Audi S8 D3 P2006/2007 Intake Flaps Stuck Closed Codes
Bob C
MA, USA
C?ID=410254
Hello, I recently cleaned my Throttle Bodies and MAF sensors on my 5.2 V10 and maybe by coincidence, had codes 2006/2007 for Stuck closed Intake Flaps immediate after this work. Checked vacuum lines etc. but nothing found.
Ran VCDS output tests: The Intake Manifold Tuning valve test (motor V183 tests fine). The Intake Manifold Flap Test Does nothing (no clicks, no nothing). Is that output test supposed to drive Flap Motor V157 ?
The V157 control arms can be moved manually. Is there a fuse dedicated to this motor? Read that it was combined with a cooling fan, but cooling fans 1 & 2 both test fine.
Tried a 142 adaption but get an "Error" message in block 4.
Any ideas where else to look other than bad V157 motor?
Thank you, Bob
Bob C
MA, USA
C?ID=410254
Mileage: 253750km-157672miles
>>> 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status:
>>> Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS
>>> Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status:
>>> Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control
>>> Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010
>>> 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 --
>>> Status: OK 0000 0F-Digital Radio -- Status: Malfunction 0010
>>> 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status:
>>> Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering
>>> wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010
>>> 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK
>>> 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: OK
>>> 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status:
>>> OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door
>>> Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000
>>> 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status:
>>> Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking
>>> Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK
>>> 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status:
>>> Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire
>>> Pressure -- Status: Malfunction 0010 67-Voice Control -- Status: OK
>>> 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right --
>>> Status: OK 0000 76-Park Assist -- Status: Malfunction 0010
>>> 77-Telephone -- Status: OK 0000
>>> Address 01: Engine        Labels: Redir Fail!
>>>    Part No SW: 4E0 910 552 A    HW: 4E0 907 552    Component: 5.2L V10/4V FSI    ª0040     Revision: 5AH15---    Serial number: AUX3Z0G1716063
>>>    Coding: 01060009190F0160
>>>    Shop #: WSC 08167 444 92038
>>>    VCID: 2019E551C6C7DBFB723-8074
>>> 3 Faults Found:
>>> 008198 - Intake Manifold Flap; Bank 1                P2006 - 008 - Stuck Closed
>>>              Freeze Frame:
>>>                     Fault Status: 01101000
>>>                     Fault Priority: 0
>>>                     Fault Frequency: 1
>>>                     Reset counter: 255
>>>                     Mileage: 253737 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.23
>>>                     Time: 13:49:43
>>>              Freeze Frame:
>>>                     RPM: 728 /min
>>>                     Load: 19.2 %
>>>                     Speed: 0.0 km/h
>>>                     Temperature: 42.0°C
>>>                     Temperature: 24.0°C
>>>                     Absolute Pres.: 990.0 mbar
>>>                     Voltage: 14.351 V
>>> 008198 - Intake Manifold Flap; Bank 1                P2006 - 001 - Stuck Closed - MIL ON
>>>              Freeze Frame:
>>>                     Fault Status: 11100001
>>>                     Fault Priority: 0
>>>                     Fault Frequency: 1
>>>                     Reset counter: 255
>>>                     Mileage: 253737 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.23
>>>                     Time: 13:54:37
>>>              Freeze Frame:
>>>                     RPM: 1818 /min
>>>                     Load: 54.5 %
>>>                     Speed: 37.0 km/h
