Audi A4 2011 2.0 Switch off engine oil pressure too low!
crisseibert
boston
C?ID=224999
i got this message on the dash board ... switch off engine oil pressure too low....i did change oil pressure switch ..i did change the oil pump ..and i did change the engine oil separator crankase vent valve....and i still have the same light on the dash board....please help...
Sunday,04,October,2020,13:11:43:20576
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUFFAFL9BN037793   License Plate:
Mileage: 104400km-64871mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
          72
VIN: WAUFFAFL9BN037793   Mileage: 104400km-64871miles
Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H19 0002
   Revision: E1H19---
   Coding: 0104010A290F0160
   Shop #: WSC 01122 444 11740
   ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
   ROD: EV_ECM20TFS0118K2907115AG.rod
   VCID: 74A41B74DFEB4F2607-8020
5582 - Oil Pressure Switch for reduced Oil Pressure
          P164D 00 [032] - Malfunction
                    Mileage: 104405 km
                    Date: 2020.10.03
                    Time: 16:17:10
                    Engine speed: 711.50 /min
                    Normed load value: 12.5 %
                    Coolant temperature: 59 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 13.122 V
4010 - Idle Control System
          P0506 00 [100] - RPM Lower than Expected
                    Mileage: 104405 km
                    Date: 2020.10.03
                    Time: 16:17:57
                    Engine speed: 754.50 /min
                    Normed load value: 16.9 %
                    Coolant temperature: 64 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 13.735 V
Readiness: 1110 0101
   Part No SW: 8K0 927 158 K    HW: 0BK 927 156 N
   Component: 0BK 20TFSIUSA H08 0010
   Revision: --H08---
   Coding: 001112
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL551211 001013
   ROD: EV_TCMAL551211_001.rod
   VCID: 3E30F95CA127D57621-806A
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 1D0D18
   Shop #: WSC 02391 823 56573
   VCID: 02484DAC9D5F719605-8056
02214 - Tire Pressure Warning
                    Reset counter: 31
                    Mileage: 104386 km
                    Date: 2020.09.30
                    Time: 12:33:46
                    Hex Value: 0x0000
                    Hex Value: 0x4202
                    Hex Value: 0x1237
                    Hex Value: 0x1FB2
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
   Component: BCM2 2.0      H05 0434
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 76A0217CC1975D3639-8022
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Component: FBSAUDIB8 IDG  H50 0071
   Serial number: 0810000121581007
   Serial number: 2310000074932013
   Revision: C1000000    Serial number: 01061220100116
   Coding: 64102000
   VCID: 004C47A49353638613-8054
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000876130
   Coding: 26001091063CAF010000080300003D0D0F1C520802010161000000
   VCID: 3C34F354BF3BC7660F-8068
   Component: WWS 081210  H06 0070
   Serial number: SWF10120085543
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11180810
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002511100707
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0080
   Revision: 11001001    Serial number: 36891033409342
   Coding: 200103
   VCID: 4AD8A58CE5EF69D68D-801E
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GLD0GY0J-
   Coding: 303837354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   VCID: 45C296B0C4F186AE60-8010
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1000002LSA
   Serial number: 6334MSME59644733E
   Serial number: 6344MSME5963641DL
   Serial number: 6352QSME587B1110B
   Serial number: 6362QSME33765816H
   Serial number: 63732SME3177390C+
   Serial number: 63832SME4E7C0B06B
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372JL300037
   Coding: 000016
   VCID: 3D32FE50A421CE6E38-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 981 C    HW: 8K0 920 981 C
   Component: KOMBIINSTR.   H23 0258
   Revision: 00100000    Serial number: EJB32M0DA
   Coding: 8B1609000300D705020000
   VCID: 3326D8689265081EDE-8066
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E10B15817E
   Coding: 00C303
   VCID: 034648A88245789E0E-8056
   Component: J367-BDM  H07 0170
   Serial number: 1000B172301110
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1401
   Coding: 011C03204000410001
   VCID: 53E6B8E832A5281EFE-8006
   Revision: 00002001    Serial number: 0139666721
   Coding: 0106023A00FA440480B0013200000000
   Component: GTO BF  H01 0050
   Serial number: 00000000000000336481
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS039  H07 0041
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1401
   VCID: 52E8BDEC0DBF2116F5-8006
   Revision: 00000003    Serial number: 10000000674924
   VCID: 3424DB74976B0F26C7-8060
   Part No: 8K5 907 357
   Coding: 0000004
   VCID: 77BE2C78069D243E22-8022
   Part No SW: 4G0 035 082     HW: 4G0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 471L$0A7547115
   Coding: 020007020100000001
   VCID: 5DF25ED04461EE6E58-8008
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Reset counter: 247
                    Mileage: 104386 km
                    Date: 2020.09.30
                    Time: 12:33:46
                    Voltage: 14.20 V
   Part No SW: 8T1 035 664 C    HW: 8T1 035 664 B
   Component: H-BN-NA       H51 0116
   Revision: --------    Serial number: 490LG0A7595959
   Coding: 010200000006A1EF01000B0E000000030000
   VCID: 383CEF448B03EB46EB-806C
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466L00A0271938
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000694976
   Component: CD-Database  1886
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1401
   Coding: 010C03204000210001
   VCID: 56E041FC21573D3619-8002
   Revision: --H04---    Serial number: 525PA8-J0Y90P4
   Coding: 1000006
   Shop #: WSC 02391 785 00200
   VCID: 383CEF444B03EB46EB-806C
   Component: TSG HR        H06 1401
End----(Elapsed Time: 01:46, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
crisseibert
boston
C?ID=224999
Have you connected a mechanical oil pressure gauge to find out whether you've really got a problem with the oil pressure or not?
