Hi all
Probabaly a simple, obvious answer, but struggling to get confirmation.
I have just retrofitted TPMS to UK 2011 Touareg. Fitted secondhand Control Module 65 (J502), 4 x secondhand Receivers in each wheel well, new cable set from Kufatec, 4 x new wheel transmitters in the wheels - https://www.ebay.co.uk/itm/283928576486
Then coded as per Kufatec instructions -
Address 65 added in Module 19 installation list, added TPMS in Module 17, in module 5F - adaptation Channel 6 was already set to 1.
In green menu, car, cardevicelist, activated RDK, in car, carmenuoperation, RDK set to 5, RNS850 rebooted.
Now I get the display working, but no pressures displayed. Did take it for a good run after clearing various other codes, but still no luck.
The fact that I have display correct in display and I seem to be getting comms between controller and receivers, does this confirm that the transmitters in the wheels are not talking to the receivers? Do I need to do some basic setup in Controller 65? More coding needed in 5F? Is it simply that the wheel transmitters are no good?
Here is full scan -
Here is full scan -
Tuesday,22,September,2020,17:22:06:40778
VCDS Version: 20.4.2.0 (x64)
VIN: WVGZZZ7PZBD04xxxx License Plate:
Mileage: 120877km-75109mi Repair Order: afterclear
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 32 34 42 46 52 53 56 5F
62 65 69 72
VIN: WVGZZZ7PZBD04xxxx Mileage: 120877km-75109miles
32-Differential Locks -- Status: Malfunction 0010
Address 01: Engine (J623-CASA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 HW: 7P0 907 401
Component: 3.0TDI EDC17 H17 0009
Revision: 51H17---
Coding: 296A4012233E01020000
Shop #: WSC 59816 001 1048576
ASAM Dataset: EV_ECM30TDI0117P0907401 002011
ROD: EV_ECM30TDI0117P0907401.rod
VCID: 6CD7FE2A8714BDE6DF-8038
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 H HW: 0C8 927 750 H
Component: AL1000 AISIN 001 1885
Coding: 001568
Shop #: WSC 80093 222 69422
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_VW52.rod
VCID: 31692F5E60B6100EAC-8064
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 K HW: 7P0 907 379 A
Component: MK25A H36 0418
Revision: -------- Serial number: 408810010EC010
Coding: 4B6B13C30B282555D2F9C897D0D5A4507700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 45816B8EC43EACAE60-8010
Part No SW: 4H0 907 064 AL HW: 4H0 907 064 AL
Component: BCM2 2.0 H24 0217
Coding: 01B60000000000000000
VCID: 73E5E556D22A621E1E-8026
Subsystem 1 - Part No SW: 7P6 959 754 AA HW: 7P6 959 754 AA
Component: FBSTOUAREGIDG H05 0051
Serial number: 0511000006863003
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000064792009
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0613
Coding: B626000890
VCID: 79F9D77EF846184E54-802C
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0092
Revision: 15012002 Serial number: 00000000983783
Coding: 6900001181345D010005000300005F5F431D670807000241000000000000
VCID: 31692F5E68B6100EAC-8064
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 110322 31 0020
Serial number: 90243401110330185104
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10146184
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 B HW: 7P6 941 431 B
Component: E1 - LDS H04 0031
Serial number: 00000000001003110167
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 HW: 7P6 919 475
Component: PARKHILFE 8K H03 0016
Revision: -------- Serial number: 55901105901039
Coding: 328501
ASAM Dataset: EV_VW526ParkiAssis2 001008
ROD: EV_VW526ParkiAssis2.rod
VCID: 55A1BBCE349E1C2E10-8000
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag00K H05 0023
Revision: -------- Serial number: 003JX0023TJM
Coding: 00000000000000000000000000000000304B
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 408F7A9ADB1C898653-8014
Serial number: 3575LRB405D0CE32297L
Serial number: 3585LRB405V0DGESAOMW
Serial number: 3515RRB405D0H4DU4P7T
Serial number: 3525RRB40650H1GGMP9T
Serial number: 3555NRB405T0G2HUC0BX
Serial number: 3565NRB405T0G2HU59B-
Part No SW: 4H0 953 568 A HW: 7P6 953 507
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815KCL00014
Coding: 000015