>>>                     Temperature: 60.0°C
>>>                     Temperature: 27.0°C
>>>                     Voltage: 12.192 V
>>> 006435 - Please Check DTC Memory of ECU Number 2                P1923 - 008 -              Freeze Frame:
>>>                     Fault Priority: 0
>>>                     Fault Frequency: 1
>>>                     Reset counter: 255
>>>                     Mileage: 253741 km
>>>                     Time Indication: 0
>>>              Freeze Frame:
>>>                     RPM: 124 /min
>>>                     Load: 67.0 %
>>>                     Speed: 0.0 km/h
>>>                     Temperature: 20.0°C
>>>                     Temperature: 26.0°C
>>>                     Absolute Pres.: 1000.0 mbar
>>>                     Voltage: 8.128 V
>>> Readiness: 0000 0001
>>> Address 02: Auto Trans        Labels: 09E-927-156.lbl
>>>    Part No SW: 4E1 910 156 K    HW: 09E 927 156 B
>>>    Component: AG6 09E 5,2 FSI USA 0030     Revision: --H01---    Serial number:        0101256
>>>    Coding: 0000002
>>>    Shop #: WSC 02313 785 00200
>>>    VCID: 2B03027DBF0108A3D71-807E
>>> 1 Fault Found:
>>> 006231 - Load Signal                P1857 - 001 - Error Message from ECU - Intermittent
>>>              Freeze Frame:
>>>                     Fault Status: 00100001
>>>                     Fault Priority: 0
>>>                     Fault Frequency: 2
>>>                     Reset counter: 255
>>>                     Mileage: 253695 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.19
>>>                     Time: 18:23:12
>>>              Freeze Frame:
>>>                     RPM: 0 /min
>>>                     RPM: 0 /min
>>>                     RPM: 0 /min
>>>                     (no units): 30.0
>>>                     (no units): 157.0
>>>                     Temperature: 22.0°C
>>>                     T.B. Angle: 0.0°
>>> Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
>>>    Part No SW: 4E0 910 517 D    HW: 4E0 614 517 AB
>>>    Component: ESP 5.7 allrad  H46 0500     Coding: 0001627
>>>    Shop #: WSC 02313 000 00000
>>>    VCID: 2411E941D2DFC7DB16B-8070
>>> 2 Faults Found:
>>> 18265 - Load Signal             P1857 - 000 - Error Message from ECU - Intermittent
>>> 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30             000 - - - Intermittent
>>> Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
>>>    Part No SW: 4E0 910 131     HW: 4E0 909 131 L
>>>    Component:     FBS AUDID3  H10 0190     Revision: 01904910    Serial number: AUX3Z0G1716063
>>>    Coding: 0410624
>>>    Shop #: WSC 02311 785 00200
>>>    VCID: 58E98DB1DE17533B4A3-800C
>>>    Subsystem 1 - Part No: XXXXXXXXXXX    Component: ELV                 XXXX
>>> 1 Fault Found:
>>> 00668 - Supply Voltage Terminal 30             002 - Lower Limit Exceeded - Intermittent
>>>              Freeze Frame:
>>>                     Fault Status: 00100010
>>>                     Fault Priority: 2
>>>                     Fault Frequency: 0
>>>                     Reset counter: 99
>>>                     Mileage: 253728 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.23
>>>                     Time: 23:01:22
>>> Address 06: Seat Mem. Pass        Labels: None
>>>    Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
>>>    Component: Sitzmemory BFS H02  0010     Revision: 00000000    Serial number: 5DS 008 795-03
>>>    Coding: 3940448
>>>    Shop #: WSC 08316 444 53986
>>> No fault code found.
>>> Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
>>>    Part No SW: 4E0 910 732 T    HW: 4E0 035 729 A
>>>    Component: Interfacebox    H43 4610     Revision: 00000000    Serial number: 348AT077509454
>>>    Coding: 0000003
>>>    VCID: 33331A1D673150639F1-8066
>>>    Subsystem 1 - Part No: 4E0 910 611    Component: E0380 BedienteilH01 0050
>>>    Subsystem 2 - Serial number: 00000000049526
>>>    Subsystem 3 - Serial number: 0125.10.070000000100010189ÿ
>>>    Subsystem 4 - Serial number: 010189ÿ No fault code found.
