DBF2116F5-8006
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000674924
VCID: 3424DB74976B0F26C7-8060
Part No: 8K5 907 357
Coding: 0000004
VCID: 77BE2C78069D243E22-8022
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471L$0A7547115
Coding: 020007020100000001
VCID: 5DF25ED04461EE6E58-8008
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Fault Status: 01101011
Reset counter: 247
Mileage: 104386 km
Date: 2020.09.30
Time: 12:33:46
Voltage: 14.20 V
Part No SW: 8T1 035 664 C HW: 8T1 035 664 B
Component: H-BN-NA H51 0116
Revision: -------- Serial number: 490LG0A7595959
Coding: 010200000006A1EF01000B0E000000030000
VCID: 383CEF448B03EB46EB-806C
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466L00A0271938
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000694976
Component: CD-Database 1886
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010C03204000210001
VCID: 56E041FC21573D3619-8002
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H04--- Serial number: 525PA8-J0Y90P4
Coding: 1000006
Shop #: WSC 02391 785 00200
VCID: 383CEF444B03EB46EB-806C
Component: TSG HR H06 1401
End----(Elapsed Time: 01:46, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
