Mileage: 253750km-157672miles
>>> 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status:
>>> Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS
>>> Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status:
>>> Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control
>>> Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010
>>> 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 --
>>> Status: OK 0000 0F-Digital Radio -- Status: Malfunction 0010
>>> 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status:
>>> Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering
>>> wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010
>>> 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK
>>> 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: OK
>>> 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status:
>>> OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door
>>> Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000
>>> 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status:
>>> Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking
>>> Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK
>>> 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status:
>>> Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire
>>> Pressure -- Status: Malfunction 0010 67-Voice Control -- Status: OK
>>> 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right --
>>> Status: OK 0000 76-Park Assist -- Status: Malfunction 0010
>>> 77-Telephone -- Status: OK 0000
>>> Address 01: Engine Labels: Redir Fail!
>>> Part No SW: 4E0 910 552 A HW: 4E0 907 552 Component: 5.2L V10/4V FSI ª0040 Revision: 5AH15--- Serial number: AUX3Z0G1716063
>>> Coding: 01060009190F0160
>>> Shop #: WSC 08167 444 92038
>>> VCID: 2019E551C6C7DBFB723-8074
>>> 3 Faults Found:
>>> 008198 - Intake Manifold Flap; Bank 1 P2006 - 008 - Stuck Closed
>>> Freeze Frame:
>>> Fault Status: 01101000
>>> Fault Priority: 0
>>> Fault Frequency: 1
>>> Reset counter: 255
>>> Mileage: 253737 km
>>> Time Indication: 0
>>> Date: 2020.09.23
>>> Time: 13:49:43
>>> Freeze Frame:
>>> RPM: 728 /min
>>> Load: 19.2 %
>>> Speed: 0.0 km/h
>>> Temperature: 42.0°C
>>> Temperature: 24.0°C
>>> Absolute Pres.: 990.0 mbar
>>> Voltage: 14.351 V
>>> 008198 - Intake Manifold Flap; Bank 1 P2006 - 001 - Stuck Closed - MIL ON
>>> Freeze Frame:
>>> Fault Status: 11100001
>>> Fault Priority: 0
>>> Fault Frequency: 1
>>> Reset counter: 255
>>> Mileage: 253737 km
>>> Time Indication: 0
>>> Date: 2020.09.23
>>> Time: 13:54:37
>>> Freeze Frame:
>>> RPM: 1818 /min
>>> Load: 54.5 %
>>> Speed: 37.0 km/h
>>> Temperature: 60.0°C
>>> Temperature: 27.0°C
>>> Voltage: 12.192 V
>>> 006435 - Please Check DTC Memory of ECU Number 2 P1923 - 008 - Freeze Frame:
>>> Fault Priority: 0
>>> Fault Frequency: 1
>>> Reset counter: 255
>>> Mileage: 253741 km
>>> Time Indication: 0
>>> Freeze Frame:
>>> RPM: 124 /min
>>> Load: 67.0 %
>>> Speed: 0.0 km/h
>>> Temperature: 20.0°C
>>> Temperature: 26.0°C
>>> Absolute Pres.: 1000.0 mbar
>>> Voltage: 8.128 V
>>> Readiness: 0000 0001
>>> Address 02: Auto Trans Labels: 09E-927-156.lbl
>>> Part No SW: 4E1 910 156 K HW: 09E 927 156 B
>>> Component: AG6 09E 5,2 FSI USA 0030 Revision: --H01--- Serial number: 0101256
>>> Coding: 0000002
>>> Shop #: WSC 02313 785 00200
>>> VCID: 2B03027DBF0108A3D71-807E
>>> 1 Fault Found:
>>> 006231 - Load Signal P1857 - 001 - Error Message from ECU - Intermittent
>>> Freeze Frame:
>>> Fault Status: 00100001
>>> Fault Priority: 0
>>> Fault Frequency: 2
>>> Reset counter: 255
>>> Mileage: 253695 km
>>> Time Indication: 0
>>> Date: 2020.09.19
>>> Time: 18:23:12
>>> Freeze Frame:
>>> RPM: 0 /min
>>> RPM: 0 /min
>>> RPM: 0 /min
>>> (no units): 30.0
>>> (no units): 157.0
>>> Temperature: 22.0°C
>>> T.B. Angle: 0.0°
>>> Address 03: ABS Brakes Labels: 4E0-910-517.lbl
>>> Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
>>> Component: ESP 5.7 allrad H46 0500 Coding: 0001627
>>> Shop #: WSC 02313 000 00000
>>> VCID: 2411E941D2DFC7DB16B-8070
>>> 2 Faults Found:
>>> 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent
>>> 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - - Intermittent
>>> Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
>>> Part No SW: 4E0 910 131 HW: 4E0 909 131 L
>>> Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0G1716063
>>> Coding: 0410624
>>> Shop #: WSC 02311 785 00200
>>> VCID: 58E98DB1DE17533B4A3-800C
>>> Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX
>>> 1 Fault Found:
>>> 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent
>>> Freeze Frame:
>>> Fault Status: 00100010
>>> Fault Priority: 2
>>> Fault Frequency: 0
>>> Reset counter: 99
>>> Mileage: 253728 km
>>> Time Indication: 0
>>> Date: 2020.09.23
>>> Time: 23:01:22
>>> Address 06: Seat Mem. Pass Labels: None
>>> Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
>>> Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03
>>> Coding: 3940448
>>> Shop #: WSC 08316 444 53986
>>> No fault code found.