>>> Address 08: Auto HVAC        Labels: None
>>>    Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
>>>    Component: KLIMAAUTOMAT    017 0450     Revision: 00000032    Serial number: 00000000166059
>>>    Coding: 0106833
>>>    Shop #: WSC 08316 444 999999
>>>    VCID: 1C61D1A1EAAFFF1BAEB-8048
>>> 2 Faults Found:
>>> 00065 - Rear Left Footwell Heater (Z42)             012 - Electrical Fault in Circuit
>>>              Freeze Frame:
>>>                     Fault Status: 01101100
>>>                     Fault Priority: 3
>>>                     Fault Frequency: 31
>>>                     Reset counter: 60
>>>                     Mileage: 253359 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.11
>>>                     Time: 12:48:04
>>>              Freeze Frame:
>>>                     Voltage: 11.30 V
>>> 00066 - Rear Right Footwell Heater (Z43)             012 - Electrical Fault in Circuit
>>>              Freeze Frame:
>>>                     Fault Priority: 3
>>>                     Fault Frequency: 3
>>>                     Reset counter: 58
>>>                     Mileage: 253359 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.11
>>>                     Time: 12:48:04
>>>              Freeze Frame:
>>>                     Voltage: 11.30 V
>>> Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
>>>    Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
>>>    Component: ILM Fahrer      H15 0230     Coding: 0133123
>>>    VCID: 363523097443454BB8F-8062
>>>    Subsystem 1 - Part No: 4E1 910 113 C
>>>    Component: Wischer WWS D3  H60 0420     Coding: 00000035
>>>    Shop #: WSC 02313     Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
>>>    Component: REGENLICHTSENSORH13 0090     Coding: 00139548
>>>    Shop #: WSC 02313  1 Fault Found:
>>> 01800 - Light Switch (E1)             008 - Implausible Signal - Intermittent
>>>              Freeze Frame:
>>>                     Fault Status: 00101000
>>>                     Fault Priority: 2
>>>                     Fault Frequency: 2
>>>                     Reset counter: 83
>>>                     Mileage: 252802 km
>>>                     Time Indication: 0
>>>                     Date: 2020.08.18
>>>                     Time: 03:16:50
>>> Address 0E: Media Player 1 (R192)       Labels:. 4E0-035-785.lbl
>>>    Part No SW: 4E0 035 785     HW: 4E0 035 785    Component: SG ext.Player H09 0170     Revision: 00000000       VCID: 6597B4459565FED3C15-8030
>>> Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
>>>    Part No SW: 4E0 910 593 H    HW: 4E0 035 593 D
>>>    Component: SDAR SIRIUS     H06 0080     Revision: 00000000    Serial number: AUZ4Z7G0046434
>>>    Shop #: WSC 00000 000 00000
>>>    VCID: 2C010161BA0F0F9BDEB-8078
>>> Address 11: Engine II        Labels: Redir Fail!
>>> 2 Faults Found:
>>> 008199 - Intake Manifold Flap; Bank 2                P2007 - 008 - Stuck Closed
>>>              Freeze Frame:
>>>                     Fault Priority: 0
>>>                     Fault Frequency: 1
>>>                     Reset counter: 255
>>>                     Mileage: 253737 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.23
>>>                     Time: 13:50:20
>>>              Freeze Frame:
>>>                     RPM: 714 /min
>>>                     Load: 19.2 %
>>>                     Speed: 0.0 km/h
>>>                     Temperature: 45.0°C
>>>                     Temperature: 24.0°C
>>>                     Voltage: 14.351 V
>>> 008199 - Intake Manifold Flap; Bank 2                P2007 - 001 - Stuck Closed - MIL ON
>>>              Freeze Frame:
>>>                     Fault Priority: 0
>>>                     Fault Frequency: 1
>>>                     Reset counter: 255
>>>                     Mileage: 253737 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.23
>>>                     Time: 13:54:37
>>>              Freeze Frame:
>>>                     RPM: 1817 /min
>>>                     Load: 56.1 %
>>>                     Speed: 37.0 km/h