Also, FWIW, this seems to be a pretty common fault:
https://www.ross-tech.com/Search-Results.html?q=P164D
. Yes I did !! It has 39psi at idle..
That strikes me as pretty high. What was the oil temperature like? Stone-cold? If so, what happens when it's fully up to operating temperature?
crisseibert
boston
C?ID=224999
the only thing i did not replace it was this ...Oil Pressure Regulation Valve N428 . should i replace that too? i know this valve works with the oil pump....i will try to check the tempetures . thanks
MasterTommy
Amsterdam
C?ID=295586
Seems like the part that the fault code refers to...
crisseibert
boston
C?ID=224999
i just replace the valve N428 too and nothing change? same dash warning light..the car run fine about 5 minutes after 5 minutes the oil pressure drops to 10 psi
crisseibert
boston
C?ID=224999
Thursday,08,October,2020,19:48:34:20576
Address 01: Engine Labels: 06H-907-115-CAB.clb
Control Module Part Number: 8K2 907 115 AG HW: 8K2 907 115 D
Component and/or Version: 2.0l R4/4V TF H19 0002
Software Coding: 0104010A290F0160
Work Shop Code: WSC 01122 444 11740
ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002 (AU48)
P164D 00 [036] - Malfunction
Mileage: 104405 km
Date: 2020.10.08
Time: 18:45:22
Engine speed: 702.00 /min
Normed load value: 14.5 %
Coolant temperature: 63 °C
Intake air temperature: 17 °C
Voltage terminal 30: 13.593 V
crisseibert
boston
C?ID=224999
That strikes me as pretty high. What was the oil temperature like? Stone-cold? If so, what happens when it's fully up to operating temperati connect the oil
i connect the oil gauge and star up the engine the engine run fine about 5 minutes with 40 psi . after 5 minutes the warning oil light came back and the oil pressure drops to 10 psi.. any help?
crisseibert
boston
C?ID=224999
          72
   Revision: E1H19---
                    Mileage: 104405 km
                    Date: 2020.10.03
                    Time: 16:17:10
                    Mileage: 104405 km
                    Date: 2020.10.03
                    Time: 16:17:57
   Revision: --H08---
   Coding: 001112
   Coding: 1D0D18
                    Reset counter: 31
                    Mileage: 104386 km
                    Date: 2020.09.30
                    Time: 12:33:46
                    Hex Value: 0x0000
                    Hex Value: 0x4202
                    Hex Value: 0x1237
                    Hex Value: 0x1FB2
                    Hex Value: 0x00FF
   Coding: 090100
   Coding: 64102000
   Coding: 00FD11
   Coding: 025028
   Coding: 200103
   Coding: 000016
   Coding: 00C303
   Coding: 0000004
                    Reset counter: 247
                    Mileage: 104386 km
                    Date: 2020.09.30
                    Time: 12:33:46
                    Voltage: 14.20 V
   Coding: 1000006
obs.... the oil pressure stay 40 psi for 5 minutes . after 5 minutes the oil pressure drops to 10 psi
crisseibert
boston
C?ID=224999
Ok I start up the engine the engine run fine for 5 minutes And I got 40 psi on the mechanical gauge... but after 5 minutes the oil pressure drop to 10 psi and I got this warning light. .(Switch off engine oil pressure too low!)
sorry ... i made 2 post by mistake..
          72
   Revision: E1H19---
                    Mileage: 104405 km
                    Date: 2020.10.03
                    Time: 16:17:10
                    Mileage: 104405 km
                    Date: 2020.10.03
                    Time: 16:17:57
   Revision: --H08---
   Coding: 001112
   Coding: 1D0D18
                    Reset counter: 31
                    Mileage: 104386 km
                    Date: 2020.09.30
                    Time: 12:33:46
                    Hex Value: 0x0000
                    Hex Value: 0x4202
                    Hex Value: 0x1237
                    Hex Value: 0x1FB2
                    Hex Value: 0x00FF
   Coding: 090100
   Coding: 64102000
   Coding: 00FD11
   Coding: 025028
   Coding: 200103
   Coding: 000016
   Coding: 00C303
   Coding: 0000004
                    Reset counter: 247
                    Mileage: 104386 km
                    Date: 2020.09.30
                    Time: 12:33:46
                    Voltage: 14.20 V
   Coding: 1000006
So this is a sudden drop, not linear?
Threads merged. Please do not open new threads about the same issue in the same car when you've already got a thread about it.
Yes real fast !!!! Sudden from 40psi to 10 psi...!!!
That sounds like a valve opening, not a general mechanical problem like bearing tolerances. Have you tried disconnecting N428 to see what happens then?
crisseibert
boston
C?ID=224999
Yes I did disconect the valve N428 .. i start up the engine with the valve off but still after like 4 or 5 minutes the pressure drop again...
crisseibert
boston
C?ID=224999
what else can i do? thanks
crisseibert
boston
C?ID=224999
Hi look i just re checked the oil pressure and now the pressure drop slow not fast any more !! It takes about 4 minutes to from 30 to 10 psi!
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
At this point dropping to 10 psi is no good. The fact it does it fast is bad also.
Changing oil pump and valve and it still does it.
I am sure you changed the oil thru all this?
The idle high code could cause diluted oil with gas thinning the oil.
I would waist 5 qt. of oil by draining and adding a lot thicker oil as a test. Don't drive it!
It's either oil as it heats up thins out bad or oil clearances somewhere in motor are too large.
I would do this and see what pressures do?
Then drain oil hot as hell to get the thicker oil out once you see result.
Consider it an oil flush to clean everything inside out.
Good Luck
crisseibert
boston
C?ID=224999
Good Luck
Thanks i really appreciate your time..I will do that!!!!