>>> Address 07: Control Head Labels: 4E0-910-7xx-07.clb
>>> Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
>>> Component: Interfacebox H43 4610 Revision: 00000000 Serial number: 348AT077509454
>>> Coding: 0000003
>>> VCID: 33331A1D673150639F1-8066
>>> Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0050
>>> Subsystem 2 - Serial number: 00000000049526
>>> Subsystem 3 - Serial number: 0125.10.070000000100010189ÿ
>>> Subsystem 4 - Serial number: 010189ÿ No fault code found.
>>> Address 08: Auto HVAC Labels: None
>>> Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
>>> Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000166059
>>> Coding: 0106833
>>> Shop #: WSC 08316 444 999999
>>> VCID: 1C61D1A1EAAFFF1BAEB-8048
>>> 2 Faults Found:
>>> 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit
>>> Freeze Frame:
>>> Fault Status: 01101100
>>> Fault Priority: 3
>>> Fault Frequency: 31
>>> Reset counter: 60
>>> Mileage: 253359 km
>>> Time Indication: 0
>>> Date: 2020.09.11
>>> Time: 12:48:04
>>> Freeze Frame:
>>> Voltage: 11.30 V
>>> 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit
>>> Freeze Frame:
>>> Fault Priority: 3
>>> Fault Frequency: 3
>>> Reset counter: 58
>>> Mileage: 253359 km
>>> Time Indication: 0
>>> Date: 2020.09.11
>>> Time: 12:48:04
>>> Freeze Frame:
>>> Voltage: 11.30 V
>>> Address 09: Cent. Elect. Labels: 4E0-910-279.clb
>>> Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
>>> Component: ILM Fahrer H15 0230 Coding: 0133123
>>> VCID: 363523097443454BB8F-8062
>>> Subsystem 1 - Part No: 4E1 910 113 C
>>> Component: Wischer WWS D3 H60 0420 Coding: 00000035
>>> Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
>>> Component: REGENLICHTSENSORH13 0090 Coding: 00139548
>>> Shop #: WSC 02313 1 Fault Found:
>>> 01800 - Light Switch (E1) 008 - Implausible Signal - Intermittent
>>> Freeze Frame:
>>> Fault Status: 00101000
>>> Fault Priority: 2
>>> Fault Frequency: 2
>>> Reset counter: 83
>>> Mileage: 252802 km
>>> Time Indication: 0
>>> Date: 2020.08.18
>>> Time: 03:16:50
>>> Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
>>> Part No SW: 4E0 035 785 HW: 4E0 035 785 Component: SG ext.Player H09 0170 Revision: 00000000 VCID: 6597B4459565FED3C15-8030
>>> Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
>>> Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
>>> Component: SDAR SIRIUS H06 0080 Revision: 00000000 Serial number: AUZ4Z7G0046434
>>> Shop #: WSC 00000 000 00000
>>> VCID: 2C010161BA0F0F9BDEB-8078
>>> Address 11: Engine II Labels: Redir Fail!