>>>                     Temperature: 60.0°C
>>>                     Temperature: 27.0°C
>>>                     Voltage: 11.811 V
>>> Address 15: Airbags        Labels: 4E0-910-655-94.lbl
>>>    Part No SW: 4E0 910 655 C    HW: 4E0 959 655 J
>>>    Component:    Airbag 9.41  H14 4230     Revision: 91H14423    Serial number: 0037Q0G01FVD     Coding: 0532707
>>>    VCID: 2615F349A4E335CB08F-8072
>>>    Subsystem 1 - Part No: 4E0 910 339    Component: BF-Gewichtsens. H01 0030
>>>    Subsystem 2 - Serial number: 3J1ET            Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ† 63
>>>    Subsystem 4 - Serial number: 000000ÿ† 63328RB401F20010/ÿ† 63
>>>    Subsystem 5 - Serial number: 20010/ÿ† 63428RB401F204F3Jÿ† 63
>>>    Subsystem 6 - Serial number: 204F3Jÿ† 63528RB401F204B9Mÿ† 63
>>>    Subsystem 7 - Serial number: 204B9Mÿ† 63628RB401F20445Cÿ† 63
>>>    Subsystem 8 - Serial number: 20445Cÿ† 63729RB401F92407Lÿ† 63
>>>    Subsystem 9 - Serial number: 92407Lÿ† 63829RB401F92252Kÿ
>>>    Subsystem 10 - Serial number: 92252Kÿ
>>> 1 Fault Found:
>>> 00532 - Supply Voltage B+             002 - Lower Limit Exceeded - Intermittent
>>>              Freeze Frame:
>>>                     Fault Priority: 2
>>>                     Fault Frequency: 91
>>>                     Reset counter: 99
>>>                     Mileage: 252802 km
>>>                     Time Indication: 0
>>>                     Date: 2020.08.18
>>>                     Time: 15:44:58
>>> Address 16: Steering wheel        Labels: 4E0-910-549.lbl
>>>    Part No SW: 4E0 910 549     HW: 4E0 953 549    Component: Lenksäulenmodul H14 0040     Coding: 0012141
>>>    VCID: 6597B4459965FED3C15-8030
>>>    Subsystem 1 - Part No: XXXXXXXXXXX    Component: Lenkradmodul    H07 0090
>>> Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
>>>    Part No SW: 4E0 910 951 F    HW: 4E0 920 951 F
>>>    Component: KOMBIINSTR. VDO H82 0530     Revision: D04         Serial number: AUDID3G1001181
>>>    Coding: 0048003
>>>    Shop #: WSC 03601 003 104857
>>>    VCID: 2809FD71AEF723BB3A3-807C
>>> 1 Fault Found:
>>> 16346 - Control Module - ROM Error             014 - Defective
>>>              Freeze Frame:
>>>                     Fault Status: 00000011
>>>                     Fault Priority: 1
>>>                     Fault Frequency: 1
>>>                     Reset counter: 255
>>>                     Mileage: 85376 km
>>>                     Time Indication: 0
>>>                     Date: 2012.01.07
>>>                     Time: 10:14:21
>>> Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
>>>    Part No SW: 4L0 910 468     HW: 4L0 907 468    Component: J533__Gateway   H06 0040     Revision: 00H06000    Serial number: 0900B0712580FC
>>>    Coding: F5F5DFFF707A0E
>>>    VCID: 6C81C1617A8FCF9B9EB-8038
>>> Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
>>>    Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
>>>    Component: MP3-Changer     H44 0390     Revision: 00044000    Serial number: AUZ5ZBG3157676
>>>    VCID: 1A6DD7B9E09B812BBC7-804E
>>> Address 28: HVAC, Rear        Labels: None
>>>    Part No SW: 4E0 910 158     HW: 4E0 919 158 D
>>>    Component: KLIMA-STG. FOND 017 0230     Revision: 00000019    Serial number: 00000000050288
>>>    Coding: 0000000
>>>    VCID: 619FA0558D4D92F33DD-8034
>>> Address 34: Level Control        Labels: 4E0-910-553.clb
>>>    Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
>>>    Component: LUFTFDR.-CDC    H06 6310     Coding: 0011110
>>>    VCID: 2A0D0779B0FB11AB2C7-807E
>>> Address 36: Seat Mem. Drvr        Labels: None
>>>    Component: Sitzmemory FS  H02  0010     Revision: 00000000    Serial number: 5DS 008 795-03
>>>    Coding: 4071530
>>> Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
>>>    Part No SW: 4E0 910 888 D    HW: 4E0 919 887 L
>>>    Component: MNS US          H48 0970     Revision: 00000000    Serial number: 381BX077517398
>>>    VCID: 2F3B166D8B197483FB9-807A
>>> Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
>>>    Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