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0001087
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 981 HW: 7P6 920 981
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658220211593040
Coding: 33273300B3002600010004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 7AFBC872FD4013565D-802E
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000118263
Coding: 000D077500
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 387F127A83CCC146EB-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005653000589
Voltage stabilizer:
Subsystem 2 - Part No SW: 7PP 959 663 E HW: 7PP 959 663 E
Component: J532_DCDCStab H17 0042
Serial number: 11069001648011200181
Address 22: AWD Labels: None
Part No SW: 0BV 927 755 A HW: 0BV 927 755 A
Component: TRANSFERCASE 0217
VCID: 4C975EAA2F545DE6BF-8018
Address 32: Differential Locks Labels: None
Part No SW: 0BN 927 771 HW: 0BN 927 771
Component: Quersperre 5220
Revision: H04 Serial number: 411607253104
VCID: 0109BF9E5896408E1C-8054
16353 - Control Module - Internal Malfunction
02062 - Differential Lock
02412 - Differential Lock Rear
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 K HW: 7P0 907 553 K
Component: PASM H01 1110
Revision: 00000000 Serial number: 00000110130690
Coding: 14210000
Shop #: WSC 00606 210 88440
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
VCID: 3F8D7966A6E2F67E2A-806A
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000114291138
Coding: 011D0620D001451005080002
VCID: 3C770E6ABFF4ED660F-8068
Revision: 00002001 Serial number: 0145501779
Coding: 019B162228B9009483200624200000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Subsystem 3 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H07 0006
Serial number: WOO11612870
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H07 0006
Serial number: WOO11630791
Coding: 191100
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000114272719
Coding: 011D0620D001451005080000
VCID: 3B750D76BAFAEA5E06-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 D HW: 7P0 907 801 D
Component: EPB H51 1000
Revision: 00000000 Serial number: A11308001C7
Coding: 01040000
ROD: EV_ParkbA7.rod
VCID: 3467264A9FA42526C7-8060
Slave 3:
0033 - Dynamic Start Assist Function Not Available
C10DE 00 [008] - -
Reset counter: 87
Mileage: 120642 km
Date: 2020.09.12
Time: 07:52:52
Voltage: 14.0 V
Part No SW: 4G0 035 061 A HW: 4G0 035 061
Component: Radio U DAB H52 0065
Revision: AB001007 Serial number: 109CU0B7514067
Coding: 010105020100000001
VCID: 1B35EDF61A3A8A5EE6-804E
Part No SW: 7P6 035 670 B HW: 7P6 035 670 B
Component: H-BNT-EU H44 0203
Revision: -------- Serial number: 478C00B7539551
Coding: 010101050040E1ED01002B0E00000003F0040100
VCID: 3467264A97A42526C7-8060
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: DU8 SV Touch H24 0045
Serial number: VWZ8Z9L2800WNN
Subsystem 3 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: CD-Database 1886
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000114572062
Coding: 011C06200001251005080000
VCID: 3A7B0872B5C0D3561D-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000115978
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
8397058 - Front Left TPMS Sensor
C1050 31 [009] - No Signal
Reset counter: 60
Mileage: 120872 km
Date: 2020.09.22
Time: 16:39:01
Vehicle speed: 84 km/h
Outside air temperature: 21 ∞C
Reception level antenna 1: 800 mV
Offset level antenna 1: 770 mV
8397314 - Front Right TPMS Sensor
C1051 31 [009] - No Signal
Reset counter: 60
Mileage: 120872 km
Date: 2020.09.22
Time: 16:39:01
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Reset counter: 60
Mileage: 120872 km
Date: 2020.09.22
Time: 16:39:01
8397826 - Rear Right TPMS Sensor
C1053 31 [009] - No Signal
Reset counter: 60
Mileage: 120872 km
Date: 2020.09.22
Time: 16:39:01
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 G HW: 7P0 907 383 C
Component: Anhaenger H09 0110
Revision: 5H001001 Serial number: 00000145858187
Coding: 0106040000000000
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000114570625
End-------------------------(Elapsed Time: 04:47)--------------------------