>>> 2 Faults Found:
>>> 008199 - Intake Manifold Flap; Bank 2 P2007 - 008 - Stuck Closed
>>> Freeze Frame:
>>> Fault Priority: 0
>>> Fault Frequency: 1
>>> Reset counter: 255
>>> Mileage: 253737 km
>>> Time Indication: 0
>>> Date: 2020.09.23
>>> Time: 13:50:20
>>> Freeze Frame:
>>> RPM: 714 /min
>>> Load: 19.2 %
>>> Speed: 0.0 km/h
>>> Temperature: 45.0°C
>>> Temperature: 24.0°C
>>> Voltage: 14.351 V
>>> 008199 - Intake Manifold Flap; Bank 2 P2007 - 001 - Stuck Closed - MIL ON
>>> Freeze Frame:
>>> Fault Priority: 0
>>> Fault Frequency: 1
>>> Reset counter: 255
>>> Mileage: 253737 km
>>> Time Indication: 0
>>> Date: 2020.09.23
>>> Time: 13:54:37
>>> Freeze Frame:
>>> RPM: 1817 /min
>>> Load: 56.1 %
>>> Speed: 37.0 km/h
>>> Temperature: 60.0°C
>>> Temperature: 27.0°C
>>> Voltage: 11.811 V
>>> Address 15: Airbags Labels: 4E0-910-655-94.lbl
>>> Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
>>> Component: Airbag 9.41 H14 4230 Revision: 91H14423 Serial number: 0037Q0G01FVD Coding: 0532707
>>> VCID: 2615F349A4E335CB08F-8072
>>> Subsystem 1 - Part No: 4E0 910 339 Component: BF-Gewichtsens. H01 0030
>>> Subsystem 2 - Serial number: 3J1ET Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ† 63
>>> Subsystem 4 - Serial number: 000000ÿ† 63328RB401F20010/ÿ† 63
>>> Subsystem 5 - Serial number: 20010/ÿ† 63428RB401F204F3Jÿ† 63
>>> Subsystem 6 - Serial number: 204F3Jÿ† 63528RB401F204B9Mÿ† 63
>>> Subsystem 7 - Serial number: 204B9Mÿ† 63628RB401F20445Cÿ† 63
>>> Subsystem 8 - Serial number: 20445Cÿ† 63729RB401F92407Lÿ† 63
>>> Subsystem 9 - Serial number: 92407Lÿ† 63829RB401F92252Kÿ
>>> Subsystem 10 - Serial number: 92252Kÿ
>>> 1 Fault Found:
>>> 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent
>>> Freeze Frame:
>>> Fault Priority: 2
>>> Fault Frequency: 91
>>> Reset counter: 99
>>> Mileage: 252802 km
>>> Time Indication: 0
>>> Date: 2020.08.18
>>> Time: 15:44:58
>>> Address 16: Steering wheel Labels: 4E0-910-549.lbl
>>> Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H14 0040 Coding: 0012141
>>> VCID: 6597B4459965FED3C15-8030
>>> Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090
>>> Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
>>> Part No SW: 4E0 910 951 F HW: 4E0 920 951 F
>>> Component: KOMBIINSTR. VDO H82 0530 Revision: D04 Serial number: AUDID3G1001181
>>> Coding: 0048003
>>> Shop #: WSC 03601 003 104857
>>> VCID: 2809FD71AEF723BB3A3-807C
>>> 1 Fault Found:
>>> 16346 - Control Module - ROM Error 014 - Defective
>>> Freeze Frame:
>>> Fault Status: 00000011
>>> Fault Priority: 1
>>> Fault Frequency: 1
>>> Reset counter: 255
>>> Mileage: 85376 km
>>> Time Indication: 0
>>> Date: 2012.01.07
>>> Time: 10:14:21
>>> Address 19: CAN Gateway Labels:. 4L0-910-468.clb
>>> Part No SW: 4L0 910 468 HW: 4L0 907 468 Component: J533__Gateway H06 0040 Revision: 00H06000 Serial number: 0900B0712580FC
>>> Coding: F5F5DFFF707A0E
>>> VCID: 6C81C1617A8FCF9B9EB-8038
>>> Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
>>> Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
>>> Component: MP3-Changer H44 0390 Revision: 00044000 Serial number: AUZ5ZBG3157676
>>> VCID: 1A6DD7B9E09B812BBC7-804E
>>> Address 28: HVAC, Rear Labels: None
>>> Part No SW: 4E0 910 158 HW: 4E0 919 158 D
>>> Component: KLIMA-STG. FOND 017 0230 Revision: 00000019 Serial number: 00000000050288
>>> Coding: 0000000
>>> VCID: 619FA0558D4D92F33DD-8034
>>> Address 34: Level Control Labels: 4E0-910-553.clb
>>> Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
>>> Component: LUFTFDR.-CDC H06 6310 Coding: 0011110