>>>    Component: Dachknoten D3   H05 0090     Coding: 0004078
>>>    Shop #: WSC 08316 444 05187
>>>    VCID: 1D67DCA5F1B5F613595-8048
>>> 2 Faults Found:
>>> 02104 - Light Detection Sensor (G399)             010 - Open or Short to Plus
>>>              Freeze Frame:
>>>                     Fault Status: 01101010
>>>                     Fault Priority: 0
>>>                     Fault Frequency: 1
>>>                     Reset counter: 58
>>>                     Mileage: 253732 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.22
>>>                     Time: 14:27:00
>>> 02003 - Driver Identification Control Module (J589)             004 - No Signal/Communication
>>>              Freeze Frame:
>>>                     Fault Status: 01100100
>>>                     Fault Priority: 0
>>>                     Fault Frequency: 15
>>>                     Reset counter: 59
>>>                     Mileage: 253732 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.22
>>>                     Time: 14:27:00
>>> Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
>>>    Part No SW: 4E1 910 802 B    HW: 4E1 959 801 D
>>>    Component: Türsteuer.FS BRM005 0180     Coding: 0032364
>>> Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
>>>    Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
>>>    Component: Komfortgeraet   H07 0010     Revision: 00100007    Serial number:  W040605250281
>>>    Coding: 0048766
>>>    Subsystem 1 - Part No: 4E0 910 853    Component: Heckdeckel   P14H06 0070
>>>    Subsystem 2 - Part No: 4E0 907 719    Component: Neigungssensor  H05 0020
>>> Address 47: Sound System        Labels: 4E0-910-223.lbl
>>>    Part No SW: 4E0 910 223 R    HW: 4E0 035 223 G
>>>    Component: DSP-High D3     H03 0120     Revision: PROD_01     Serial number: 00000000003997
>>>    Coding: 0000026
>>> Address 4F: Centr. Electr. II        Labels: None
>>>    Part No SW: 4E0 910 280 A    HW: 4E0 907 280 B
>>>    Component: ILM Beifahrer   H11 0070     Revision:             Serial number: 00000000005181
>>>    Coding: 0010111
>>>    VCID: 1E65DBA9FCB3ED0B40F-804A
>>>    Subsystem 1 - Part No: 4E0 910 511 A
>>>    Component: UGDO HL US      H04 0050
>>>    Subsystem 2 - Serial number: 0253440T193A05
>>> 1 Fault Found:
>>> 02258 - Door Opener Transmitter             004 - No Signal/Communication - Intermittent
>>>              Freeze Frame:
>>>                     Fault Status: 00100100
>>>                     Fault Priority: 3
>>>                     Fault Frequency: 1
>>>                     Reset counter: 100
>>>                     Mileage: 253736 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.22
>>>                     Time: 14:43:00
>>> Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
>>>    Part No SW: 4E1 910 802 B    HW: 4E1 959 802 D
>>>    Component: Türsteuer.BF BRM005 0180     Coding: 0032364
>>> Address 53: Parking Brake        Labels: 4E0-910-801.clb
>>>    Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
>>>    Component: EPB  A4EC0230   H03 0230     Revision: --H03---       Coding: 0000732
>>>    Shop #: WSC 10918 002 104857
>>> 1 Fault Found:
>>> 02596 - Rear Brake Pads Worn             008 - Implausible Signal
>>>              Freeze Frame:
>>>                     Fault Status: 01111000
>>>                     Fault Priority: 6
>>>                     Fault Frequency: 2
>>>                     Reset counter: 228
>>>                     Time Indication: 0
>>>              Freeze Frame:
>>>                     Voltage: 5.59 V
>>>                     Count: 61
>>> Address 55: Headlight Range        Labels: 4F0-910-357.lbl
>>>    Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
>>>    Component: AFS 1           H01 0020     Revision: 00000001    Serial number:                  Coding: 0000018
>>>    VCID: 290FF875B5FD1AB325D-807C
>>>    Subsystem 1 - Part No: 4F0 941 329 B
>>>    Component: AFS-Modul links H02 0020
>>>    Subsystem 2 - Part No: 4F0 941 329 B
>>>    Component: AFS-Modul rechtsH02 0020 No fault code found.