>>> VCID: 2A0D0779B0FB11AB2C7-807E
>>> Address 36: Seat Mem. Drvr Labels: None
>>> Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03
>>> Coding: 4071530
>>> Address 37: Navigation Labels: 4E0-910-88x-37.lbl
>>> Part No SW: 4E0 910 888 D HW: 4E0 919 887 L
>>> Component: MNS US H48 0970 Revision: 00000000 Serial number: 381BX077517398
>>> VCID: 2F3B166D8B197483FB9-807A
>>> Address 38: Roof Electronics Labels: 4E0-910-135.lbl
>>> Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
>>> Component: Dachknoten D3 H05 0090 Coding: 0004078
>>> Shop #: WSC 08316 444 05187
>>> VCID: 1D67DCA5F1B5F613595-8048
>>> 2 Faults Found:
>>> 02104 - Light Detection Sensor (G399) 010 - Open or Short to Plus
>>> Freeze Frame:
>>> Fault Status: 01101010
>>> Fault Priority: 0
>>> Fault Frequency: 1
>>> Reset counter: 58
>>> Mileage: 253732 km
>>> Time Indication: 0
>>> Date: 2020.09.22
>>> Time: 14:27:00
>>> 02003 - Driver Identification Control Module (J589) 004 - No Signal/Communication
>>> Freeze Frame:
>>> Fault Status: 01100100
>>> Fault Priority: 0
>>> Fault Frequency: 15
>>> Reset counter: 59
>>> Mileage: 253732 km
>>> Time Indication: 0
>>> Date: 2020.09.22
>>> Time: 14:27:00
>>> Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
>>> Part No SW: 4E1 910 802 B HW: 4E1 959 801 D
>>> Component: Türsteuer.FS BRM005 0180 Coding: 0032364
>>> Address 46: Central Conv. Labels:. 4E0-910-289.lbl
>>> Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
>>> Component: Komfortgeraet H07 0010 Revision: 00100007 Serial number: W040605250281
>>> Coding: 0048766
>>> Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070
>>> Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H05 0020
>>> Address 47: Sound System Labels: 4E0-910-223.lbl
>>> Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
>>> Component: DSP-High D3 H03 0120 Revision: PROD_01 Serial number: 00000000003997
>>> Coding: 0000026
>>> Address 4F: Centr. Electr. II Labels: None
>>> Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
>>> Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000005181
>>> Coding: 0010111
>>> VCID: 1E65DBA9FCB3ED0B40F-804A
>>> Subsystem 1 - Part No: 4E0 910 511 A
>>> Component: UGDO HL US H04 0050
>>> Subsystem 2 - Serial number: 0253440T193A05
>>> 1 Fault Found:
>>> 02258 - Door Opener Transmitter 004 - No Signal/Communication - Intermittent
>>> Freeze Frame:
>>> Fault Status: 00100100
>>> Fault Priority: 3
>>> Fault Frequency: 1
>>> Reset counter: 100
>>> Mileage: 253736 km
>>> Time Indication: 0
>>> Date: 2020.09.22
>>> Time: 14:43:00
>>> Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
>>> Part No SW: 4E1 910 802 B HW: 4E1 959 802 D
>>> Component: Türsteuer.BF BRM005 0180 Coding: 0032364
>>> Address 53: Parking Brake Labels: 4E0-910-801.clb
>>> Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
>>> Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000732
>>> Shop #: WSC 10918 002 104857
>>> 1 Fault Found:
>>> 02596 - Rear Brake Pads Worn 008 - Implausible Signal
>>> Freeze Frame:
>>> Fault Status: 01111000
>>> Fault Priority: 6
>>> Fault Frequency: 2
>>> Reset counter: 228
>>> Time Indication: 0
>>> Freeze Frame:
>>> Voltage: 5.59 V
>>> Count: 61
>>> Address 55: Headlight Range Labels: 4F0-910-357.lbl
>>> Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
>>> Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000018
>>> VCID: 290FF875B5FD1AB325D-807C
>>> Subsystem 1 - Part No: 4F0 941 329 B
>>> Component: AFS-Modul links H02 0020
>>> Subsystem 2 - Part No: 4F0 941 329 B
>>> Component: AFS-Modul rechtsH02 0020 No fault code found.
>>> Address 56: Radio Labels: 4E0-910-541.lbl
>>> Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
>>> Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 396BZ077559406
>>> Coding: 0000002
>>> VCID: 313F10159D2D6273EDD-8064
>>> Address 61: Battery Regul. Labels: 4E0-910-181.lbl
>>> Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
>>> Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000000381
>>> Shop #: WSC 08316 444 68302
>>> Subsystem 1 - Part No: 4E0 915 105 A
>>> Component: von VA0 9876543212 Coding: 344530393135313035412056413039383736353433323132
>>> Shop #: WSC 62916 001 1048576
>>> 5 Faults Found:
>>> 02272 - Quiescent Current Stage 1 000 - - - Intermittent
>>> Freeze Frame:
>>> Fault Status: 00100000
>>> Fault Priority: 7
>>> Fault Frequency: 23
>>> Reset counter: 255
>>> Mileage: 253383 km
>>> Time Indication: 0
>>> Date: 2020.09.12
>>> Time: 08:23:23
>>> 02273 - Quiescent Current Stage 2 000 - - - Intermittent
>>> Freeze Frame:
>>> Fault Priority: 7
>>> Fault Frequency: 9
>>> Reset counter: 255
>>> Mileage: 253493 km
>>> Time Indication: 0
>>> Date: 2020.09.12
>>> Time: 10:25:23
>>> 02276 - Quiescent Current Stage 5 000 - - - Intermittent
>>> Freeze Frame:
>>> Fault Priority: 7
>>> Fault Frequency: 7
>>> Reset counter: 255
>>> Mileage: 253493 km
>>> Time Indication: 0
>>> Date: 2020.09.12
>>> Time: 10:25:33
>>> 02274 - Quiescent Current Stage 3 000 - - - Intermittent
>>> Freeze Frame:
>>> Fault Priority: 7
>>> Fault Frequency: 7
>>> Reset counter: 255
>>> Mileage: 253493 km
>>> Time Indication: 0
>>> Date: 2020.09.12
>>> Time: 10:25:43
>>> 02277 - Quiescent Current Stage 6 000 - - - Intermittent
>>> Freeze Frame:
>>> Fault Priority: 7
>>> Fault Frequency: 6
>>> Reset counter: 255
>>> Mileage: 253493 km
>>> Time Indication: 0
>>> Date: 2020.09.12
>>> Time: 10:25:53
>>> Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
>>> Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
>>> Component: Türsteuer.HL BRM005 0180 Coding: 0032364
>>> Address 65: Tire Pressure Labels: 4E0-910-273.lbl
>>> Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
>>> Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000700063202
>>> Coding: 0202222
>>> Shop #: WSC 65793 000 00000
>>> 2 Faults Found:
>>> 01477 - System Switched Off 000 - -
>>> Freeze Frame:
>>> Fault Status: 01100000
>>> Fault Priority: 4
>>> Fault Frequency: 57
>>> Reset counter: 59
>>> Mileage: 253638 km
>>> Time Indication: 0
>>> Date: 2020.09.13
>>> Time: 12:34:29
>>> Freeze Frame:
>>> (no units): 0.0
>>> Temperature: 17.0°C
>>> Error Code: 0
>>> Not Recogn.
>>> Not Recogn.
>>> Not Recogn.
>>> Not Recogn.
>>> 01521 - Sensor for Tire Pressure 002 - Lower Limit Exceeded - Intermittent
>>> Freeze Frame:
>>> Fault Priority: 3
>>> Fault Frequency: 31
>>> Reset counter: 84
>>> Mileage: 253377 km
>>> Time Indication: 0
>>> Date: 2020.09.11
>>> Time: 13:16:28
>>> Freeze Frame:
>>> (no units): 44.0
>>> Temperature: 16.0°C
>>> Error Code: 0
>>> Not Recogn.
>>> Not Recogn.
>>> Not Recogn.
>>> Not Recogn.
>>> Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
>>> Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
>>> Component: SDS 3501 US H45 0630 Revision: 00000000 Serial number: 00000701230330
>>> Shop #: WSC 12336 024 394758
>>> VCID: 34311901623F575B86B-8060
>>> Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
>>> Part No SW: 4E0 910 441 HW: 4L0 907 441 A
>>> Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J7110H2
>>> Coding: 1121402
>>> VCID: 5CE191A1AA2FBF1B6EB-8008
>>> Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
>>> Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
>>> Component: Türsteuer.HR BRM005 0180 Coding: 0032364
>>> Address 76: Park Assist Labels: 4E0-910-283.lbl
>>> Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
>>> Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08730703110188
>>> Coding: 0221208
>>> VCID: 2313EA5DD7D1C0E36F1-8076
>>> 1 Fault Found:
>>> 01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 009 - Open or Short to Ground - Intermittent
>>> Freeze Frame:
>>> Fault Status: 00101001
>>> Fault Priority: 3
>>> Fault Frequency: 1
>>> Reset counter: 94
>>> Mileage: 253653 km
>>> Time Indication: 0
>>> Date: 2020.09.14
>>> Time: 18:53:07
>>> Address 77: Telephone Labels: 4E0-910-336.lbl
>>> Part No SW: 4F0 910 336 H HW: 4E0 862 335 Component: Handyvorb2 H16 1130 Revision: 00000000 Serial number: 00000007564366
>>> Coding: 0010900
>>> End----------(Elapsed Time: 02:24, VBatt start/end:
>>> 14.4V/14.5V)-----------