>>> Address 56: Radio        Labels: 4E0-910-541.lbl
>>>    Part No SW: 4E0 910 541 T    HW: 4E0 035 541 S
>>>    Component: TUNER EU/US/RDW H42 0630     Revision: 00000000    Serial number: 396BZ077559406
>>>    Coding: 0000002
>>>    VCID: 313F10159D2D6273EDD-8064
>>> Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
>>>    Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
>>>    Component: J0644 BEM       H12 0550     Revision: 00000000    Serial number: 00000000000381
>>>    Shop #: WSC 08316 444 68302
>>>    Subsystem 1 - Part No: 4E0 915 105 A
>>>    Component: von VA0  9876543212          Coding: 344530393135313035412056413039383736353433323132
>>>    Shop #: WSC 62916 001 1048576
>>> 5 Faults Found:
>>> 02272 - Quiescent Current Stage 1             000 - - - Intermittent
>>>              Freeze Frame:
>>>                     Fault Status: 00100000
>>>                     Fault Priority: 7
>>>                     Fault Frequency: 23
>>>                     Reset counter: 255
>>>                     Mileage: 253383 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.12
>>>                     Time: 08:23:23
>>> 02273 - Quiescent Current Stage 2             000 - - - Intermittent
>>>              Freeze Frame:
>>>                     Fault Priority: 7
>>>                     Fault Frequency: 9
>>>                     Reset counter: 255
>>>                     Mileage: 253493 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.12
>>>                     Time: 10:25:23
>>> 02276 - Quiescent Current Stage 5             000 - - - Intermittent
>>>              Freeze Frame:
>>>                     Fault Priority: 7
>>>                     Fault Frequency: 7
>>>                     Reset counter: 255
>>>                     Mileage: 253493 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.12
>>>                     Time: 10:25:33
>>> 02274 - Quiescent Current Stage 3             000 - - - Intermittent
>>>              Freeze Frame:
>>>                     Fault Priority: 7
>>>                     Fault Frequency: 7
>>>                     Reset counter: 255
>>>                     Mileage: 253493 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.12
>>>                     Time: 10:25:43
>>> 02277 - Quiescent Current Stage 6             000 - - - Intermittent
>>>              Freeze Frame:
>>>                     Fault Priority: 7
>>>                     Fault Frequency: 6
>>>                     Reset counter: 255
>>>                     Mileage: 253493 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.12
>>>                     Time: 10:25:53
>>> Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
>>>    Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
>>>    Component: Türsteuer.HL BRM005 0180     Coding: 0032364
>>> Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
>>>    Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
>>>    Component: Reifendruck 3   H05     Revision: 00050340    Serial number: 00000700063202
>>>    Coding: 0202222
>>>    Shop #: WSC 65793 000 00000
>>> 2 Faults Found:
>>> 01477 - System Switched Off             000 - -
>>>              Freeze Frame:
>>>                     Fault Status: 01100000
>>>                     Fault Priority: 4
>>>                     Fault Frequency: 57
>>>                     Reset counter: 59
>>>                     Mileage: 253638 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.13
>>>                     Time: 12:34:29
>>>              Freeze Frame:
>>>                     (no units): 0.0
>>>                     Temperature: 17.0°C
>>>                     Error Code: 0
>>>                         Not Recogn.
>>>                         Not Recogn.
>>>                         Not Recogn.
>>>                         Not Recogn.
>>> 01521 - Sensor for Tire Pressure             002 - Lower Limit Exceeded - Intermittent
>>>              Freeze Frame:
>>>                     Fault Priority: 3
>>>                     Fault Frequency: 31
>>>                     Reset counter: 84
>>>                     Mileage: 253377 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.11
>>>                     Time: 13:16:28
>>>              Freeze Frame:
>>>                     (no units): 44.0
>>>                     Temperature: 16.0°C
>>>                     Error Code: 0
>>>                         Not Recogn.
>>>                         Not Recogn.
>>>                         Not Recogn.
>>>                         Not Recogn.
>>> Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
>>>    Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
>>>    Component: SDS 3501 US     H45 0630     Revision: 00000000    Serial number: 00000701230330
>>>    Shop #: WSC 12336 024 394758
>>>    VCID: 34311901623F575B86B-8060
>>> Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
>>>    Part No SW: 4E0 910 441     HW: 4L0 907 441 A
>>>    Component: J772__Rearview      0050     Revision: --H12---    Serial number: 525PA8-J7110H2
>>>    Coding: 1121402
>>>    VCID: 5CE191A1AA2FBF1B6EB-8008
>>> Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
>>>    Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
>>>    Component: Türsteuer.HR BRM005 0180     Coding: 0032364
>>> Address 76: Park Assist        Labels: 4E0-910-283.lbl
>>>    Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
>>>    Component: Parkhilfe 8-Kan H12 0040     Revision: 00H12000    Serial number: 08730703110188
>>>    Coding: 0221208
>>>    VCID: 2313EA5DD7D1C0E36F1-8076
>>> 1 Fault Found:
>>> 01546 - Sensor for Parking Aid; Rear Mid-Left (G204)             009 - Open or Short to Ground - Intermittent
>>>              Freeze Frame:
>>>                     Fault Status: 00101001
>>>                     Fault Priority: 3
>>>                     Fault Frequency: 1
>>>                     Reset counter: 94
>>>                     Mileage: 253653 km
>>>                     Time Indication: 0
>>>                     Date: 2020.09.14
>>>                     Time: 18:53:07
>>> Address 77: Telephone        Labels: 4E0-910-336.lbl
>>>    Part No SW: 4F0 910 336 H    HW: 4E0 862 335    Component: Handyvorb2      H16 1130     Revision: 00000000    Serial number: 00000007564366
>>>    Coding: 0010900
>>> End----------(Elapsed Time: 02:24, VBatt start/end:
>>> 14.4V/14.5V)-----------
Jef
HQ
Lets first be sure we are all on the same page:
sourced from this video ----> https://www.youtube.com/watch?v=pEOrCiyzR2g
The red arrow pointing towards the right is locating the V183. The red arrow pointing up is locating the V157. Note that the green arrows point to the G336 and G512 sensors. Said sensor report changes caused by the V157 operation.
V183 or V157, what are you able to visually verify operation of?
Bob C
MA, USA
C?ID=410254
Hello Jef and thank you.
I performed a Function test (only sequential output tests are allowed with VCDS here). The Variable Intake Runner Motor V183 (using the "intake manifold tuning valve control circuit" test) operates perfectly during the test. I am not certain, but the next test (called "Intake Manifold Flap, Bank 1) does nothing (no clicking, no movement). I am guessing that this test that is supposed to operate that intake flap motor V157 (and corresponding sensors noted) but I have been unable to get a confirmation from Ross-Tech technical support thus far and do not know what other operation or VCDS test might verify that fact.
Thank you
Also: Completely coincidental I am sure, but I now have a EPC light with a low fuel pressure code and very poor engine performance. Started a couple days later.
Jef
HQ
Is it possible to undo the linkage from the V157 and see if you can then operate the linkage / intake runners? Is they are not seized up, it would appear at face value you have a bad V157 unit (assuming electrical paths for it are to factory design).
Bob C
MA, USA
C?ID=410254
I can manipulate the runners manually, yes. My question is on VCDS can you confirm that the 4th. set of output test commands is supposed to operate that V157 Motor ( "Intake Manifold Flap, Bank 1")? And within VCDS can you confirm of there is another test or method to operate this V157 motor electronically? I have also tried to perform a "142" adaption in basic settings on Engine 1 or II CPU's and I get an Error message when attempted. Thank you !
Bob C
MA, USA
C?ID=410254
Thought I would close the loop here in case anyone runs into the same situation. I did confirm that the VCDS sequential output test # 4 output test Intake Manifold Flap, Bank 1 (actually both banks) is intended to operate the lower flap solenoid motor V157. I ordered a replacement and installed it. Cleared the codes and performed an adaption 142 in basic settings (engine running) to calibrate this new V157 motor. All is very happy with the V10 now !
Thank you, Bob
